gtx 470 showing 112 cores
Hi
I just got a GTX 470 for my own development and cuda-3.0 shows 112 cores as following:
[codebox]Device 0: “GeForce GTX 470”
CUDA Driver Version: 3.0
CUDA Runtime Version: 3.0
CUDA Capability Major revision number: 2
CUDA Capability Minor revision number: 0
Total amount of global memory: 1341325312 bytes
Number of multiprocessors: 14
Number of cores: 112
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 49152 bytes
Total number of registers available per block: 32768
Warp size: 32
Maximum number of threads per block: 1024
Maximum sizes of each dimension of a block: 1024 x 1024 x 64
Maximum sizes of each dimension of a grid: 65535 x 65535 x 1
Maximum memory pitch: 2147483647 bytes
Texture alignment: 512 bytes
Clock rate: 1.22 GHz
Concurrent copy and execution: Yes
Run time limit on kernels: Yes
Integrated: No
Support host page-locked memory mapping:       Yes
Compute mode: Default (multiple host threads can use this device simultaneously)
[/codebox]
I’m not really sure what this means? does it mean only 112 cores is being used? or this hardware is configured to run with 112 cores or I need to install the 3.1 driver?
deviceQuery assumes 8 cores per MP: an invalid assumption for compute 2.0 devices.
Interesting… But wont deviceQuery get the info from “cudaGetDeviceProperties” – which should be returned by the driver, as such… No?
The device properties structure only returns the number of multiprocessors, not the number of CUDA cores. You have to check the compute capability value and multiply by 8 or 32 depending on it. The newer version of deviceQuery for CUDA >3.0 does this properly, but the older version does not.
installed 3.1 driver and toolkit and sdk, now showing 448 cores.
thanks all.
thanks all.
