Hardware for running dedicated Jupyter Lab server on lan
What hardware should I be looking for?
Xeon CPU and Quadro GPU? How would you build yours, for $1000, for $5000? What add on processing cards/peripherals should I look at?
Right now I have:
System 1: i9 9900k @ 5GHZ all cores with 32GB of 4133ram, multiple SSD’s that I would probably replace with a really great new one.
GTX 1080.
System 2: i9 9900kf @ 5GHZ all cores with 16GB 4133ram, single SSD(not amazing). RTX 2080super
It seems like you do not use Jetson Nano? You may not make the post in correct category.
I have a jetson nano 2gb. but i want to process some data on my desktop because I cant run a epoch still without having my nano lock up.
i even shut down the GUI.
running tegrastats with a 10 second interval. im not totally locked up but its been running for hours. (1 image thumbs up, 1 image thumbs down, got 1 epoch to run, then to see if i was going to have issues still, I ran 10 epochs. cant even login to tty1 on the nano its lagged so hard.
nano@nano:~$ tegrastats --interval 5000
RAM 1845/1972MB (lfb 1x4MB) SWAP 2078/12096MB (cached 14MB) CPU [16%@1479,15%@1479,11%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@43.5C CPU@46.5C PMIC@100C GPU@45.5C AO@52C thermal@46.25C
RAM 1845/1972MB (lfb 1x4MB) SWAP 2077/12096MB (cached 14MB) CPU [11%@1479,22%@1479,6%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@43.5C CPU@46.5C PMIC@100C GPU@45.5C AO@51.5C thermal@46C
RAM 1859/1972MB (lfb 1x1MB) SWAP 2085/12096MB (cached 4MB) CPU [24%@1479,65%@1479,19%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@44.5C CPU@48.5C PMIC@100C GPU@46.5C AO@52C thermal@47C
RAM 1858/1972MB (lfb 1x1MB) SWAP 2086/12096MB (cached 4MB) CPU [15%@1479,95%@1479,5%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@44C CPU@48C PMIC@100C GPU@46C AO@52C thermal@47C
RAM 1857/1972MB (lfb 1x1MB) SWAP 2087/12096MB (cached 5MB) CPU [68%@1479,50%@1479,26%@1479,98%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@44C CPU@48C PMIC@100C GPU@46C AO@52.5C thermal@47.25C
^C
nano@nano:~$ tegrastats --interval 20000
RAM 1858/1972MB (lfb 1x1MB) SWAP 2087/12096MB (cached 4MB) CPU [45%@1479,41%@1479,82%@1479,85%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@44.5C CPU@48.5C PMIC@100C GPU@46.5C AO@52.5C thermal@47.25C
RAM 1859/1972MB (lfb 1x1MB) SWAP 2085/12096MB (cached 5MB) CPU [15%@1479,45%@1479,100%@1479,51%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@44.5C CPU@49C PMIC@100C GPU@46.5C AO@53C thermal@47.5C
RAM 1858/1972MB (lfb 1x1MB) SWAP 2085/12096MB (cached 4MB) CPU [19%@1479,51%@1479,100%@1479,33%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@44.5C CPU@48.5C PMIC@100C GPU@46.5C AO@53.5C thermal@47.5C
RAM 1857/1972MB (lfb 1x1MB) SWAP 2086/12096MB (cached 3MB) CPU [40%@1479,37%@1479,100%@1479,36%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@44.5C CPU@49C PMIC@100C GPU@46.5C AO@53C thermal@48C
RAM 1856/1972MB (lfb 1x1MB) SWAP 2087/12096MB (cached 3MB) CPU [27%@1479,64%@1479,100%@1479,31%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@45C CPU@49.5C PMIC@100C GPU@47C AO@53C thermal@47.75C
RAM 1858/1972MB (lfb 1x1MB) SWAP 2085/12096MB (cached 4MB) CPU [16%@1479,78%@1479,100%@1479,9%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@45C CPU@49C PMIC@100C GPU@47C AO@53C thermal@47.25C
RAM 1856/1972MB (lfb 1x1MB) SWAP 2087/12096MB (cached 3MB) CPU [19%@1479,89%@1479,100%@1479,9%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@43.5C CPU@47.5C PMIC@100C GPU@46C AO@51.5C thermal@47C
RAM 1858/1972MB (lfb 1x1MB) SWAP 2086/12096MB (cached 4MB) CPU [13%@1479,15%@1479,100%@1479,81%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@41.5C CPU@44.5C PMIC@100C GPU@45.5C AO@49C thermal@45.25C
RAM 1857/1972MB (lfb 1x1MB) SWAP 2085/12096MB (cached 3MB) CPU [16%@1479,7%@1479,100%@1479,80%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@38.5C CPU@42C PMIC@100C GPU@42.5C AO@46.5C thermal@43C
RAM 1859/1972MB (lfb 1x1MB) SWAP 2085/12096MB (cached 4MB) CPU [22%@1479,36%@1479,100%@1479,45%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@37C CPU@41C PMIC@100C GPU@41C AO@45C thermal@41.25C
RAM 1858/1972MB (lfb 1x1MB) SWAP 2086/12096MB (cached 4MB) CPU [16%@1479,35%@1479,100%@1479,61%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@35.5C CPU@39.5C PMIC@100C GPU@39.5C AO@43C thermal@39.5C
RAM 1857/1972MB (lfb 1x1MB) SWAP 2087/12096MB (cached 4MB) CPU [23%@1479,86%@1479,99%@1479,17%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@34C CPU@38.5C PMIC@100C GPU@38C AO@41.5C thermal@38.25C
RAM 1856/1972MB (lfb 1x1MB) SWAP 2087/12096MB (cached 3MB) CPU [24%@1479,71%@1479,100%@1479,35%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@33C CPU@37.5C PMIC@100C GPU@37C AO@40.5C thermal@37.25C
RAM 1857/1972MB (lfb 1x1MB) SWAP 2087/12096MB (cached 3MB) CPU [25%@1479,41%@1479,100%@1479,59%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@32C CPU@36C PMIC@100C GPU@36C AO@39C thermal@36.5C
RAM 1858/1972MB (lfb 1x1MB) SWAP 2085/12096MB (cached 4MB) CPU [18%@1479,9%@1479,100%@1479,81%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@30.5C CPU@35C PMIC@100C GPU@34.5C AO@38.5C thermal@35.25C
RAM 1857/1972MB (lfb 1x1MB) SWAP 2086/12096MB (cached 4MB) CPU [23%@1479,91%@1479,99%@1479,11%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@30C CPU@35C PMIC@100C GPU@34C AO@37.5C thermal@34.5C
RAM 1856/1972MB (lfb 1x1MB) SWAP 2087/12096MB (cached 3MB) CPU [34%@1479,67%@1479,100%@1479,41%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@30C CPU@34.5C PMIC@100C GPU@34C AO@37C thermal@33.5C
RAM 1858/1972MB (lfb 1x1MB) SWAP 2085/12096MB (cached 5MB) CPU [21%@1479,88%@1479,100%@1479,19%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@29C CPU@33.5C PMIC@100C GPU@33C AO@36.5C thermal@33.25C
RAM 1858/1972MB (lfb 1x512kB) SWAP 2085/12096MB (cached 5MB) CPU [24%@1479,50%@1479,100%@1479,46%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@28.5C CPU@32C PMIC@100C GPU@32.5C AO@36C thermal@32.5C
RAM 1858/1972MB (lfb 1x512kB) SWAP 2085/12096MB (cached 4MB) CPU [24%@1479,37%@1479,100%@1479,65%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@28.5C CPU@33C PMIC@100C GPU@31C AO@35.5C thermal@31.75C
RAM 1859/1972MB (lfb 1x512kB) SWAP 2083/12096MB (cached 5MB) CPU [21%@1479,54%@1479,100%@1479,37%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@28C CPU@32.5C PMIC@100C GPU@31C AO@35C thermal@32C
RAM 1857/1972MB (lfb 1x512kB) SWAP 2085/12096MB (cached 4MB) CPU [20%@1479,34%@1479,100%@1479,62%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@28C CPU@32C PMIC@100C GPU@31C AO@34.5C thermal@31.5C
RAM 1856/1972MB (lfb 1x512kB) SWAP 2088/12096MB (cached 5MB) CPU [21%@1479,37%@1479,100%@1479,59%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@27.5C CPU@32C PMIC@100C GPU@29.5C AO@34.5C thermal@31C
RAM 1861/1972MB (lfb 1x512kB) SWAP 2085/12096MB (cached 8MB) CPU [16%@1479,67%@1479,100%@1479,38%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@27.5C CPU@31.5C PMIC@100C GPU@29.5C AO@34.5C thermal@30.25C
RAM 1856/1972MB (lfb 1x512kB) SWAP 2086/12096MB (cached 3MB) CPU [15%@1479,17%@1479,100%@1479,93%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@27.5C CPU@30.5C PMIC@100C GPU@29.5C AO@34C thermal@30.5C
RAM 1856/1972MB (lfb 1x512kB) SWAP 2086/12096MB (cached 3MB) CPU [21%@1479,10%@1479,100%@1479,83%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@27C CPU@31C PMIC@100C GPU@29C AO@33.5C thermal@30C
RAM 1865/1972MB (lfb 1x512kB) SWAP 2086/12096MB (cached 12MB) CPU [27%@1479,61%@1479,100%@1479,44%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@27C CPU@31.5C PMIC@100C GPU@29C AO@34C thermal@30.75C
RAM 1857/1972MB (lfb 1x1MB) SWAP 2085/12096MB (cached 4MB) CPU [30%@1479,24%@1479,100%@1479,54%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@26.5C CPU@31C PMIC@100C GPU@29C AO@33.5C thermal@30C
RAM 1857/1972MB (lfb 1x1MB) SWAP 2085/12096MB (cached 4MB) CPU [15%@1479,60%@1479,100%@1479,37%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@26.5C CPU@31C PMIC@100C GPU@29C AO@33.5C thermal@30C
RAM 1857/1972MB (lfb 1x1MB) SWAP 2086/12096MB (cached 3MB) CPU [23%@1479,62%@1479,100%@1479,27%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@26.5C CPU@30.5C PMIC@100C GPU@29C AO@33.5C thermal@29.25C
RAM 1860/1972MB (lfb 1x512kB) SWAP 2085/12096MB (cached 5MB) CPU [22%@1479,21%@1479,100%@1479,74%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@26C CPU@30.5C PMIC@100C GPU@29C AO@33.5C thermal@29.75C
RAM 1857/1972MB (lfb 1x512kB) SWAP 2086/12096MB (cached 3MB) CPU [29%@1479,25%@1479,100%@1479,66%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@26C CPU@30.5C PMIC@100C GPU@28C AO@33C thermal@29.25C
RAM 1857/1972MB (lfb 1x512kB) SWAP 2086/12096MB (cached 3MB) CPU [12%@1479,12%@1479,100%@1479,78%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@26C CPU@30.5C PMIC@100C GPU@28C AO@33C thermal@28.75C
RAM 1858/1972MB (lfb 1x512kB) SWAP 2086/12096MB (cached 4MB) CPU [16%@1479,8%@1479,100%@1479,80%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@26C CPU@30C PMIC@100C GPU@28C AO@33C thermal@29.25C
RAM 1859/1972MB (lfb 2x512kB) SWAP 2084/12096MB (cached 5MB) CPU [19%@1479,10%@1479,100%@1479,83%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@26C CPU@29.5C PMIC@100C GPU@28C AO@33C thermal@29.5C
RAM 1856/1972MB (lfb 2x512kB) SWAP 2087/12096MB (cached 3MB) CPU [31%@1479,33%@1479,70%@1479,80%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25.5C CPU@29.5C PMIC@100C GPU@28C AO@32.5C thermal@28.75C
RAM 1858/1972MB (lfb 2x512kB) SWAP 2085/12096MB (cached 5MB) CPU [17%@1479,47%@1479,49%@1479,97%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@26C CPU@30C PMIC@100C GPU@28C AO@33C thermal@28.75C
RAM 1857/1972MB (lfb 2x512kB) SWAP 2087/12096MB (cached 4MB) CPU [14%@1479,36%@1479,47%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@26C CPU@30C PMIC@100C GPU@28C AO@33C thermal@28.75C
RAM 1858/1972MB (lfb 2x512kB) SWAP 2086/12096MB (cached 4MB) CPU [20%@1479,75%@1479,15%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@26C CPU@30.5C PMIC@100C GPU@28C AO@32.5C thermal@29.25C
RAM 1856/1972MB (lfb 2x512kB) SWAP 2087/12096MB (cached 3MB) CPU [23%@1479,48%@1479,50%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@26C CPU@30C PMIC@100C GPU@28C AO@32C thermal@29C
RAM 1858/1972MB (lfb 2x512kB) SWAP 2084/12096MB (cached 5MB) CPU [31%@1479,15%@1479,79%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@26C CPU@30C PMIC@100C GPU@28C AO@32.5C thermal@28.5C
RAM 1857/1972MB (lfb 2x512kB) SWAP 2085/12096MB (cached 4MB) CPU [23%@1479,69%@1479,35%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@26C CPU@30C PMIC@100C GPU@28C AO@32.5C thermal@29C
RAM 1857/1972MB (lfb 2x512kB) SWAP 2087/12096MB (cached 4MB) CPU [38%@1479,39%@1479,55%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25.5C CPU@29.5C PMIC@100C GPU@27.5C AO@32.5C thermal@28.75C
RAM 1859/1972MB (lfb 2x512kB) SWAP 2085/12096MB (cached 5MB) CPU [18%@1479,12%@1479,82%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@26C CPU@29C PMIC@100C GPU@28C AO@32.5C thermal@28.75C
RAM 1859/1972MB (lfb 2x512kB) SWAP 2085/12096MB (cached 5MB) CPU [25%@1479,16%@1479,80%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@26C CPU@29.5C PMIC@100C GPU@28C AO@32.5C thermal@28.75C
RAM 1855/1972MB (lfb 2x512kB) SWAP 2088/12096MB (cached 2MB) CPU [32%@1479,45%@1479,67%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25.5C CPU@29C PMIC@100C GPU@27.5C AO@32.5C thermal@28.5C
RAM 1859/1972MB (lfb 2x512kB) SWAP 2085/12096MB (cached 4MB) CPU [30%@1479,85%@1479,44%@1479,70%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@26C CPU@29.5C PMIC@100C GPU@28C AO@32.5C thermal@28.5C
RAM 1860/1972MB (lfb 2x512kB) SWAP 2086/12096MB (cached 7MB) CPU [27%@1479,100%@1479,67%@1479,32%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@29C PMIC@100C GPU@27.5C AO@32.5C thermal@28.5C
RAM 1860/1972MB (lfb 2x512kB) SWAP 2085/12096MB (cached 7MB) CPU [32%@1479,80%@1479,47%@1479,74%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25.5C CPU@29.5C PMIC@100C GPU@27.5C AO@32.5C thermal@28.5C
RAM 1858/1972MB (lfb 2x512kB) SWAP 2084/12096MB (cached 4MB) CPU [46%@1479,52%@1479,35%@1479,96%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@26C CPU@30C PMIC@100C GPU@28C AO@32.5C thermal@28.75C
RAM 1861/1972MB (lfb 2x512kB) SWAP 2081/12096MB (cached 6MB) CPU [34%@1479,60%@1479,67%@1479,69%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25.5C CPU@29.5C PMIC@100C GPU@27.5C AO@32.5C thermal@28.5C
RAM 1861/1972MB (lfb 1x1MB) SWAP 2084/12096MB (cached 5MB) CPU [26%@1479,40%@1479,81%@1479,83%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@26C CPU@29.5C PMIC@100C GPU@28C AO@32C thermal@28.75C
RAM 1862/1972MB (lfb 1x1MB) SWAP 2088/12096MB (cached 9MB) CPU [30%@1479,100%@1479,58%@1479,47%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@26C CPU@30C PMIC@100C GPU@28C AO@32.5C thermal@29C
RAM 1858/1972MB (lfb 1x1MB) SWAP 2086/12096MB (cached 5MB) CPU [37%@1479,69%@1479,90%@1479,38%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@26C CPU@30C PMIC@100C GPU@28C AO@33C thermal@29C
RAM 1862/1972MB (lfb 1x1MB) SWAP 2088/12096MB (cached 6MB) CPU [51%@1479,61%@1479,78%@1479,77%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25.5C CPU@30C PMIC@100C GPU@27.5C AO@32.5C thermal@28.75C
RAM 1857/1972MB (lfb 1x1MB) SWAP 2090/12096MB (cached 1MB) CPU [75%@1479,68%@1479,90%@1479,40%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@26C CPU@30C PMIC@100C GPU@28C AO@33C thermal@29.5C
RAM 1857/1972MB (lfb 1x1MB) SWAP 2084/12096MB (cached 3MB) CPU [39%@1479,92%@1479,32%@1479,75%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@26C CPU@29.5C PMIC@100C GPU@28C AO@32.5C thermal@29C
RAM 1859/1972MB (lfb 1x1MB) SWAP 2083/12096MB (cached 5MB) CPU [55%@1479,11%@1479,56%@1479,81%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@26C CPU@30C PMIC@100C GPU@28C AO@32.5C thermal@29C
RAM 1860/1972MB (lfb 1x1MB) SWAP 2082/12096MB (cached 5MB) CPU [21%@1479,37%@1479,100%@1479,40%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25.5C CPU@29.5C PMIC@100C GPU@28C AO@32.5C thermal@28.75C
RAM 1855/1972MB (lfb 1x1MB) SWAP 2086/12096MB (cached 3MB) CPU [20%@1479,24%@1479,100%@1479,65%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25.5C CPU@30C PMIC@100C GPU@28C AO@32.5C thermal@29.25C
RAM 1860/1972MB (lfb 1x1MB) SWAP 2083/12096MB (cached 6MB) CPU [40%@1479,28%@1479,84%@1479,83%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25.5C CPU@30C PMIC@100C GPU@28C AO@32.5C thermal@28.75C
RAM 1859/1972MB (lfb 1x1MB) SWAP 2082/12096MB (cached 5MB) CPU [64%@1479,52%@1479,94%@1479,36%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25.5C CPU@30.5C PMIC@100C GPU@27.5C AO@32.5C thermal@28.75C
RAM 1856/1972MB (lfb 1x1MB) SWAP 2085/12096MB (cached 3MB) CPU [30%@1479,48%@1479,100%@1479,27%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@30.5C PMIC@100C GPU@27.5C AO@32.5C thermal@28.75C
RAM 1859/1972MB (lfb 1x1MB) SWAP 2084/12096MB (cached 5MB) CPU [24%@1479,51%@1479,100%@1479,38%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25.5C CPU@30C PMIC@100C GPU@27.5C AO@32C thermal@28.5C
RAM 1859/1972MB (lfb 1x1MB) SWAP 2083/12096MB (cached 4MB) CPU [28%@1479,19%@1479,99%@1479,80%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25.5C CPU@30C PMIC@100C GPU@27.5C AO@32.5C thermal@28.75C
RAM 1859/1972MB (lfb 1x1MB) SWAP 2085/12096MB (cached 5MB) CPU [15%@1479,5%@1479,100%@1479,94%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@29.5C PMIC@100C GPU@27.5C AO@32.5C thermal@28.75C
RAM 1858/1972MB (lfb 1x1MB) SWAP 2083/12096MB (cached 4MB) CPU [41%@1479,56%@1479,92%@1479,59%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25.5C CPU@30C PMIC@100C GPU@27.5C AO@32C thermal@28.75C
RAM 1855/1972MB (lfb 1x1MB) SWAP 2086/12096MB (cached 3MB) CPU [48%@1479,57%@1479,78%@1479,47%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@29C PMIC@100C GPU@27.5C AO@32.5C thermal@28.5C
RAM 1857/1972MB (lfb 1x1MB) SWAP 2084/12096MB (cached 4MB) CPU [20%@1479,27%@1479,54%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@26C CPU@29.5C PMIC@100C GPU@28C AO@32.5C thermal@28.25C
RAM 1857/1972MB (lfb 1x512kB) SWAP 2084/12096MB (cached 4MB) CPU [19%@1479,32%@1479,36%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25.5C CPU@30C PMIC@100C GPU@27.5C AO@32.5C thermal@28.5C
RAM 1857/1972MB (lfb 1x512kB) SWAP 2084/12096MB (cached 4MB) CPU [28%@1479,20%@1479,51%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@30C PMIC@100C GPU@27.5C AO@32.5C thermal@28.25C
RAM 1858/1972MB (lfb 1x512kB) SWAP 2083/12096MB (cached 4MB) CPU [20%@1479,70%@1479,20%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25.5C CPU@30.5C PMIC@100C GPU@27.5C AO@32C thermal@28.75C
RAM 1857/1972MB (lfb 1x512kB) SWAP 2084/12096MB (cached 4MB) CPU [25%@1479,71%@1479,39%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@29C PMIC@100C GPU@27.5C AO@32C thermal@28.75C
RAM 1856/1972MB (lfb 1x512kB) SWAP 2086/12096MB (cached 3MB) CPU [34%@1479,39%@1479,82%@1479,72%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@30C PMIC@100C GPU@27C AO@32C thermal@28.5C
RAM 1857/1972MB (lfb 1x512kB) SWAP 2085/12096MB (cached 4MB) CPU [14%@1479,20%@1479,100%@1479,57%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@29C PMIC@100C GPU@27C AO@32C thermal@28C
RAM 1861/1972MB (lfb 7x256kB) SWAP 2082/12096MB (cached 6MB) CPU [19%@1479,12%@1479,100%@1479,63%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@29C PMIC@100C GPU@27C AO@32C thermal@28C
RAM 1859/1972MB (lfb 7x256kB) SWAP 2084/12096MB (cached 4MB) CPU [17%@1479,92%@1479,100%@1479,7%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@30C PMIC@100C GPU@27C AO@32C thermal@28.75C
RAM 1856/1972MB (lfb 7x256kB) SWAP 2086/12096MB (cached 2MB) CPU [23%@1479,67%@1479,100%@1479,34%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25.5C CPU@30C PMIC@100C GPU@27.5C AO@32C thermal@28.5C
RAM 1859/1972MB (lfb 7x256kB) SWAP 2083/12096MB (cached 6MB) CPU [34%@1479,68%@1479,93%@1479,57%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25.5C CPU@30C PMIC@100C GPU@27.5C AO@32C thermal@29.25C
RAM 1857/1972MB (lfb 7x256kB) SWAP 2086/12096MB (cached 4MB) CPU [92%@1479,35%@1479,61%@1479,53%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25.5C CPU@29.5C PMIC@100C GPU@27.5C AO@32.5C thermal@28.5C
RAM 1860/1972MB (lfb 7x256kB) SWAP 2082/12096MB (cached 5MB) CPU [60%@1479,23%@1479,67%@1479,65%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25.5C CPU@30.5C PMIC@100C GPU@27.5C AO@32.5C thermal@28.5C
RAM 1860/1972MB (lfb 7x256kB) SWAP 2081/12096MB (cached 5MB) CPU [20%@1479,64%@1479,100%@1479,38%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25.5C CPU@30C PMIC@100C GPU@27.5C AO@32.5C thermal@28.5C
RAM 1861/1972MB (lfb 7x256kB) SWAP 2081/12096MB (cached 6MB) CPU [40%@1479,22%@1479,100%@1479,60%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@29.5C PMIC@100C GPU@27.5C AO@32C thermal@29C
RAM 1860/1972MB (lfb 7x256kB) SWAP 2081/12096MB (cached 5MB) CPU [31%@1479,28%@1479,100%@1479,73%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25.5C CPU@29.5C PMIC@100C GPU@27.5C AO@32C thermal@28.5C
RAM 1858/1972MB (lfb 7x256kB) SWAP 2085/12096MB (cached 5MB) CPU [37%@1479,37%@1479,97%@1479,83%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25.5C CPU@29.5C PMIC@100C GPU@27.5C AO@32C thermal@28.25C
RAM 1856/1972MB (lfb 7x256kB) SWAP 2087/12096MB (cached 4MB) CPU [27%@1479,37%@1479,79%@1479,96%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25.5C CPU@29.5C PMIC@100C GPU@27.5C AO@32.5C thermal@28.5C
RAM 1856/1972MB (lfb 7x256kB) SWAP 2085/12096MB (cached 3MB) CPU [19%@1479,100%@1479,15%@1479,65%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25.5C CPU@29.5C PMIC@100C GPU@27.5C AO@32C thermal@28.5C
RAM 1859/1972MB (lfb 1x512kB) SWAP 2083/12096MB (cached 5MB) CPU [26%@1479,54%@1479,58%@1479,61%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25.5C CPU@29C PMIC@100C GPU@27.5C AO@32C thermal@29.25C
RAM 1858/1972MB (lfb 1x512kB) SWAP 2084/12096MB (cached 4MB) CPU [22%@1479,49%@1479,49%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@30.5C PMIC@100C GPU@27.5C AO@32C thermal@29C
RAM 1858/1972MB (lfb 1x512kB) SWAP 2084/12096MB (cached 4MB) CPU [15%@1479,41%@1479,50%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@29C PMIC@100C GPU@27C AO@32C thermal@28C
RAM 1858/1972MB (lfb 1x512kB) SWAP 2084/12096MB (cached 4MB) CPU [16%@1479,11%@1479,74%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@29C PMIC@100C GPU@27C AO@32C thermal@27.75C
RAM 1858/1972MB (lfb 1x512kB) SWAP 2084/12096MB (cached 5MB) CPU [25%@1479,11%@1479,82%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@29C PMIC@100C GPU@27C AO@32C thermal@28C
RAM 1858/1972MB (lfb 1x512kB) SWAP 2085/12096MB (cached 4MB) CPU [23%@1479,53%@1479,48%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@30C PMIC@100C GPU@27C AO@32C thermal@29C
RAM 1859/1972MB (lfb 1x512kB) SWAP 2083/12096MB (cached 5MB) CPU [19%@1479,89%@1479,11%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@29.5C PMIC@100C GPU@27.5C AO@32C thermal@29C
RAM 1858/1972MB (lfb 1x512kB) SWAP 2084/12096MB (cached 5MB) CPU [31%@1479,58%@1479,40%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@29.5C PMIC@100C GPU@27.5C AO@31.5C thermal@29C
RAM 1859/1972MB (lfb 1x512kB) SWAP 2083/12096MB (cached 5MB) CPU [18%@1479,27%@1479,72%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25.5C CPU@29.5C PMIC@100C GPU@27.5C AO@32C thermal@28.5C
RAM 1857/1972MB (lfb 1x512kB) SWAP 2085/12096MB (cached 3MB) CPU [15%@1479,11%@1479,85%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@29.5C PMIC@100C GPU@27C AO@31.5C thermal@28C
RAM 1858/1972MB (lfb 1x512kB) SWAP 2083/12096MB (cached 4MB) CPU [44%@1479,37%@1479,65%@1479,84%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25.5C CPU@29.5C PMIC@100C GPU@27.5C AO@32C thermal@28.25C
RAM 1864/1972MB (lfb 1x512kB) SWAP 2085/12096MB (cached 12MB) CPU [26%@1479,100%@1479,86%@1479,17%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25.5C CPU@29.5C PMIC@100C GPU@27C AO@32.5C thermal@28.25C
RAM 1857/1972MB (lfb 1x512kB) SWAP 2086/12096MB (cached 4MB) CPU [19%@1479,93%@1479,18%@1479,73%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@29C PMIC@100C GPU@27C AO@32C thermal@27.75C
RAM 1860/1972MB (lfb 1x512kB) SWAP 2082/12096MB (cached 5MB) CPU [18%@1479,82%@1479,12%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@29.5C PMIC@100C GPU@27C AO@32C thermal@28.5C
RAM 1858/1972MB (lfb 1x512kB) SWAP 2085/12096MB (cached 4MB) CPU [18%@1479,67%@1479,30%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25.5C CPU@30C PMIC@100C GPU@27.5C AO@32C thermal@28.75C
RAM 1858/1972MB (lfb 1x512kB) SWAP 2084/12096MB (cached 4MB) CPU [14%@1479,31%@1479,59%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@30C PMIC@100C GPU@27C AO@31.5C thermal@28C
RAM 1860/1972MB (lfb 1x512kB) SWAP 2082/12096MB (cached 4MB) CPU [16%@1479,31%@1479,56%@1479,99%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@29C PMIC@100C GPU@27C AO@32C thermal@28C
RAM 1862/1972MB (lfb 1x512kB) SWAP 2085/12096MB (cached 5MB) CPU [14%@1479,11%@1479,84%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@29.5C PMIC@100C GPU@27C AO@32C thermal@28C
RAM 1860/1972MB (lfb 1x512kB) SWAP 2084/12096MB (cached 8MB) CPU [33%@1479,37%@1479,42%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@29C PMIC@100C GPU@27C AO@32C thermal@28C
RAM 1856/1972MB (lfb 1x512kB) SWAP 2086/12096MB (cached 3MB) CPU [18%@1479,7%@1479,89%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25.5C CPU@29C PMIC@100C GPU@27.5C AO@32C thermal@27.75C
RAM 1855/1972MB (lfb 1x512kB) SWAP 2087/12096MB (cached 2MB) CPU [34%@1479,74%@1479,47%@1479,78%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25.5C CPU@29.5C PMIC@100C GPU@27.5C AO@32C thermal@29C
RAM 1858/1972MB (lfb 1x512kB) SWAP 2084/12096MB (cached 5MB) CPU [17%@1479,14%@1479,100%@1479,85%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@29C PMIC@100C GPU@27C AO@32C thermal@28.5C
RAM 1858/1972MB (lfb 1x512kB) SWAP 2084/12096MB (cached 4MB) CPU [16%@1479,39%@1479,100%@1479,51%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25.5C CPU@29.5C PMIC@100C GPU@27.5C AO@32C thermal@27.75C
RAM 1856/1972MB (lfb 1x512kB) SWAP 2086/12096MB (cached 3MB) CPU [21%@1479,51%@1479,100%@1479,45%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@30.5C PMIC@100C GPU@27C AO@32C thermal@28.75C
RAM 1856/1972MB (lfb 1x512kB) SWAP 2086/12096MB (cached 3MB) CPU [73%@1479,25%@1479,100%@1479,31%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25.5C CPU@29.5C PMIC@100C GPU@27.5C AO@32C thermal@28.5C
RAM 1857/1972MB (lfb 1x512kB) SWAP 2086/12096MB (cached 3MB) CPU [33%@1479,33%@1479,100%@1479,55%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@29.5C PMIC@100C GPU@27C AO@32C thermal@28C
RAM 1858/1972MB (lfb 1x512kB) SWAP 2084/12096MB (cached 4MB) CPU [18%@1479,56%@1479,100%@1479,31%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@30C PMIC@100C GPU@27C AO@32C thermal@28.5C
RAM 1858/1972MB (lfb 1x512kB) SWAP 2083/12096MB (cached 4MB) CPU [32%@1479,70%@1479,64%@1479,57%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25.5C CPU@29C PMIC@100C GPU@27.5C AO@32C thermal@28.25C
RAM 1859/1972MB (lfb 3x512kB) SWAP 2083/12096MB (cached 5MB) CPU [20%@1479,7%@1479,67%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25.5C CPU@29.5C PMIC@100C GPU@27.5C AO@32C thermal@28C
RAM 1858/1972MB (lfb 7x256kB) SWAP 2084/12096MB (cached 4MB) CPU [74%@1479,13%@1479,25%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@29C PMIC@100C GPU@27C AO@32C thermal@28.5C
RAM 1857/1972MB (lfb 7x256kB) SWAP 2085/12096MB (cached 4MB) CPU [38%@1479,22%@1479,79%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25.5C CPU@29C PMIC@100C GPU@27.5C AO@32C thermal@28.25C
RAM 1858/1972MB (lfb 7x256kB) SWAP 2085/12096MB (cached 4MB) CPU [15%@1479,31%@1479,43%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25.5C CPU@29C PMIC@100C GPU@27.5C AO@32C thermal@28.25C
RAM 1860/1972MB (lfb 7x256kB) SWAP 2083/12096MB (cached 6MB) CPU [21%@1479,20%@1479,75%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25.5C CPU@29C PMIC@100C GPU@27.5C AO@32.5C thermal@28.25C
RAM 1857/1972MB (lfb 7x256kB) SWAP 2085/12096MB (cached 4MB) CPU [37%@1479,18%@1479,52%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@29C PMIC@100C GPU@27C AO@32C thermal@28.25C
RAM 1858/1972MB (lfb 7x256kB) SWAP 2085/12096MB (cached 4MB) CPU [15%@1479,32%@1479,67%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@30C PMIC@100C GPU@27C AO@32.5C thermal@29C
RAM 1858/1972MB (lfb 7x256kB) SWAP 2085/12096MB (cached 4MB) CPU [25%@1479,21%@1479,43%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@29C PMIC@100C GPU@27C AO@32C thermal@28C
RAM 1858/1972MB (lfb 7x256kB) SWAP 2086/12096MB (cached 5MB) CPU [18%@1479,38%@1479,84%@1479,72%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25.5C CPU@29.5C PMIC@100C GPU@27.5C AO@32C thermal@28.25C
RAM 1858/1972MB (lfb 7x256kB) SWAP 2084/12096MB (cached 4MB) CPU [51%@1479,37%@1479,80%@1479,58%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@29C PMIC@100C GPU@27C AO@32.5C thermal@28.25C
RAM 1858/1972MB (lfb 7x256kB) SWAP 2085/12096MB (cached 3MB) CPU [22%@1479,28%@1479,63%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@30C PMIC@100C GPU@27C AO@32.5C thermal@28.75C
RAM 1857/1972MB (lfb 7x256kB) SWAP 2085/12096MB (cached 4MB) CPU [19%@1479,26%@1479,60%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@29C PMIC@100C GPU@27C AO@32C thermal@28.25C
RAM 1858/1972MB (lfb 7x256kB) SWAP 2084/12096MB (cached 4MB) CPU [62%@1479,36%@1479,36%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@29.5C PMIC@100C GPU@27C AO@32.5C thermal@28.25C
RAM 1859/1972MB (lfb 7x256kB) SWAP 2083/12096MB (cached 5MB) CPU [38%@1479,63%@1479,21%@1479,83%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25.5C CPU@29.5C PMIC@100C GPU@27.5C AO@32C thermal@28.5C
RAM 1863/1972MB (lfb 7x256kB) SWAP 2085/12096MB (cached 8MB) CPU [21%@1479,100%@1479,74%@1479,15%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@30C PMIC@100C GPU@27C AO@32.5C thermal@28.5C
RAM 1857/1972MB (lfb 7x256kB) SWAP 2085/12096MB (cached 4MB) CPU [21%@1479,100%@1479,51%@1479,51%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@29.5C PMIC@100C GPU@27C AO@32.5C thermal@28.25C
RAM 1856/1972MB (lfb 7x256kB) SWAP 2087/12096MB (cached 2MB) CPU [22%@1479,100%@1479,73%@1479,24%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@30C PMIC@100C GPU@27C AO@32C thermal@28.25C
RAM 1860/1972MB (lfb 7x256kB) SWAP 2082/12096MB (cached 5MB) CPU [25%@1479,100%@1479,39%@1479,48%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@29.5C PMIC@100C GPU@27C AO@32C thermal@28.5C
RAM 1858/1972MB (lfb 6x256kB) SWAP 2084/12096MB (cached 4MB) CPU [19%@1479,56%@1479,70%@1479,48%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@29C PMIC@100C GPU@27C AO@32C thermal@28.5C
RAM 1858/1972MB (lfb 5x256kB) SWAP 2084/12096MB (cached 4MB) CPU [24%@1479,20%@1479,93%@1479,74%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@29.5C PMIC@100C GPU@27C AO@32C thermal@28.25C
RAM 1859/1972MB (lfb 5x256kB) SWAP 2084/12096MB (cached 6MB) CPU [26%@1479,100%@1479,18%@1479,93%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25.5C CPU@29.5C PMIC@100C GPU@27.5C AO@32C thermal@29C
RAM 1856/1972MB (lfb 5x256kB) SWAP 2086/12096MB (cached 3MB) CPU [19%@1479,100%@1479,6%@1479,94%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25.5C CPU@29.5C PMIC@100C GPU@27.5C AO@32C thermal@28.25C
RAM 1857/1972MB (lfb 5x256kB) SWAP 2085/12096MB (cached 4MB) CPU [27%@1479,91%@1479,45%@1479,64%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@30.5C PMIC@100C GPU@27C AO@32C thermal@28.5C
RAM 1858/1972MB (lfb 5x256kB) SWAP 2083/12096MB (cached 5MB) CPU [23%@1479,45%@1479,100%@1479,44%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25.5C CPU@29.5C PMIC@100C GPU@27.5C AO@32C thermal@28.5C
RAM 1859/1972MB (lfb 5x256kB) SWAP 2084/12096MB (cached 5MB) CPU [16%@1479,18%@1479,100%@1479,80%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25.5C CPU@29.5C PMIC@100C GPU@27.5C AO@32C thermal@28.5C
RAM 1858/1972MB (lfb 6x256kB) SWAP 2084/12096MB (cached 4MB) CPU [25%@1479,18%@1479,100%@1479,76%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25.5C CPU@29.5C PMIC@100C GPU@27.5C AO@32C thermal@28.25C
RAM 1856/1972MB (lfb 6x256kB) SWAP 2086/12096MB (cached 3MB) CPU [22%@1479,48%@1479,100%@1479,46%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@29.5C PMIC@100C GPU@27C AO@32.5C thermal@28.5C
RAM 1858/1972MB (lfb 6x256kB) SWAP 2085/12096MB (cached 4MB) CPU [24%@1479,48%@1479,49%@1479,92%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25.5C CPU@29C PMIC@100C GPU@27.5C AO@32.5C thermal@28.25C
RAM 1859/1972MB (lfb 6x256kB) SWAP 2083/12096MB (cached 5MB) CPU [28%@1479,17%@1479,55%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@29.5C PMIC@100C GPU@27C AO@32C thermal@28.25C
RAM 1858/1972MB (lfb 6x256kB) SWAP 2084/12096MB (cached 4MB) CPU [37%@1479,29%@1479,44%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25.5C CPU@29.5C PMIC@100C GPU@27.5C AO@32C thermal@28.75C
RAM 1859/1972MB (lfb 6x256kB) SWAP 2083/12096MB (cached 5MB) CPU [15%@1479,30%@1479,61%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25.5C CPU@29.5C PMIC@100C GPU@27.5C AO@32C thermal@28C
RAM 1859/1972MB (lfb 6x256kB) SWAP 2083/12096MB (cached 4MB) CPU [24%@1479,71%@1479,26%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25.5C CPU@30.5C PMIC@100C GPU@27.5C AO@32.5C thermal@28.75C
RAM 1858/1972MB (lfb 6x256kB) SWAP 2083/12096MB (cached 4MB) CPU [23%@1479,93%@1479,53%@1479,60%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25.5C CPU@30.5C PMIC@100C GPU@27C AO@32.5C thermal@28.5C
RAM 1857/1972MB (lfb 6x256kB) SWAP 2085/12096MB (cached 3MB) CPU [34%@1479,23%@1479,99%@1479,53%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25.5C CPU@29.5C PMIC@100C GPU@27.5C AO@32C thermal@28.5C
RAM 1855/1972MB (lfb 6x256kB) SWAP 2086/12096MB (cached 3MB) CPU [14%@1479,17%@1479,100%@1479,81%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@30C PMIC@100C GPU@27C AO@32C thermal@27.75C
RAM 1858/1972MB (lfb 6x256kB) SWAP 2084/12096MB (cached 4MB) CPU [16%@1479,9%@1479,100%@1479,78%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25.5C CPU@29.5C PMIC@100C GPU@27.5C AO@31.5C thermal@28.75C
RAM 1858/1972MB (lfb 6x256kB) SWAP 2084/12096MB (cached 4MB) CPU [18%@1479,26%@1479,100%@1479,45%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@29C PMIC@100C GPU@27C AO@32C thermal@28C
RAM 1858/1972MB (lfb 6x256kB) SWAP 2084/12096MB (cached 4MB) CPU [17%@1479,16%@1479,100%@1479,63%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@29C PMIC@100C GPU@27C AO@31.5C thermal@27.5C
RAM 1857/1972MB (lfb 6x256kB) SWAP 2083/12096MB (cached 5MB) CPU [18%@1479,19%@1479,100%@1479,59%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@29C PMIC@100C GPU@27C AO@32C thermal@28.25C
RAM 1859/1972MB (lfb 6x256kB) SWAP 2082/12096MB (cached 5MB) CPU [27%@1479,37%@1479,98%@1479,53%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@24.5C CPU@28.5C PMIC@100C GPU@27C AO@31.5C thermal@28C
RAM 1857/1972MB (lfb 6x256kB) SWAP 2084/12096MB (cached 5MB) CPU [29%@1479,38%@1479,100%@1479,28%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@29.5C PMIC@100C GPU@27C AO@32C thermal@28C
RAM 1858/1972MB (lfb 6x256kB) SWAP 2084/12096MB (cached 4MB) CPU [34%@1479,48%@1479,40%@1479,91%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@29.5C PMIC@100C GPU@27C AO@32C thermal@28.5C
RAM 1858/1972MB (lfb 6x256kB) SWAP 2085/12096MB (cached 4MB) CPU [16%@1479,30%@1479,51%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@29C PMIC@100C GPU@27C AO@31.5C thermal@28.25C
RAM 1859/1972MB (lfb 5x256kB) SWAP 2084/12096MB (cached 5MB) CPU [23%@1479,13%@1479,80%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@29C PMIC@100C GPU@27C AO@31.5C thermal@28C
RAM 1859/1972MB (lfb 5x256kB) SWAP 2085/12096MB (cached 4MB) CPU [15%@1479,20%@1479,54%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@29C PMIC@100C GPU@27C AO@32C thermal@28C
RAM 1858/1972MB (lfb 5x256kB) SWAP 2087/12096MB (cached 5MB) CPU [25%@1479,61%@1479,39%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25.5C CPU@30C PMIC@100C GPU@27.5C AO@31.5C thermal@28.5C
RAM 1862/1972MB (lfb 5x256kB) SWAP 2084/12096MB (cached 6MB) CPU [20%@1479,80%@1479,10%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@30C PMIC@100C GPU@27C AO@32C thermal@28.5C
RAM 1858/1972MB (lfb 5x256kB) SWAP 2087/12096MB (cached 4MB) CPU [22%@1479,50%@1479,60%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@29.5C PMIC@100C GPU@27C AO@32.5C thermal@28C
RAM 1860/1972MB (lfb 5x256kB) SWAP 2083/12096MB (cached 5MB) CPU [19%@1479,51%@1479,40%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@30C PMIC@100C GPU@27C AO@32C thermal@28.75C
RAM 1858/1972MB (lfb 5x256kB) SWAP 2084/12096MB (cached 4MB) CPU [18%@1479,34%@1479,47%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@29C PMIC@100C GPU@27C AO@32C thermal@28.25C
RAM 1858/1972MB (lfb 5x256kB) SWAP 2085/12096MB (cached 3MB) CPU [23%@1479,57%@1479,32%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25.5C CPU@30C PMIC@100C GPU@27.5C AO@31.5C thermal@28.5C
RAM 1861/1972MB (lfb 5x256kB) SWAP 2085/12096MB (cached 8MB) CPU [15%@1479,29%@1479,68%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@29C PMIC@100C GPU@27C AO@32C thermal@28C
RAM 1858/1972MB (lfb 5x256kB) SWAP 2085/12096MB (cached 4MB) CPU [23%@1479,43%@1479,51%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@30C PMIC@100C GPU@27C AO@32C thermal@28.25C
RAM 1858/1972MB (lfb 5x256kB) SWAP 2085/12096MB (cached 4MB) CPU [23%@1479,25%@1479,64%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@24.5C CPU@29C PMIC@100C GPU@27C AO@31.5C thermal@28C
RAM 1858/1972MB (lfb 2x512kB) SWAP 2085/12096MB (cached 3MB) CPU [15%@1479,58%@1479,14%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@24.5C CPU@28.5C PMIC@100C GPU@27C AO@32C thermal@28C
RAM 1859/1972MB (lfb 2x512kB) SWAP 2084/12096MB (cached 5MB) CPU [40%@1479,15%@1479,44%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@29.5C PMIC@100C GPU@27C AO@31.5C thermal@28C
RAM 1858/1972MB (lfb 3x512kB) SWAP 2085/12096MB (cached 4MB) CPU [19%@1479,56%@1479,29%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@29C PMIC@100C GPU@27C AO@31.5C thermal@28C
RAM 1859/1972MB (lfb 3x512kB) SWAP 2085/12096MB (cached 5MB) CPU [25%@1479,57%@1479,32%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@24.5C CPU@29C PMIC@100C GPU@27C AO@31.5C thermal@28C
RAM 1859/1972MB (lfb 3x512kB) SWAP 2083/12096MB (cached 5MB) CPU [20%@1479,35%@1479,53%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25.5C CPU@30C PMIC@100C GPU@27.5C AO@32C thermal@28C
RAM 1858/1972MB (lfb 3x512kB) SWAP 2083/12096MB (cached 4MB) CPU [19%@1479,47%@1479,41%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@30C PMIC@100C GPU@27C AO@32C thermal@28.75C
RAM 1860/1972MB (lfb 3x512kB) SWAP 2082/12096MB (cached 5MB) CPU [22%@1479,48%@1479,32%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25.5C CPU@30C PMIC@100C GPU@27.5C AO@32C thermal@28.5C
RAM 1861/1972MB (lfb 3x512kB) SWAP 2082/12096MB (cached 5MB) CPU [16%@1479,29%@1479,58%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@29C PMIC@100C GPU@27C AO@32C thermal@28C
RAM 1858/1972MB (lfb 3x512kB) SWAP 2084/12096MB (cached 4MB) CPU [18%@1479,24%@1479,65%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@30C PMIC@100C GPU@27C AO@32C thermal@28.5C
RAM 1859/1972MB (lfb 3x512kB) SWAP 2084/12096MB (cached 4MB) CPU [28%@1479,48%@1479,27%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@28.5C PMIC@100C GPU@27C AO@32C thermal@28.75C
RAM 1858/1972MB (lfb 3x512kB) SWAP 2085/12096MB (cached 4MB) CPU [18%@1479,77%@1479,17%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@29C PMIC@100C GPU@27C AO@32C thermal@28C
RAM 1858/1972MB (lfb 1x512kB) SWAP 2085/12096MB (cached 3MB) CPU [15%@1479,52%@1479,27%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@29C PMIC@100C GPU@27C AO@32C thermal@28C
RAM 1857/1972MB (lfb 1x512kB) SWAP 2086/12096MB (cached 3MB) CPU [28%@1479,33%@1479,47%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@30C PMIC@100C GPU@27C AO@32C thermal@28.5C
RAM 1858/1972MB (lfb 1x512kB) SWAP 2086/12096MB (cached 3MB) CPU [19%@1479,19%@1479,55%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@29.5C PMIC@100C GPU@27C AO@32C thermal@28.5C
RAM 1860/1972MB (lfb 1x512kB) SWAP 2084/12096MB (cached 4MB) CPU [25%@1479,54%@1479,11%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@24.5C CPU@29C PMIC@100C GPU@27C AO@32C thermal@28C
RAM 1861/1972MB (lfb 1x512kB) SWAP 2082/12096MB (cached 8MB) CPU [16%@1479,60%@1479,38%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25.5C CPU@29C PMIC@100C GPU@27.5C AO@32C thermal@28C
RAM 1858/1972MB (lfb 1x512kB) SWAP 2083/12096MB (cached 4MB) CPU [29%@1479,67%@1479,47%@1479,88%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@29.5C PMIC@100C GPU@27C AO@32C thermal@28.25C
RAM 1858/1972MB (lfb 1x512kB) SWAP 2083/12096MB (cached 4MB) CPU [29%@1479,100%@1479,28%@1479,65%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@29.5C PMIC@100C GPU@27C AO@32C thermal@28.25C
RAM 1856/1972MB (lfb 1x512kB) SWAP 2084/12096MB (cached 3MB) CPU [19%@1479,100%@1479,63%@1479,26%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@29.5C PMIC@100C GPU@27C AO@31.5C thermal@28.5C
RAM 1860/1972MB (lfb 1x512kB) SWAP 2081/12096MB (cached 5MB) CPU [35%@1479,91%@1479,42%@1479,38%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@30.5C PMIC@100C GPU@27C AO@31.5C thermal@28.5C
RAM 1857/1972MB (lfb 1x512kB) SWAP 2083/12096MB (cached 3MB) CPU [24%@1479,15%@1479,100%@1479,64%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@24.5C CPU@29C PMIC@100C GPU@27C AO@31.5C thermal@28.25C
RAM 1857/1972MB (lfb 1x512kB) SWAP 2083/12096MB (cached 3MB) CPU [27%@1479,50%@1479,71%@1479,46%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@29.5C PMIC@100C GPU@27C AO@32C thermal@28C
RAM 1857/1972MB (lfb 1x512kB) SWAP 2083/12096MB (cached 3MB) CPU [25%@1479,13%@1479,68%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@24.5C CPU@29C PMIC@100C GPU@26.5C AO@31.5C thermal@27.75C
RAM 1860/1972MB (lfb 1x512kB) SWAP 2081/12096MB (cached 5MB) CPU [22%@1479,29%@1479,50%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@30C PMIC@100C GPU@27C AO@31.5C thermal@27.5C
RAM 1858/1972MB (lfb 1x512kB) SWAP 2083/12096MB (cached 4MB) CPU [34%@1479,31%@1479,28%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@29C PMIC@100C GPU@27C AO@31.5C thermal@28C
RAM 1867/1972MB (lfb 1x512kB) SWAP 2083/12096MB (cached 13MB) CPU [56%@1479,22%@1479,24%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@29.5C PMIC@100C GPU@27C AO@32C thermal@28.25C
RAM 1858/1972MB (lfb 1x512kB) SWAP 2082/12096MB (cached 4MB) CPU [17%@1479,31%@1479,43%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@28.5C PMIC@100C GPU@27C AO@31.5C thermal@27.75C
RAM 1858/1972MB (lfb 1x512kB) SWAP 2083/12096MB (cached 4MB) CPU [41%@1479,16%@1479,48%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@24.5C CPU@29.5C PMIC@100C GPU@27C AO@31.5C thermal@28C
RAM 1859/1972MB (lfb 1x512kB) SWAP 2082/12096MB (cached 5MB) CPU [13%@1479,31%@1479,56%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@29.5C PMIC@100C GPU@27C AO@31.5C thermal@28C
RAM 1860/1972MB (lfb 1x512kB) SWAP 2084/12096MB (cached 7MB) CPU [31%@1479,97%@1479,17%@1479,85%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@24.5C CPU@30C PMIC@100C GPU@27C AO@32C thermal@28.25C
RAM 1859/1972MB (lfb 1x512kB) SWAP 2082/12096MB (cached 5MB) CPU [40%@1479,45%@1479,27%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@29C PMIC@100C GPU@27C AO@32C thermal@28C
RAM 1859/1972MB (lfb 1x512kB) SWAP 2082/12096MB (cached 5MB) CPU [28%@1479,37%@1479,30%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@29C PMIC@100C GPU@27C AO@32C thermal@28C
RAM 1856/1972MB (lfb 1x512kB) SWAP 2084/12096MB (cached 3MB) CPU [18%@1479,20%@1479,76%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@24.5C CPU@29C PMIC@100C GPU@27C AO@31.5C thermal@28C
RAM 1858/1972MB (lfb 1x512kB) SWAP 2083/12096MB (cached 4MB) CPU [18%@1479,35%@1479,35%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@29C PMIC@100C GPU@27C AO@31.5C thermal@28.5C
RAM 1857/1972MB (lfb 1x512kB) SWAP 2083/12096MB (cached 3MB) CPU [18%@1479,8%@1479,83%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@24.5C CPU@28.5C PMIC@100C GPU@27C AO@31.5C thermal@28C
RAM 1862/1972MB (lfb 5x256kB) SWAP 2082/12096MB (cached 8MB) CPU [24%@1479,15%@1479,53%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@29C PMIC@100C GPU@27C AO@31.5C thermal@28C
RAM 1858/1972MB (lfb 5x256kB) SWAP 2082/12096MB (cached 4MB) CPU [15%@1479,43%@1479,35%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@24.5C CPU@29C PMIC@100C GPU@27C AO@32C thermal@28.25C
RAM 1856/1972MB (lfb 5x256kB) SWAP 2083/12096MB (cached 2MB) CPU [17%@1479,31%@1479,65%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@29C PMIC@100C GPU@27C AO@31.5C thermal@28C
RAM 1856/1972MB (lfb 5x256kB) SWAP 2084/12096MB (cached 2MB) CPU [20%@1479,62%@1479,35%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@29.5C PMIC@100C GPU@27C AO@32C thermal@28.75C
RAM 1861/1972MB (lfb 5x256kB) SWAP 2083/12096MB (cached 7MB) CPU [17%@1479,40%@1479,48%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@30C PMIC@100C GPU@27C AO@32C thermal@28.5C
RAM 1859/1972MB (lfb 5x256kB) SWAP 2081/12096MB (cached 4MB) CPU [23%@1479,36%@1479,40%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@30C PMIC@100C GPU@27C AO@32C thermal@28C
RAM 1859/1972MB (lfb 5x256kB) SWAP 2081/12096MB (cached 4MB) CPU [16%@1479,56%@1479,28%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@30C PMIC@100C GPU@27C AO@32C thermal@28.5C
RAM 1858/1972MB (lfb 5x256kB) SWAP 2084/12096MB (cached 3MB) CPU [16%@1479,45%@1479,54%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@30C PMIC@100C GPU@27C AO@31.5C thermal@28.5C
RAM 1858/1972MB (lfb 5x256kB) SWAP 2082/12096MB (cached 4MB) CPU [19%@1479,27%@1479,53%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@29C PMIC@100C GPU@27C AO@32C thermal@28C
RAM 1860/1972MB (lfb 5x256kB) SWAP 2081/12096MB (cached 6MB) CPU [20%@1479,41%@1479,37%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@29C PMIC@100C GPU@27C AO@31.5C thermal@28.5C
RAM 1861/1972MB (lfb 5x256kB) SWAP 2083/12096MB (cached 7MB) CPU [25%@1479,26%@1479,48%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@29C PMIC@100C GPU@27C AO@31.5C thermal@28.25C
RAM 1861/1972MB (lfb 5x256kB) SWAP 2080/12096MB (cached 6MB) CPU [31%@1479,47%@1479,50%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@24.5C CPU@29C PMIC@100C GPU@27C AO@31.5C thermal@28C
RAM 1858/1972MB (lfb 5x256kB) SWAP 2083/12096MB (cached 3MB) CPU [22%@1479,49%@1479,43%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@30C PMIC@100C GPU@27C AO@32C thermal@28.25C
RAM 1858/1972MB (lfb 5x256kB) SWAP 2083/12096MB (cached 4MB) CPU [27%@1479,71%@1479,12%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@29C PMIC@100C GPU@27C AO@32C thermal@28C
RAM 1860/1972MB (lfb 5x256kB) SWAP 2081/12096MB (cached 4MB) CPU [14%@1479,71%@1479,11%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@30C PMIC@100C GPU@27C AO@31.5C thermal@28.25C
RAM 1859/1972MB (lfb 5x256kB) SWAP 2083/12096MB (cached 4MB) CPU [33%@1479,40%@1479,61%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@29C PMIC@100C GPU@27C AO@32C thermal@28C
RAM 1857/1972MB (lfb 5x256kB) SWAP 2084/12096MB (cached 3MB) CPU [34%@1479,31%@1479,82%@1479,91%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@29.5C PMIC@100C GPU@27C AO@31.5C thermal@28.75C
RAM 1860/1972MB (lfb 5x256kB) SWAP 2082/12096MB (cached 4MB) CPU [19%@1479,7%@1479,100%@1479,71%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25.5C CPU@29.5C PMIC@100C GPU@27.5C AO@31.5C thermal@28.25C
RAM 1859/1972MB (lfb 5x256kB) SWAP 2082/12096MB (cached 3MB) CPU [24%@1479,41%@1479,100%@1479,44%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@24.5C CPU@28.5C PMIC@100C GPU@27C AO@31.5C thermal@28.5C
RAM 1860/1972MB (lfb 5x256kB) SWAP 2082/12096MB (cached 5MB) CPU [20%@1479,21%@1479,100%@1479,74%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@24.5C CPU@29C PMIC@100C GPU@27C AO@32C thermal@28.25C
RAM 1859/1972MB (lfb 5x256kB) SWAP 2082/12096MB (cached 4MB) CPU [16%@1479,37%@1479,100%@1479,40%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@29.5C PMIC@100C GPU@27C AO@31.5C thermal@28.25C
RAM 1861/1972MB (lfb 5x256kB) SWAP 2081/12096MB (cached 5MB) CPU [21%@1479,46%@1479,100%@1479,42%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@29.5C PMIC@100C GPU@27C AO@31.5C thermal@28.25C
RAM 1864/1972MB (lfb 6x256kB) SWAP 2085/12096MB (cached 11MB) CPU [21%@1479,13%@1479,99%@1479,80%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@29C PMIC@100C GPU@27C AO@31.5C thermal@28.75C
RAM 1859/1972MB (lfb 1x512kB) SWAP 2081/12096MB (cached 4MB) CPU [20%@1479,62%@1479,35%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@29C PMIC@100C GPU@27C AO@31.5C thermal@28.25C
RAM 1860/1972MB (lfb 1x512kB) SWAP 2083/12096MB (cached 4MB) CPU [19%@1479,40%@1479,50%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@28.5C PMIC@100C GPU@27C AO@31.5C thermal@28.5C
RAM 1862/1972MB (lfb 1x512kB) SWAP 2084/12096MB (cached 7MB) CPU [20%@1479,61%@1479,37%@1479,96%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@30C PMIC@100C GPU@27C AO@32C thermal@28.5C
RAM 1859/1972MB (lfb 1x512kB) SWAP 2083/12096MB (cached 3MB) CPU [15%@1479,55%@1479,52%@1479,84%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@29C PMIC@100C GPU@27C AO@31.5C thermal@28.25C
RAM 1864/1972MB (lfb 1x512kB) SWAP 2080/12096MB (cached 5MB) CPU [18%@1479,11%@1479,76%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@29C PMIC@100C GPU@27C AO@32C thermal@28C
RAM 1860/1972MB (lfb 1x512kB) SWAP 2081/12096MB (cached 5MB) CPU [29%@1479,30%@1479,66%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@29C PMIC@100C GPU@27C AO@32C thermal@28C
RAM 1860/1972MB (lfb 1x512kB) SWAP 2081/12096MB (cached 4MB) CPU [43%@1479,71%@1479,37%@1479,83%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25.5C CPU@29.5C PMIC@100C GPU@27.5C AO@32C thermal@28.25C
RAM 1860/1972MB (lfb 1x512kB) SWAP 2082/12096MB (cached 3MB) CPU [28%@1479,100%@1479,10%@1479,73%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@29.5C PMIC@100C GPU@27C AO@32C thermal@28.25C
RAM 1860/1972MB (lfb 1x512kB) SWAP 2082/12096MB (cached 4MB) CPU [31%@1479,74%@1479,55%@1479,42%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25.5C CPU@29.5C PMIC@100C GPU@27.5C AO@31.5C thermal@28C
RAM 1859/1972MB (lfb 1x512kB) SWAP 2084/12096MB (cached 3MB) CPU [21%@1479,11%@1479,91%@1479,94%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@29C PMIC@100C GPU@27C AO@32C thermal@28.25C
RAM 1860/1972MB (lfb 1x512kB) SWAP 2083/12096MB (cached 3MB) CPU [26%@1479,53%@1479,46%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@29C PMIC@100C GPU@27C AO@32C thermal@28.5C
RAM 1859/1972MB (lfb 1x512kB) SWAP 2084/12096MB (cached 3MB) CPU [17%@1479,83%@1479,7%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@30C PMIC@100C GPU@27C AO@32C thermal@28C
RAM 1859/1972MB (lfb 1x512kB) SWAP 2084/12096MB (cached 3MB) CPU [20%@1479,37%@1479,64%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@29.5C PMIC@100C GPU@27C AO@31.5C thermal@28.25C
RAM 1859/1972MB (lfb 1x512kB) SWAP 2084/12096MB (cached 3MB) CPU [27%@1479,45%@1479,52%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@29C PMIC@100C GPU@27C AO@32C thermal@28.5C
RAM 1860/1972MB (lfb 1x512kB) SWAP 2083/12096MB (cached 4MB) CPU [18%@1479,8%@1479,87%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@29.5C PMIC@100C GPU@27C AO@32C thermal@28.25C
RAM 1861/1972MB (lfb 1x512kB) SWAP 2083/12096MB (cached 3MB) CPU [23%@1479,11%@1479,87%@1479,99%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@30C PMIC@100C GPU@27C AO@32C thermal@28.25C
RAM 1861/1972MB (lfb 1x512kB) SWAP 2080/12096MB (cached 5MB) CPU [19%@1479,14%@1479,100%@1479,84%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@30C PMIC@100C GPU@27C AO@32C thermal@28.25C
RAM 1859/1972MB (lfb 1x512kB) SWAP 2084/12096MB (cached 3MB) CPU [44%@1479,21%@1479,100%@1479,56%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@24.5C CPU@29.5C PMIC@100C GPU@27C AO@32C thermal@28.25C
RAM 1862/1972MB (lfb 1x512kB) SWAP 2082/12096MB (cached 5MB) CPU [20%@1479,52%@1479,100%@1479,37%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@30C PMIC@100C GPU@27C AO@32C thermal@28.25C
RAM 1859/1972MB (lfb 1x512kB) SWAP 2083/12096MB (cached 3MB) CPU [32%@1479,97%@1479,65%@1479,51%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@29.5C PMIC@100C GPU@27C AO@32C thermal@28.25C
RAM 1861/1972MB (lfb 1x512kB) SWAP 2083/12096MB (cached 4MB) CPU [26%@1479,100%@1479,47%@1479,51%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@29.5C PMIC@100C GPU@27.5C AO@32C thermal@28.5C
RAM 1863/1972MB (lfb 1x512kB) SWAP 2082/12096MB (cached 8MB) CPU [19%@1479,88%@1479,69%@1479,34%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@29.5C PMIC@100C GPU@27.5C AO@31.5C thermal@28.5C
RAM 1861/1972MB (lfb 1x512kB) SWAP 2082/12096MB (cached 4MB) CPU [15%@1479,7%@1479,100%@1479,79%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@29.5C PMIC@100C GPU@27.5C AO@32C thermal@28.5C
RAM 1860/1972MB (lfb 1x512kB) SWAP 2082/12096MB (cached 4MB) CPU [30%@1479,65%@1479,100%@1479,22%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@30C PMIC@100C GPU@27.5C AO@32C thermal@28.75C
RAM 1861/1972MB (lfb 1x512kB) SWAP 2081/12096MB (cached 5MB) CPU [18%@1479,53%@1479,100%@1479,41%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@29.5C PMIC@100C GPU@27C AO@32.5C thermal@28.5C
RAM 1861/1972MB (lfb 1x512kB) SWAP 2083/12096MB (cached 6MB) CPU [22%@1479,45%@1479,100%@1479,52%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25.5C CPU@30C PMIC@100C GPU@27.5C AO@32C thermal@28.5C
RAM 1861/1972MB (lfb 1x512kB) SWAP 2081/12096MB (cached 5MB) CPU [26%@1479,38%@1479,77%@1479,83%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@29C PMIC@100C GPU@27C AO@32C thermal@28.25C
RAM 1862/1972MB (lfb 1x512kB) SWAP 2084/12096MB (cached 7MB) CPU [13%@1479,26%@1479,100%@1479,78%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@29.5C PMIC@100C GPU@27C AO@32C thermal@28.25C
RAM 1861/1972MB (lfb 1x512kB) SWAP 2082/12096MB (cached 4MB) CPU [18%@1479,22%@1479,100%@1479,74%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@29C PMIC@100C GPU@27C AO@32C thermal@28.5C
RAM 1861/1972MB (lfb 1x512kB) SWAP 2082/12096MB (cached 3MB) CPU [23%@1479,43%@1479,100%@1479,49%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@24.5C CPU@29.5C PMIC@100C GPU@27C AO@32C thermal@28C
RAM 1858/1972MB (lfb 1x512kB) SWAP 2081/12096MB (cached 4MB) CPU [50%@1479,38%@1479,100%@1479,27%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@24.5C CPU@29C PMIC@100C GPU@27C AO@32C thermal@28C
RAM 1860/1972MB (lfb 1x512kB) SWAP 2082/12096MB (cached 5MB) CPU [63%@1479,35%@1479,75%@1479,48%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25.5C CPU@29.5C PMIC@100C GPU@27.5C AO@32C thermal@28.75C
RAM 1858/1972MB (lfb 1x512kB) SWAP 2084/12096MB (cached 2MB) CPU [32%@1479,39%@1479,71%@1479,89%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@24.5C CPU@29C PMIC@100C GPU@27C AO@32C thermal@28.25C
RAM 1858/1972MB (lfb 1x512kB) SWAP 2085/12096MB (cached 2MB) CPU [17%@1479,83%@1479,100%@1479,13%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@30.5C PMIC@100C GPU@27C AO@32C thermal@28.75C
RAM 1859/1972MB (lfb 1x512kB) SWAP 2084/12096MB (cached 3MB) CPU [22%@1479,41%@1479,100%@1479,56%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@24.5C CPU@30C PMIC@100C GPU@27C AO@32C thermal@28.25C
RAM 1860/1972MB (lfb 1x512kB) SWAP 2083/12096MB (cached 4MB) CPU [11%@1479,13%@1479,100%@1479,76%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25.5C CPU@29.5C PMIC@100C GPU@27.5C AO@31.5C thermal@28.5C
RAM 1860/1972MB (lfb 1x512kB) SWAP 2081/12096MB (cached 4MB) CPU [23%@1479,27%@1479,100%@1479,71%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@30C PMIC@100C GPU@27C AO@32.5C thermal@28.25C
RAM 1862/1972MB (lfb 1x512kB) SWAP 2082/12096MB (cached 8MB) CPU [25%@1479,35%@1479,99%@1479,66%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@24.5C CPU@29C PMIC@100C GPU@27C AO@32C thermal@28.5C
RAM 1861/1972MB (lfb 1x512kB) SWAP 2082/12096MB (cached 6MB) CPU [23%@1479,55%@1479,100%@1479,42%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25.5C CPU@30C PMIC@100C GPU@27.5C AO@32C thermal@28.75C
RAM 1859/1972MB (lfb 1x512kB) SWAP 2083/12096MB (cached 3MB) CPU [23%@1479,72%@1479,100%@1479,23%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25.5C CPU@29.5C PMIC@100C GPU@27.5C AO@32C thermal@28.5C
RAM 1860/1972MB (lfb 1x512kB) SWAP 2082/12096MB (cached 4MB) CPU [22%@1479,23%@1479,100%@1479,69%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@24.5C CPU@28.5C PMIC@100C GPU@27C AO@32C thermal@28.25C
RAM 1860/1972MB (lfb 1x512kB) SWAP 2083/12096MB (cached 4MB) CPU [14%@1479,91%@1479,100%@1479,9%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@29C PMIC@100C GPU@27C AO@32C thermal@28.5C
RAM 1859/1972MB (lfb 1x512kB) SWAP 2084/12096MB (cached 3MB) CPU [19%@1479,67%@1479,100%@1479,8%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@24.5C CPU@30C PMIC@100C GPU@27C AO@32C thermal@28.5C
RAM 1861/1972MB (lfb 1x512kB) SWAP 2083/12096MB (cached 4MB) CPU [39%@1479,36%@1479,100%@1479,38%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@29.5C PMIC@100C GPU@27C AO@32C thermal@27.75C
RAM 1860/1972MB (lfb 1x512kB) SWAP 2083/12096MB (cached 3MB) CPU [13%@1479,8%@1479,100%@1479,91%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25.5C CPU@30C PMIC@100C GPU@27.5C AO@32C thermal@28.75C
RAM 1860/1972MB (lfb 1x512kB) SWAP 2083/12096MB (cached 4MB) CPU [17%@1479,14%@1479,100%@1479,82%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@30C PMIC@100C GPU@27.5C AO@32C thermal@28.5C
RAM 1860/1972MB (lfb 1x512kB) SWAP 2082/12096MB (cached 4MB) CPU [21%@1479,11%@1479,100%@1479,72%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@30C PMIC@100C GPU@27.5C AO@32C thermal@28.5C
RAM 1859/1972MB (lfb 1x512kB) SWAP 2083/12096MB (cached 3MB) CPU [21%@1479,9%@1479,100%@1479,83%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25.5C CPU@29.5C PMIC@100C GPU@27.5C AO@32C thermal@28.75C
RAM 1859/1972MB (lfb 1x512kB) SWAP 2083/12096MB (cached 3MB) CPU [21%@1479,29%@1479,100%@1479,58%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@24.5C CPU@28.5C PMIC@100C GPU@27C AO@32C thermal@28.25C
RAM 1860/1972MB (lfb 1x512kB) SWAP 2082/12096MB (cached 4MB) CPU [20%@1479,41%@1479,100%@1479,44%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@29.5C PMIC@100C GPU@27C AO@32C thermal@28.25C
RAM 1863/1972MB (lfb 1x512kB) SWAP 2083/12096MB (cached 7MB) CPU [31%@1479,75%@1479,100%@1479,23%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@30C PMIC@100C GPU@27C AO@32C thermal@28.25C
RAM 1859/1972MB (lfb 1x512kB) SWAP 2084/12096MB (cached 3MB) CPU [29%@1479,27%@1479,100%@1479,80%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@30C PMIC@100C GPU@27C AO@32C thermal@28.75C
RAM 1861/1972MB (lfb 1x512kB) SWAP 2082/12096MB (cached 5MB) CPU [42%@1479,56%@1479,100%@1479,42%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@30C PMIC@100C GPU@27.5C AO@32.5C thermal@28.75C
RAM 1860/1972MB (lfb 2x512kB) SWAP 2083/12096MB (cached 4MB) CPU [27%@1479,18%@1479,100%@1479,71%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25.5C CPU@30C PMIC@100C GPU@27.5C AO@32C thermal@28.5C
RAM 1860/1972MB (lfb 2x512kB) SWAP 2083/12096MB (cached 4MB) CPU [20%@1479,42%@1479,100%@1479,40%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@28.5C PMIC@100C GPU@27.5C AO@32C thermal@29C
RAM 1859/1972MB (lfb 2x512kB) SWAP 2083/12096MB (cached 3MB) CPU [26%@1479,31%@1479,100%@1479,54%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25.5C CPU@30C PMIC@100C GPU@27.5C AO@32C thermal@28.5C
RAM 1860/1972MB (lfb 2x512kB) SWAP 2083/12096MB (cached 4MB) CPU [18%@1479,41%@1479,100%@1479,44%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@29C PMIC@100C GPU@27.5C AO@31.5C thermal@28.75C
RAM 1860/1972MB (lfb 2x512kB) SWAP 2083/12096MB (cached 4MB) CPU [27%@1479,30%@1479,100%@1479,50%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@30C PMIC@100C GPU@27.5C AO@32C thermal@28.5C
RAM 1857/1972MB (lfb 2x512kB) SWAP 2084/12096MB (cached 3MB) CPU [29%@1479,85%@1479,92%@1479,23%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@30.5C PMIC@100C GPU@27.5C AO@32C thermal@28.75C
RAM 1860/1972MB (lfb 2x512kB) SWAP 2082/12096MB (cached 5MB) CPU [14%@1479,56%@1479,100%@1479,33%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@24.5C CPU@30C PMIC@100C GPU@27.5C AO@31.5C thermal@28.5C
RAM 1860/1972MB (lfb 2x512kB) SWAP 2082/12096MB (cached 4MB) CPU [26%@1479,67%@1479,100%@1479,38%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@24.5C CPU@30C PMIC@100C GPU@27.5C AO@32C thermal@28.75C
RAM 1858/1972MB (lfb 2x512kB) SWAP 2083/12096MB (cached 3MB) CPU [19%@1479,82%@1479,100%@1479,7%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@24.5C CPU@30C PMIC@100C GPU@27.5C AO@31.5C thermal@28C
RAM 1862/1972MB (lfb 2x512kB) SWAP 2084/12096MB (cached 7MB) CPU [22%@1479,78%@1479,100%@1479,11%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@24.5C CPU@30C PMIC@100C GPU@27.5C AO@31.5C thermal@28.25C
RAM 1860/1972MB (lfb 2x512kB) SWAP 2083/12096MB (cached 5MB) CPU [20%@1479,78%@1479,100%@1479,19%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@30C PMIC@100C GPU@27.5C AO@31.5C thermal@28.5C
RAM 1859/1972MB (lfb 2x512kB) SWAP 2084/12096MB (cached 3MB) CPU [18%@1479,85%@1479,100%@1479,10%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@30C PMIC@100C GPU@27.5C AO@31.5C thermal@28.75C
RAM 1860/1972MB (lfb 2x512kB) SWAP 2083/12096MB (cached 3MB) CPU [13%@1479,55%@1479,100%@1479,40%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@24.5C CPU@30.5C PMIC@100C GPU@27.5C AO@32C thermal@28.75C
RAM 1859/1972MB (lfb 2x512kB) SWAP 2082/12096MB (cached 4MB) CPU [17%@1479,58%@1479,100%@1479,26%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@24.5C CPU@28.5C PMIC@100C GPU@27.5C AO@32C thermal@28.5C
RAM 1859/1972MB (lfb 2x512kB) SWAP 2084/12096MB (cached 3MB) CPU [21%@1479,45%@1479,100%@1479,36%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@29.5C PMIC@100C GPU@27.5C AO@32C thermal@28.5C
RAM 1859/1972MB (lfb 2x512kB) SWAP 2083/12096MB (cached 3MB) CPU [16%@1479,27%@1479,100%@1479,68%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@30C PMIC@100C GPU@27.5C AO@31.5C thermal@28.75C
RAM 1858/1972MB (lfb 2x512kB) SWAP 2083/12096MB (cached 3MB) CPU [33%@1479,46%@1479,85%@1479,56%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@24.5C CPU@29.5C PMIC@100C GPU@27.5C AO@31.5C thermal@28.25C
RAM 1860/1972MB (lfb 2x512kB) SWAP 2083/12096MB (cached 5MB) CPU [50%@1479,100%@1479,65%@1479,46%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@29.5C PMIC@100C GPU@28C AO@32C thermal@28.75C
RAM 1861/1972MB (lfb 2x512kB) SWAP 2082/12096MB (cached 4MB) CPU [34%@1479,89%@1479,82%@1479,24%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25.5C CPU@29.5C PMIC@100C GPU@28C AO@32C thermal@29C
RAM 1859/1972MB (lfb 2x512kB) SWAP 2084/12096MB (cached 3MB) CPU [18%@1479,100%@1479,52%@1479,45%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@29.5C PMIC@100C GPU@28C AO@32C thermal@28.75C
RAM 1859/1972MB (lfb 4x512kB) SWAP 2084/12096MB (cached 3MB) CPU [19%@1479,100%@1479,25%@1479,64%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25.5C CPU@30C PMIC@100C GPU@28C AO@32C thermal@29C
RAM 1862/1972MB (lfb 4x512kB) SWAP 2082/12096MB (cached 5MB) CPU [17%@1479,100%@1479,33%@1479,63%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25.5C CPU@30C PMIC@100C GPU@28C AO@32.5C thermal@29C
RAM 1860/1972MB (lfb 4x512kB) SWAP 2083/12096MB (cached 4MB) CPU [22%@1479,35%@1479,80%@1479,82%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25.5C CPU@30C PMIC@100C GPU@28C AO@32.5C thermal@29C
RAM 1862/1972MB (lfb 4x512kB) SWAP 2082/12096MB (cached 4MB) CPU [17%@1479,35%@1479,49%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25.5C CPU@30C PMIC@100C GPU@28C AO@32.5C thermal@29.25C
RAM 1859/1972MB (lfb 4x512kB) SWAP 2084/12096MB (cached 3MB) CPU [55%@1479,49%@1479,96%@1479,33%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25.5C CPU@30.5C PMIC@100C GPU@28C AO@32.5C thermal@29C
RAM 1862/1972MB (lfb 4x512kB) SWAP 2082/12096MB (cached 4MB) CPU [30%@1479,80%@1479,100%@1479,18%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25.5C CPU@30.5C PMIC@100C GPU@28C AO@32.5C thermal@29C
RAM 1861/1972MB (lfb 4x512kB) SWAP 2081/12096MB (cached 5MB) CPU [27%@1479,53%@1479,58%@1479,87%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25.5C CPU@31C PMIC@100C GPU@27.5C AO@32.5C thermal@29C
RAM 1861/1972MB (lfb 4x512kB) SWAP 2081/12096MB (cached 5MB) CPU [38%@1479,40%@1479,31%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@29.5C PMIC@100C GPU@27.5C AO@32C thermal@28.5C
RAM 1858/1972MB (lfb 6x256kB) SWAP 2084/12096MB (cached 3MB) CPU [34%@1479,17%@1479,67%@1479,99%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25.5C CPU@29.5C PMIC@100C GPU@27.5C AO@32C thermal@28.75C
RAM 1862/1972MB (lfb 6x256kB) SWAP 2081/12096MB (cached 4MB) CPU [18%@1479,27%@1479,64%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25.5C CPU@30C PMIC@100C GPU@27.5C AO@32.5C thermal@28.75C
RAM 1856/1972MB (lfb 6x256kB) SWAP 2085/12096MB (cached 2MB) CPU [28%@1479,50%@1479,63%@1479,95%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25.5C CPU@30C PMIC@100C GPU@27.5C AO@32C thermal@28.25C
RAM 1861/1972MB (lfb 5x256kB) SWAP 2082/12096MB (cached 4MB) CPU [17%@1479,21%@1479,100%@1479,68%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25.5C CPU@30C PMIC@100C GPU@27.5C AO@32C thermal@29C
RAM 1859/1972MB (lfb 5x256kB) SWAP 2083/12096MB (cached 3MB) CPU [24%@1479,39%@1479,100%@1479,36%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@30.5C PMIC@100C GPU@27.5C AO@32.5C thermal@28.75C
RAM 1859/1972MB (lfb 5x256kB) SWAP 2083/12096MB (cached 4MB) CPU [29%@1479,30%@1479,100%@1479,38%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@29C PMIC@100C GPU@27.5C AO@32C thermal@28.75C
RAM 1860/1972MB (lfb 5x256kB) SWAP 2085/12096MB (cached 5MB) CPU [46%@1479,40%@1479,84%@1479,71%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@30.5C PMIC@100C GPU@28C AO@32C thermal@29.25C
RAM 1858/1972MB (lfb 5x256kB) SWAP 2083/12096MB (cached 3MB) CPU [25%@1479,37%@1479,39%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25.5C CPU@29.5C PMIC@100C GPU@28C AO@32.5C thermal@29C
RAM 1859/1972MB (lfb 5x256kB) SWAP 2083/12096MB (cached 4MB) CPU [19%@1479,7%@1479,86%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25.5C CPU@29.5C PMIC@100C GPU@28C AO@32.5C thermal@28.75C
RAM 1861/1972MB (lfb 5x256kB) SWAP 2082/12096MB (cached 5MB) CPU [27%@1479,29%@1479,58%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@29.5C PMIC@100C GPU@28C AO@32C thermal@28.75C
RAM 1862/1972MB (lfb 5x256kB) SWAP 2082/12096MB (cached 5MB) CPU [18%@1479,13%@1479,74%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@26C CPU@30.5C PMIC@100C GPU@28C AO@32.5C thermal@29.25C
RAM 1860/1972MB (lfb 5x256kB) SWAP 2083/12096MB (cached 4MB) CPU [19%@1479,40%@1479,50%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25.5C CPU@30C PMIC@100C GPU@27.5C AO@32C thermal@28.75C
RAM 1863/1972MB (lfb 5x256kB) SWAP 2082/12096MB (cached 8MB) CPU [21%@1479,11%@1479,78%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25.5C CPU@29.5C PMIC@100C GPU@27.5C AO@32.5C thermal@28.5C
RAM 1860/1972MB (lfb 5x256kB) SWAP 2082/12096MB (cached 3MB) CPU [25%@1479,57%@1479,45%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@30.5C PMIC@100C GPU@27.5C AO@32C thermal@29C
RAM 1860/1972MB (lfb 5x256kB) SWAP 2083/12096MB (cached 4MB) CPU [30%@1479,49%@1479,40%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25.5C CPU@30.5C PMIC@100C GPU@27.5C AO@32.5C thermal@28.75C
RAM 1861/1972MB (lfb 5x256kB) SWAP 2084/12096MB (cached 6MB) CPU [55%@1479,67%@1479,23%@1479,81%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25.5C CPU@30C PMIC@100C GPU@27.5C AO@32.5C thermal@28.5C
RAM 1859/1972MB (lfb 5x256kB) SWAP 2082/12096MB (cached 4MB) CPU [77%@1479,53%@1479,27%@1479,76%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25.5C CPU@30C PMIC@100C GPU@27.5C AO@32.5C thermal@28.5C
RAM 1859/1972MB (lfb 5x256kB) SWAP 2083/12096MB (cached 4MB) CPU [20%@1479,100%@1479,18%@1479,82%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@24.5C CPU@29.5C PMIC@100C GPU@27.5C AO@32C thermal@28.5C
RAM 1864/1972MB (lfb 5x256kB) SWAP 2082/12096MB (cached 9MB) CPU [37%@1479,96%@1479,70%@1479,21%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@29.5C PMIC@100C GPU@27.5C AO@32.5C thermal@28.75C
RAM 1858/1972MB (lfb 5x256kB) SWAP 2084/12096MB (cached 3MB) CPU [30%@1479,70%@1479,16%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@29.5C PMIC@100C GPU@27.5C AO@32C thermal@28.5C
RAM 1858/1972MB (lfb 5x256kB) SWAP 2082/12096MB (cached 3MB) CPU [35%@1479,22%@1479,71%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@24.5C CPU@29.5C PMIC@100C GPU@27.5C AO@32.5C thermal@28.5C
RAM 1864/1972MB (lfb 5x256kB) SWAP 2083/12096MB (cached 7MB) CPU [56%@1479,53%@1479,21%@1479,97%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25.5C CPU@29.5C PMIC@100C GPU@27.5C AO@32.5C thermal@28.5C
RAM 1858/1972MB (lfb 5x256kB) SWAP 2082/12096MB (cached 3MB) CPU [41%@1479,81%@1479,48%@1479,80%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@30C PMIC@100C GPU@27C AO@32.5C thermal@28.5C
RAM 1858/1972MB (lfb 5x256kB) SWAP 2084/12096MB (cached 3MB) CPU [24%@1479,15%@1479,100%@1479,69%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25.5C CPU@29.5C PMIC@100C GPU@27.5C AO@32C thermal@27.75C
RAM 1863/1972MB (lfb 5x256kB) SWAP 2083/12096MB (cached 7MB) CPU [17%@1479,7%@1479,100%@1479,81%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@30C PMIC@100C GPU@27C AO@32C thermal@28.25C
RAM 1859/1972MB (lfb 5x256kB) SWAP 2083/12096MB (cached 3MB) CPU [21%@1479,17%@1479,100%@1479,83%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@30C PMIC@100C GPU@27C AO@32C thermal@28.5C
RAM 1859/1972MB (lfb 5x256kB) SWAP 2083/12096MB (cached 4MB) CPU [18%@1479,91%@1479,100%@1479,8%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@29C PMIC@100C GPU@27C AO@31.5C thermal@28.5C
RAM 1860/1972MB (lfb 5x256kB) SWAP 2082/12096MB (cached 4MB) CPU [18%@1479,70%@1479,100%@1479,16%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@29.5C PMIC@100C GPU@27C AO@32C thermal@28.5C
RAM 1858/1972MB (lfb 5x256kB) SWAP 2084/12096MB (cached 3MB) CPU [30%@1479,70%@1479,77%@1479,55%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@25C CPU@29.5C PMIC@100C GPU@27C AO@31.5C thermal@28C
nano@nano:~$ ps -ax
  PID TTY      STAT   TIME COMMAND
    1 ?        Ds     2:22 /sbin/init 2
    2 ?        S      0:12 [kthreadd]
    3 ?        S      0:02 [ksoftirqd/0]
    5 ?        S<     0:00 [kworker/0:0H]
    7 ?        S      0:05 [rcu_preempt]
    8 ?        S      0:00 [rcu_sched]
    9 ?        S      0:00 [rcu_bh]
   10 ?        S      0:00 [migration/0]
   11 ?        S<     0:00 [lru-add-drain]
   12 ?        S      0:00 [watchdog/0]
   13 ?        S      0:00 [cpuhp/0]
   14 ?        S      0:00 [cpuhp/1]
   15 ?        S      0:00 [watchdog/1]
   16 ?        S      0:00 [migration/1]
   17 ?        S      0:00 [ksoftirqd/1]
   19 ?        S<     0:00 [kworker/1:0H]
   20 ?        S      0:00 [cpuhp/2]
   21 ?        S      0:00 [watchdog/2]
   22 ?        S      0:00 [migration/2]
   23 ?        S      0:00 [ksoftirqd/2]
   25 ?        S<     0:00 [kworker/2:0H]
   26 ?        S      0:00 [cpuhp/3]
   27 ?        S      0:00 [watchdog/3]
   28 ?        S      0:00 [migration/3]
   29 ?        S      0:00 [ksoftirqd/3]
   31 ?        S<     0:00 [kworker/3:0H]
   32 ?        S      0:00 [kdevtmpfs]
   33 ?        S<     0:00 [netns]
   96 ?        S      0:00 [irq/18-mc_statu]
  587 ?        S      0:00 [khungtaskd]
  588 ?        S      0:00 [oom_reaper]
  589 ?        S<     0:00 [writeback]
  591 ?        S      0:00 [kcompactd0]
  592 ?        SN     0:00 [ksmd]
  593 ?        SN     0:15 [khugepaged]
  594 ?        S<     0:00 [crypto]
  595 ?        S<     0:00 [kintegrityd]
  596 ?        S<     0:00 [bioset]
  598 ?        S<     0:00 [kblockd]
  618 ?        S<     0:00 [ata_sff]
  642 ?        S      0:00 [irq/353-max7762]
  692 ?        S<     0:00 [devfreq_wq]
  718 ?        S<     0:00 [watchdogd]
  736 ?        S      0:00 [nvmap-bz]
  827 ?        S<     0:00 [rpciod]
  828 ?        S<     0:00 [xprtiod]
  832 ?        S<     0:00 [host_low_prio_w]
  833 ?        S      0:01 [irq/69-host_syn]
  834 ?        S      0:00 [irq/70-host_sta]
  874 ?        D    182:47 [kswapd0]
  875 ?        S<     0:00 [vmstat]
  957 ?        S<     0:00 [SquashFS read w]
  960 ?        S<     0:00 [nfsiod]
 1000 ?        S<     0:00 [kthrotld]
 1086 ?        S<     0:00 [nvhdcp0]
 1106 ?        S<     0:00 [nvhdcp0]
 1125 ?        S      0:00 [tegradc.0/a]
 1136 ?        S      0:00 [tegradc.0/b]
 1137 ?        S      0:00 [tegradc.0/c]
 1138 ?        S      0:00 [tegradc.0/d]
 1139 ?        S      0:00 [tegradc.0/e]
 1141 ?        S      0:00 [tegradc.0/sl]
 1142 ?        S      0:56 [irq/74-tegradc.]
 1229 ?        S<     0:00 [bioset]
 1230 ?        S<     0:00 [bioset]
 1231 ?        S<     0:00 [bioset]
 1232 ?        S<     0:00 [bioset]
 1234 ?        S<     0:00 [bioset]
 1235 ?        S<     0:00 [bioset]
 1236 ?        S<     0:00 [bioset]
 1237 ?        S<     0:00 [bioset]
 1238 ?        S<     0:00 [bioset]
 1239 ?        S<     0:00 [bioset]
 1240 ?        S<     0:00 [bioset]
 1241 ?        S<     0:00 [bioset]
 1242 ?        S<     0:00 [bioset]
 1243 ?        S<     0:00 [bioset]
 1244 ?        S<     0:00 [bioset]
 1245 ?        S<     0:00 [bioset]
 1259 ?        S      0:00 [irq/322-tegradc]
 1282 ?        S<     0:00 [bioset]
 1285 ?        S<     0:00 [bioset]
 1288 ?        S<     0:00 [bioset]
 1291 ?        S<     0:00 [bioset]
 1294 ?        S<     0:00 [bioset]
 1297 ?        S<     0:00 [bioset]
 1300 ?        S<     0:00 [bioset]
 1303 ?        S<     0:00 [bioset]
 1312 ?        S<     0:00 [kworker/u9:0]
 1328 ?        S<     0:00 [nvme]
 1337 ?        S      0:00 [irq/66-7000d400]
 1338 ?        S      0:00 [spi0]
 1342 ?        S      0:00 [irq/67-7000d600]
 1344 ?        S      0:00 [spi1]
 1349 ?        S      0:00 [irq/68-70410000]
 1350 ?        S      0:00 [spi32766]
 1355 ?        S<     0:00 [bioset]
 1418 ?        S<     0:00 [ixgbe]
 1420 ?        S<     0:00 [mlxsw_core]
 1442 ?        S<     0:00 [vfio-irqfd-clea]
 1488 ?        S      0:00 [irq/19-tegra_rt]
 1521 ?        S      0:00 [irq/93-700e2000]
 1524 ?        S      0:00 [irq/94-soctherm]
 1540 ?        S      0:00 [irq/299-pwm-fan]
 1544 ?        S      0:00 [irq/96-60005100]
 1552 ?        S      0:00 [cfinteractive]
 1561 ?        S      0:00 [irq/90-mmc0]
 1670 ?        S      0:00 [irq/13-6000c800]
 1754 ?        S      0:00 [irq/298-sdhci-t]
 1783 ?        S<     0:00 [ipv6_addrconf]
 1785 ?        S<     0:00 [krfcommd]
 1862 ?        S<     0:00 [bioset]
 1863 ?        S     21:18 [mmcqd/0]
 1882 ?        S<     0:00 [kworker/3:1H]
 1886 ?        S<     0:00 [kworker/0:1H]
 1888 ?        S      0:06 [jbd2/mmcblk0p1-]
 1889 ?        S<     0:00 [ext4-rsv-conver]
 1900 ?        S<     0:00 [kworker/u9:1]
 1983 ?        D<s    2:21 /lib/systemd/systemd-journald
 1987 ?        S<     0:00 [kworker/1:1H]
 2068 ?        S      0:00 [kauditd]
 2148 ?        S      0:00 [irq/78-gk20a_st]
 2455 ?        Ss     0:16 /lib/systemd/systemd-udevd
 2924 ?        Ss     0:05 /usr/sbin/haveged --Foreground --verbose=1 -w 1024
 2926 ?        Ssl    0:01 /lib/systemd/systemd-timesyncd
 2944 ?        Ss     0:41 /lib/systemd/systemd-resolved
 2945 ?        Ss     0:01 /sbin/rpcbind -f -w
 3797 ?        Ssl    0:00 /usr/lib/udisks2/udisksd
 3853 ?        Ssl    0:00 /usr/bin/python3 /usr/bin/networkd-dispatcher --run-startup-triggers
 3883 ?        Ds     0:40 avahi-daemon: running [nano.local]
 3894 ?        Ssl    0:55 /usr/sbin/rsyslogd -n
 3928 ?        Ss     0:17 /usr/bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation --
 4018 ?        S      0:00 avahi-daemon: chroot helper
 4147 ?        Ss     0:58 /sbin/wpa_supplicant -u -s -O /run/wpa_supplicant
 4149 ?        Ssl    1:33 /usr/sbin/NetworkManager --no-daemon
 4164 ?        Ssl    0:10 /usr/lib/accountsservice/accounts-daemon
 4172 ?        Ss     0:04 /lib/systemd/systemd-logind
 4213 ?        Ssl    0:00 /usr/sbin/ModemManager --filter-policy=strict
 4226 ?        Ss     0:03 /usr/sbin/cron -f
 4290 ?        S<     0:00 [kworker/2:1H]
 4321 ?        Ssl    0:00 /usr/lib/policykit-1/polkitd --no-debug
 4393 ?        S      0:00 [sugov:0]
 4454 ?        S      0:00 [file-storage]
 4492 ?        S<     0:00 [loop0]
 4651 ?        S      0:00 [irq/60-70090000]
 4654 ?        S      0:00 [irq/62-70090000]
 4667 ?        Ssl    0:00 /usr/bin/whoopsie -f
 4702 ?        Ss     0:00 /usr/sbin/kerneloops --test
 4797 ?        Ss     0:01 /usr/sbin/kerneloops
 4804 ?        Ss     0:06 /bin/bash /etc/systemd/nvmemwarning.sh
 4816 ?        Ssl    0:00 /usr/sbin/nvs-service
 4840 ?        Ssl    9:30 /usr/bin/containerd
 4891 ttyS0    Ss+    0:00 /sbin/agetty -o -p -- \u --keep-baud 115200,38400,9600 ttyS0 vt220
 4959 ?        S      0:19 [nvgpu_channel_p]
 4968 ?        Ss     0:00 /usr/sbin/sshd -D
 4985 ?        S      0:00 /usr/sbin/xrdp-sesman
 5034 ?        Ssl    0:00 /usr/sbin/nvargus-daemon
 5084 ?        Ssl    0:00 /usr/sbin/lightdm
 5165 ?        S      0:00 /usr/sbin/xrdp
 5183 ?        S<     0:00 [bioset]
 5186 ?        S<     0:00 [bioset]
 5262 ?        Ss     0:00 /usr/sbin/nvphsd
 5264 ?        Sl     0:00 /usr/sbin/nvphsd
 5348 ttyGS0   Ss+    0:00 /sbin/agetty -o -p -- \u --keep-baud 115200,38400,9600 ttyGS0 vt220
 5349 ?        Ss     0:00 /bin/bash /etc/systemd/nvgetty.sh
 5413 ttyTHS1  Ss+    0:00 /sbin/getty -L 115200 ttyTHS1
 5475 ?        S<     0:00 [cfg80211]
 5490 ?        Ss     0:00 /lib/systemd/systemd --user
 5510 ?        S      0:00 (sd-pam)
 5616 ?        Ss     0:00 /usr/bin/dbus-daemon --session --address=systemd: --nofork --nopidfile --systemd-activation -
 5657 ?        Ssl    0:00 /usr/lib/gvfs/gvfsd
 5662 ?        Sl     0:00 /usr/lib/gvfs/gvfsd-fuse /run/user/1000/gvfs -f -o big_writes
 5672 ?        Ssl    0:00 /usr/lib/gvfs/gvfsd-metadata
 5739 ?        Ssl    0:00 /usr/lib/at-spi2-core/at-spi-bus-launcher
 5744 ?        S      0:00 /usr/bin/dbus-daemon --config-file=/usr/share/defaults/at-spi2/accessibility.conf --nofork --
 5772 ?        Ss     0:00 /usr/bin/ssh-agent -s
 5776 ?        Sl     0:00 /usr/lib/deja-dup/deja-dup-monitor
 5828 ?        Sl     0:02 zeitgeist-datahub
 5846 ?        Ssl    0:00 /usr/bin/zeitgeist-daemon
 5863 ?        Ssl    0:00 /usr/lib/zeitgeist/zeitgeist/zeitgeist-fts
 5924 ?        Ssl    0:00 /usr/lib/gvfs/gvfs-udisks2-volume-monitor
 5936 ?        SNsl   0:01 /usr/lib/rtkit/rtkit-daemon
 5978 ?        Ssl    0:00 /usr/lib/gvfs/gvfs-goa-volume-monitor
 5983 ?        Sl     0:00 /usr/lib/gnome-online-accounts/goa-daemon
 6007 ?        S      0:09 [RTW_CMD_THREAD]
 6023 ?        Ss     0:00 /usr/lib/bluetooth/bluetoothd -d --noplugin=audio,a2dp,avrcp
 6047 ?        Sl     0:00 /usr/lib/gnome-online-accounts/goa-identity-service
 6061 ?        Ssl    0:00 /usr/lib/gvfs/gvfs-afc-volume-monitor
 6069 ?        Ssl    0:00 /usr/lib/gvfs/gvfs-gphoto2-volume-monitor
 6078 ?        Ssl    0:00 /usr/lib/gvfs/gvfs-mtp-volume-monitor
 6148 ?        Sl     0:00 /usr/lib/gvfs/gvfsd-trash --spawner :1.3 /org/gtk/gvfs/exec_spaw/0
 6168 ?        Ss     0:22 /usr/sbin/dhcpd -cf /opt/nvidia/l4t-usb-device-mode/dhcpd.conf -pf /run/l4t-usb-devmode-dhcpd
 6175 ?        S      0:00 python3 /usr/share/nvpmodel_indicator/nvpmodel_indicator.py
 6176 ?        S      0:00 python3 /usr/share/nvpmodel_indicator/nvpmodel_indicator.py
 6185 ?        S      0:00 python3 /usr/share/nvpmodel_indicator/nvpmodel_indicator.py
 6190 ?        S      0:00 python3 /usr/share/nvpmodel_indicator/nvpmodel_indicator.py
 6191 ?        Dl     4:51 python3 /usr/share/nvpmodel_indicator/nvpmodel_indicator.py
 6192 ?        S      0:00 python3 /usr/share/nvpmodel_indicator/nvpmodel_indicator.py
 6194 ?        S      0:00 python3 /usr/share/nvpmodel_indicator/nvpmodel_indicator.py
 8039 ?        S      0:00 sudo docker run --runtime nvidia -it --rm --network host --volume /home/nano/nvdli-data:/nvdl
 8042 ?        Sl     2:10 docker run --runtime nvidia -it --rm --network host --volume /home/nano/nvdli-data:/nvdli-nan
 8049 ?        Ssl    4:43 /usr/bin/dockerd -H fd:// --containerd=/run/containerd/containerd.sock
 8503 ?        Sl     1:54 containerd-shim -namespace moby -workdir /var/lib/containerd/io.containerd.runtime.v1.linux/m
 8536 ?        Ss     0:00 /bin/sh -c /bin/bash -c "jupyter lab --ip 0.0.0.0 --port 8888 --allow-root &> /var/log/jupyte
 8593 ?        S      0:00 /bin/bash -c jupyter lab --ip 0.0.0.0 --port 8888 --allow-root &> /var/log/jupyter.log
 8595 ?        Dl     5:53 /usr/bin/python3 /usr/local/bin/jupyter-lab --ip 0.0.0.0 --port 8888 --allow-root
 8598 ?        S+     0:00 /bin/bash
 9617 ?        Dsl   15:17 /usr/bin/python3 -m ipykernel_launcher -f /root/.local/share/jupyter/runtime/kernel-0c6abe4e-
 9980 ?        Ssl    0:00 /usr/lib/upower/upowerd
10084 tty7     Ssl+   2:27 /usr/lib/xorg/Xorg -core :0 -seat seat0 -auth /var/run/lightdm/root/:0 -nolisten tcp vt7 -nov
10103 ?        Sl     0:00 lightdm --session-child 16 19
10106 ?        Ss     0:00 /lib/systemd/systemd --user
10107 ?        S      0:00 (sd-pam)
10123 ?        Ss     0:00 /bin/sh /usr/lib/lightdm/lightdm-greeter-session /usr/sbin/unity-greeter
10124 ?        RL   243:58 /usr/sbin/unity-greeter
10127 ?        Ss     0:00 /usr/bin/dbus-daemon --session --address=systemd: --nofork --nopidfile --systemd-activation -
10130 ?        Ssl    0:00 /usr/lib/gvfs/gvfsd
10131 ?        Ssl    0:00 /usr/lib/at-spi2-core/at-spi-bus-launcher
10138 ?        Sl     0:00 /usr/lib/gvfs/gvfsd-fuse /run/user/121/gvfs -f -o big_writes
10145 ?        S      0:00 /usr/bin/dbus-daemon --config-file=/usr/share/defaults/at-spi2/accessibility.conf --nofork --
10153 ?        Sl     0:00 /usr/lib/at-spi2-core/at-spi2-registryd --use-gnome-session
14276 ?        Ss     0:00 /bin/sh /usr/lib/apt/apt.systemd.daily install
14305 ?        Ss     0:00 sshd: nano [priv]
14311 ?        S      0:00 /bin/sh /usr/lib/apt/apt.systemd.daily lock_is_held install
14321 ?        D      6:09 apt-get check -qq
14453 ?        S      0:02 sshd: nano@pts/1
14454 pts/1    Ss     0:00 -bash
15930 ?        S      0:01 [kworker/2:1]
15956 ?        S      0:03 [kworker/1:1]
16055 ?        S      0:00 [kworker/3:2]
16058 ?        S      0:02 [kworker/0:2]
16143 ?        S      0:00 [kworker/u8:1]
16148 ?        S      0:00 [kworker/3:0]
16167 ?        S      0:00 [kworker/1:2]
16174 ?        S      0:00 [kworker/0:1]
16194 ?        S      0:00 [kworker/u8:0]
16206 ?        S      0:00 [kworker/2:2]
16211 tty1     Ss+    0:00 /sbin/agetty -o -p -- \u --noclear tty1 linux
16212 tty3     Ss+    0:00 /sbin/agetty -o -p -- \u --noclear tty3 linux
16238 ?        S      0:00 [kworker/3:1]
16239 ?        S      0:00 [kworker/0:0]
16241 tty2     Ss+    0:00 /sbin/agetty -o -p -- \u --noclear tty2 linux
16242 ?        S      0:00 [kworker/1:0]
16245 ?        S      0:00 sleep 300
16251 pts/1    R+     0:00 ps -ax
nano@nano:~$ dmesg -w
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.9.140-tegra (buildbrain@mobile-u64-4428) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Tue Oct 27 21:02:37 PDT 2020
[    0.000000] Boot CPU: AArch64 Processor [411fd071]
[    0.000000] OF: fdt:memory scan node memory@80000000, reg size 48,
[    0.000000] OF: fdt: - 80000000 ,  3f800000
[    0.000000] OF: fdt: - bfa00000 ,  3fe00000
[    0.000000] OF: fdt: - ffa00000 ,  600000
[    0.000000] Found tegra_fbmem: 00800000@92cb4000
[    0.000000] earlycon: uart8250 at MMIO32 0x0000000070006000 (options '')
[    0.000000] bootconsole [uart8250] enabled
[    0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb0_carveout': base 0x0000000000000000, size 0 MiB
[    0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb1_carveout': base 0x0000000000000000, size 0 MiB
[    0.000000] OF: reserved mem: initialized node iram-carveout, compatible id nvidia,iram-carveout
[    0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[    0.000000] cma: Reserved 64 MiB at 0x00000000fb800000
[    0.000000] On node 0 totalpages: 522752
[    0.000000]   DMA zone: 8192 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 522752 pages, LIFO batch:31
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.0 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] psci: SMC Calling Convention v1.1
[    0.000000] percpu: Embedded 25 pages/cpu @ffffffc07fe63000 s61656 r8192 d32552 u102400
[    0.000000] pcpu-alloc: s61656 r8192 d32552 u102400 alloc=25*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] CPU features: enabling workaround for ARM erratum 832075
[    0.000000] Speculative Store Bypass Disable mitigation not required
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 514560
[    0.000000] Kernel command line: tegraid=21.1.2.0.0 ddr_die=2048M@2048M section=256M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,2 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 core_edp_mv=1075 core_edp_ma=4000 tegra_fbmem=0x800000@0x92cb4000 is_hdmi_initialised=1  earlycon=uart8250,mmio32,0x70006000  root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 quiet root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[    0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[    0.000000] log_buf_len total cpu_extra contributions: 98304 bytes
[    0.000000] log_buf_len min size: 32768 bytes
[    0.000000] log_buf_len: 131072 bytes
[    0.000000] early log buf free: 29436(89%)
[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes)
[    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes)
[    0.000000] Memory: 1939708K/2091008K available (15294K kernel code, 2936K rwdata, 6644K rodata, 8576K init, 611K bss, 85764K reserved, 65536K cma-reserved)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     modules : 0xffffff8000000000 - 0xffffff8008000000   (   128 MB)
[    0.000000]     vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000   (   250 GB)
[    0.000000]       .text : 0xffffff8008080000 - 0xffffff8008f70000   ( 15296 KB)
[    0.000000]     .rodata : 0xffffff8008f70000 - 0xffffff8009600000   (  6720 KB)
[    0.000000]       .init : 0xffffff8009600000 - 0xffffff8009e60000   (  8576 KB)
[    0.000000]       .data : 0xffffff8009e60000 - 0xffffff800a13e008   (  2937 KB)
[    0.000000]        .bss : 0xffffff800a13e008 - 0xffffff800a1d6f7c   (   612 KB)
[    0.000000]     fixed   : 0xffffffbefe7fd000 - 0xffffffbefec00000   (  4108 KB)
[    0.000000]     PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000   (    16 MB)
[    0.000000]     vmemmap : 0xffffffbf00000000 - 0xffffffc000000000   (     4 GB maximum)
[    0.000000]               0xffffffbf00000000 - 0xffffffbf02000000   (    32 MB actual)
[    0.000000]     memory  : 0xffffffc000000000 - 0xffffffc080000000   (  2048 MB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000]  Build-time adjustment of leaf fanout to 64.
[    0.000000]  RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
[    0.000000] NR_IRQS:64 nr_irqs:64 0
[    0.000000] /interrupt-controller@60004000: 192 interrupts forwarded to /interrupt-controller
[    0.000000] t210 clock and reset probe
[    0.000000] tegra-pmc: get_secure_pmc_setting: done secure_pmc=1
[    0.000000] clk_cbus_recalc_rate: no gbus parent
[    0.000000] arm_arch_timer: Architected cp15 timer(s) running at 19.20MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[    0.000006] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[    0.001847] Console: colour dummy device 80x25
[    0.001856] console [tty0] enabled
[    0.001863] bootconsole [uart8250] disabled
[    0.001881] kmemleak: Kernel memory leak detector disabled
[    0.001900] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=76800)
[    0.001913] pid_max: default: 32768 minimum: 301
[    0.002373] Security Framework initialized
[    0.002598] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes)
[    0.002604] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes)
[    0.003722] ftrace: allocating 47119 entries in 185 pages
[    0.173157] sched-energy: CPU device node has no sched-energy-costs
[    0.173191] ASID allocator initialised with 65536 entries
[    0.212601] tegra-id: chipid=22117.
[    0.212614] tegra-id: opt_subrevision=0.
[    0.212631] Tegra Speedo/IDDQ fuse revision 4
[    0.212635] Tegra: CPU Speedo ID 9, SoC Speedo ID 0, GPU Speedo ID 2
[    0.212639] Tegra: CPU Process ID 0, SoC Process ID 1, GPU Process ID 0
[    0.212645] Tegra: CPU Speedo Value 2104, SoC Speedo Value 2029, GPU Speedo Value 2120
[    0.212648] Tegra: CPU IDDQ Value 2544, SoC IDDQ Value 3016, GPU IDDQ Value 3725
[    0.212668] Tegra Revision: A02 SKU: 0x8f CPU Process: 0 SoC Process: 1
[    0.212684] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t210/batuu/kernel-dts/tegra210-p3448-0003-p3542-0000.dts
[    0.212691] DTB Build time: Oct 27 2020 21:08:33
[    0.261098] CPU1: Booted secondary processor [411fd071]
[    0.293003] CPU2: Booted secondary processor [411fd071]
[    0.324969] CPU3: Booted secondary processor [411fd071]
[    0.325063] Brought up 4 CPUs
[    0.325071] SMP: Total of 4 processors activated.
[    0.325079] CPU features: detected feature: 32-bit EL0 Support
[    0.325338] CPU: All CPU(s) started at EL2
[    0.325356] alternatives: patching kernel code
[    0.333130] devtmpfs: initialized
[    0.374426] Initilizing CustomIPI irq domain
[    0.374841] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.374863] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    0.376706] pinctrl core: initialized pinctrl subsystem
[    0.377186] OS set in device tree is not L4T.
[    0.377564] regulator-dummy: no parameters
[    0.377822] Initializing plugin-manager
[    0.377967] Plugin module not found
[    0.378303] node /plugin-manager/fragment@1 match with board >=3448-0003-400
[    0.379376] node /plugin-manager/fragement@6 match with odm-data enable-tegra-wdt
[    0.379762] node /plugin-manager/fragement@8 match with odm-data enable-tegra-wdt
[    0.380151] node /plugin-manager/fragement@9 match with board >=3448-0003-000
[    0.381549] node /plugin-manager/fragment@12 match with board >=3448-0003-400
[    0.381815] node /plugin-manager/fragement@13 match with board >=3448-0003-400
[    0.385686] NET: Registered protocol family 16
[    0.387064] pstore: using zlib compression
[    0.387099] console [pstore-1] enabled
[    0.387105] pstore: Registered ramoops as persistent store backend
[    0.387111] ramoops: attached 0x200000@0xb0000000, ecc: 0/0
[    0.401119] cpuidle: using governor menu
[    0.404424] tegra_smmu 70019000.iommu: Loaded Tegra IOMMU driver
[    0.406393] vdso: 2 pages (1 code @ ffffff8008f77000, 1 data @ ffffff8009e64000)
[    0.406417] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.409655] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[    0.412384] Serial: AMBA PL011 UART driver
[    0.412916] tegra_powergate_init: DONE
[    0.412932] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t210/batuu/kernel-dts/tegra210-p3448-0003-p3542-0000.dts
[    0.412939] DTB Build time: Oct 27 2020 21:08:33
[    0.415106] Tegra reboot handler registered.
[    0.419733] iommu: Adding device tegra-carveouts to group 0
[    0.419845] platform tegra-carveouts: domain=ffffffc078bf0258 allocates as[0]=ffffffc078bf40a8
[    0.420204] iommu: Adding device smmu_test to group 1
[    0.420255] platform smmu_test: domain=ffffffc078bf0498 allocates as[0]=ffffffc078bf4110
[    0.421074] mc: mapped MMIO address: 0xffffff800802e000 -> 0x70019000
[    0.421167] mc: mapped MMIO address: 0xffffff8008065000 -> 0x7001c000
[    0.421225] mc: mapped MMIO address: 0xffffff8008079000 -> 0x7001d000
[    0.421236] nv-tegra-mc 70019000.mc: No mssnvlink node
[    0.421272] mc-err: mcerr ops are set to t21x
[    0.430718] iommu: Adding device 70090000.xusb to group 2
[    0.431019] iommu: Adding device 70006000.serial to group 3
[    0.431075] platform 70006000.serial: domain=ffffffc078b7bb58 allocates as[0]=ffffffc078bf4178
[    0.431511] iommu: Adding device 70006040.serial to group 4
[    0.431779] iommu: Adding device 70006200.serial to group 5
[    0.431973] iommu: Adding device sound to group 6
[    0.432022] platform sound: domain=ffffffc0784d30d8 allocates as[0]=ffffffc078bf41e0
[    0.432596] iommu: Adding device 7000d400.spi to group 7
[    0.432860] iommu: Adding device 7000d600.spi to group 8
[    0.433185] iommu: Adding device 70410000.spi to group 9
[    0.433498] iommu: Adding device 50000000.host1x to group 10
[    0.433768] iommu: Adding device 54080000.vi to group 11
[    0.434169] iommu: Adding device 54600000.isp to group 12
[    0.434457] iommu: Adding device 54680000.isp to group 13
[    0.434725] iommu: Adding device tegradc.0 to group 14
[    0.434777] platform tegradc.0: domain=ffffffc07853a018 allocates as[0]=ffffffc078bf4248
[    0.438932] platform tegradc.0: IOVA linear map 0x0000000092cb4000(800000)
[    0.439199] iommu: Adding device 54340000.vic to group 15
[    0.439398] iommu: Adding device 544c0000.nvenc to group 16
[    0.439619] iommu: Adding device 54500000.tsec to group 17
[    0.439810] iommu: Adding device 54100000.tsecb to group 18
[    0.439998] iommu: Adding device 54480000.nvdec to group 19
[    0.440182] iommu: Adding device 54380000.nvjpg to group 20
[    0.440883] iommu: Adding device 546c0000.i2c to group 21
[    0.441245] iommu: Adding device 57000000.gpu to group 22
[    0.441296] platform 57000000.gpu: domain=ffffffc07853ae58 allocates as[0]=ffffffc078bf42b0
[    0.441333] platform 57000000.gpu: domain=ffffffc07853ae58 allocates as[1]=ffffffc078bf4318
[    0.441368] platform 57000000.gpu: domain=ffffffc07853ae58 allocates as[2]=ffffffc078bf4380
[    0.441424] platform 57000000.gpu: domain=ffffffc07853ae58 allocates as[3]=ffffffc078bf43e8
[    0.442312] tegra-pmc 7000e400.pmc: i2c-thermtrip node not found, emergency thermal reset disabled.
[    0.442324] tegra-pmc 7000e400.pmc: scratch reg offset dts data not present
[    0.442336] tegra-pmc: ### PMC reset source: TEGRA_POWER_ON_RESET
[    0.442341] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_WARM
[    0.442345] tegra-pmc: ### PMC reset status reg: 0x0
[    0.493269] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[    0.493276] tegra-pmc: Clear bootloader IO dpd settings
[    0.493295] tegra-pmc 7000e400.pmc: IO padctrl driver initialized
[    0.493363] tegra-pmc 7000e400.pmc: PMC: Successfully configure bootrom reset commands
[    0.493656] iommu: Adding device 70012000.se to group 23
[    0.494407] iommu: Adding device 7000c000.i2c to group 24
[    0.494667] iommu: Adding device 7000c400.i2c to group 25
[    0.494945] iommu: Adding device 7000c500.i2c to group 26
[    0.495208] iommu: Adding device 7000c700.i2c to group 27
[    0.495457] iommu: Adding device 7000d000.i2c to group 28
[    0.495702] iommu: Adding device 7000d100.i2c to group 29
[    0.495995] iommu: Adding device sdhci-tegra.0 to group 30
[    0.496048] platform sdhci-tegra.0: domain=ffffffc0785a4018 allocates as[0]=ffffffc078bf4450
[    0.496869] iommu: Adding device 700d0000.xudc to group 31
[    0.500231] vdd-ac-bat: 5000 mV
[    0.500602] vdd-5v0-sys: 5000 mV
[    0.501577] vdd-5v0-hdmi: supplied by vdd-5v0-sys
[    0.501615] vdd-5v0-hdmi: 5000 mV
[    0.502010] vdd-1v8-sys: 1800 mV
[    0.502452] vdd-fan: supplied by vdd-5v0-sys
[    0.502512] vdd-fan: 5000 mV
[    0.502919] vdd-usb-vbus: supplied by vdd-5v0-sys
[    0.502953] vdd-usb-vbus: 5000 mV
[    0.503459] vdd-usb-vbus2: 5000 mV
[    0.534363] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[    0.536919] gpio gpiochip0: gpio-line-names specifies 240 line names but there are 256 lines on the chip
[    0.539271] GPIO line 151 (camera-control-output-low) hogged as output/low
[    0.539293] GPIO line 152 (camera-control-output-low) hogged as output/low
[    0.539331] GPIO line 6 (system-suspend-gpio) hogged as output/high
[    0.539713] gpiochip_setup_dev: registered GPIOs 0 to 255 on device: gpiochip0 (tegra-gpio)
[    0.547638] eventlib_kernel: keventlib is initialized, test id: 0
[    0.547998] SCSI subsystem initialized
[    0.548227] libata version 3.00 loaded.
[    0.548553] usbcore: registered new interface driver usbfs
[    0.548603] usbcore: registered new interface driver hub
[    0.548687] usbcore: registered new device driver usb
[    0.552684] max77620 4-003c: PMIC Version OTP:0x35 and ES:0x8
[    0.557229] vdd-core: 600 <--> 1162 mV at 1075 mV
[    0.558270] random: fast init done
[    0.558277] vdd-ddr-1v1: Bringing 1125000uV into 1150000-1150000uV
[    0.561022] vdd-ddr-1v1: 1150 mV
[    0.565021] vdd-pre-reg-1v35: 1350 mV
[    0.569023] vdd-1v8: 1800 mV
[    0.573019] avdd-sys-1v2: 1200 mV
[    0.577019] vdd-pex-1v0: 1050 mV
[    0.577661] vddio-sdmmc-ap: 1800 <--> 3300 mV at 3300 mV
[    0.578211] max77620-ldo3: at 3100 mV
[    0.581021] vdd-rtc: 850 <--> 1100 mV at 1000 mV
[    0.581592] max77620-ldo5: at 3100 mV
[    0.582141] max77620-ldo6: at 2800 mV
[    0.585020] avdd-1v05-pll: 1050 mV
[    0.589018] avdd-io-hdmi-dp: 1050 mV
[    0.591704] GPIO line 505 (spmic-default-output-high) hogged as output/high
[    0.592025] gpiochip_setup_dev: registered GPIOs 504 to 511 on device: gpiochip1 (max77620-gpio)
[    0.592367] max77620 4-003c: max77620 probe successful
[    0.595085] media: Linux media interface: v0.10
[    0.595148] Linux video capture interface: v2.00
[    0.596132] pps_core: LinuxPPS API ver. 1 registered
[    0.596139] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.596161] PTP clock support registered
[    0.599473] tegra210-emc 7001b000.external-memory-controller: validated EMC DFS table
[    0.600388] Advanced Linux Sound Architecture Driver Initialized.
[    0.601068] Bluetooth: Core ver 2.22
[    0.601120] NET: Registered protocol family 31
[    0.601124] Bluetooth: HCI device and connection manager initialized
[    0.601140] Bluetooth: HCI socket layer initialized
[    0.601150] Bluetooth: L2CAP socket layer initialized
[    0.601178] Bluetooth: SCO socket layer initialized
[    0.602993] tegra210_dvfs: no clock found for sdmmc2_ddr
[    0.603010] tegra210_dvfs: no clock found for sdmmc4_ddr
[    0.603059] tegra210_dvfs: no clock found for sdmmc1_ddr
[    0.603074] tegra210_dvfs: no clock found for sdmmc3_ddr
[    0.607055] tegra_dvfs: Unable to get vdd-cpu rail for step info, defering probe
[    0.608299] vdd-3v3-sys: supplied by vdd-5v0-sys
[    0.608364] vdd-3v3-sys: 3300 mV
[    0.608675] vdd-1v8-sys: supplied by vdd-3v3-sys
[    0.612310] vdd-usb-vbus2: supplied by vdd-3v3-sys
[    0.612783] vdd-3v3-sd: supplied by vdd-3v3-sys
[    0.612823] vdd-3v3-sd: 3300 mV
[    0.613903] avdd-io-edp-1v05: supplied by avdd-1v05-pll
[    0.613974] avdd-io-edp-1v05: 1050 mV
[    0.614414] vdd-usb-hub-en: supplied by vdd-1v8-sys
[    0.614449] vdd-usb-hub-en: 5000 mV
[    0.615783] camchar: rtcpu character device driver loaded
[    0.616540] extcon-gpio-states extcon:extcon@1: Cable state:1, cable id:1
[    0.617976] clocksource: Switched to clocksource arch_sys_counter
[    0.658800] VFS: Disk quotas dquot_6.6.0
[    0.658926] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.659412] nvmap_heap_init: nvmap_heap_init: created heap block cache
[    0.659835] nvmap: nvmap_select_cache_ops() nvmap cache ops set to set/ways
[    0.659845] nvmap_page_pool_init: Total RAM pages: 501311
[    0.659850] nvmap_page_pool_init: nvmap page pool size: 62663 pages (244 MB)
[    0.659983] nvmap_background_zero_thread: PP zeroing thread starting.
[    0.660245] misc nvmap: iram :dma coherent mem declare 0x0000000040001000,258048
[    0.660408] misc nvmap: created heap iram base 0x0000000040001000 size (252KiB)
[    0.669820] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type AO-therm
[    0.670406] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type CPU-therm
[    0.670822] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[    0.671114] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[    0.671298] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type PMIC-Die
[    0.671584] pre_t19x_iso_plat_init(): iso emc max clk=1600000KHz
[    0.671590] pre_t19x_iso_plat_init(): max_iso_bw=11520000KB
[    0.672050] NET: Registered protocol family 2
[    0.673041] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[    0.673153] TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
[    0.673427] TCP: Hash tables configured (established 16384 bind 16384)
[    0.673576] UDP hash table entries: 1024 (order: 3, 32768 bytes)
[    0.673619] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[    0.674040] NET: Registered protocol family 1
[    0.674811] RPC: Registered named UNIX socket transport module.
[    0.674818] RPC: Registered udp transport module.
[    0.674822] RPC: Registered tcp transport module.
[    0.674826] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.674842] PCI: CLS 0 bytes, default 64
[    0.675083] Trying to unpack rootfs image as initramfs...
[    0.906185] Freeing initrd memory: 5356K
[    0.916142] host1x 50000000.host1x: initialized
[    0.918051] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[    0.921370] audit: initializing netlink subsys (disabled)
[    0.921439] audit: type=2000 audit(0.767:1): initialized
[    0.922270] workingset: timestamp_bits=46 max_order=19 bucket_order=0
[    0.932204] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.933644] ntfs: driver 2.1.32 [Flags: R/W].
[    0.934478] 9p: Installing v9fs 9p2000 file system support
[    0.937823] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[    0.938085] io scheduler noop registered
[    0.938397] io scheduler cfq registered (default)
[    0.941106] gic 702f9000.agic: GIC IRQ controller registered
[    0.944146] iommu: Adding device 702ef000.adsp to group 32
[    0.953033] iommu: Adding device aconnect@702c0000:adsp_audio to group 33
[    0.953184] tegra-aconnect aconnect@702c0000: Tegra ACONNECT bus registered
[    0.953767] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_SKU_CALIB_0 = 0x9aa9c14
[    0.953775] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_USB_CALIB_EXT_0 = 0x4
[    0.955539] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.0, lane = usb2-0, function = xusb
[    0.955641] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.1, lane = usb2-1, function = xusb
[    0.955740] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.2, lane = usb2-2, function = xusb
[    0.955934] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.3, lane = pcie-0, function = pcie-x1
[    0.956022] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.4, lane = pcie-1, function = pcie-x4
[    0.956115] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.5, lane = pcie-2, function = pcie-x4
[    0.956201] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.6, lane = pcie-3, function = pcie-x4
[    0.956294] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.7, lane = pcie-4, function = pcie-x4
[    0.956379] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.8, lane = pcie-5, function = xusb
[    0.956474] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.9, lane = pcie-6, function = xusb
[    0.957100] tegra-xusb-padctl 7009f000.xusb_padctl: failed to setup XUSB ports: -517
[    0.963587] tegra-pwm 7000a000.pwm: PWM clk cannot sleep in ops
[    0.965305] tegra-dfll-pwm 70110000.pwm: DFLL pwm-rate: 12800000
[    0.967169] tegra-pcie 1003000.pcie: 4x1, 1x1 configuration
[    0.967208] tegra-pcie 1003000.pcie: PHY get deferred: -517
[    0.967215] tegra-pcie 1003000.pcie: failed to get PHYs: -517
[    0.968554] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[    0.968775] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1500000, vi_iso_bw=750000, max_bw=1500000
[    0.969039] Adding domain tsec-pd to PM domain host1x-pd
[    0.972348] tsec 54500000.tsec: initialized
[    0.973722] tsec 54100000.tsecb: initialized
[    0.974487] Adding domain nvdec-pd to PM domain host1x-pd
[    0.978186] nvdec 54480000.nvdec: initialized
[    0.979343] Adding domain vic03-pd to PM domain host1x-pd
[    0.979526] Adding domain msenc-pd to PM domain host1x-pd
[    0.979692] Adding domain nvjpg-pd to PM domain host1x-pd
[    0.984391] falcon 54340000.vic: initialized
[    0.985649] falcon 544c0000.nvenc: initialized
[    0.987130] falcon 54380000.nvjpg: initialized
[    0.991777] tegra_cec 70015000.tegra_cec: dt=1 start=0x70015000 end=0x70015FFF irq=95
[    0.991818] tegra_cec 70015000.tegra_cec: Enable clock result: 0.
[    0.991857] tegra_cec 70015000.tegra_cec: tegra_cec_init started
[    0.991947] tegradc tegradc.0: disp0 connected to head0->/host1x/sor1
[    0.992056] display board info: id 0x0, fab 0x0
[    0.992120] generic_infoframe_type: 0x87
[    0.992209] tegra_cec 70015000.tegra_cec: cec_add_sysfs ret=0
[    0.992215] tegra_cec 70015000.tegra_cec: probed
[    0.992303] tegradc tegradc.0: DT parsed successfully
[    0.992356] tegradc tegradc.0: Display dc.ffffff800ab80000 registered with id=0
[    0.992955] tegradc tegradc.0: Bootloader disp_param detected. Detected mode: 1920x1080 (on 0x0mm) pclk=148350781
[    0.999968] tegra-apbdma 60020000.dma: Tegra20 APB DMA driver register 32 channels
[    1.000903] tegradc tegradc.0: probed
[    1.006440] tegra-adma 702e2000.adma: Tegra210 ADMA driver registered 22 channels
[    1.007920] tegra-fuse-burn 7000f800.efuse:efuse-burn: shutdown limit check disabled
[    1.007930] tegra-fuse-burn 7000f800.efuse:efuse-burn: Fuse burn driver initialized
[    1.008350] kfuse 7000fc00.kfuse: initialized
[    1.010018] tegra-pmc-iopower pmc-iopower: Regulator supply iopower-dbg-supply not available
[    1.011055] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[    1.012694] tegra-dfll-pwm 70110000.pwm: DFLL_PWM regulator is available now
[    1.012719] vdd-cpu: 708 <--> 1322 mV at 708 mV
[    1.013256] pwm-regulator pwm_regulators:pwm-regulator@0: PWM regulator registration passed
[    1.014976] vdd-gpu: applied init 1000000uV constraint
[    1.014990] vdd-gpu: 708 <--> 1323 mV at 997 mV
[    1.015449] pwm-regulator pwm_regulators:pwm-regulator@1: PWM regulator registration passed
[    1.020320] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    1.020490] No Device Node present for smmu client: serial8250 !!
[    1.020501] platform serial8250: No iommus property found in DT node, got swgids from fixup(101004000)
[    1.020571] iommu: Adding device serial8250 to group 34
[    1.024135] console [ttyS0] disabled
[    1.024268] 70006000.serial: ttyS0 at MMIO 0x70006000 (irq = 63, base_baud = 25500000) is a Tegra
[    1.024431] console [ttyS0] enabled
[    1.025690] 70006040.serial: ttyTHS1 at MMIO 0x70006040 (irq = 64, base_baud = 0) is a TEGRA_UART
[    1.026205] serial-tegra 70006200.serial: RX in PIO mode
[    1.026345] 70006200.serial: ttyTHS2 at MMIO 0x70006200 (irq = 65, base_baud = 0) is a TEGRA_UART
[    1.027505] [drm] Initialized
[    1.034033] Console: switching to colour frame buffer device 240x67
[    1.034222] tegradc tegradc.0: fb registered
[    1.039311] brd: module loaded
[    1.042069] tegradc tegradc.0: DC initialized, skipping tegra_dc_program_mode.
[    1.042128] tegradc tegradc.0: hdmi: tmds rate:148351K prod-setting:prod_c_hdmi_75m_150m
[    1.042668] tegradc tegradc.0: hdmi: get RGB quant from REG programmed by BL.
[    1.042682] tegradc tegradc.0: hdmi: get YCC quant from REG programmed by BL.
[    1.044955] loop: module loaded
[    1.045064] tegra_profiler: version: 1.141, samples/io: 48/28
[    1.045188] tegra_profiler: auth: init
[    1.046531] THERMAL EST: found 2 subdevs
[    1.046541] THERMAL EST num_resources: 0
[    1.046546] [THERMAL EST subdev 0]
[    1.046553] [THERMAL EST subdev 1]
[    1.047020] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type thermal-fan-est
[    1.047024] THERMAL EST: thz register success.
[    1.047184] THERMAL EST: end of probe, return err: 0
[    1.048341] sd: No Scsi addr parsed to reserve index
[    1.048381] hisi_sas: driver version v1.6
[    1.053268] tegra-qspi 70410000.spi: Prod settings list not found
[    1.054602] qspi_mtd spi32766.0: MX25U3235F (4096 Kbytes)
[    1.054614] qspi_mtd spi32766.0: mtd .name = spi32766.0, .size = 0x400000 (4MiB) .erasesize = 0x00001000 (4KiB) .numeraseregions = 0
[    1.057675] libphy: Fixed MDIO Bus: probed
[    1.058470] tun: Universal TUN/TAP device driver, 1.6
[    1.058478] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    1.059570] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[    1.059575] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    1.059639] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[    1.059643] igb: Copyright (c) 2007-2014 Intel Corporation.
[    1.059691] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[    1.059695] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[    1.059751] Intel(R) 10GbE PCI Express Linux Network Driver - version 4.6.4
[    1.059756] Copyright(c) 1999 - 2017 Intel Corporation.
[    1.060986] PPP generic driver version 2.4.2
[    1.061211] PPP BSD Compression module registered
[    1.061217] PPP Deflate Compression module registered
[    1.061261] PPP MPPE Compression module registered
[    1.061268] NET: Registered protocol family 24
[    1.061344] usbcore: registered new interface driver r8152
[    1.061390] usbcore: registered new interface driver asix
[    1.061437] usbcore: registered new interface driver ax88179_178a
[    1.061475] usbcore: registered new interface driver cdc_ether
[    1.061520] usbcore: registered new interface driver net1080
[    1.061553] usbcore: registered new interface driver cdc_subset
[    1.061587] usbcore: registered new interface driver zaurus
[    1.061635] usbcore: registered new interface driver cdc_ncm
[    1.061820] VFIO - User Level meta-driver version: 0.3
[    1.063590] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.063612] ehci-pci: EHCI PCI platform driver
[    1.063658] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    1.063671] ohci-pci: OHCI PCI platform driver
[    1.063719] ohci-platform: OHCI generic platform driver
[    1.065525] usbcore: registered new interface driver uas
[    1.065590] usbcore: registered new interface driver usb-storage
[    1.065720] usbcore: registered new interface driver usbserial
[    1.069126] extcon-disp-state extcon:disp-state: cable 47 state 1
[    1.069140] Extcon AUX1(HDMI) enable
[    1.070355] mousedev: PS/2 mouse device common for all mice
[    1.070468] usbcore: registered new interface driver xpad
[    1.115974] tegradc tegradc.0: nominal-pclk:148351648 parent:148350781 div:1.0 pclk:148350781 146868084~161703244
[    1.199298] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[    1.201473] tegradc tegradc.0: blank - powerdown
[    1.201527] rtc rtc1: alarm rtc device
[    1.201539] tegra_rtc 7000e000.rtc: rtc core: registered 7000e000.rtc as rtc1
[    1.201555] tegra_rtc 7000e000.rtc: Tegra internal Real Time Clock
[    1.201994] i2c /dev entries driver
[    1.203531] imx219 6-0010: tegracam sensor driver:imx219_v2.0.6
[    1.226818] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x10
[    1.226894] imx219 6-0010: imx219_board_setup: error during i2c read probe (-121)
[    1.226922] imx219 6-0010: board setup failed
[    1.226982] imx219: probe of 6-0010 failed with error -121
[    1.227881] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[    1.229812] tegra_soctherm 700e2000.soctherm: pllx_offset tz:0 max:14, min:2
[    1.229816] tegra_soctherm 700e2000.soctherm: pllx_offset tz:2 max:8, min:4
[    1.230141] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[    1.230153] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when cpu reaches 102500 mC
[    1.230161] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when cpu reaches 100500 mC
[    1.230292] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[    1.230302] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when gpu reaches 103000 mC
[    1.230308] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when gpu reaches 101000 mC
[    1.230453] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[    1.230462] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when pll reaches 127000 mC
[    1.230466] tegra_soctherm 700e2000.soctherm: throttrip: pll: missing hot temperature
[    1.230639] tegra_soctherm 700e2000.soctherm: failed to register sensor: -19
[    1.231200] tegra_aotag tegra-aotag: Registering sensor 0
[    1.231245] tegra_aotag tegra-aotag: Invalid temp readout
[    1.231266] tegra_aotag tegra-aotag: Invalid temp readout
[    1.231282] tegra_aotag tegra-aotag: Bound to TZ : ID 0
[    1.231291] tegra_aotag tegra-aotag: Probe done [SUCCESS]:0
[    1.232033] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[    1.232047] tegra_dfll_action dfll-cdev-cap: Tegra DFLL 'cap cooling device' registered
[    1.232184] tegra_aotag tegra-aotag: Invalid temp readout
[    1.232206] tegra_dfll_action dfll-cdev-floor: Tegra DFLL 'floor cooling device' registered
[    1.232535] parse_throttle_dt_data: Num cap clks = 6
[    1.232538] parse_throttle_dt_data: clk=cclk_g type=2
[    1.232545] parse_throttle_dt_data: clk=gpu type=4
[    1.232565] parse_throttle_dt_data: clk=cap.throttle.c2bus type=0
[    1.232581] parse_throttle_dt_data: clk=cap.throttle.c3bus type=0
[    1.232599] parse_throttle_dt_data: clk=cap.throttle.sclk type=0
[    1.232602] parse_throttle_dt_data: clk=emc type=3
[    1.232974] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[    1.233064] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[    1.233166] tegra_throttle_probe: probe successful. #cdevs=4
[    1.233830] FAN dev name: pwm-fan
[    1.233878] FAN:gpio request success.
[    1.233935] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[    1.234194] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
[    1.234311] pwm_fan_driver pwm-fan: fan tach request irq success
[    1.234317] pwm_fan_driver pwm-fan: tach period: 1000
[    1.234391] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[    1.234395] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[    1.234399] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[    1.234403] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[    1.234407] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[    1.234411] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[    1.234415] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[    1.234419] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[    1.234423] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[    1.234427] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[    1.234995] tegra-wdt 60005100.watchdog: Tegra WDT enabled on probe. Timeout = 120 seconds.
[    1.235220] tegra-wdt 60005100.watchdog: initialized (timeout = 120 sec, nowayout = 1)
[    1.235921] device-mapper: uevent: version 1.0.3
[    1.236309] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[    1.239044] tegra210-cpufreq cpufreq: probe()...completed
[    1.239755] sdhci: Secure Digital Host Controller Interface driver
[    1.239756] sdhci: Copyright(c) Pierre Ossman
[    1.239758] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.240229] sdhci-tegra sdhci-tegra.0: Got CD GPIO
[    1.240567] sdhci-tegra sdhci-tegra.0: Client registration for eMC Successful
[    1.240694] sdhci-tegra sdhci-tegra.0: wakeup init done, cdirq 298
[    1.245237] tegra-se 70012000.se: tegra_se_probe: complete
[    1.245752] hidraw: raw HID events driver (C) Jiri Kosina
[    1.247105] usbcore: registered new interface driver usbhid
[    1.247106] usbhid: USB HID core driver
[    1.248101] tegra21x_actmon 6000c800.actmon: in actmon_register()...
[    1.248270] tegra21x_actmon 6000c800.actmon: initialization Completed for the device mc_all
[    1.250200] nvpmodel: initialized successfully
[    1.250317] extcon-disp-state extcon:disp-state: cable 47 state 0
[    1.250319] Extcon AUX1(HDMI) disable
[    1.251339] usbcore: registered new interface driver snd-usb-audio
[    1.251396] No Device Node present for smmu client: snd-soc-dummy !!
[    1.251400] platform snd-soc-dummy: No iommus property found in DT node, got swgids from fixup(101004000)
[    1.251417] iommu: Adding device snd-soc-dummy to group 35
[    1.263566] input: tegra-hda HDMI/DP,pcm=3 as /devices/70030000.hda/sound/card0/input0
[    1.272490] OPE platform probe
[    1.272578] OPE platform probe successful
[    1.272831] OPE platform probe
[    1.272915] OPE platform probe successful
[    1.277926] tegradc tegradc.0: unblank
[    1.290169] mmc0: SDHCI controller on sdhci-tegra.0 [sdhci-tegra.0] using ADMA 64-bit with 64 bit addr
[    1.296624] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[    1.296756] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[    1.296908] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[    1.297033] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[    1.297165] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[    1.297317] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[    1.297444] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[    1.297568] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[    1.297710] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[    1.297838] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[    1.309467] u32 classifier
[    1.309468]     Actions configured
[    1.309539] Initializing XFRM netlink socket
[    1.310262] NET: Registered protocol family 10
[    1.310988] NET: Registered protocol family 17
[    1.310998] NET: Registered protocol family 15
[    1.311070] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[    1.311115] Bluetooth: RFCOMM socket layer initialized
[    1.311124] Bluetooth: RFCOMM ver 1.11
[    1.311129] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    1.311135] Bluetooth: HIDP socket layer initialized
[    1.311152] 9pnet: Installing 9P2000 support
[    1.311187] Key type dns_resolver registered
[    1.311566] Registered cp15_barrier emulation handler
[    1.311571] Registered setend emulation handler
[    1.312626] registered taskstats version 1
[    1.313154] Adding domain ve2-pd to PM domain host1x-pd
[    1.313402] Adding domain ve-pd to PM domain host1x-pd
[    1.315520] isp 54600000.isp: initialized
[    1.316472] isp 54680000.isp: initialized
[    1.326692] tegradc tegradc.0: nominal-pclk:332180000 parent:332178125 div:1.0 pclk:332178125 328858200~362076200
[    1.326726] last reset is due to power on reset
[    1.326728] KERNEL: PMC reset status reg: 0x0
[    1.326788] BL: PMC reset status reg: 0x0
[    1.326789] BL: PMIC poweroff Event Recorder: 0x40
[    1.326803] tegradc tegradc.0: hdmi: tmds rate:332180K prod-setting:prod_c_hdmi_300m_600m
[    1.327403] vdd-usb-vbus-en: supplied by vdd-5v0-sys
[    1.327427] vdd-usb-vbus-en: 5000 mV
[    1.327897] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[    1.327905] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[    1.328705] clk_cbus_recalc_rate: no gbus parent
[    1.328708] clk_cbus_round_rate: no gbus parent
[    1.328710] clk_cbus_round_rate: no gbus parent
[    1.328714] clk_cbus_recalc_rate: no gbus parent
[    1.328814] clk_cbus_recalc_rate: no gbus parent
[    1.328816] clk_cbus_round_rate: no gbus parent
[    1.328818] clk_cbus_round_rate: no gbus parent
[    1.328821] clk_cbus_recalc_rate: no gbus parent
[    1.329506] tegra_dvfs: GPU-cap: registered
[    1.329558] tegra dvfs: vdd-cpu: nominal 1168mV, offset 708000uV, step 19200uV, scaling enabled
[    1.329560] tegra dvfs: vdd-core: nominal 1075mV, offset 600000uV, step 12500uV, scaling enabled
[    1.329562] tegra dvfs: vdd-gpu: nominal 1038mV, offset 708000uV, step 10000uV, scaling enabled
[    1.330754] tegra_dvfs: vdd-gpu-vts: registered
[    1.330898] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_SKU_CALIB_0 = 0x9aa9c14
[    1.330903] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_USB_CALIB_EXT_0 = 0x4
[    1.331609] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.0, lane = usb2-0, function = xusb
[    1.331670] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.1, lane = usb2-1, function = xusb
[    1.331724] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.2, lane = usb2-2, function = xusb
[    1.331825] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.3, lane = pcie-0, function = pcie-x1
[    1.331879] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.4, lane = pcie-1, function = pcie-x4
[    1.331934] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.5, lane = pcie-2, function = pcie-x4
[    1.331987] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.6, lane = pcie-3, function = pcie-x4
[    1.332042] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.7, lane = pcie-4, function = pcie-x4
[    1.332093] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.8, lane = pcie-5, function = xusb
[    1.332148] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.9, lane = pcie-6, function = xusb
[    1.333443] tegra-pcie 1003000.pcie: 4x1, 1x1 configuration
[    1.335406] tegra-xusb 70090000.xusb: USB2 port 0 has OTG_CAP
[    1.335560] tegra-pcie 1003000.pcie: PCIE: Enable power rails
[    1.335883] tegra-xusb-padctl 7009f000.xusb_padctl: enabled OTG on UTMI pad 0
[    1.336636] tegra-pcie 1003000.pcie: probing port 0, using 4 lanes
[    1.336884] tegra-xusb 70090000.xusb: extcon 0: ffffffc078018c00 id
[    1.337866] tegra-xudc-new 700d0000.xudc: device count: 1
[    1.338718] tegra-xudc-new 700d0000.xudc: USB charger detection disabled
[    1.338725] tegra-xudc-new 700d0000.xudc: vbus state: 1
[    1.338732] tegra-xudc-new 700d0000.xudc: device mode on: 0
[    1.338738] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 0
[    1.338760] tegra-xudc-new 700d0000.xudc: active: 0 => 1
[    1.339064] tegra_core_action core_dvfs_cdev_floor: Tegra CORE DVFS 'floor cooling device' registered
[    1.339675] tegra_core_action core_dvfs_cdev_cap: Tegra CORE DVFS 'cap cooling device' registered
[    1.339757] tegra-pcie 1003000.pcie: probing port 1, using 1 lanes
[    1.340228] input: gpio-keys as /devices/gpio-keys/input/input1
[    1.341946] tegra-xusb 70090000.xusb: Firmware timestamp: 2019-10-17 15:58:59 UTC, Version: 50.25 release
[    1.341994] tegra-xusb 70090000.xusb: xHCI Host Controller
[    1.342007] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 1
[    1.342706] tegra-xusb 70090000.xusb: hcc params 0x0184f525 hci version 0x100 quirks 0x00050010
[    1.342729] tegra-xusb 70090000.xusb: irq 61, io mem 0x70090000
[    1.342830] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    1.342834] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.342836] usb usb1: Product: xHCI Host Controller
[    1.342839] usb usb1: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[    1.342841] usb usb1: SerialNumber: 70090000.xusb
[    1.343181] hub 1-0:1.0: USB hub found
[    1.343204] hub 1-0:1.0: 5 ports detected
[    1.343522] tegra-xusb 70090000.xusb: xHCI Host Controller
[    1.343528] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 2
[    1.343579] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[    1.343631] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[    1.343635] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.343637] usb usb2: Product: xHCI Host Controller
[    1.343640] usb usb2: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[    1.343642] usb usb2: SerialNumber: 70090000.xusb
[    1.343885] hub 2-0:1.0: USB hub found
[    1.343905] hub 2-0:1.0: 4 ports detected
[    1.363015] extcon-disp-state extcon:disp-state: cable 47 state 1
[    1.363017] Extcon AUX1(HDMI) enable
[    1.369766] tegradc tegradc.0: sync windows ret = 249
[    1.371130] tegra_rtc 7000e000.rtc: setting system clock to 2000-01-01 01:00:25 UTC (946688425)
[    1.372206] vi 54080000.vi: vi_probe: ++
[    1.374513] vi 54080000.vi: initialized
[    1.376551] vi 54080000.vi: subdev nvcsi--1 bound
[    1.377385] Disable partitions left on by BL
[    1.377388]   disb
[    1.377430] bwmgr: missing cdev-type property
[    1.377562] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[    1.377569] DRAM derating cdev registered.
[    1.378717] vdd-fan: disabling
[    1.378720] vdd-usb-vbus: disabling
[    1.378722] vdd-usb-vbus2: disabling
[    1.378731] avdd-io-edp-1v05: disabling
[    1.378733] vdd-usb-hub-en: disabling
[    1.378889] ALSA device list:
[    1.378892]   #0: tegra-hda at 0x70038000 irq 81
[    1.378894]   #1: tegra-snd-t210ref-mobile-rt565x
[    1.399035] extcon-disp-state extcon:disp-state: cable 51 state 1
[    1.399037] Extcon HDMI: HPD enabled
[    1.399049] tegradc tegradc.0: hdmi: plugged
[    1.402163] Freeing unused kernel memory: 8576K
[    1.426365] Root device found: mmcblk0p1
[    1.446102] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 2
[    1.518685] mmc0: Applying tuning correction
[    1.518700] mmc0: Tap value after applying correction 58
[    1.518719] mmc0: hw tuning done ...
[    1.518763] mmc0: new ultra high speed SDR104 SDXC card at address aaaa
[    1.519132] mmcblk0: mmc0:aaaa SF128 119 GiB
[    1.524439]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14
[    1.631117] Found dev node: /dev/mmcblk0p1
[    1.670036] usb 1-3: new high-speed USB device number 2 using tegra-xusb
[    1.690590] usb 1-3: New USB device found, idVendor=1a40, idProduct=0801
[    1.690595] usb 1-3: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    1.690598] usb 1-3: Product: USB 2.0 Hub
[    1.691337] hub 1-3:1.0: USB hub found
[    1.691401] hub 1-3:1.0: 4 ports detected
[    1.767997] tegra-pcie 1003000.pcie: link 0 down, retrying
[    1.974791] EXT4-fs (mmcblk0p1): recovery complete
[    1.975594] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[    1.976299] Rootfs mounted over mmcblk0p1
[    1.977991] usb 1-3.1: new high-speed USB device number 3 using tegra-xusb
[    1.992884] Switching from initrd to actual rootfs
[    1.998700] usb 1-3.1: New USB device found, idVendor=0bda, idProduct=c811
[    1.998705] usb 1-3.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    1.998709] usb 1-3.1: Product: 802.11ac NIC
[    1.998712] usb 1-3.1: Manufacturer: Realtek
[    1.998715] usb 1-3.1: SerialNumber: 123456
[    2.010053] tegra_cec 70015000.tegra_cec: physical address: 10:00.
[    2.077989] usb 1-3.2: new high-speed USB device number 4 using tegra-xusb
[    2.101451] usb 1-3.2: New USB device found, idVendor=05e3, idProduct=0610
[    2.101457] usb 1-3.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    2.101460] usb 1-3.2: Product: USB2.0 Hub
[    2.101464] usb 1-3.2: Manufacturer: GenesysLogic
[    2.102360] hub 1-3.2:1.0: USB hub found
[    2.102696] hub 1-3.2:1.0: 4 ports detected
[    2.180247] tegra-pcie 1003000.pcie: link 0 down, retrying
[    2.197489] systemd[1]: System time before build time, advancing clock.
[    2.231452] ip_tables: (C) 2000-2006 Netfilter Core Team
[    2.243785] cgroup: cgroup2: unknown option "nsdelegate"
[    2.269985] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[    2.270744] systemd[1]: Detected architecture arm64.
[    2.298024] systemd[1]: Set hostname to <nano>.
[    2.394043] usb 1-3.2.1: new low-speed USB device number 5 using tegra-xusb
[    2.421893] usb 1-3.2.1: New USB device found, idVendor=03f0, idProduct=2f4a
[    2.421900] usb 1-3.2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    2.421904] usb 1-3.2.1: Product: HP Business Slim Keyboard
[    2.421907] usb 1-3.2.1: Manufacturer: Chicony
[    2.426298] input: Chicony HP Business Slim Keyboard as /devices/70090000.xusb/usb1/1-3/1-3.2/1-3.2.1/1-3.2.1:1.0/0003:03F0:2F4A.0001/input/input2
[    2.480253] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[    2.480263] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[    2.486378] hid-generic 0003:03F0:2F4A.0001: input,hidraw0: USB HID v1.10 Keyboard [Chicony HP Business Slim Keyboard] on usb-70090000.xusb-3.2.1/input0
[    2.492974] input: Chicony HP Business Slim Keyboard as /devices/70090000.xusb/usb1/1-3/1-3.2/1-3.2.1/1-3.2.1:1.1/0003:03F0:2F4A.0002/input/input3
[    2.550265] hid-generic 0003:03F0:2F4A.0002: input,hidraw1: USB HID v1.10 Device [Chicony HP Business Slim Keyboard] on usb-70090000.xusb-3.2.1/input1
[    2.584430] tegra-pcie 1003000.pcie: link 0 down, retrying
[    2.586502] tegra-pcie 1003000.pcie: link 0 down, ignoring
[    2.629985] usb 1-3.2.2: new low-speed USB device number 6 using tegra-xusb
[    2.654295] usb 1-3.2.2: New USB device found, idVendor=18f8, idProduct=0f99
[    2.654300] usb 1-3.2.2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    2.654303] usb 1-3.2.2: Product: USB OPTICAL MOUSE
[    2.657572] input: USB OPTICAL MOUSE  as /devices/70090000.xusb/usb1/1-3/1-3.2/1-3.2.2/1-3.2.2:1.0/0003:18F8:0F99.0003/input/input4
[    2.657804] hid-generic 0003:18F8:0F99.0003: input,hidraw2: USB HID v1.10 Mouse [USB OPTICAL MOUSE ] on usb-70090000.xusb-3.2.2/input0
[    2.661013] input: USB OPTICAL MOUSE  as /devices/70090000.xusb/usb1/1-3/1-3.2/1-3.2.2/1-3.2.2:1.1/0003:18F8:0F99.0004/input/input5
[    2.689986] tegra-pcie 1003000.pcie: PCI host bridge to bus 0000:00
[    2.689991] pci_bus 0000:00: root bus resource [io  0x0000-0xffff]
[    2.689995] pci_bus 0000:00: root bus resource [mem 0x13000000-0x1fffffff]
[    2.689998] pci_bus 0000:00: root bus resource [mem 0x20000000-0x3fffffff pref]
[    2.690002] pci_bus 0000:00: root bus resource [bus 00-ff]
[    2.690022] pci 0000:00:02.0: [10de:0faf] type 01 class 0x060400
[    2.690080] pci 0000:00:02.0: PME# supported from D0 D1 D2 D3hot D3cold
[    2.690218] pci 0000:00:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    2.690321] pci 0000:01:00.0: [10ec:8168] type 00 class 0x020000
[    2.690345] pci 0000:01:00.0: reg 0x10: [io  0x0000-0x00ff]
[    2.690373] pci 0000:01:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit]
[    2.690393] pci 0000:01:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit]
[    2.690526] pci 0000:01:00.0: supports D1 D2
[    2.690529] pci 0000:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    2.702107] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[    2.702132] pci 0000:00:02.0: BAR 14: assigned [mem 0x13000000-0x130fffff]
[    2.702135] pci 0000:00:02.0: BAR 13: assigned [io  0x1000-0x1fff]
[    2.702140] pci 0000:01:00.0: BAR 4: assigned [mem 0x13000000-0x13003fff 64bit]
[    2.702156] pci 0000:01:00.0: BAR 2: assigned [mem 0x13004000-0x13004fff 64bit]
[    2.702171] pci 0000:01:00.0: BAR 0: assigned [io  0x1000-0x10ff]
[    2.702178] pci 0000:00:02.0: PCI bridge to [bus 01]
[    2.702181] pci 0000:00:02.0:   bridge window [io  0x1000-0x1fff]
[    2.702185] pci 0000:00:02.0:   bridge window [mem 0x13000000-0x130fffff]
[    2.702408] pcieport 0000:00:02.0: Signaling PME through PCIe PME interrupt
[    2.702411] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[    2.702416] pcie_pme 0000:00:02.0:pcie001: service driver pcie_pme loaded
[    2.702492] aer 0000:00:02.0:pcie002: service driver aer loaded
[    2.702655] r8168 0000:01:00.0: enabling device (0000 -> 0003)
[    2.702672] r8168 Gigabit Ethernet driver 8.045.08-NAPI loaded
[    2.716693] r8168 0000:01:00.0 (unnamed net_device) (uninitialized): Invalid ethernet address 00:00:00:00:00:00, trying device tree node
[    2.716757] r8168 0000:01:00.0 (unnamed net_device) (uninitialized): Found valid ethernet address 48:b0:2d:2e:c1:52 from device tree
[    2.717167] r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
[    2.717181] r8168  Copyright (C) 2017  Realtek NIC software team <nicfae@realtek.com>
                This program comes with ABSOLUTELY NO WARRANTY; for details, please see <http://www.gnu.org/licenses/>.
                This is free software, and you are welcome to redistribute it under certain conditions; see <http://www.gnu.org/licenses/>.
[    2.718253] hid-generic 0003:18F8:0F99.0004: input,hidraw3: USB HID v1.10 Keyboard [USB OPTICAL MOUSE ] on usb-70090000.xusb-3.2.2/input1
[    2.736496] random: systemd: uninitialized urandom read (16 bytes read)
[    2.737921] systemd[1]: Created slice System Slice.
[    2.738136] random: systemd: uninitialized urandom read (16 bytes read)
[    2.738160] systemd[1]: Reached target User and Group Name Lookups.
[    2.738377] random: systemd: uninitialized urandom read (16 bytes read)
[    2.738501] systemd[1]: Listening on Journal Audit Socket.
[    2.738655] systemd[1]: Listening on RPCbind Server Activation Socket.
[    2.738778] systemd[1]: Listening on udev Kernel Socket.
[    2.804954] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[    2.934480] nvgpu: 57000000.gpu           gm20b_init_clk_setup_sw:1268 [INFO]  GPCPLL initial settings: NA mode, M=1, N=34, P=3 (id = 1)
[    2.944673] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[    2.944698] cpu-throttle-alert cooling device registered.
[    2.944853] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[    2.944868] gpu-throttle-alert cooling device registered.
[    2.945046] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[    2.945059] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[    2.945072] hot-surface-alert cooling device registered.
[    3.051013] systemd-journald[1983]: Received request to flush runtime journal from PID 1
[    3.208406] Adding 4194300k swap on /swapfile.  Priority:-1 extents:6 across:4513788k SS
[    3.570716] usb 1-3.2-port3: Cannot enable. Maybe the USB cable is bad?
[    3.831324] using random self ethernet address
[    3.840236] using random host ethernet address
[    4.071755] random: crng init done
[    4.075189] random: 7 urandom warning(s) missed due to ratelimiting
[    4.214002] tegra_cec 70015000.tegra_cec: timeout in tegra_cec_native_write_l:172.
[    4.221829] tegra_cec 70015000.tegra_cec: Sent <Text View On> res: -62.
[    4.228721] tegra_cec 70015000.tegra_cec: tegra_cec_init Done.
[    4.901237] Mass Storage Function, version: 2009/09/11
[    4.901243] LUN: removable file: (no medium)
[    4.906610] using random self ethernet address
[    4.911152] using random host ethernet address
[    5.011395] rndis0: HOST MAC a6:17:5a:79:9a:f0
[    5.011906] rndis0: MAC a6:17:5a:79:9a:f1
[    5.013154] usb0: HOST MAC a6:17:5a:79:9a:f2
[    5.013185] usb0: MAC a6:17:5a:79:9a:f3
[    5.013237] tegra-xudc-new 700d0000.xudc: ep 0 (type: 0, dir: out) enabled
[    5.020832] l4tbr0: port 1(rndis0) entered blocking state
[    5.020837] l4tbr0: port 1(rndis0) entered disabled state
[    5.021009] device rndis0 entered promiscuous mode
[    5.027310] IPv6: ADDRCONF(NETDEV_UP): rndis0: link is not ready
[    5.036258] l4tbr0: port 2(usb0) entered blocking state
[    5.036264] l4tbr0: port 2(usb0) entered disabled state
[    5.036430] device usb0 entered promiscuous mode
[    5.043838] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[    5.266773] android_work: did not send uevent (0 0           (null))
[    5.299467] android_work: sent uevent USB_STATE=CONNECTED
[    5.374010] usb 1-3.2.4: new high-speed USB device number 9 using tegra-xusb
[    5.388861] configfs-gadget gadget: high-speed config #1: c
[    5.388893] tegra-xudc-new 700d0000.xudc: ep 5 (type: 3, dir: in) enabled
[    5.388909] tegra-xudc-new 700d0000.xudc: ep 3 (type: 2, dir: in) enabled
[    5.388925] tegra-xudc-new 700d0000.xudc: ep 2 (type: 2, dir: out) enabled
[    5.389019] tegra-xudc-new 700d0000.xudc: ep 9 (type: 3, dir: in) enabled
[    5.389035] tegra-xudc-new 700d0000.xudc: ep 7 (type: 2, dir: in) enabled
[    5.389050] tegra-xudc-new 700d0000.xudc: ep 4 (type: 2, dir: out) enabled
[    5.389082] tegra-xudc-new 700d0000.xudc: ep 15 (type: 3, dir: in) enabled
[    5.389140] IPv6: ADDRCONF(NETDEV_CHANGE): rndis0: link becomes ready
[    5.389283] android_work: sent uevent USB_STATE=CONFIGURED
[    5.389323] tegra-xudc-new 700d0000.xudc: ep 11 (type: 2, dir: in) enabled
[    5.389339] tegra-xudc-new 700d0000.xudc: ep 6 (type: 2, dir: out) enabled
[    5.512262] tegra-xusb 70090000.xusb: Upgrade port 0 to USB3.0
[    5.512270] tegra-xusb 70090000.xusb: Upgrade port 1 to USB3.0
[    5.618051] usb 1-3.2.4: New USB device found, idVendor=046d, idProduct=0825
[    5.618059] usb 1-3.2.4: New USB device strings: Mfr=0, Product=0, SerialNumber=2
[    5.618063] usb 1-3.2.4: SerialNumber: 218C46A0
[    5.618716] usb usb2: usb_suspend_both: status 0
[    5.778280] IRQ11 no longer affine to CPU2
[    5.782655] CPU2: shutdown
[    5.785434] psci: CPU2 killed.
[    5.846892] IRQ12 no longer affine to CPU3
[    5.851581] CPU3: shutdown
[    5.855298] psci: CPU3 killed.
[    6.569267] zram: Added device: zram0
[    6.573609] zram: Added device: zram1
[    6.773929] zram0: detected capacity change from 0 to 4194304000
[    6.815696] Adding 4095996k swap on /dev/zram0.  Priority:5 extents:1 across:4095996k SS
[    6.854761] zram1: detected capacity change from 0 to 4194304000
[    6.864742] usb 1-3.2.4: set resolution quirk: cval->res = 384
[    6.921407] Adding 4095996k swap on /dev/zram1.  Priority:5 extents:1 across:4095996k SS
[    7.461229] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[    7.462768] eth0: 0xffffff800d4fc000, 48:b0:2d:2e:c1:52, IRQ 405
[    7.547785] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[    8.521594] tegradc tegradc.0: blank - powerdown
[    8.550625] extcon-disp-state extcon:disp-state: cable 47 state 0
[    8.550629] Extcon AUX1(HDMI) disable
[    8.573768] tegradc tegradc.0: unblank
[    8.618239] tegradc tegradc.0: nominal-pclk:332180000 parent:332178125 div:1.0 pclk:332178125 328858200~362076200
[    8.620510] tegradc tegradc.0: hdmi: tmds rate:332180K prod-setting:prod_c_hdmi_300m_600m
[    8.622245] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[    8.622256] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[    8.664224] extcon-disp-state extcon:disp-state: cable 47 state 1
[    8.664228] Extcon AUX1(HDMI) enable
[    8.683686] tegradc tegradc.0: unblank
[   11.868172] fuse init (API version 7.26)
[   13.746761] tegradc tegradc.0: blank - powerdown
[   13.782225] extcon-disp-state extcon:disp-state: cable 47 state 0
[   13.782229] Extcon AUX1(HDMI) disable
[   13.838741] tegradc tegradc.0: blank - powerdown
[   13.838791] tegradc tegradc.0: unblank
[   13.877894] tegradc tegradc.0: nominal-pclk:65000000 parent:65000000 div:1.0 pclk:65000000 64350000~70850000
[   13.878117] tegradc tegradc.0: hdmi: tmds rate:65000K prod-setting:prod_c_hdmi_54m_75m
[   13.879590] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[   13.879601] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[   13.942168] extcon-disp-state extcon:disp-state: cable 47 state 1
[   13.942172] Extcon AUX1(HDMI) enable
[   13.969809] tegradc tegradc.0: unblank
[   14.092589] usbcore: registered new interface driver rtl8821cu
[   14.779446] uvcvideo: Found UVC 1.00 device <unnamed> (046d:0825)
[   14.826377] uvcvideo 1-3.2.4:1.0: Entity type for entity Extension 4 was not initialized!
[   15.058843] uvcvideo 1-3.2.4:1.0: Entity type for entity Extension 6 was not initialized!
[   15.322036] uvcvideo 1-3.2.4:1.0: Entity type for entity Extension 7 was not initialized!
[   16.247014] uvcvideo 1-3.2.4:1.0: Entity type for entity Processing 2 was not initialized!
[   16.598224] uvcvideo 1-3.2.4:1.0: Entity type for entity Extension 3 was not initialized!
[   16.978725] uvcvideo 1-3.2.4:1.0: Entity type for entity Camera 1 was not initialized!
[   17.356173] input: UVC Camera (046d:0825) as /devices/70090000.xusb/usb1/1-3/1-3.2/1-3.2.4/1-3.2.4:1.0/input/input6
[   17.390658] usbcore: registered new interface driver uvcvideo
[   17.390663] USB Video Class driver (1.1.1)
[   19.388766] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[   20.632675] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   20.632691] Bluetooth: BNEP socket layer initialized
[   20.646539] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[   20.755283] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[   21.066189] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[   22.883046] l4tbr0: port 1(rndis0) entered blocking state
[   22.883053] l4tbr0: port 1(rndis0) entered forwarding state
[   22.898412] IPv6: ADDRCONF(NETDEV_UP): l4tbr0: link is not ready
[   22.898445] IPv6: ADDRCONF(NETDEV_CHANGE): l4tbr0: link becomes ready
[   26.525748] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[   26.875478] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[   28.010820] usb 1-3.2.4: usb_suspend_both: status 0
[  108.969512] Bridge firewalling registered
[  109.001674] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[  109.358511] Netfilter messages via NETLINK v0.30.
[  109.361775] ctnetlink v0.93: registering with nfnetlink.
[  109.660376] IPv6: ADDRCONF(NETDEV_UP): docker0: link is not ready
[  841.352882] usb 1-3.2.4: reset high-speed USB device number 9 using tegra-xusb
[  905.393851] CPU2: Booted secondary processor [411fd071]
[  905.419585] CPU3: Booted secondary processor [411fd071]
[  944.982984] tegradc tegradc.0: blank - powerdown
[  945.034170] extcon-disp-state extcon:disp-state: cable 47 state 0
[  945.034173] Extcon AUX1(HDMI) disable
[  945.071548] tegradc tegradc.0: blank - powerdown
[  945.071571] tegradc tegradc.0: unblank
[  945.085502] tegradc tegradc.0: nominal-pclk:332180000 parent:332178125 div:1.0 pclk:332178125 328858200~362076200
[  945.085597] tegradc tegradc.0: hdmi: tmds rate:332180K prod-setting:prod_c_hdmi_300m_600m
[  945.087683] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[  945.087691] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[  945.122669] extcon-disp-state extcon:disp-state: cable 47 state 1
[  945.122671] Extcon AUX1(HDMI) enable
[  945.129773] tegradc tegradc.0: sync windows ret = 248
[  945.430909] tegradc tegradc.0: blank - powerdown
[  945.456202] extcon-disp-state extcon:disp-state: cable 47 state 0
[  945.456204] Extcon AUX1(HDMI) disable
[  945.467430] tegradc tegradc.0: unblank
[  945.482041] tegradc tegradc.0: nominal-pclk:332180000 parent:332178125 div:1.0 pclk:332178125 328858200~362076200
[  945.482130] tegradc tegradc.0: hdmi: tmds rate:332180K prod-setting:prod_c_hdmi_300m_600m
[  945.483727] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[  945.483735] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[  945.519990] extcon-disp-state extcon:disp-state: cable 47 state 1
[  945.519993] Extcon AUX1(HDMI) enable
[  945.526286] tegradc tegradc.0: unblank
[ 1119.796662] soctherm: OC ALARM 0x00000001
[ 1121.360011] soctherm: OC ALARM 0x00000001
[ 1558.711432] tegradc tegradc.0: blank - powerdown
[ 1558.736088] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 1558.736091] Extcon AUX1(HDMI) disable
[ 3251.036137] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[ 3292.623582] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[ 3324.569510] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[ 3433.687161] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 3446.177886] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[ 3530.758523] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[ 3567.995392] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[ 3615.627401] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[ 3678.783959] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[ 3751.652663] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[ 3827.902594] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[ 3890.529785] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[ 4006.055770] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[ 4068.699029] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[ 4132.178957] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[ 4198.221017] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[ 4277.948918] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[ 4337.456420] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[ 4401.402538] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[ 4465.420519] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[ 4536.505960] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[ 4617.140047] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[ 4682.758981] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[ 4754.446767] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[ 4815.324763] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[ 4880.858647] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[ 4954.196895] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[ 5019.722854] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[ 5090.196270] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[ 5160.938726] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[ 5227.653129] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[ 5291.860266] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[ 5363.464735] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[ 5435.728412] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[ 5502.979037] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[ 5574.691148] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[ 5644.234525] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[ 5719.522023] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[ 5788.296358] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[ 5857.490715] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[ 5920.993026] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[ 5986.619033] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[ 6055.038110] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[ 6129.020688] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[ 6195.398965] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[ 6268.167153] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[ 6327.118523] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[ 6397.634183] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[ 6465.046400] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[ 6533.741246] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[ 6599.488227] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[ 6662.618530] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[ 6734.869607] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[ 6802.146913] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[ 6866.492644] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[ 6933.347364] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[ 7000.975031] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[ 7077.653844] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[ 7140.514468] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[ 7208.793616] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[ 7275.476663] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[ 7350.700652] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[ 7414.609527] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[ 7489.473223] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[ 7559.297184] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[ 7625.063032] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[ 7696.449545] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[ 7761.620789] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[ 7837.052365] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[ 7908.925029] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[ 7972.822540] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[ 8040.359603] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[ 8108.505422] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[ 8177.778223] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[ 8245.473846] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[ 8310.907031] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[ 8386.233908] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[ 8447.236095] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[ 8521.435407] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[ 8583.740280] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[ 8658.000350] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[ 8723.952282] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[ 8788.441273] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[ 8860.767842] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[ 8930.229928] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[ 8998.112599] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[ 9067.314911] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[ 9140.143282] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[ 9210.714408] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[ 9269.450486] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[ 9336.925375] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[ 9403.464158] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[ 9481.274851] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[ 9547.254981] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[ 9617.466060] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[ 9699.219783] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[ 9763.423004] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[ 9830.545725] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[ 9900.604603] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[ 9969.847225] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[10044.431976] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[10115.337600] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[10184.916661] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[10254.717030] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[10329.599287] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[10404.225436] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[10469.855289] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[10542.517552] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[10610.435455] tegradc tegradc.0: unblank
[10610.444959] tegradc tegradc.0: nominal-pclk:332180000 parent:332178125 div:1.0 pclk:332178125 328858200~362076200
[10610.445046] tegradc tegradc.0: hdmi: tmds rate:332180K prod-setting:prod_c_hdmi_300m_600m
[10610.447732] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[10610.447740] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[10610.497283] extcon-disp-state extcon:disp-state: cable 47 state 1
[10610.497286] Extcon AUX1(HDMI) enable
[10612.340214] extcon-disp-state extcon:disp-state: cable 47 state 0
[10612.340219] Extcon AUX1(HDMI) disable
[10612.378810] tegradc tegradc.0: blank - powerdown
[10612.378885] extcon-disp-state extcon:disp-state: cable 51 state 0
[10612.378888] Extcon HDMI: HPD disabled
[10612.408459] tegradc tegradc.0: hdmi: unplugged
[10612.858435] tegradc tegradc.0: blank - powerdown
[10612.858451] tegradc tegradc.0: unblank
[10612.874826] tegradc tegradc.0: nominal-pclk:332180000 parent:332178125 div:1.0 pclk:332178125 328858200~362076200
[10612.890022] tegradc tegradc.0: hdmi: tmds rate:332180K prod-setting:prod_c_hdmi_300m_600m
[10612.892316] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[10612.892324] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[10612.927911] extcon-disp-state extcon:disp-state: cable 47 state 1
[10612.927913] Extcon AUX1(HDMI) enable
[10612.936062] extcon-disp-state extcon:disp-state: cable 51 state 1
[10612.936065] Extcon HDMI: HPD enabled
[10612.936087] tegradc tegradc.0: hdmi: plugged
[10620.629559] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[10630.983969] tegradc tegradc.0: blank - powerdown
[10631.010947] extcon-disp-state extcon:disp-state: cable 47 state 0
[10631.010949] Extcon AUX1(HDMI) disable
[10631.022935] tegradc tegradc.0: unblank
[10631.038604] tegradc tegradc.0: nominal-pclk:332180000 parent:332178125 div:1.0 pclk:332178125 328858200~362076200
[10631.038683] tegradc tegradc.0: hdmi: tmds rate:332180K prod-setting:prod_c_hdmi_300m_600m
[10631.040085] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[10631.040092] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[10631.075001] extcon-disp-state extcon:disp-state: cable 47 state 1
[10631.075003] Extcon AUX1(HDMI) enable
[10631.713962] tegradc tegradc.0: unblank
[10665.748412] tegradc tegradc.0: unblank
[10682.142286] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[10696.478130] tegradc tegradc.0: unblank
[10748.746818] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[10814.309296] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[10889.288978] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[10958.389148] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[11026.468860] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[11094.192107] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[11160.147115] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[11234.054614] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[11259.021063] tegradc tegradc.0: blank - powerdown
[11259.042781] extcon-disp-state extcon:disp-state: cable 47 state 0
[11259.042784] Extcon AUX1(HDMI) disable
[11302.598041] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[11370.217205] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[11429.891789] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[11493.823363] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[11566.083913] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[11644.700290] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[11712.129042] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[11781.667311] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[11855.500609] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[11924.534419] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[11992.216043] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[12064.790109] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[12134.332668] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[12202.784983] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[12270.812791] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[12343.976276] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[12416.380039] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[12483.671498] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[12555.088431] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[12629.259671] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[12694.870169] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[12766.833755] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[12830.768364] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[12899.110291] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[12965.789547] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[13030.686794] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[13104.081066] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[13170.271762] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[13233.843698] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[13308.590424] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[13375.730924] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[13445.879615] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[13515.427014] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[13583.722049] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[13593.018871] tegradc tegradc.0: unblank
[13593.027200] tegradc tegradc.0: nominal-pclk:332180000 parent:332178125 div:1.0 pclk:332178125 328858200~362076200
[13593.027298] tegradc tegradc.0: hdmi: tmds rate:332180K prod-setting:prod_c_hdmi_300m_600m
[13593.028835] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[13593.028843] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[13593.063752] extcon-disp-state extcon:disp-state: cable 47 state 1
[13593.063754] Extcon AUX1(HDMI) enable
[13594.911032] extcon-disp-state extcon:disp-state: cable 47 state 0
[13594.911037] Extcon AUX1(HDMI) disable
[13594.922545] tegradc tegradc.0: blank - powerdown
[13594.922607] extcon-disp-state extcon:disp-state: cable 51 state 0
[13594.922610] Extcon HDMI: HPD disabled
[13594.922633] tegradc tegradc.0: hdmi: unplugged
[13595.441614] tegradc tegradc.0: blank - powerdown
[13595.441631] tegradc tegradc.0: unblank
[13595.464434] tegradc tegradc.0: nominal-pclk:332180000 parent:332178125 div:1.0 pclk:332178125 328858200~362076200
[13595.464522] tegradc tegradc.0: hdmi: tmds rate:332180K prod-setting:prod_c_hdmi_300m_600m
[13595.467113] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[13595.467121] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[13595.501922] extcon-disp-state extcon:disp-state: cable 47 state 1
[13595.501925] Extcon AUX1(HDMI) enable
[13595.517789] extcon-disp-state extcon:disp-state: cable 51 state 1
[13595.517792] Extcon HDMI: HPD enabled
[13595.520752] tegradc tegradc.0: hdmi: plugged
[13602.027023] tegradc tegradc.0: blank - powerdown
[13602.092459] extcon-disp-state extcon:disp-state: cable 47 state 0
[13602.092461] Extcon AUX1(HDMI) disable
[13602.110527] tegradc tegradc.0: unblank
[13602.124868] tegradc tegradc.0: nominal-pclk:332180000 parent:332178125 div:1.0 pclk:332178125 328858200~362076200
[13602.124944] tegradc tegradc.0: hdmi: tmds rate:332180K prod-setting:prod_c_hdmi_300m_600m
[13602.142080] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[13602.142088] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[13602.196294] extcon-disp-state extcon:disp-state: cable 47 state 1
[13602.196296] Extcon AUX1(HDMI) enable
[13603.086970] tegradc tegradc.0: unblank
[13659.397044] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[13669.647831] tegradc tegradc.0: unblank
[13712.444785] tegradc tegradc.0: unblank
[13726.260923] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[13784.864585] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[13856.166921] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[13952.756797] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[14026.863612] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[14054.927263] soctherm: OC ALARM 0x00000001
[14099.660802] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[14168.787123] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[14229.892195] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[14237.512676] tegradc tegradc.0: blank - powerdown
[14237.553176] extcon-disp-state extcon:disp-state: cable 47 state 0
[14237.553179] Extcon AUX1(HDMI) disable
[14303.380126] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[14364.469576] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[14439.872332] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[14506.768113] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[14538.207697] tegradc tegradc.0: unblank
[14538.217518] tegradc tegradc.0: nominal-pclk:332180000 parent:332178125 div:1.0 pclk:332178125 328858200~362076200
[14538.217605] tegradc tegradc.0: hdmi: tmds rate:332180K prod-setting:prod_c_hdmi_300m_600m
[14538.219508] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[14538.219516] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[14538.269577] extcon-disp-state extcon:disp-state: cable 47 state 1
[14538.269579] Extcon AUX1(HDMI) enable
[14540.101767] extcon-disp-state extcon:disp-state: cable 47 state 0
[14540.101772] Extcon AUX1(HDMI) disable
[14540.113108] tegradc tegradc.0: blank - powerdown
[14540.113278] extcon-disp-state extcon:disp-state: cable 51 state 0
[14540.113281] Extcon HDMI: HPD disabled
[14540.113312] tegradc tegradc.0: hdmi: unplugged
[14540.630091] tegradc tegradc.0: blank - powerdown
[14540.630107] tegradc tegradc.0: unblank
[14540.644314] tegradc tegradc.0: nominal-pclk:332180000 parent:332178125 div:1.0 pclk:332178125 328858200~362076200
[14540.644540] tegradc tegradc.0: hdmi: tmds rate:332180K prod-setting:prod_c_hdmi_300m_600m
[14540.645898] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[14540.645905] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[14540.681288] extcon-disp-state extcon:disp-state: cable 47 state 1
[14540.681290] Extcon AUX1(HDMI) enable
[14540.681432] extcon-disp-state extcon:disp-state: cable 51 state 1
[14540.681435] Extcon HDMI: HPD enabled
[14540.681463] tegradc tegradc.0: hdmi: plugged
[14546.650308] tegradc tegradc.0: blank - powerdown
[14546.674065] extcon-disp-state extcon:disp-state: cable 47 state 0
[14546.674067] Extcon AUX1(HDMI) disable
[14546.867944] tegradc tegradc.0: unblank
[14546.895925] tegradc tegradc.0: nominal-pclk:332180000 parent:332178125 div:1.0 pclk:332178125 328858200~362076200
[14546.896013] tegradc tegradc.0: hdmi: tmds rate:332180K prod-setting:prod_c_hdmi_300m_600m
[14546.923582] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[14546.923591] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[14546.958405] extcon-disp-state extcon:disp-state: cable 47 state 1
[14546.958407] Extcon AUX1(HDMI) enable
[14548.339202] tegradc tegradc.0: unblank
[14578.969219] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[14591.200499] tegradc tegradc.0: unblank
[14630.068646] tegradc tegradc.0: unblank
[14653.589371] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[14720.696927] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[14789.122941] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[14872.825472] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[14941.205621] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[15004.932928] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[15071.539368] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[15127.694436] tegradc tegradc.0: blank - powerdown
[15127.717124] extcon-disp-state extcon:disp-state: cable 47 state 0
[15127.717127] Extcon AUX1(HDMI) disable
[15136.425645] tegradc tegradc.0: blank - powerdown
[15136.425660] tegradc tegradc.0: unblank
[15136.439690] tegradc tegradc.0: nominal-pclk:332180000 parent:332178125 div:1.0 pclk:332178125 328858200~362076200
[15136.452093] tegradc tegradc.0: hdmi: tmds rate:332180K prod-setting:prod_c_hdmi_300m_600m
[15136.456545] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[15136.456553] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[15136.527061] extcon-disp-state extcon:disp-state: cable 47 state 1
[15136.527064] Extcon AUX1(HDMI) enable
[15136.533119] tegradc tegradc.0: sync windows ret = 248
[15140.459551] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[15140.505936] soctherm: OC ALARM 0x00000001
[15211.239426] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[15276.889945] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[15347.358631] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[15415.734809] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[15477.503550] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[15546.015926] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[15621.589303] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[15690.530650] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[15759.214431] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[15831.440052] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[15892.801464] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[15960.137934] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[16026.647654] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
So, either I do have a faulty board, or my power supplys are not keeping up.
If you can dual-boot it into Ubuntu, that should be just fine for running JupyterLab and training some DNN’s on. I have an i7-6700K (32GB) + GeForce 1070M (8GB) laptop that I use for training large models/datasets on. But mostly I just use the Jetson for training smaller datasets of a few thousand images.
I will follow-up with you in your other topic about the Jupyter issues you are having with Nano 2GB. Let’s keep that discussion in that thread.
