Is the source for the gstreamer OMX plugins available?
hi kunice, we have source in https://developer.nvidia.com/embedded/dlc/l4t-sources-27-1
gstegl_src
gstjpeg_src
gstomx1_src
There are some errors doing a build of the gstomx1_src:
nvidia@tegra-ubuntu:~/src/gstomx1_src/gst-omx1$ sh -x …/setup.sh
- export NOCONFIGURE=true
- export GST_EGL_LIBS=-lgstnvegl-1.0 -lEGL -lX11 -lgstreamer-1.0 -lgobject-2.0 -lglib-2.0
- sudo ln -s /usr/lib/arm-linux-gnueabihf/libgstnvegl-1.0.so.0 /usr/lib/arm-linux-gnueabihf/libgstnvegl-1.0.so
ln: failed to create symbolic link ‘/usr/lib/arm-linux-gnueabihf/libgstnvegl-1.0.so’: No such file or directory - ./autogen.sh
fatal: Not a git repository (or any of the parent directories): .git
ln: failed to create symbolic link ‘.git/hooks/pre-commit’: No such file or directory - check for build tools
checking for autoconf >= 2.60 … found 2.69, ok.
checking for automake >= 1.10 … found 1.15, ok.
checking for libtoolize >= 1.5.0 … found 2.4.6, ok.
checking for pkg-config >= 0.8.0 … found 0.29.1, ok. - checking for autogen.sh options
This autogen script will automatically run ./configure as:
./configure --enable-maintainer-mode --enable-gtk-doc
To pass any additional options, please specify them on the ./autogen.sh
command line. - running libtoolize --copy --force…
libtoolize: putting auxiliary files in ‘.’.
libtoolize: copying file ‘./ltmain.sh’
libtoolize: putting macros in ‘m4’.
libtoolize: copying file ‘m4/libtool.m4’
libtoolize: copying file ‘m4/ltoptions.m4’
libtoolize: copying file ‘m4/ltsugar.m4’
libtoolize: copying file ‘m4/ltversion.m4’
libtoolize: copying file ‘m4/lt~obsolete.m4’
libtoolize: Remember to add ‘LT_INIT’ to configure.ac.
libtoolize: Consider adding ‘AC_CONFIG_MACRO_DIRS([m4])’ to configure.ac,
libtoolize: and rerunning libtoolize and aclocal. - running aclocal -I m4 -I common/m4 …
^C
nvidia@tegra-ubuntu:~/src/gstomx1_src/gst-omx1$ sudo ln -s /usr/lib/aarch64-linux-gnu/libgstnvegl-1.0.so.0 /usr/lib/aarch64-linux-gnu/libgstnvegl-1.0.so
nvidia@tegra-ubuntu:~/src/gstomx1_src/gst-omx1$ ./autogen.sh
- running autoheader …
- running autoconf …
- running automake -a -c…
configure.ac:48: installing ‘./compile’
configure.ac:15: installing ‘./missing’
examples/egl/Makefile.am: installing ‘./depcomp’
omx/Makefile.am:13: warning: source file ‘$(top_builddir)/gstomx_config.c’ is in a subdirectory,
omx/Makefile.am:13: but option ‘subdir-objects’ is disabled
automake: warning: possible forward-incompatibility.
automake: At least a source file is in a subdirectory, but the ‘subdir-objects’
automake: automake option hasn’t been enabled. For now, the corresponding output
automake: object file(s) will be placed in the top-level directory. However,
automake: this behaviour will change in future Automake versions: they will
automake: unconditionally cause object files to be placed in the same subdirectory
automake: of the corresponding sources.
automake: You are advised to start using ‘subdir-objects’ option throughout your
automake: project, to avoid future incompatibilities. - running configure …
./configure default flags: --enable-maintainer-mode --enable-gtk-doc
checking build system type… aarch64-unknown-linux-gnu
checking host system type… aarch64-unknown-linux-gnu
checking target system type… aarch64-unknown-linux-gnu
checking for a BSD-compatible install… /usr/bin/install -c
checking whether build environment is sane… yes
checking for a thread-safe mkdir -p… /bin/mkdir -p
checking for gawk… no
checking for mawk… mawk
checking whether make sets $(MAKE)… yes
checking whether make supports nested variables… yes
checking whether UID ‘1001’ is supported by ustar format… yes
checking whether GID ‘1001’ is supported by ustar format… yes
checking how to create a ustar tar archive… gnutar
checking nano version… 1
checking whether to enable maintainer-specific portions of Makefiles… yes
checking whether make supports nested variables… (cached) yes
checking how to print strings… printf
checking for style of include used by make… GNU
checking for gcc… gcc
checking whether the C compiler works… yes
checking for C compiler default output file name… a.out
checking for suffix of executables…
checking whether we are cross compiling… no
checking for suffix of object files… o
checking whether we are using the GNU C compiler… yes
checking whether gcc accepts -g… yes
checking for gcc option to accept ISO C89… none needed
checking whether gcc understands -c and -o together… yes
checking dependency style of gcc… gcc3
checking for a sed that does not truncate output… /bin/sed
checking for grep that handles long lines and -e… /bin/grep
checking for egrep… /bin/grep -E
checking for fgrep… /bin/grep -F
checking for ld used by gcc… /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld… yes
checking for BSD- or MS-compatible name lister (nm)… /usr/bin/nm -B
checking the name lister (/usr/bin/nm -B) interface… BSD nm
checking whether ln -s works… yes
checking the maximum length of command line arguments… 1572864
checking how to convert aarch64-unknown-linux-gnu file names to aarch64-unknown-linux-gnu format… func_convert_file_noop
checking how to convert aarch64-unknown-linux-gnu file names to toolchain format… func_convert_file_noop
checking for /usr/bin/ld option to reload object files… -r
checking for objdump… objdump
checking how to recognize dependent libraries… pass_all
checking for dlltool… no
checking how to associate runtime and link libraries… printf %s\n
checking for ar… ar
checking for archiver @FILE support… @
checking for strip… strip
checking for ranlib… ranlib
checking command to parse /usr/bin/nm -B output from gcc object… ok
checking for sysroot… no
checking for a working dd… /bin/dd
checking how to truncate binary pipes… /bin/dd bs=4096 count=1
checking for mt… mt
checking if mt is a manifest tool… no
checking how to run the C preprocessor… gcc -E
checking for ANSI C header files… yes
checking for sys/types.h… yes
checking for sys/stat.h… yes
checking for stdlib.h… yes
checking for string.h… yes
checking for memory.h… yes
checking for strings.h… yes
checking for inttypes.h… yes
checking for stdint.h… yes
checking for unistd.h… yes
checking for dlfcn.h… yes
checking for objdir… .libs
checking if gcc supports -fno-rtti -fno-exceptions… no
checking for gcc option to produce PIC… -fPIC -DPIC
checking if gcc PIC flag -fPIC -DPIC works… yes
checking if gcc static flag -static works… yes
checking if gcc supports -c -o file.o… yes
checking if gcc supports -c -o file.o… (cached) yes
checking whether the gcc linker (/usr/bin/ld) supports shared libraries… yes
checking whether -lc should be explicitly linked in… no
checking dynamic linker characteristics… GNU/Linux ld.so
checking how to hardcode library paths into programs… immediate
checking for shl_load… no
checking for shl_load in -ldld… no
checking for dlopen… no
checking for dlopen in -ldl… yes
checking whether a program can dlopen itself… yes
checking whether a statically linked program can dlopen itself… no
checking whether stripping libraries is possible… yes
checking if libtool supports shared libraries… yes
checking whether to build shared libraries… yes
checking whether to build static libraries… no
checking for pkg-config… /usr/bin/pkg-config
checking pkg-config is at least version 0.9.0… yes
checking for VALGRIND… no
configure: Using GStreamer OpenMAX Plug-ins git as package name
configure: Using Unknown package origin as package origin
configure: Using GST_PKG_CONFIG_PATH = $(top_builddir)/pkgconfig
configure: *** checking feature: building of experimental plug-ins ***
configure: not building experimental plug-ins
checking whether byte ordering is bigendian… no
checking for special C compiler options needed for large files… no
checking for _FILE_OFFSET_BITS value needed for large files… no
checking for gcc… (cached) gcc
checking whether we are using the GNU C compiler… (cached) yes
checking whether gcc accepts -g… (cached) yes
checking for gcc option to accept ISO C89… (cached) none needed
checking whether gcc understands -c and -o together… (cached) yes
checking dependency style of gcc… (cached) gcc3
checking for gcc option to accept ISO C99… none needed
checking for gcc option to accept ISO Standard C… (cached) none needed
checking for valgrind… no
checking for gtkdoc-check… /usr/bin/gtkdoc-check
checking for gtkdoc-rebase… /usr/bin/gtkdoc-rebase
checking for gtkdoc-mkpdf… /usr/bin/gtkdoc-mkpdf
checking for GTKDOC_DEPS… yes
checking whether to build gtk-doc documentation… yes
configure: Looking for Python version >= 2.1
checking for python… /usr/bin/python
checking “/usr/bin/python”:… okay
checking local Python configuration… looks good
checking for python version… 2.7
checking for python platform… linux2
checking for python script directory… ${prefix}/lib/python2.7/dist-packages
checking for python extension module directory… ${exec_prefix}/lib/python2.7/dist-packages
checking whether to build plugin documentation… yes
checking for cos in -lm… yes
checking for ANSI C header files… (cached) yes
checking for stdint types… stdint.h (shortcircuit)
make use of stdint.h in _stdint.h (assuming C99 compatible system)
checking whether gcc implements PRETTY_FUNCTION… yes
checking whether gcc implements FUNCTION… yes
checking whether gcc implements func… yes
checking for GLIB… yes
checking for glib-genmarshal… glib-genmarshal (from pkg-config path)
checking for glib-mkenums… glib-mkenums
checking for GIO… yes
checking for GST… yes
configure: using GStreamer tools in /usr/bin
configure: using GStreamer plug-ins in /usr/lib/aarch64-linux-gnu/gstreamer-1.0
checking for GST_BASE… yes
checking for GST_CONTROLLER… yes
checking for GST_CHECK… yes
checking for GST_PLUGINS_BASE… no
configure: No package ‘gstreamer-plugins-base-1.0’ found
configure: error: no gstreamer-plugins-base-1.0 >= 1.0.0 (GStreamer Base Plugins) found
configure failed
Hi kunice, we have it fixed in next release.
DaneLLL,
Can you give an ETA on the next release?
Thx,
K-
Please try r28.1
