I have a single GTX 295 card installed on to a Rampage II extreme board, 12 GB RAM, i7 965 CPU, and I am running Vista x64.
When I compile & run the ‘deviceQuery’ project included with the CUDA SDK samples, I get the following output:
There is 1 device supporting CUDA
Device 0: "GeForce GTX 295"
Major revision number: 1
Minor revision number: 3
Total amount of global memory: 939524096 bytes
Number of multiprocessors: 30
Number of cores: 240
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 16384 bytes
Total number of registers available per block: 16384
Warp size: 32
Maximum number of threads per block: 512
Maximum sizes of each dimension of a block: 512 x 512 x 64
Maximum sizes of each dimension of a grid: 65535 x 65535 x 1
Maximum memory pitch: 262144 bytes
Texture alignment: 256 bytes
Clock rate: 1.24 GHz
Concurrent copy and execution: No
Test PASSED
Press ENTER to exit...
I was expecting that CUDA would ‘see’ 2 cards with 30 MPs each, or possible 1 card with 60 MPs (either way, a total of 480 cores).
This would suggest that the CUDA code I write cannot take full advantage of the GTX 295.
How can I ‘see’ the full resources of the GTX 295? External Media
