I have a GTX 1070 and I’m trying to use it with VMware vsphere.
My ubuntu version is 16.04, and related outputs are as following:
lspci output:
$ lspci | grep NVIDIA
13:00.0 VGA compatible controller: NVIDIA Corporation Device 1b81 (rev a1)
13:00.1 Audio device: NVIDIA Corporation Device 10f0 (rev a1)
device files:
crw-rw-rw- 1 root root 195, 0 Aug 29 19:46 /dev/nvidia0
crw-rw-rw- 1 root root 195, 255 Aug 29 19:46 /dev/nvidiactl
crw-rw-rw- 1 root root 246, 0 Aug 29 19:46 /dev/nvidia-uvm
driver version:
NVRM version: NVIDIA UNIX x86_64 Kernel Module 396.54 Tue Aug 14 19:02:34 PDT 2018
GCC version: gcc version 5.4.0 20160609 (Ubuntu 5.4.0-6ubuntu1~16.04.10)
driver gpu info:
Model: GeForce GTX 1070
IRQ: 65
GPU UUID: GPU-???-???-???-???-???
Video BIOS: ??.??.??.??.??
Bus Type: PCIe
DMA Size: 47 bits
DMA Mask: 0x7fffffffffff
Bus Location: 0000:13:00.0
Device Minor: 0
I installed the CUDA 9.2 following the instructions here:
https://developer.nvidia.com/cuda-downloads?target_os=Linux&target_arch=x86_64&target_distro=Ubuntu&target_version=1604&target_type=deblocal
The commands I ran are:
sudo dpkg -i cuda-repo-ubuntu1604-9-2-local_9.2.148-1_amd64.deb
sudo apt-key add /var/cuda-repo-<version>/7fa2af80.pub
sudo apt-get update
sudo apt-get install cuda
But when I nvidia-smi, it says “No devices found”. I’m wondering if I did any of the steps incorrectly?
Thanks in advance!
