GRAY8 to NV12 conversation darkens preprocessed tensor
• Hardware Platform (Jetson / GPU) Jetson TX2
• DeepStream Version 5.1
• TensorRT Version 7.1.3
• Issue Type( questions, new requirements, bugs) question
I have 2 gstreamer pipelines.
First of them uses NV12 as format of input image for nvinfer:
multifilesrc location=/home/data/cher/14373/night_frames_png/frame_%05d.png caps=image/png !
pngdec ! video/x-raw,format=RGB !
videoconvert ! video/x-raw,format=GRAY8 !
nvvideoconvert ! video/x-raw(memory:NVMM),format=NV12,colorimetry=bt601 !
nvinfer name=nvinfer_cd ! ...
The other one uses RGBA:
multifilesrc location=/home/data/night_frames_png/frame_%05d.png caps=image/png!
videoconvert ! video/x-raw,format=RGBA !
nvvideoconvert ! video/x-raw(memory:NVMM),format=RGBA,colorimetry=bt709 !
Then, I dump preprocessed tensors from nvinfer using code from this topic from both pipelines.
If I compare them, I’ll see, that tensor from pipeline with NV12 is darker than another one from pipeline with RGBA.
Too dark frames cause worse car detection.
Is this a problem of NV12? Can I make preprocessed tensors in NV12 pipeline as light as in RGBA using available parameters of nvinfer or nvvideoconvert?
  1. The colorimetry you used is different.
  2. Why did you convert to GRAY8 first in the first pipeline? The losses of this conversion in the 1st pipeline(RGB->GRAY8->NV12 NVMM) is definitely higher than the 2nd(RGB->RGBA->RGBA NVMM).
Ok, I’ve changed my RGBA pipeline to:
nvvideoconvert ! video/x-raw(memory:NVMM),format=RGBA,colorimetry=bt601 !
nvinfer name=nvinfer_cd ...
Now, it uses equal colorimetry and converts frame to GRAY8 first.
But results are the same. Using RGBA, I get light preprocessed tensors, while NV12 have dark tensors
Is this a problem of NV12 compression?
Yes. The NV12 is compressed relative to RGBA, so there may be losses of accuracy.
Got it, thanks)
