AGX Xavier
DeepStream 6.1
Since yesterday i’m trying to modify this code :https://github.com/NVIDIA-AI-IOT/deepstream_python_apps/tree/master/apps/deepstream-test1-usbcam
which convert from NV12 to RGBA to make the video stream grayscale. The probleme is i cannot find an understandable Gstream/Deepstream Python documentation.
So i would like to know how to convert from NV12 to Gray, and then convert it to rgba so it’s gray but in the rgba format so it can be used by nvosd.
In a classical Gstreamer pipeline i supposed i would have to add something like
video/x-raw,format=GRAY8 ! videoconvert
and the convert it again to rgba.
Thanks !
yuweiw
December 24, 2022, 12:01am
#3
You can refer the source code, use the capstilert to set the color format.
Like:
caps_vidconvsrc = Gst.ElementFactory.make("capsfilter", "nvmm_caps")
caps_v4l2src.set_property('caps', Gst.Caps.from_string("format=GRAY8"))
Thanks for you replied, i tried your solution, it doesn’t show any error and it process correctly but image is still colored.
yuweiw
January 3, 2023, 9:40am
#5
Could you attach your pipeline graph by refering to the link below?
https://forums.developer.nvidia.com/t/deepstream-sdk-faq/80236/10
Here it is :
pipeline.dot (9.2 KB)
yuweiw
January 3, 2023, 12:17pm
#7
You need add the capsfilter to videoconvert. You can create a new capsfilter and set the format. Then you link it after the videoconvert plugin.
I created a caps filter with Gray8 format :
caps_gray = Gst.ElementFactory.make("capsfilter", "gray_caps")
if not caps_gray:
sys.stderr.write(" Unable to create v4l2src capsfilter \n")
caps_gray.set_property('caps', Gst.Caps.from_string("format=GRAY8"))
i added it to the pipeline and linked it like that :
vidconvsrc.link(caps_gray)
caps_gray.link(nvvidconvsrc)
Program is working but still no gray filter, here is the pipeline.dot file
pipeline.dot (10.0 KB)
yuweiw
January 4, 2023, 1:43pm
#9
You should add the caps after the nvvideoconvert. I have tried the cli:
gst-launch-1.0 -e filesrc location=/opt/nvidia/deepstream/deepstream/samples/streams/sam
ple_720p.mp4 ! qtdemux ! h264parse ! nvv4l2decoder ! queue2 ! nvvideoconvert ! 'video/x-raw(memory:NVMM),format=GRAY8' ! nvvideoconvert ! 'video/x-raw(memory:NVMM),format=NV12' ! nvv4l2h264enc ! h264parse ! qtmux ! filesink location=out.mp4
It works well. So you can use nvvideconvert to change the format.
