Hi!
xubuntu 20.04 + GeForce GTX 550 Ti
Drivers work wrong:
$ ubuntu-drivers devices
WARNING:root:_pkg_get_support nvidia-driver-390: package has invalid Support Legacyheader, cannot determine support level
== /sys/devices/pci0000:00/0000:00:03.0/0000:03:00.0 ==
modalias : pci:v000010DEd00001244sv00001043sd000083C2bc03sc00i00
vendor : NVIDIA Corporation
model : GF116 [GeForce GTX 550 Ti]
driver : nvidia-driver-390 - distro non-free recommended
driver : nvidia-driver-418-server - distro non-free
driver : nvidia-340 - distro non-free
driver : nvidia-driver-450-server - distro non-free
driver : xserver-xorg-video-nouveau - distro free builtin
$ lspci -nnv | grep -i vga -A12
03:00.0 VGA compatible controller [0300]: NVIDIA Corporation GF116 [GeForce GTX 550 Ti] [10de:1244] (rev a1) (prog-if 00 [VGA controller])
Subsystem: ASUSTeK Computer Inc. GF116 [GeForce GTX 550 Ti] [1043:83c2]
Physical Slot: 4
Flags: bus master, fast devsel, latency 0, IRQ 35, NUMA node 0
Memory at f8000000 (32-bit, non-prefetchable) [size=32M]
Memory at e8000000 (64-bit, prefetchable) [size=128M]
Memory at f0000000 (64-bit, prefetchable) [size=64M]
I/O ports at e000 [size=128]
Expansion ROM at 000c0000 [virtual] [disabled] [size=128K]
Capabilities: <access denied>
Kernel driver in use: nvidia
Kernel modules: nvidiafb, nouveau, nvidia_drm, nvidia
glmark2 get errors
$ glmark2
glmark2 2021.02
OpenGL Information
GL_VENDOR: NVIDIA Corporation
GL_RENDERER: GeForce GTX 550 Ti/PCIe/SSE2
GL_VERSION: 4.6.0 NVIDIA 390.144
[build] use-vbo=false: FPS: 4015 FrameTime: 0.249 ms
[build] use-vbo=true: FPS: 5875 FrameTime: 0.170 ms
[texture] texture-filter=nearest: FPS: 5553 FrameTime: 0.180 ms
[texture] texture-filter=linear: FPS: 5652 FrameTime: 0.177 ms
[texture] texture-filter=mipmap: FPS: 5940 FrameTime: 0.168 ms
[shading] shading=gouraud: FPS: 5212 FrameTime: 0.192 ms
[shading] shading=blinn-phong-inf: FPS: 5290 FrameTime: 0.189 ms
[shading] shading=phong: FPS: 4774 FrameTime: 0.209 ms
[shading] shading=cel: FPS: 4727 FrameTime: 0.212 ms
[bump] bump-render=high-poly: FPS: 2925 FrameTime: 0.342 ms
[bump] bump-render=normals: FPS: 5856 FrameTime: 0.171 ms
Error: Failed to add fragment shader from file None:
Error: 0(15) : error C0000: syntax error, unexpected identifier, expecting "::" at token "highp"
Error:
[bump] bump-render=height: Set up failed
[effect2d] kernel=0,1,0;1,-4,1;0,1,0;: FPS: 4070 FrameTime: 0.246 ms
[effect2d] kernel=1,1,1,1,1;1,1,1,1,1;1,1,1,1,1;: FPS: 2028 FrameTime: 0.493 ms
[pulsar] light=false:quads=5:texture=false: FPS: 4969 FrameTime: 0.201 ms
[desktop] blur-radius=5:effect=blur:passes=1:separable=true:windows=4: FPS: 1648 FrameTime: 0.607 ms
[desktop] effect=shadow:windows=4: FPS: 2686 FrameTime: 0.372 ms
[buffer] columns=200:interleave=false:update-dispersion=0.9:update-fraction=0.5:update-method=map: FPS: 951 FrameTime: 1.052 ms
[buffer] columns=200:interleave=false:update-dispersion=0.9:update-fraction=0.5:update-method=subdata: FPS: 1236 FrameTime: 0.809 ms
[buffer] columns=200:interleave=true:update-dispersion=0.9:update-fraction=0.5:update-method=map: FPS: 1088 FrameTime: 0.919 ms
[ideas] speed=duration: FPS: 4230 FrameTime: 0.236 ms
[jellyfish] <default>: FPS: 3077 FrameTime: 0.325 ms
Error: 0(26) : warning C7022: unrecognized profile specifier "highp"
Error: 0(26) : error C0502: syntax error at token "highp"
Error:
Error: 0(75) : warning C7022: unrecognized profile specifier "highp"
Error: 0(75) : error C0502: syntax error at token "highp"
Error:
[terrain] <default>:Segmentation fault (core dumped)
What I tred:
1.
ubuntu-drivers autoupdate
reboot
apt install -y nvidia-driver-390
reboot
apt update
apt upgrade
apt remove --purge '*nvidia*'
apt autoremove
bash NVIDIA-Linux-x86_64-390.147.run
reboot
- Reinstall OS, drop hwe-core, install ga-core, install driver
$ uname -r
5.4.0-107-generic
$ apt list --installed | grep hwe
$ apt list --installed | grep linux-ima
linux-image-5.4.0-107-generic/focal-updates,focal-security,now 5.4.0-107.121 amd64 [installed,automatic]
linux-image-generic/focal-updates,focal-security,now 5.4.0.107.111 amd64 [installed]
