H265 Encoder GOP Settings and Multi-Instance Issues
Hi, Nvidia Expert!
I encountered the following issues while using the H265 encoder, please provide support.
  1. The I-frame interval is always 256, changing the GOP parameter has no effect.
  2. After instantiating the H265 encoder multiple times in a single process, frame drops occur.
Please help check if there is any problem with my code, thank you.
h265_encoder.zip (4.2 KB)
Please make a patch to the sample:
/usr/src/jetson_multimedia_api/samples/01_video_encode
And share the command to replicate the issue. So that we can set up developer kit and check.
Hi, DaneLLL
May I ask where I can find the patch? Thanks
We would need your help to run 01 sample, and make a patch to the sample for reproducing the issue. So that we can run 01 sample on developer kit to reproduce the same symptom and check check further.
