I have live feeds @1080i25 i am encoding it to 720p25 some off them suddenly stops with kernel message ; nvhost_syncpt_wait_timeout: invalid syncpoint id 0
Pipeline is still active but no video and sound.
This is my gsteamer command; gst-launch-1.0 souphttpsrc location=$stream_input ! decodebin name=demux demux. ! audioconvert voaacenc bitrate=64000 ! queue ! tee name=audio ! queue ! mux1. demux. ! deinterlace ! tee name=video ! queue ! nvvidconv interpolation-method=5 ! "video/x-raw(memory:NVMM),width=$res_width,height=$res_height,format=I420" ! nvv4l2h264enc maxperf-enable=1 control-rate=0 peak-bitrate=$bitrate_max bitrate=$bitrate preset-level=4 profile=High insert-sps-pps=1 iframeinterval=250 ! h264parse ! mux1. mpegtsmux name=mux1 ! tcpserversink host=192.168.1.67 port=5000
@ the moment i am encoding 8x 1080i25 live events to 8x 720p25
what i saw was after couple of hours the mem usage of process is decreasing from approx. 105MB to 75MB.
So this means buffers are not filled quickly, the is no problem with the source (Quadro cards working fine).
Network is not fast enoff the handle the request.
Incomming traffic is http approx 75 Mbit/s outgoing is 25 Mbit/s
Have to figure it out with irq balancing for eth0, now is it using core0
