Gst Pylon install on jetson orin nx with deepstream 6.4
Hi. I cannot install pylonsrc gst for Jetson Nx on Ubuntu 22 with Deepstream 6.4.
I have build system on SDK manager. DS 6.4 test samples work. Pylon camera works too. A Pylonsrc camera requires meson ninja as…:
ninja -C builddir test
ninja: Entering directory `builddir’
[1/2] Running all tests.
1/1 generic_states FAIL 1.01s killed by signal 6 SIGABRT
GST_PLUGIN_SCANNER_1_0=/usr/lib/x86_64-linux-gnu/gstreamer1.0/gstreamer-1.0/gst-plugin-scanner GST_PLUGIN_SYSTEM_PATH_1_0=‘’ GST_PLUGIN_PATH_1_0=/home/orin/Downloads/gst-plugin-pylon-main/builddir:/usr/lib/aarch64-linux-gnu/gstreamer-1.0:/usr/lib/aarch64-linux-gnu/gstreamer-1.0 GST_PLUGIN_LOADING_WHITELIST=gstreamer:gst-plugins-base:gst-plugin-pylon@/home/orin/Downloads/gst-plugin-pylon-main/builddir GST_STATE_IGNORE_ELEMENTS=’
’ CK_DEFAULT_TIMEOUT=20 MALLOC_PERTURB_=30 GSETTINGS_BACKEND=memory ASAN_OPTIONS=halt_on_error=1:abort_on_error=1:print_summary=1 GST_REGISTRY=/home/orin/Downloads/gst-plugin-pylon-main/builddir/tests/check/generic_states.registry UBSAN_OPTIONS=halt_on_error=1:abort_on_error=1:print_summary=1:print_stacktrace=1 /home/orin/Downloads/gst-plugin-pylon-main/builddir/tests/check/generic_states
stderr:
(generic_states:5025): GStreamer-WARNING **: 21:17:24.972: External plugin loader failed. This most likely means that the plugin loader helper binary was not found or could not be run. You might need to set the GST_PLUGIN_SCANNER environment variable if your setup is unusual. This should normally not be required though.
(generic_states:5025): GStreamer-WARNING **: 21:17:25.576: Failed to load plugin ‘/home/orin/Downloads/gst-plugin-pylon-main/builddir/bindings/pygstpylon.cpython-310-aarch64-linux-gnu.so’: /home/orin/Downloads/gst-plugin-pylon-main/builddir/bindings/pygstpylon.cpython-310-aarch64-linux-gnu.so: undefined symbol: PyInstanceMethod_Type
GLib (gthread-posix.c): Unexpected error from C library during ‘pthread_setspecific’: Invalid argument. Aborting.
Summary of Failures:
Ok: 0
Expected Fail: 0
Fail: 1
Unexpected Pass: 0
Skipped: 0
Timeout: 0
Full log written to /home/orin/Downloads/gst-plugin-pylon-main/builddir/meson-logs/testlog.txt
FAILED: meson-internal__test
/usr/local/bin/meson test --no-rebuild --print-errorlogs
ninja: build stopped: subcommand failed.
LOG is AS follows:
Log of Meson test suite run on 2024-03-22T21:17:24.951322
Inherited environment: LESSOPEN=‘| /usr/bin/lesspipe %s’ USER=orin XDG_SESSION_TYPE=x11 SHLVL=1 LD_LIBRARY_PATH=/usr/local/cuda-12.2/lib64: HOME=/home/orin DESKTOP_SESSION=ubuntu GNOME_SHELL_SESSION_MODE=ubuntu GTK_MODULES=gail:atk-bridge DBUS_STARTER_BUS_TYPE=session SYSTEMD_EXEC_PID=2521 DBUS_SESSION_BUS_ADDRESS=unix:path=/run/user/1000/bus,guid=72f53dc33c5c207045e998cb0000002c COLORTERM=truecolor IM_CONFIG_PHASE=1 GTK_IM_MODULE=ibus LOGNAME=orin _=/usr/local/bin/ninja XDG_SESSION_CLASS=user USERNAME=orin TERM=xterm-256color GNOME_DESKTOP_SESSION_ID=this-is-deprecated WINDOWPATH=2 PATH=/usr/local/cuda-12.2/bin:/home/orin/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin:/snap/bin SESSION_MANAGER=local/ubuntu:@/tmp/.ICE-unix/2521,unix/ubuntu:/tmp/.ICE-unix/2521 XDG_MENU_PREFIX=gnome- GNOME_TERMINAL_SCREEN=/org/gnome/Terminal/screen/d532de52_6168_4927_be36_ea14ac7d37d1 XDG_RUNTIME_DIR=/run/user/1000 DISPLAY=:1 LANG=en_US.UTF-8 XDG_CURRENT_DESKTOP=ubuntu:GNOME XMODIFIERS=@im=ibus XDG_SESSION_DESKTOP=ubuntu XAUTHORITY=/run/user/1000/gdm/Xauthority LS_COLORS=‘rs=0:di=01;34:ln=01;36:mh=00:pi=40;33:so=01;35:do=01;35:bd=40;33;01:cd=40;33;01:or=40;31;01:mi=00:su=37;41:sg=30;43:ca=30;41:tw=30;42:ow=34;42:st=37;44:ex=01;32:.tar=01;31:.tgz=01;31:.arc=01;31:.arj=01;31:.taz=01;31:.lha=01;31:.lz4=01;31:.lzh=01;31:.lzma=01;31:.tlz=01;31:.txz=01;31:.tzo=01;31:.t7z=01;31:.zip=01;31:.z=01;31:.dz=01;31:.gz=01;31:.lrz=01;31:.lz=01;31:.lzo=01;31:.xz=01;31:.zst=01;31:.tzst=01;31:.bz2=01;31:.bz=01;31:.tbz=01;31:.tbz2=01;31:.tz=01;31:.deb=01;31:.rpm=01;31:.jar=01;31:.war=01;31:.ear=01;31:.sar=01;31:.rar=01;31:.alz=01;31:.ace=01;31:.zoo=01;31:.cpio=01;31:.7z=01;31:.rz=01;31:.cab=01;31:.wim=01;31:.swm=01;31:.dwm=01;31:.esd=01;31:.jpg=01;35:.jpeg=01;35:.mjpg=01;35:.mjpeg=01;35:.gif=01;35:.bmp=01;35:.pbm=01;35:.pgm=01;35:.ppm=01;35:.tga=01;35:.xbm=01;35:.xpm=01;35:.tif=01;35:.tiff=01;35:.png=01;35:.svg=01;35:.svgz=01;35:.mng=01;35:.pcx=01;35:.mov=01;35:.mpg=01;35:.mpeg=01;35:.m2v=01;35:.mkv=01;35:.webm=01;35:.webp=01;35:.ogm=01;35:.mp4=01;35:.m4v=01;35:.mp4v=01;35:.vob=01;35:.qt=01;35:.nuv=01;35:.wmv=01;35:.asf=01;35:.rm=01;35:.rmvb=01;35:.flc=01;35:.avi=01;35:.fli=01;35:.flv=01;35:.gl=01;35:.dl=01;35:.xcf=01;35:.xwd=01;35:.yuv=01;35:.cgm=01;35:.emf=01;35:.ogv=01;35:.ogx=01;35:.aac=00;36:.au=00;36:.flac=00;36:.m4a=00;36:.mid=00;36:.midi=00;36:.mka=00;36:.mp3=00;36:.mpc=00;36:.ogg=00;36:.ra=00;36:.wav=00;36:.oga=00;36:.opus=00;36:.spx=00;36:.xspf=00;36:’ GNOME_TERMINAL_SERVICE=:1.89 SSH_AGENT_LAUNCHER=gnome-keyring SSH_AUTH_SOCK=/run/user/1000/keyring/ssh SHELL=/bin/bash QT_ACCESSIBILITY=1 GDMSESSION=ubuntu LESSCLOSE=‘/usr/bin/lesspipe %s %s’ GPG_AGENT_INFO=/run/user/1000/gnupg/S.gpg-agent:0:1 QT_IM_MODULE=ibus PWD=/home/orin/Downloads/gst-plugin-pylon-main/builddir XDG_CONFIG_DIRS=/etc/xdg/xdg-ubuntu:/etc/xdg PYLON_ROOT=/opt/pylon DBUS_STARTER_ADDRESS=unix:path=/run/user/1000/bus,guid=72f53dc33c5c207045e998cb0000002c XDG_DATA_DIRS=/usr/share/ubuntu:/usr/share/gnome:/usr/local/share/:/usr/share/:/var/lib/snapd/desktop GENICAM_GENTL64_PATH=:/opt/pylon/lib/gentlproducer/gtl VTE_VERSION=6800
==================================== 1/1 =====================================
test: generic_states
start time: 20:17:24
duration: 1.01s
result: killed by signal 6 SIGABRT
command: GST_PLUGIN_SCANNER_1_0=/usr/lib/x86_64-linux-gnu/gstreamer1.0/gstreamer-1.0/gst-plugin-scanner GST_PLUGIN_SYSTEM_PATH_1_0=‘’ GST_PLUGIN_PATH_1_0=/home/orin/Downloads/gst-plugin-pylon-main/builddir:/usr/lib/aarch64-linux-gnu/gstreamer-1.0:/usr/lib/aarch64-linux-gnu/gstreamer-1.0 GST_PLUGIN_LOADING_WHITELIST=gstreamer:gst-plugins-base:gst-plugin-pylon@/home/orin/Downloads/gst-plugin-pylon-main/builddir GST_STATE_IGNORE_ELEMENTS=’
----------------------------------- stderr -----------------------------------
Ok: 0
Expected Fail: 0
Fail: 1
Unexpected Pass: 0
Skipped: 0
Timeout: 0
.What could be the reason?
• DeepStream Version
• TensorRT Version
• The pipeline being used
You can try this FAQ to see if it solves your problem
