error while loading shared libraries: /usr/lib/aarch64-linux-gnu/tegra/libgstreamer-1.0.so.0: file too short
Our detection inference Docker gets the above error on an Orin Nano 5.1.2 but not when we use 5.1.1 (with Orin NX). We also had a the same issue on an AGX Xavier 5.1.2 and resolved it by rolling back to 5.0.2.
I read there is a Gstreamer version compatibility issue in the below linked post. What is the work around to get this working on 5.1.2? If there is an issue, will it be resolved in a future jetpack?
$ cat /etc/nv_tegra_release │
R35 (release), REVISION: 4.1, GCID: 33958178, BOARD: t186ref, EABI: aarch64, DATE: Tue Aug 1 19:57:35 UTC 2023
The issue was there was no libnvgstreamer. we fixed it by copying the files over from a working system. What might have gone wrong during the jetpack flashing process to cause this to be missing?
