Gstreamer v4l2src usb camera exposure control
Dear all,
I want to control exposure of usb camera using v4l2src in gstreamer pipeline.
I’ve seen a comments that it is not supported in 2018, but it would be included for future version.
So, I want to ask if I can control exposure of usb camera now using gstreamer pipeline with v4l2src.
Thank you in advance.
hello jwna1885,
that’s not supported since USB practically control exposure internally, and output YUV frames to user-space.
may I know what’s your actual use-case. how about toggle the brightness settings?
I just wanted to set exposure time manually since sometimes it is too bright.
Can I toggle the brightness settings in USB camera?
If I can, how can I do it? I’m using gstreamer pipeline as below.
std::sprintf(gstreamer_api_str, "v4l2src device=/dev/video0 "
                "! image/jpeg,width=%d,height=%d,framerate=%d/1 "
                "! nvv4l2decoder mjpeg=1 "
                "! nvvidconv "
                "! video/x-raw(memory:NVMM),format=NV12 "
                "! nvvidconv flip-method=0 "
                "! video/x-raw, format=(string)BGRx "
                "! videoconvert "
                "! appsink", config.stream_w, config.stream_h, config.frame_rate);
hello jwna1885,
please check the Element Properties for v4l2src,
for example,
  brightness          : Picture brightness, or more precisely, the black level
                        flags: readable, writable, controllable
                        Integer. Range: -2147483648 - 2147483647 Default: 0
