Hi!
I recently switched to Linux so I’m kind of a noob when it comes to this, but I recently found out that instead of the Nvidia graphic card, my laptop uses the integrated Intel card. Even after trying all sorts of solutions found online, I didn’t manage to solve this issue.
I’ve attached the bug report log below.
$ glxinfo | grep render
direct rendering: Yes
GLX_MESA_multithread_makecurrent, GLX_MESA_query_renderer,
GLX_MESA_copy_sub_buffer, GLX_MESA_query_renderer, GLX_MESA_swap_control,
Extended renderer info (GLX_MESA_query_renderer):
OpenGL renderer string: Mesa DRI Intel(R) HD Graphics 630 (Kaby Lake GT2)
GL_ARB_compute_shader, GL_ARB_conditional_render_inverted,
GL_NV_conditional_render, GL_NV_depth_clamp,
GL_NV_conditional_render, GL_NV_depth_clamp, GL_NV_fog_distance,
GL_EXT_read_format_bgra, GL_EXT_render_snorm, GL_EXT_robustness,
GL_NV_conditional_render, GL_NV_draw_buffers, GL_NV_fbo_color_attachments,
GL_OES_element_index_uint, GL_OES_fbo_render_mipmap,
$ nvidia-smi
| NVIDIA-SMI 435.21 Driver Version: 435.21 CUDA Version: 10.1 |
| 0 GeForce GTX 105... Off | 00000000:01:00.0 Off | N/A |
| N/A 46C P8 N/A / N/A | 0MiB / 4042MiB | 0% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| No running processes found |
$ sudo lshw -c video
*-display
description: 3D controller
product: GP107M [GeForce GTX 1050 Ti Mobile]
vendor: NVIDIA Corporation
physical id: 0
bus info: pci@0000:01:00.0
version: a1
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list rom
configuration: driver=nvidia latency=0
resources: irq:134 memory:de000000-deffffff memory:c0000000-cfffffff memory:d0000000-d1ffffff ioport:e000(size=128) memory:df000000-df07ffff
*-display
description: VGA compatible controller
product: HD Graphics 630
vendor: Intel Corporation
physical id: 2
bus info: pci@0000:00:02.0
version: 04
width: 64 bits
clock: 33MHz
capabilities: pciexpress msi pm vga_controller bus_master cap_list rom
configuration: driver=i915 latency=0
resources: irq:131 memory:dd000000-ddffffff memory:b0000000-bfffffff ioport:f000(size=64) memory:c0000-dffff
$ prime-select query
nvidia
nvidia-bug-report.log (985.4 KB)
