I am creating a Dockerfile for an GStreamer app I have. I am using the following image :
FROM dustynv/deepstream:r35.4.1
I use the hardware : Jetson AGX ORIN.
I have the following tegra release : R35 (release), REVISION: 5.0, GCID: 35550185, BOARD: t186ref, EABI: aarch64…
I can compile the app without error using CMake, but when I start making request I get the following error message :
(gst-plugin-scanner:30): GStreamer-WARNING **: 09:03:30.211: Failed to load plugin [13/961]
b/aarch64-linux-gnu/gstreamer-1.0/libgstnveglstreamsrc.so': /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnveglstreamsrc.so: file too short
(gst-plugin-scanner:30): GStreamer-WARNING **: 09:03:30.211: Failed to load plugin '/usr/li
b/aarch64-linux-gnu/gstreamer-1.0/libgstnvtee.so': /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvtee.so: file too short
b/aarch64-linux-gnu/gstreamer-1.0/libgstnvjpeg.so': /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvjpeg.so: file too short
(gst-plugin-scanner:30): GStreamer-WARNING **: 09:03:30.212: Failed to load plugin '/usr/li
b/aarch64-linux-gnu/gstreamer-1.0/libgstnvvidconv.so': /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvvidconv.so: file too short
(gst-plugin-scanner:30): GStreamer-WARNING **: 09:03:30.212: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvv4l2camerasrc.so': /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvv4l2camerasrc.so: file too short
(gst-plugin-scanner:30): GStreamer-WARNING **: 09:03:30.212: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvarguscamerasrc.so': /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvarguscamerasrc.so: file too short
b/aarch64-linux-gnu/gstreamer-1.0/libgstnvcompositor.so': /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvcompositor.so: file too short
(gst-plugin-scanner:30): GStreamer-WARNING **: 09:03:30.212: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvvideosinks.so': /usr/lib/aarch64-linux-gnu/gstrea
mer-1.0/libgstnvvideosinks.so: file too short
b/aarch64-linux-gnu/gstreamer-1.0/libgstnvegltransform.so': /usr/lib/aarch64-linux-gnu/gstr
eamer-1.0/libgstnvegltransform.so: file too short
b/aarch64-linux-gnu/gstreamer-1.0/libgstnvvideo4linux2.so': /usr/lib/aarch64-linux-gnu/gstr
eamer-1.0/libgstnvvideo4linux2.so: file too short
b/aarch64-linux-gnu/gstreamer-1.0/libgstnvivafilter.so': /usr/lib/aarch64-linux-gnu/gstream
er-1.0/libgstnvivafilter.so: file too short
b/aarch64-linux-gnu/gstreamer-1.0/libgstnvvideosink.so': /usr/lib/aarch64-linux-gnu/gstream
er-1.0/libgstnvvideosink.so: file too short
b/aarch64-linux-gnu/gstreamer-1.0/libgstnveglglessink.so': /usr/lib/aarch64-linux-gnu/gstre...
When I look at the plugins they indeed seem empty :
-rw-r--r-- 1 root root 10336 Aug 1 2023 libgstnavigationtest.so
-rw-r--r-- 1 root root 27416 Nov 28 2023 libgstnetsim.so
-rw-r--r-- 1 root root 43808 Nov 16 2018 libgstnrtp.so
-rwxr-xr-x 1 root root 0 Aug 3 2023 libgstnvarguscamerasrc.so*
-rwxr-xr-x 1 root root 0 Aug 3 2023 libgstnvcompositor.so*
-rwxr-xr-x 1 root root 0 Aug 3 2023 libgstnvdrmvideosink.so*
-rwxr-xr-x 1 root root 0 Aug 3 2023 libgstnveglglessink.so*
-rwxr-xr-x 1 root root 0 Aug 3 2023 libgstnveglstreamsrc.so*
-rwxr-xr-x 1 root root 0 Aug 3 2023 libgstnvegltransform.so*
-rwxr-xr-x 1 root root 0 Aug 3 2023 libgstnvivafilter.so*
-rwxr-xr-x 1 root root 0 Aug 3 2023 libgstnvjpeg.so*
-rwxr-xr-x 1 root root 0 Aug 3 2023 libgstnvtee.so*
-rwxr-xr-x 1 root root 0 Aug 3 2023 libgstnvv4l2camerasrc.so*
-rwxr-xr-x 1 root root 0 Aug 3 2023 libgstnvvidconv.so*
-rwxr-xr-x 1 root root 0 Aug 3 2023 libgstnvvideo4linux2.so*
-rwxr-xr-x 1 root root 0 Aug 3 2023 libgstnvvideosink.so*
-rwxr-xr-x 1 root root 0 Aug 3 2023 libgstnvvideosinks.so*
-rw-r--r-- 1 root root 14616 Nov 28 2023 libgstofa.so
-rw-r--r-- 1 root root 218136 Jul 26 2022 libgstogg.so
I tried copying from my local machine all the files to the docker, to replace the empty files, that didn’t work.
