Hello.
I got a new GTX 970 card, and I’m using 2 monitors.
I’m using archlinux. As it is updated, I’m running the latest Nvidia drivers.
Using Nvidia settings, I can set the place of each monitor (layout).
But saving xorg.conf only saves informations for one monitor.
So, when I reboot, my monitors are not well placed (layout), and have to launch Nvidia settings again.
Of course, I tried running this nvidia tool as root - same problem !
What can I do so that nvidia-settings generates a good xorg.conf file ?
Thanks in advance.
I solved my problem :
archlinux / cinnamon do not use nvidia- settings; xorg.conf is not loaded upon boot.
Instead, my computer uses the cinnamon preference panel to set location of monitors.
I answer in case someone gets the same problem.
