Hello
JETSON ORIN NANO
L4T: 36.4.3
Jetpack: 6.2
OpenCV: 4.12.0-dev with CUDA YES
The problem is as follows:
I want to use the IMX219-83 Stereo Camera, however, GSTREAMER is not enabled to use the Python code.
When compiling OpenCV, it is enabled in cmake -D WITH_GSTREAMER=ON and shows that it is enabled upon completion.
When checking in Python, GSTREAMER is not enabled.
When running this in the terminal, the camera does open.
gst-launch-1.0 nvarguscamerasrc sensor-id=0 !
‘video/x-raw(memory:NVMM), width=1280, height=720, format=NV12, framerate=30/1’ !
queue ! nvvidconv ! nvegltransform ! nveglglessink
But when I try to adapt it in Python, it says that gstreamer is not enabled.
Hello @JorgeLdeJesus
You could try following the instructions at Compiling OpenCV from Source to enable GStreamer when installing OpenCV.
For capturing with your camera sensor, you could take a look the examples at RidgeRun Linux Camera Drivers - Jetson OpenCV Examples
I hope this helps!
Regards!
Eduardo Salazar
Embedded SW Engineer at RidgeRun
Contact us: support@ridgerun.com
Developers wiki: https://developer.ridgerun.com/
Website: www.ridgerun.com
Thanks, Eduardo.
It seems that GSTREAMER was being installed with OpenCV and worked with gst-launch-1.0, but when trying to use it with Python, it didn’t.
The problem is that the OpenCV .so file for Python wasn’t found (cv2*.so). The PYTHON3_PACKAGES_PATH variable wasn’t pointing correctly, or the .so file wasn’t being generated in the expected path.
We created a build_opencv.sh script to automate a clean installation of OpenCV with full support, including:
WITH_GSTREAMER=ON
WITH_CUDA=ON
OPENCV_ENABLE_NONFREE=ON
BUILD_opencv_python3=ON
We deleted the contents of opencv/build/ and successfully ran cmake from a clean directory.
Reinstall CMake and verify the paths are correct with:
PYTHON3_EXECUTABLE
Thanks for the help
So, is the issue already solved?
Regards!
