GPU Requirement
Hi there, I couldn’t buy a RTX 6000 ADA GPU in my region with proper local support. The next nearest is RTX 5000 ADA.
These are the specifications. Still able to configure certain things but at a cost. Any comments will th RTX ADA 5000 works with ISAAC SIM?
Lenovo
ThinkPad P16 Gen 2
13th Generation Intel® Core™ i9-13980HX Processor
64 GB DDR5-5600MHz (SODIMM, Over Clock) - (2 x 32 GB)
NVIDIA RTX™ 5000 Ada Generation Laptop GPU 16GB GDDR6
1 TB SSD M.2 2280 PCIe Gen4 TLC
16" WUXGA (1920 x 1200), IPS, Anti-Glare, Non-Touch, 100%sRGB, 300 nits, 60Hz, Low Blue Light
1080P FHD RGB with Microphone
3 Cell Li-Polymer 75Wh
3 Years On Site
SG$7,325.01 GST incl. and free delivery
Isaac Sim has specific system requirements, including GPU recommendations. For optimal performance:
GPU Requirements
  • Minimum: GeForce RTX 3070 with 8GB VRAM
  • Recommended: GeForce RTX 4080 with 16GB VRAM
  • Ideal: RTX Ada 6000 with 48GB VRAM
Additional Information
  • GPUs without RT Cores (e.g., A100, H100) are not supported
  • More VRAM is recommended for advanced usage and Isaac Lab training
For complete system requirements, including CPU, RAM, and storage recommendations, please refer to https://docs.omniverse.nvidia.com/isaacsim/latest/installation/requirements.html#system-requirements.
Are you saying that Isaac SIM can only run on RTX6000, RTX4080, RTX3070? What about other variants in between? RTX5000, RTX4000, RTX4070?
i am just another user, and last i checked most cards with RT cores are required to run OV with 3070 being the bottom line. RTX6000, 4080, and 3070 are just a few they listed under recommendation after testing and not exclusive to SIM use.
in other words, your RTX5000 should work just fine; but depending on the sim scope, you may wish to invest in cards with more VRAM on larger environments to avoid bottlenecks.
