• Hardware Platform : Nvidia GeForce GTX 1650 • DeepStream Version : 6.0 • NVIDIA GPU Driver Version (valid for GPU only) : 510.73.05
I am currently using the devel docker on a ubuntu machine (22.04)
I have a piece of code which runs perfectly fine when running in Deepstream 5.1 but the same piece of code when executed in Deepstream 6.0 or above throws the following error
I can’t
The thing is I have a custom faceblur plugin which I have to use to blur the face of the people detected in the video frame so to do that I need to be able to detect people and track them till they leave the frame so that their face is blurred the whole time and the problem I am facing is that this custom plugin works well in DS 5.1 but when used in DS 6.0 and above it fails and result in the error you see above
Update :
I removed the tracker as well but it didn’t solve the issue
This is how my tracker_config.ini file looks right now. Cross referenced it with what I had in the deepstream_python_app repo from github and most of it looks the same
I tried doing it. Cross referenced it with the latest dsexample plugin files and added the needed part in the 6.0 file but it still won’t work. Is there any way to you know port a plugin which was working in 5.1 to 6.0 and above?
Could you attach your whole pipeline or graph of the pipeline? From the log you attached, it seems that the format of the image generated by your faceblur plugin is not compatible with other plugins.
Basicly, If your own plugin don’t use deepstream own plugin, then you only make sure that the version of gstreamer is the same.
Which is your own plugin in the graph and what’s its src and sink format?
Can you enable gst debug to get more debug log after you change the tracker config?
Also, you can add some log in your own plugin and debug by yourself.
