When I try to set num_skip_frame for this video input, I got message warning GLib-GObject-WARNING **: 16:57:08.121: g_object_set_is_valid_property: object class 'avdec_h265' has no property named 'drop-frame-interval'
when I converted video to h264 format, it worked well.
How can I set num_skip_frame for avdec_h265 format? Thank you so much
avdec_h265 is open source GStreamer plugin for libav. avdec_h265 (gstreamer.freedesktop.org). Please check its properties with “gst-inspect-1.0” tool or in the GStreamer document.
