No, type enter a few times in the dmesg terminal in order to separate previous messages from the ones that will happen now if any.
Then in the other terminal, launch the gst-launch command. If this triggers new messages, just post these.
no messages at all after running the commands.
What about reading each camera separately as above ?
I ask that because your working pipeline doesn’t specify any mode.
I tried using the cameras separately and it just gives me the same errors as before:
WARNING: erroneous pipeline: no element "nvv4l2decoder"
here is a screenshot of the dmesg terminal and me running the commands in putty:
Hmm… Be sure it is nvv4l2decoder, not nvv412decoder.
What gives:
# Test cam1
gst-launch-1.0 -v v4l2src device=/dev/video0 ! image/jpeg ! nvv4l2decoder mjpeg=1 ! nvvidconv ! xvimagesink
# Test cam2
gst-launch-1.0 -v v4l2src device=/dev/video1 ! image/jpeg ! nvv4l2decoder mjpeg=1 ! nvvidconv ! xvimagesink
Literally copying and pasting from what you post.
Gives me:
b3ck@belabox:/usr/share/belacoder/pipelines/jetson$ gst-launch-1.0 -v v4l2src device=/dev/video0 ! image/jpeg ! nvv4l2decoder mjpeg=1 ! nvvidconv ! xvimagesink
Gives me:
b3ck@belabox:/usr/share/belacoder/pipelines/jetson$ gst-launch-1.0 -v v4l2src device=/dev/video1 ! image/jpeg ! nvv4l2decoder mjpeg=1 ! nvvidconv ! xvimagesink
Please post the output of v4l2-ctl commands above (v4l2-ctl is provided by apt package v4l-utils).
You may also try:
gst-launch-1.0 -v v4l2src device=/dev/video0 ! image/jpeg ! nvjpegdec ! 'video/x-raw(memory:NVMM),format=I420' ! nvvidconv ! xvimagesink
b3ck@belabox:/usr/share/belacoder/pipelines/jetson$ gst-launch-1.0 -v v4l2src device=/dev/video0 ! image/jpeg ! nvjpegdec ! 'video/x-raw(memory:NVMM),format=I420' ! nvvidconv ! xvimagesink
WARNING: erroneous pipeline: no element "nvjpegdec"
b3ck@belabox:/usr/share/belacoder/pipelines/jetson$ sudo v4l2-ctl -d0 --list-formats-ext
[sudo] password for b3ck:
ioctl: VIDIOC_ENUM_FMT
Index : 0
Type : Video Capture
Pixel Format: 'YUYV'
Interval: Discrete 0.033s (30.000 fps)
Interval: Discrete 0.042s (24.000 fps)
Interval: Discrete 0.050s (20.000 fps)
Interval: Discrete 0.067s (15.000 fps)
Interval: Discrete 0.100s (10.000 fps)
Interval: Discrete 0.133s (7.500 fps)
Interval: Discrete 0.200s (5.000 fps)
Size: Discrete 1920x1080
Size: Discrete 2304x1296
Index : 1
Pixel Format: 'MJPG' (compressed)
Interval: Discrete 0.017s (60.000 fps)
Index : 2
Pixel Format: 'NV12'
Seems there is something wrong in your environment. Try cleaning the gstreamer cache:
rm ~/.cache/gstreamer-1.0/registry.aarch64.bin
gst-inspect-1.0 nvv4l2decoder
PART 2:
b3ck@belabox:/usr/share/belacoder/pipelines/jetson$ sudo v4l2-ctl -d1 --list-formats-ext
Index : 0
Index : 1
Index : 2
b3ck@belabox:/usr/share/belacoder/pipelines/jetson$ sudo rm ~/.cache/gstreamer-1.0/registry.aarch64.bin
b3ck@belabox:/usr/share/belacoder/pipelines/jetson$ gst-inspect-1.0 nvv4l2decoder
Error: Can't initialize nvrm channel
Couldn't create ddkvic Session: Cannot allocate memory
nvbuf_utils: Could not create Default NvBufferSession
No such element or plugin 'nvv4l2decoder'
I also have a fresh never touched version of a belabox on another jetson nano and I get this:
**user@belabox**:**~**$ sudo gst-inspect-1.0 nvv4l2decoder
sudo: gst-inspect-1.0: command not found
I installed gstreamer1.0-tools and got a bunch of info:
Factory Details:
Rank primary + 11 (267)
Long-name NVIDIA v4l2 video decoder
Klass Codec/Decoder/Video
Description Decode video streams via V4L2 API
Author Nicolas Dufresne <nicolas.dufresne@collabora.com>, Viranjan Pagar <vpagar@nvidia.com>
Plugin Details:
Name nvvideo4linux2
Description Nvidia elements for Video 4 Linux
Filename /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvvideo4linux2.so
Version 1.14.0
License LGPL
Source module nvvideo4linux2
Binary package nvvideo4linux2
Origin URL http://nvidia.com/
GObject
+----GInitiallyUnowned
+----GstObject
+----GstElement
+----GstVideoDecoder
+----GstNvV4l2VideoDec
+----nvv4l2decoder
Pad Templates:
SRC template: 'src'
Availability: Always
Capabilities:
width: [ 1, 2147483647 ]
height: [ 1, 2147483647 ]
framerate: [ 0/1, 2147483647/1 ]
SINK template: 'sink'
Capabilities:
image/jpeg
video/x-h264
stream-format: { (string)byte-stream }
alignment: { (string)au }
video/x-h265
video/mpeg
mpegversion: 4
systemstream: false
parsed: true
video/mpeg
mpegversion: [ 1, 2 ]
systemstream: false
parsed: true
video/x-divx
divxversion: [ 4, 5 ]
video/x-vp8
video/x-vp9
Element has no clocking capabilities.
Element has no URI handling capabilities.
Pads:
SINK: 'sink'
Pad Template: 'sink'
SRC: 'src'
Pad Template: 'src'
Element Properties:
name : The name of the object
flags: readable, writable
String. Default: "nvv4l2decoder0"
parent : The parent of the object
Object of type "GstObject"
device : Device location
flags: readable
String. Default: "/dev/nvhost-nvdec"
device-name : Name of the device
flags: Opening in BLOCKING MODE
readable
String. Default: ""
device-fd : File descriptor of the device
flags: readable
Integer. Range: -1 - 2147483647 Default: -1
output-io-mode : Output side I/O mode (matches sink pad)
Enum "GstNvV4l2DecOutputIOMode" Default: 0, "auto"
(0): auto - GST_V4L2_IO_AUTO
(2): mmap - GST_V4L2_IO_MMAP
(3): userptr - GST_V4L2_IO_USERPTR
capture-io-mode : Capture I/O mode (matches src pad)
Enum "GstNvV4l2DecCaptureIOMode" Default: 0, "auto"
extra-controls : Extra v4l2 controls (CIDs) for the device
Boxed pointer of type "GstStructure"
skip-frames : Type of frames to skip during decoding
flags: readable, writable, changeable in NULL, READY, PAUSED or PLAYING state
Enum "SkipFrame" Default: 0, "decode_all"
(0): decode_all - Decode all frames
(1): decode_non_ref - Decode non-ref frames
(2): decode_key - decode key frames
drop-frame-interval : Interval to drop the frames,ex: value of 5 means every 5th frame will be given by decoder, rest all dropped
flags: readable, writable, changeable only in NULL or READY state
Unsigned Integer. Range: 0 - 30 Default: 0
num-extra-surfaces : Additional number of surfaces in addition to min decode surfaces given by the v4l2 driver
Unsigned Integer. Range: 0 - 24 Default: 1
disable-dpb : Set to disable DPB buffer for low latency
Boolean. Default: false
enable-full-frame : Whether or not the data is full framed
enable-frame-type-reporting: Set to enable frame type reporting
enable-error-check : Set to enable error check
enable-max-performance: Set to enable max performance
mjpeg : Set to open MJPEG block
bufapi-version : Set to use new buf API
Boolean. Default: false```
So that tells me I should probably wipe the SD card and start over, because who knows where I messed it up down the line =/
Ok, so now retry the pipelines for reading each cam.
I can’t I’m doing this all remotely, so I need to have the person format the SD card and re-flash it. The successful part of that was on the jetson nano I have with me.
I’ll get back to you asap, thanks!
Yes, probably you would reflash a Nano, apt update/upgrade and retry these commands before installing other packages or belabox.
The good news are the raw modes provided by your cameras, so it might overcome the USB/MJPG bw issue, but the resolution x fps may be limited.
Let us know when you’re ready before trying that if required.
I did a fresh flash of the SD Card with the belabox pre-made image, which is what I want to do, but things aren’t working… I really do appreciate your help, thanks again, I’ll let you know if I decide to tackle this in the future!
What step fails ? Finding NVIDIA gstreamer plugins ? Reading camera ? Or else ?
I don’t have a Nano so cannot try to reproduce.
