Gstreamer python appsink callback not triggering
I am trying to run a python script that reads a camera video from a rtsp, performs some yolo detections and stream the output in a multicast.
Setup: I am using a Jetson Orin NX and running the script from a conda environment.
I was able to read the rtsp and broadcast the same original video over the multicast using gstreamer.
but I’m having issues streaming the modified_frames.
In my understanding I need to add the appsink to the pipeline since I want to modify the frames by adding bounding boxes, labels or filters. The problem comes when I add the appsink to the pipeline, the callback is never triggered.
Here is my code
from ultralytics import YOLO
# GStreamer
import gi
gi.require_version('Gst', '1.0')
from gi.repository import Gst, GLib
# Initialize GStreamer
Gst.init(None)
# Gst.debug_set_active(True)
# Gst.debug_set_default_threshold(Gst.DebugLevel.DEBUG)
# YOLO Model
model = YOLO("yolo11n.pt")
def on_message(bus, message, pipeline):
    print('on_message')
    Callback function to handle messages from the pipeline's bus.
    message_type = message.type
    if message_type == Gst.MessageType.EOS:
        print("End of Stream reached")
        pipeline.set_state(Gst.State.NULL)
    elif message_type == Gst.MessageType.ERROR:
        err, debug = message.parse_error()
        print(f"Error: {err}, {debug}")
def rebroadcast_rtsp_with_annotations(rtsp_url, multicast_ip, multicast_port):
    print('rebroadcast_rtsp_with_annotations')
    This function takes an RTSP URL, runs YOLO on each frame, and rebroadcasts the annotated video over UDP multicast.
    # Create a new GStreamer pipeline
    pipeline = Gst.Pipeline.new("rtsp-rebroadcast-pipeline")
    # Create elements for the pipeline
    rtspsrc = Gst.ElementFactory.make("rtspsrc", "rtsp-source")
    rtph265depay = Gst.ElementFactory.make("rtph265depay", "rtp-depayloader")
    h265parse = Gst.ElementFactory.make("h265parse", "h265-parser")
    mpegtsmux = Gst.ElementFactory.make("mpegtsmux", "mpegts-muxer")
    udpsink = Gst.ElementFactory.make("udpsink", "udp-sink")
    appsink = Gst.ElementFactory.make("appsink", "appsink")
    if not rtspsrc or not rtph265depay or not h265parse or not mpegtsmux or not udpsink or not appsink:
        print("Failed to create one or more GStreamer elements.")
        return
    # Set properties
    rtspsrc.set_property("location", rtsp_url)
    udpsink.set_property("host", multicast_ip)
    udpsink.set_property("port", multicast_port)
    udpsink.set_property("sync", False)  # Disable sync to reduce latency
    appsink.set_property("emit-signals", True)
    appsink.set_property("sync", False)
    appsink.set_property("drop", True)
    appsink.connect("new-sample", on_new_sample_from_appsink, None)
    # Add elements to the pipeline
    pipeline.add(rtspsrc)
    pipeline.add(rtph265depay)
    pipeline.add(h265parse)
    pipeline.add(mpegtsmux)
    pipeline.add(udpsink)
    pipeline.add(appsink)
    # Link elements
    rtph265depay.link(h265parse)
    h265parse.link(mpegtsmux)
    mpegtsmux.link(udpsink)
    mpegtsmux.link(appsink)
    # Create pad-added callback
    def on_pad_added(src, pad):
        print("Pad added:", pad)
        caps = pad.query_caps(None)
        print("Pad added with capabilities:", caps.to_string())
        if caps.to_string().startswith("application/x-rtp"):
            if "H265" in caps.to_string():
                pad.link(rtph265depay.get_static_pad("sink"))
                print("Pad linked to depayloader.")
    rtspsrc.connect("pad-added", on_pad_added)
    # Start the pipeline
    pipeline.set_state(Gst.State.PLAYING)
    print("Pipeline is playing...")
    # Set up the bus to listen for messages
    bus = pipeline.get_bus()
    bus.add_signal_watch()
    bus.connect("message", on_message, pipeline)
    print(f"Rebroadcasting RTSP stream {rtsp_url} to UDP multicast {multicast_ip}:{multicast_port}")
    # Start main loop
    try:
        print('===== loop =========')
        loop = GLib.MainLoop()
        loop.run()
    except KeyboardInterrupt:
        print("Interrupted by user. Stopping...")
def on_new_sample_from_appsink(sink, user_data):
    print('====== on_new_sample_from_appsink ====')
    Called when new frames are available from the appsink.
    Processes the frame and pushes it back to the pipeline.
    sample = sink.emit("pull-sample")
    if sample:
        # Extract the frame from the sample
        buffer = sample.get_buffer()
        caps = sample.get_caps()
        width = caps.get_structure(0).get_int("width")[1]
        height = caps.get_structure(0).get_int("height")[1]
        # Map the buffer to get raw frame data
        success, map_info = buffer.map(Gst.MapFlags.READ)
        if success:
            raw_data = map_info.data
            frame = np.ndarray(
                shape=(height, width, 3),
                dtype=np.uint8,
                buffer=raw_data
            # Process the frame with YOLO
            annotated_frame = process_frame(frame)
            # Create a new GstBuffer with the annotated frame
            new_buffer = Gst.Buffer.new_wrapped(annotated_frame.tobytes())
            # Push the new annotated buffer to the pipeline
            sink.emit("push-sample", new_buffer)
        return Gst.FlowReturn.OK
    return Gst.FlowReturn.ERROR
def process_frame(frame):
    print('process frame')
    Process each frame with YOLO and annotate the detections.
    # Perform YOLO object detection
    results = model.track(frame)
    annotated_frame = frame.copy()
    # Here my custon logic to iterate through the results and modify the annotated_frame
    return annotated_frame
if __name__ == "__main__":
    rtsp_url = "rtsp://xx.xx.xx.xx:port/video1"
    multicast_ip = "xxx.x.x.x"
    multicast_port = port
If I comment out the line pipeline.add(appsink), I can see the (raw) camera video in the multicast port.
How can I stream the modify frames in a multicast using gstream from a python script?
I appreciate any help
Please try single appsink. Since udpsink works and would like to know if having single appsink works.
There is no python sample which demonstrating appsink. Some C samples for your reference:
Nvidia-desktop kernel: [407343.357549] (NULL device *): nvhost_channelctl: invalid cmd 0x80685600 - #35 by DaneLLL
I want to decode H264NAL unit data to still image data - #41 by DaneLLL
Hi @DaneLLL, thanks for your response.
I tried using only the appsink, and I was able to get the callback to trigger, but it doesn’t receive valid frames
if frame is None or frame.shape[0] == 0 or frame.shape[1] ==0:
print("Invalid frame with shape: " , frame.shape)
it prints Invalid frame with shape: (0, 0, 3)
No, it is still the same.
When I tried using just appsink, the callback is triggered but doesn’t get frames, and if I put udpsink back, it doesn’t trigger the callbacks, so I cannot stream the modified frames. I don’t know how else to configure the pipeline.
Is the error specific to python sample? Or occurs in C sample also? We think the C sample should work. Since we don’t have experience about using appsink in python, this would need other users to share experience.
Unfortunately, I haven’t had much time to test appsink in C. Currently, I’m focused on configuring FFmpeg and DeepStream, as I believe DeepStream uses GStreamer in the background
