Hardware design related question based on Jetson TX2
I am designing a system based on Jeston TX2/TX2i module. I am using a PCIe switch to connect to four mini PCIe cards. I am using PCIe0 root port on TX2 to connect to the PCIe switch. The downports (all x1) from the switch is connected to four miniPCIe cards. I am also using a clock buffer which takes the reference clocks from Jetson module as input and outputs clocks to each of the minPCIe cards based on the clkreq# signal from each of these mini PCIe cards. I am not sure about the status of PEX0_CLKREQ# pin on the TX2 module. Can i leave it NC in this scenario?
Regards
Goutam
Hi, there is no CLKREQ pin on switch? Then how to inform host to output clock when needed?
In this case, Can i connect the PEX0_CLKREQ# pin to ground permanently so that clock from host is always enabled. Clock buffer can make a decision to output clock to individual mini PCIe cards based on clock request from each miniPCIe cards?
Regards
Goutam
That is not validated and so not be suggested. Better to use a signal to do this.
