Hello Support,
I found that the GPU was spike very fast and loud when in use.
Please advise how to check whether is hardware issue.
Hello Support,
Please run nvidia-bug-report.sh as root and attach the resulting nvidia-bug-report.log.gz file to your post.
Sorry, the system OS is Windows, it’s not Linux.
I had amend the title.
I can’t really help you with Windows. What kind of system do you have, desktop or notebook? Which nvidia gpu, brand, model? How many monitors are connected to it with which resolution? Which driver version are you using?
I am using Desktop Windows 10 Pro Version 2004.
Below are my display adapter:
Nvidia GForce RTX 2080Ti - version 30.0.14.7141
Inte(R) UHD Graphics 630 - version 27.20.100.9664
There is not monitor connected to the workstation as it always using via remote.
Please use gpu-z to check if the gpu is heating up too much, check airflow of the case, make sure the fans are not blocked.
GPU_LOGS.txt (1.1 MB)
I had uploaded my gpu-z logs here, when I started to run my python code,it
Nothing unusual, when idle gpu is at 38°C, 18% fan speed, when under load at 79°C, 48% fan speed.
Seem the GPU cards are working fine, there is not hardware issue I suppose?
No, looks fine.
