My process is killed when build engine with sampleFasterRCNN
I followed the guide, and the model has been downloaded
The FasterRCNN sample uses the dataset from here:
https://dl.dropboxusercontent.com/s/o6ii098bu51d139/faster_rcnn_models.tgz
The dataset needs to be placed into the data/faster-rcnn directory.
and I do this
cd tensorrt/samples/sampleFasterRCNN
sudo make clean
sudo make
cd tensorrt/bin
./sample_fasterRCNN
and the terminal shows to me:
begin parse model...
end parse model...
begin build engine...
killed
I wonder whether the “killed” problem was caused by memory? What should I do to solve this problem?
Besides, I run the ./sample_fasterRCNN after I restart the computer. I try to kill some process such as ‘gnome-software’, but I do not know which process I should kill so that the system can keep running
Could you help to monitor the system status at the same time and share the log with us?
sudo tegrastats
Hi, the system status txt attached
monitor.txt (59.4 KB)
RAM 1379/3957MB (lfb 481x4MB) IRAM 0/252kB(lfb 252kB) CPU [14%@1428,7%@1428,4%@1428,7%@1428] EMC_FREQ 2%@1600 GR3D_FREQ 0%@921 APE 25 PLL@40.5C CPU@44.5C PMIC@100C GPU@41C AO@51C thermal@42.75C POM_5V_IN 2298/2298 POM_5V_GPU 161/161 POM_5V_CPU 362/362
RAM 1390/3957MB (lfb 472x4MB) IRAM 0/252kB(lfb 252kB) CPU [3%@1428,3%@1428,12%@1428,0%@1428] EMC_FREQ 2%@1600 GR3D_FREQ 0%@921 APE 25 PLL@40.5C CPU@45C PMIC@100C GPU@41C AO@51C thermal@43C POM_5V_IN 2808/2553 POM_5V_GPU 200/180 POM_5V_CPU 561/461
RAM 1442/3957MB (lfb 442x4MB) IRAM 0/252kB(lfb 252kB) CPU [1%@1428,10%@1428,22%@1428,1%@1428] EMC_FREQ 2%@1600 GR3D_FREQ 0%@921 APE 25 PLL@40.5C CPU@45C PMIC@100C GPU@41.5C AO@51C thermal@43C POM_5V_IN 3004/2703 POM_5V_GPU 200/187 POM_5V_CPU 760/561
RAM 1536/3957MB (lfb 400x4MB) IRAM 0/252kB(lfb 252kB) CPU [3%@1428,11%@1428,22%@1428,1%@1428] EMC_FREQ 3%@1600 GR3D_FREQ 0%@921 APE 25 PLL@40.5C CPU@44.5C PMIC@100C GPU@41C AO@51.5C thermal@43.25C POM_5V_IN 2849/2739 POM_5V_GPU 160/180 POM_5V_CPU 520/550
RAM 1939/3957MB (lfb 282x4MB) IRAM 0/252kB(lfb 252kB) CPU [6%@1428,9%@1428,31%@1428,0%@1428] EMC_FREQ 5%@1600 GR3D_FREQ 0%@921 APE 25 PLL@40.5C CPU@44.5C PMIC@100C GPU@41C AO@51C thermal@44C POM_5V_IN 2808/2753 POM_5V_GPU 160/176 POM_5V_CPU 481/536
RAM 1938/3957MB (lfb 260x4MB) IRAM 0/252kB(lfb 252kB) CPU [10%@1428,11%@1428,0%@1428,0%@1428] EMC_FREQ 4%@1600 GR3D_FREQ 0%@921 APE 25 PLL@40.5C CPU@44.5C PMIC@100C GPU@41.5C AO@51C thermal@43C POM_5V_IN 2808/2762 POM_5V_GPU 160/173 POM_5V_CPU 521/534
RAM 1938/3957MB (lfb 237x4MB) IRAM 0/252kB(lfb 252kB) CPU [9%@1428,10%@1428,4%@1428,1%@1428] EMC_FREQ 4%@1600 GR3D_FREQ 0%@921 APE 25 PLL@40C CPU@44.5C PMIC@100C GPU@41.5C AO@51C thermal@43C POM_5V_IN 2808/2769 POM_5V_GPU 160/171 POM_5V_CPU 521/532
RAM 1938/3957MB (lfb 214x4MB) IRAM 0/252kB(lfb 252kB) CPU [1%@1428,10%@1428,11%@1428,1%@1428] EMC_FREQ 4%@1600 GR3D_FREQ 4%@921 APE 25 PLL@40.5C CPU@45C PMIC@100C GPU@41.5C AO@51C thermal@42.75C POM_5V_IN 2889/2784 POM_5V_GPU 200/175 POM_5V_CPU 520/530
RAM 2003/3957MB (lfb 176x4MB) IRAM 0/252kB(lfb 252kB) CPU [22%@1428,20%@1428,6%@1428,9%@1428] EMC_FREQ 4%@1600 GR3D_FREQ 0%@921 APE 25 PLL@40.5C CPU@45C PMIC@100C GPU@41C AO@51C thermal@43C POM_5V_IN 3004/2808 POM_5V_GPU 200/177 POM_5V_CPU 600/538
RAM 2023/3957MB (lfb 155x4MB) IRAM 0/252kB(lfb 252kB) CPU [17%@1428,13%@1428,38%@1428,8%@1428] EMC_FREQ 4%@1600 GR3D_FREQ 1%@921 APE 25 PLL@40C CPU@44.5C PMIC@100C GPU@41.5C AO@51.5C thermal@43.25C POM_5V_IN 2920/2819 POM_5V_GPU 200/180 POM_5V_CPU 640/548
RAM 2109/3957MB (lfb 119x4MB) IRAM 0/252kB(lfb 252kB) CPU [7%@1428,1%@1428,11%@1428,30%@1428] EMC_FREQ 4%@1600 GR3D_FREQ 2%@921 APE 25 PLL@40.5C CPU@44.5C PMIC@100C GPU@41C AO@51C thermal@43.25C POM_5V_IN 3080/2843 POM_5V_GPU 200/181 POM_5V_CPU 800/571
RAM 2174/3957MB (lfb 113x4MB) IRAM 0/252kB(lfb 252kB) CPU [59%@1428,46%@1428,51%@1428,66%@1428] EMC_FREQ 6%@1600 GR3D_FREQ 24%@921 APE 25 PLL@41C CPU@45.5C PMIC@100C GPU@41.5C AO@51.5C thermal@43.25C POM_5V_IN 4257/2961 POM_5V_GPU 630/219 POM_5V_CPU 1259/628
RAM 2273/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [22%@1428,17%@1428,37%@1428,20%@1428] EMC_FREQ 7%@1600 GR3D_FREQ 0%@921 APE 25 PLL@41C CPU@46C PMIC@100C GPU@41.5C AO@51.5C thermal@43.75C POM_5V_IN 3160/2976 POM_5V_GPU 199/217 POM_5V_CPU 918/651
RAM 2382/3957MB (lfb 109x4MB) IRAM 0/252kB(lfb 252kB) CPU [16%@1428,24%@1428,30%@1428,18%@1428] EMC_FREQ 7%@1600 GR3D_FREQ 0%@921 APE 25 PLL@41C CPU@45.5C PMIC@100C GPU@41.5C AO@51C thermal@43.25C POM_5V_IN 3234/2994 POM_5V_GPU 199/216 POM_5V_CPU 996/675
RAM 2497/3957MB (lfb 109x4MB) IRAM 0/252kB(lfb 252kB) CPU [4%@1428,8%@1428,41%@1428,13%@1428] EMC_FREQ 6%@1600 GR3D_FREQ 0%@921 APE 25 PLL@40C CPU@45C PMIC@100C GPU@41C AO@51C thermal@44C POM_5V_IN 2889/2987 POM_5V_GPU 160/212 POM_5V_CPU 600/670
RAM 2594/3957MB (lfb 109x4MB) IRAM 0/252kB(lfb 252kB) CPU [17%@1428,31%@1428,24%@1428,9%@1428] EMC_FREQ 6%@1600 GR3D_FREQ 1%@921 APE 25 PLL@40.5C CPU@45.5C PMIC@100C GPU@41C AO@51.5C thermal@43.75C POM_5V_IN 3234/3003 POM_5V_GPU 239/214 POM_5V_CPU 998/691
RAM 2745/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [2%@1428,37%@1428,20%@1428,3%@1428] EMC_FREQ 8%@1600 GR3D_FREQ 99%@921 APE 25 PLL@40.5C CPU@46C PMIC@100C GPU@42.5C AO@51.5C thermal@44.5C POM_5V_IN 4707/3103 POM_5V_GPU 2196/330 POM_5V_CPU 392/673
RAM 2745/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [2%@1428,1%@1428,1%@1428,3%@1428] EMC_FREQ 10%@1600 GR3D_FREQ 90%@921 APE 25 PLL@41C CPU@46.5C PMIC@100C GPU@42.5C AO@51.5C thermal@44.25C POM_5V_IN 5456/3234 POM_5V_GPU 2767/466 POM_5V_CPU 428/659
RAM 2762/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [9%@1428,12%@1428,8%@1428,6%@1428] EMC_FREQ 16%@1600 GR3D_FREQ 70%@921 APE 25 PLL@41C CPU@46.5C PMIC@100C GPU@42.5C AO@52C thermal@44.5C POM_5V_IN 4990/3326 POM_5V_GPU 1532/522 POM_5V_CPU 825/668
RAM 2834/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [4%@1428,28%@1428,21%@1428,3%@1428] EMC_FREQ 21%@1600 GR3D_FREQ 99%@921 APE 25 PLL@41.5C CPU@48C PMIC@100C GPU@44C AO@52C thermal@45.75C POM_5V_IN 7948/3557 POM_5V_GPU 4032/697 POM_5V_CPU 1152/692
RAM 2834/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [5%@1428,3%@1428,1%@1428,4%@1428] EMC_FREQ 26%@1600 GR3D_FREQ 99%@921 APE 25 PLL@41.5C CPU@48C PMIC@100C GPU@44C AO@52C thermal@45.75C POM_5V_IN 7435/3742 POM_5V_GPU 4038/856 POM_5V_CPU 385/678
RAM 2840/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [16%@1428,5%@1428,7%@1428,5%@1428] EMC_FREQ 31%@1600 GR3D_FREQ 99%@921 APE 25 PLL@41.5C CPU@47.5C PMIC@100C GPU@43.5C AO@52.5C thermal@46C POM_5V_IN 6205/3854 POM_5V_GPU 3446/974 POM_5V_CPU 387/664
RAM 2840/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [2%@1428,1%@1428,2%@1428,0%@1428] EMC_FREQ 30%@1600 GR3D_FREQ 99%@921 APE 25 PLL@41.5C CPU@47.5C PMIC@100C GPU@44C AO@52C thermal@46C POM_5V_IN 6254/3958 POM_5V_GPU 3296/1075 POM_5V_CPU 387/652
RAM 2840/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [2%@1428,0%@1428,0%@1428,0%@1428] EMC_FREQ 32%@1600 GR3D_FREQ 99%@921 APE 25 PLL@41.5C CPU@47.5C PMIC@100C GPU@43.5C AO@52.5C thermal@46C POM_5V_IN 6176/4050 POM_5V_GPU 3296/1167 POM_5V_CPU 388/641
RAM 2840/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [3%@1428,0%@1428,0%@1428,1%@1428] EMC_FREQ 28%@1600 GR3D_FREQ 99%@921 APE 25 PLL@41C CPU@47C PMIC@100C GPU@43.5C AO@52.5C thermal@45.25C POM_5V_IN 4896/4084 POM_5V_GPU 2424/1218 POM_5V_CPU 391/631
RAM 2840/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [0%@1428,0%@1428,2%@1428,2%@1428] EMC_FREQ 25%@1600 GR3D_FREQ 99%@921 APE 25 PLL@41.5C CPU@48C PMIC@100C GPU@44C AO@52.5C thermal@45.75C POM_5V_IN 6726/4186 POM_5V_GPU 3627/1310 POM_5V_CPU 425/623
RAM 2840/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [4%@1428,2%@1428,1%@1428,1%@1428] EMC_FREQ 26%@1600 GR3D_FREQ 99%@921 APE 25 PLL@41.5C CPU@48C PMIC@100C GPU@44C AO@52.5C thermal@46C POM_5V_IN 6205/4261 POM_5V_GPU 3412/1388 POM_5V_CPU 426/616
RAM 2840/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [2%@1428,0%@1428,0%@1428,2%@1428] EMC_FREQ 25%@1600 GR3D_FREQ 99%@921 APE 25 PLL@41.5C CPU@49C PMIC@100C GPU@45C AO@53C thermal@46.75C POM_5V_IN 6621/4345 POM_5V_GPU 4097/1485 POM_5V_CPU 386/608
RAM 2840/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [0%@1428,1%@1428,1%@1428,0%@1428] EMC_FREQ 26%@1600 GR3D_FREQ 99%@921 APE 25 PLL@42.5C CPU@48.5C PMIC@100C GPU@44.5C AO@53C thermal@47C POM_5V_IN 6776/4429 POM_5V_GPU 3865/1567 POM_5V_CPU 425/601
RAM 2840/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [4%@1428,1%@1428,1%@1428,3%@1428] EMC_FREQ 27%@1600 GR3D_FREQ 99%@921 APE 25 PLL@42C CPU@48.5C PMIC@100C GPU@44.5C AO@53C thermal@46.25C POM_5V_IN 7062/4516 POM_5V_GPU 3891/1644 POM_5V_CPU 385/594
RAM 2840/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [0%@1428,1%@1428,2%@1428,2%@1428] EMC_FREQ 28%@1600 GR3D_FREQ 99%@921 APE 25 PLL@42C CPU@48C PMIC@100C GPU@44C AO@53C thermal@46.25C POM_5V_IN 6321/4575 POM_5V_GPU 3291/1698 POM_5V_CPU 388/587
RAM 2840/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [0%@1428,1%@1428,1%@1428,1%@1428] EMC_FREQ 29%@1600 GR3D_FREQ 99%@921 APE 25 PLL@42.5C CPU@48.5C PMIC@100C GPU@45C AO@53.5C thermal@46.25C POM_5V_IN 6515/4635 POM_5V_GPU 3407/1751 POM_5V_CPU 426/582
RAM 2840/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [2%@1428,0%@1428,0%@1428,1%@1428] EMC_FREQ 31%@1600 GR3D_FREQ 99%@921 APE 25 PLL@42.5C CPU@48.5C PMIC@100C GPU@45C AO@53.5C thermal@46.5C POM_5V_IN 6764/4700 POM_5V_GPU 3627/1808 POM_5V_CPU 386/576
RAM 2840/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [1%@1428,4%@1428,2%@1428,0%@1428] EMC_FREQ 31%@1600 GR3D_FREQ 99%@921 APE 25 PLL@42.5C CPU@49C PMIC@100C GPU@45C AO@53.5C thermal@46.75C POM_5V_IN 6842/4763 POM_5V_GPU 4052/1874 POM_5V_CPU 385/571
RAM 2840/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [1%@1428,1%@1428,1%@1428,2%@1428] EMC_FREQ 29%@1600 GR3D_FREQ 99%@921 APE 25 PLL@42.5C CPU@49C PMIC@100C GPU@45C AO@53.5C thermal@46.75C POM_5V_IN 7139/4831 POM_5V_GPU 4083/1937 POM_5V_CPU 385/565
RAM 2840/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [3%@1428,1%@1428,1%@1428,3%@1428] EMC_FREQ 29%@1600 GR3D_FREQ 99%@921 APE 25 PLL@43C CPU@49C PMIC@100C GPU@45.5C AO@54C thermal@47C POM_5V_IN 7204/4897 POM_5V_GPU 4077/1996 POM_5V_CPU 385/560
RAM 2841/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [5%@1428,2%@1428,2%@1428,4%@1428] EMC_FREQ 30%@1600 GR3D_FREQ 99%@921 APE 25 PLL@43C CPU@48.5C PMIC@100C GPU@44.5C AO@54C thermal@47C POM_5V_IN 5797/4921 POM_5V_GPU 3112/2026 POM_5V_CPU 505/559
RAM 2841/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [11%@1428,12%@1428,7%@1428,4%@1428] EMC_FREQ 26%@1600 GR3D_FREQ 99%@921 APE 25 PLL@43C CPU@49C PMIC@100C GPU@45C AO@53.5C thermal@46.5C POM_5V_IN 6244/4956 POM_5V_GPU 3600/2068 POM_5V_CPU 425/555
RAM 2858/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [27%@1428,43%@1428,52%@1428,35%@1428] EMC_FREQ 25%@1600 GR3D_FREQ 99%@921 APE 25 PLL@43C CPU@49C PMIC@100C GPU@45C AO@53.5C thermal@47.25C POM_5V_IN 6427/4993 POM_5V_GPU 2976/2091 POM_5V_CPU 927/565
RAM 2854/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [21%@1428,33%@1428,20%@1428,43%@1428] EMC_FREQ 28%@1600 GR3D_FREQ 99%@921 APE 25 PLL@43C CPU@49C PMIC@100C GPU@45C AO@54C thermal@47C POM_5V_IN 6360/5028 POM_5V_GPU 3600/2129 POM_5V_CPU 504/563
RAM 2855/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [27%@1428,10%@1428,9%@1428,16%@1428] EMC_FREQ 24%@1600 GR3D_FREQ 99%@921 APE 25 PLL@43C CPU@49C PMIC@100C GPU@45C AO@53.5C thermal@47C POM_5V_IN 6089/5053 POM_5V_GPU 3291/2157 POM_5V_CPU 580/564
RAM 2855/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [14%@1428,15%@1428,3%@1428,6%@1428] EMC_FREQ 25%@1600 GR3D_FREQ 99%@921 APE 25 PLL@43C CPU@49C PMIC@100C GPU@45.5C AO@54C thermal@47C POM_5V_IN 6869/5097 POM_5V_GPU 4006/2201 POM_5V_CPU 656/566
RAM 2855/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [16%@1428,7%@1428,14%@1428,14%@1428] EMC_FREQ 24%@1600 GR3D_FREQ 99%@921 APE 25 PLL@43.5C CPU@49C PMIC@100C GPU@45.5C AO@54C thermal@47.5C POM_5V_IN 6099/5120 POM_5V_GPU 3180/2224 POM_5V_CPU 659/568
RAM 2865/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [11%@1428,13%@1428,7%@1428,5%@1428] EMC_FREQ 29%@1600 GR3D_FREQ 90%@921 APE 25 PLL@43C CPU@48.5C PMIC@100C GPU@44.5C AO@54C thermal@47.25C POM_5V_IN 5573/5130 POM_5V_GPU 2377/2227 POM_5V_CPU 467/566
RAM 2866/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [6%@1428,6%@1428,1%@1428,0%@1428] EMC_FREQ 35%@1600 GR3D_FREQ 77%@921 APE 25 PLL@43.5C CPU@49C PMIC@100C GPU@45.5C AO@54C thermal@47C POM_5V_IN 7100/5174 POM_5V_GPU 3538/2256 POM_5V_CPU 423/563
RAM 2866/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [0%@1428,1%@1428,1%@1428,1%@1428] EMC_FREQ 39%@1600 GR3D_FREQ 99%@921 APE 25 PLL@43.5C CPU@49C PMIC@100C GPU@45.5C AO@54C thermal@47.25C POM_5V_IN 7062/5215 POM_5V_GPU 3704/2288 POM_5V_CPU 424/560
RAM 2866/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [1%@1428,1%@1428,0%@1428,1%@1428] EMC_FREQ 38%@1600 GR3D_FREQ 90%@921 APE 25 PLL@43.5C CPU@48.5C PMIC@100C GPU@45C AO@54C thermal@47C POM_5V_IN 5044/5211 POM_5V_GPU 2346/2289 POM_5V_CPU 391/556
RAM 2866/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [6%@1428,6%@1428,6%@1428,4%@1428] EMC_FREQ 41%@1600 GR3D_FREQ 99%@921 APE 25 PLL@43.5C CPU@49.5C PMIC@100C GPU@45.5C AO@54C thermal@47.5C POM_5V_IN 6792/5244 POM_5V_GPU 3473/2314 POM_5V_CPU 501/555
RAM 2866/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [22%@1428,8%@1428,12%@1428,8%@1428] EMC_FREQ 45%@1600 GR3D_FREQ 95%@921 APE 25 PLL@44C CPU@49.5C PMIC@100C GPU@46.5C AO@54.5C thermal@47.75C POM_5V_IN 7769/5296 POM_5V_GPU 4108/2350 POM_5V_CPU 422/552
RAM 2866/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [14%@1428,7%@1428,7%@1428,2%@1428] EMC_FREQ 46%@1600 GR3D_FREQ 99%@921 APE 25 PLL@43.5C CPU@49C PMIC@100C GPU@45.5C AO@54.5C thermal@47.75C POM_5V_IN 6388/5318 POM_5V_GPU 3252/2368 POM_5V_CPU 425/550
RAM 2866/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [7%@1428,9%@1428,5%@1428,3%@1428] EMC_FREQ 46%@1600 GR3D_FREQ 99%@921 APE 25 PLL@44C CPU@49.5C PMIC@100C GPU@46C AO@54.5C thermal@47.25C POM_5V_IN 7320/5357 POM_5V_GPU 3461/2390 POM_5V_CPU 1000/558
RAM 2866/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [11%@1428,5%@1428,5%@1428,7%@1428] EMC_FREQ 45%@1600 GR3D_FREQ 99%@921 APE 25 PLL@44C CPU@50C PMIC@100C GPU@46.5C AO@55C thermal@47.75C POM_5V_IN 7654/5401 POM_5V_GPU 4070/2422 POM_5V_CPU 384/555
RAM 2866/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [6%@1428,2%@1428,6%@1428,3%@1428] EMC_FREQ 45%@1600 GR3D_FREQ 99%@921 APE 25 PLL@44C CPU@49.5C PMIC@100C GPU@46C AO@54.5C thermal@48.25C POM_5V_IN 6399/5420 POM_5V_GPU 3374/2440 POM_5V_CPU 426/553
RAM 2866/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [12%@1428,8%@1428,3%@1428,4%@1428] EMC_FREQ 39%@1600 GR3D_FREQ 99%@921 APE 25 PLL@43.5C CPU@49.5C PMIC@100C GPU@46C AO@55C thermal@47.75C POM_5V_IN 5866/5428 POM_5V_GPU 3219/2455 POM_5V_CPU 426/550
RAM 2866/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [6%@1428,17%@1428,12%@1428,8%@1428] EMC_FREQ 34%@1600 GR3D_FREQ 99%@921 APE 25 PLL@44.5C CPU@50C PMIC@100C GPU@45.5C AO@55C thermal@48.5C POM_5V_IN 6532/5448 POM_5V_GPU 3015/2465 POM_5V_CPU 1198/562
RAM 2866/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [19%@1428,15%@1428,12%@1428,5%@1428] EMC_FREQ 32%@1600 GR3D_FREQ 99%@921 APE 25 PLL@44C CPU@50C PMIC@100C GPU@46.5C AO@55C thermal@47.5C POM_5V_IN 6830/5473 POM_5V_GPU 3428/2482 POM_5V_CPU 578/562
RAM 2866/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [4%@1428,0%@1428,3%@1428,1%@1428] EMC_FREQ 41%@1600 GR3D_FREQ 99%@921 APE 25 PLL@44C CPU@50.5C PMIC@100C GPU@46.5C AO@55C thermal@48.5C POM_5V_IN 7243/5504 POM_5V_GPU 3577/2501 POM_5V_CPU 423/560
RAM 2866/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [5%@1428,9%@1428,3%@1428,3%@1428] EMC_FREQ 47%@1600 GR3D_FREQ 99%@921 APE 25 PLL@44.5C CPU@50.5C PMIC@100C GPU@47C AO@55C thermal@48.5C POM_5V_IN 6969/5529 POM_5V_GPU 3401/2517 POM_5V_CPU 425/557
RAM 2866/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [0%@1428,7%@1428,1%@1428,1%@1428] EMC_FREQ 50%@1600 GR3D_FREQ 99%@921 APE 25 PLL@44.5C CPU@50C PMIC@100C GPU@47C AO@55C thermal@48.75C POM_5V_IN 7615/5564 POM_5V_GPU 3878/2540 POM_5V_CPU 422/555
RAM 2866/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [3%@1428,1%@1428,2%@1428,0%@1428] EMC_FREQ 47%@1600 GR3D_FREQ 99%@921 APE 25 PLL@44.5C CPU@50.5C PMIC@100C GPU@46C AO@55.5C thermal@48.75C POM_5V_IN 6830/5586 POM_5V_GPU 3318/2553 POM_5V_CPU 463/554
RAM 2866/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [3%@1428,0%@1428,2%@1428,3%@1428] EMC_FREQ 46%@1600 GR3D_FREQ 99%@921 APE 25 PLL@44C CPU@50C PMIC@100C GPU@46C AO@55.5C thermal@48.5C POM_5V_IN 5122/5578 POM_5V_GPU 2420/2550 POM_5V_CPU 390/551
RAM 2866/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [0%@1428,7%@1428,2%@1428,0%@1428] EMC_FREQ 44%@1600 GR3D_FREQ 99%@921 APE 25 PLL@45C CPU@50.5C PMIC@100C GPU@46.5C AO@55.5C thermal@48.25C POM_5V_IN 6803/5598 POM_5V_GPU 3318/2563 POM_5V_CPU 463/550
RAM 2866/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [3%@1428,0%@1428,2%@1428,1%@1428] EMC_FREQ 44%@1600 GR3D_FREQ 99%@921 APE 25 PLL@44.5C CPU@50.5C PMIC@100C GPU@46.5C AO@55.5C thermal@48.75C POM_5V_IN 7089/5621 POM_5V_GPU 3500/2578 POM_5V_CPU 423/548
RAM 2866/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [2%@1428,0%@1428,1%@1428,3%@1428] EMC_FREQ 49%@1600 GR3D_FREQ 99%@921 APE 25 PLL@45C CPU@51C PMIC@100C GPU@47C AO@55.5C thermal@49C POM_5V_IN 7948/5658 POM_5V_GPU 4101/2601 POM_5V_CPU 421/546
RAM 2866/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [3%@1428,3%@1428,2%@1428,0%@1428] EMC_FREQ 52%@1600 GR3D_FREQ 99%@921 APE 25 PLL@45C CPU@50.5C PMIC@100C GPU@47C AO@55.5C thermal@49C POM_5V_IN 7100/5680 POM_5V_GPU 3621/2617 POM_5V_CPU 462/544
RAM 2866/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [4%@1428,1%@1428,1%@1428,1%@1428] EMC_FREQ 54%@1600 GR3D_FREQ 99%@921 APE 25 PLL@44.5C CPU@50.5C PMIC@100C GPU@46.5C AO@56C thermal@48.75C POM_5V_IN 6543/5693 POM_5V_GPU 2976/2623 POM_5V_CPU 425/542
RAM 2866/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [2%@1428,2%@1428,3%@1428,1%@1428] EMC_FREQ 53%@1600 GR3D_FREQ 99%@921 APE 25 PLL@44.5C CPU@51C PMIC@100C GPU@47.5C AO@56C thermal@49C POM_5V_IN 7756/5724 POM_5V_GPU 4063/2644 POM_5V_CPU 422/541
RAM 2866/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [1%@1428,0%@1428,1%@1428,1%@1428] EMC_FREQ 53%@1600 GR3D_FREQ 64%@921 APE 25 PLL@44.5C CPU@51C PMIC@100C GPU@47C AO@56C thermal@49C POM_5V_IN 6996/5742 POM_5V_GPU 3434/2656 POM_5V_CPU 463/539
RAM 2866/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [8%@1428,12%@1428,3%@1428,1%@1428] EMC_FREQ 50%@1600 GR3D_FREQ 99%@921 APE 25 PLL@45C CPU@51C PMIC@100C GPU@47C AO@56C thermal@49C POM_5V_IN 6919/5759 POM_5V_GPU 3434/2667 POM_5V_CPU 694/542
RAM 2867/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [25%@1428,10%@1428,9%@1428,15%@1428] EMC_FREQ 50%@1600 GR3D_FREQ 99%@921 APE 25 PLL@45.5C CPU@51.5C PMIC@100C GPU@47.5C AO@56C thermal@49C POM_5V_IN 7641/5786 POM_5V_GPU 3948/2685 POM_5V_CPU 460/541
RAM 2867/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [3%@1428,1%@1428,1%@1428,0%@1428] EMC_FREQ 51%@1600 GR3D_FREQ 99%@921 APE 25 PLL@45C CPU@51.5C PMIC@100C GPU@47.5C AO@56C thermal@49.5C POM_5V_IN 7756/5814 POM_5V_GPU 4025/2704 POM_5V_CPU 422/539
RAM 2867/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [1%@1428,0%@1428,3%@1428,1%@1428] EMC_FREQ 52%@1600 GR3D_FREQ 66%@921 APE 25 PLL@45.5C CPU@51C PMIC@100C GPU@47C AO@56.5C thermal@49.5C POM_5V_IN 6670/5826 POM_5V_GPU 3368/2713 POM_5V_CPU 465/538
RAM 2867/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [9%@1428,25%@1428,6%@1428,5%@1428] EMC_FREQ 42%@1600 GR3D_FREQ 99%@921 APE 25 PLL@46C CPU@51.5C PMIC@100C GPU@47.5C AO@56.5C thermal@49C POM_5V_IN 6803/5839 POM_5V_GPU 3434/2723 POM_5V_CPU 964/544
RAM 2866/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [9%@1428,15%@1428,6%@1428,10%@1428] EMC_FREQ 40%@1600 GR3D_FREQ 99%@921 APE 25 PLL@45C CPU@51C PMIC@100C GPU@47.5C AO@56.5C thermal@49C POM_5V_IN 6311/5846 POM_5V_GPU 3523/2734 POM_5V_CPU 464/543
RAM 2867/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [3%@1428,3%@1428,3%@1428,1%@1428] EMC_FREQ 33%@1600 GR3D_FREQ 99%@921 APE 25 PLL@45.5C CPU@51.5C PMIC@100C GPU@47C AO@56.5C thermal@49.5C POM_5V_IN 6205/5851 POM_5V_GPU 3562/2745 POM_5V_CPU 426/541
RAM 2866/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [0%@1428,2%@1428,2%@1428,4%@1428] EMC_FREQ 30%@1600 GR3D_FREQ 99%@921 APE 25 PLL@45.5C CPU@51.5C PMIC@100C GPU@47.5C AO@56.5C thermal@49C POM_5V_IN 6089/5854 POM_5V_GPU 3451/2754 POM_5V_CPU 465/540
RAM 2867/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [22%@1428,24%@1428,10%@1428,12%@1428] EMC_FREQ 31%@1600 GR3D_FREQ 81%@921 APE 25 PLL@45C CPU@51C PMIC@100C GPU@47C AO@56.5C thermal@49.5C POM_5V_IN 5426/5848 POM_5V_GPU 2299/2748 POM_5V_CPU 506/540
RAM 2869/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [14%@1428,16%@1428,7%@1428,5%@1428] EMC_FREQ 36%@1600 GR3D_FREQ 90%@921 APE 25 PLL@45.5C CPU@52C PMIC@100C GPU@47.5C AO@57C thermal@50C POM_5V_IN 7243/5866 POM_5V_GPU 3500/2758 POM_5V_CPU 423/538
RAM 2869/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [1%@1428,3%@1428,2%@1428,2%@1428] EMC_FREQ 43%@1600 GR3D_FREQ 75%@921 APE 25 PLL@46C CPU@52.5C PMIC@100C GPU@48C AO@56.5C thermal@50C POM_5V_IN 7201/5883 POM_5V_GPU 3434/2767 POM_5V_CPU 502/538
RAM 2869/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [0%@1428,0%@1428,4%@1428,0%@1428] EMC_FREQ 44%@1600 GR3D_FREQ 99%@921 APE 25 PLL@45.5C CPU@51.5C PMIC@100C GPU@47.5C AO@57C thermal@50C POM_5V_IN 5642/5880 POM_5V_GPU 2563/2764 POM_5V_CPU 428/536
RAM 2869/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [2%@1428,0%@1428,5%@1428,2%@1428] EMC_FREQ 47%@1600 GR3D_FREQ 99%@921 APE 25 PLL@46C CPU@52C PMIC@100C GPU@48C AO@57C thermal@49.5C POM_5V_IN 6946/5893 POM_5V_GPU 3583/2774 POM_5V_CPU 424/535
RAM 2869/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [0%@1428,4%@1428,3%@1428,0%@1428] EMC_FREQ 52%@1600 GR3D_FREQ 99%@921 APE 25 PLL@46C CPU@52.5C PMIC@100C GPU@49C AO@57C thermal@50C POM_5V_IN 8151/5921 POM_5V_GPU 4241/2792 POM_5V_CPU 420/533
RAM 2869/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [12%@1428,16%@1428,8%@1428,6%@1428] EMC_FREQ 53%@1600 GR3D_FREQ 99%@921 APE 25 PLL@46C CPU@52C PMIC@100C GPU@48C AO@57C thermal@50.5C POM_5V_IN 6648/5929 POM_5V_GPU 3357/2799 POM_5V_CPU 425/532
RAM 2869/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [13%@1428,7%@1428,5%@1428,17%@1428] EMC_FREQ 52%@1600 GR3D_FREQ 99%@921 APE 25 PLL@46.5C CPU@52.5C PMIC@100C GPU@48C AO@57.5C thermal@50.25C POM_5V_IN 7293/5946 POM_5V_GPU 3164/2803 POM_5V_CPU 1119/539
RAM 2869/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [16%@1428,20%@1428,6%@1428,6%@1428] EMC_FREQ 52%@1600 GR3D_FREQ 99%@921 APE 25 PLL@46C CPU@52.5C PMIC@100C GPU@48.5C AO@57.5C thermal@50.5C POM_5V_IN 7858/5968 POM_5V_GPU 4018/2817 POM_5V_CPU 536/539
RAM 2868/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [12%@1428,7%@1428,10%@1428,8%@1428] EMC_FREQ 52%@1600 GR3D_FREQ 99%@921 APE 25 PLL@46.5C CPU@52.5C PMIC@100C GPU@48C AO@57.5C thermal@50.75C POM_5V_IN 6515/5974 POM_5V_GPU 3213/2822 POM_5V_CPU 736/541
RAM 2869/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [14%@1428,9%@1428,7%@1428,4%@1428] EMC_FREQ 44%@1600 GR3D_FREQ 99%@921 APE 25 PLL@45.5C CPU@52C PMIC@100C GPU@48C AO@57.5C thermal@50.25C POM_5V_IN 6166/5977 POM_5V_GPU 3329/2828 POM_5V_CPU 619/542
RAM 2869/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [30%@1428,17%@1428,21%@1428,20%@1428] EMC_FREQ 37%@1600 GR3D_FREQ 99%@921 APE 25 PLL@46C CPU@52C PMIC@100C GPU@48C AO@57.5C thermal@50C POM_5V_IN 5720/5974 POM_5V_GPU 2801/2828 POM_5V_CPU 622/543
RAM 2866/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [19%@1428,16%@1428,18%@1428,22%@1428] EMC_FREQ 34%@1600 GR3D_FREQ 99%@921 APE 25 PLL@46.5C CPU@53C PMIC@100C GPU@48.5C AO@58C thermal@50.5C POM_5V_IN 7718/5993 POM_5V_GPU 3488/2835 POM_5V_CPU 1265/551
RAM 2866/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [18%@1428,28%@1428,10%@1428,12%@1428] EMC_FREQ 43%@1600 GR3D_FREQ 99%@921 APE 25 PLL@47C CPU@52.5C PMIC@100C GPU@49C AO@58C thermal@50.5C POM_5V_IN 7654/6012 POM_5V_GPU 3532/2843 POM_5V_CPU 729/553
RAM 2866/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [12%@1428,8%@1428,5%@1428,6%@1428] EMC_FREQ 48%@1600 GR3D_FREQ 99%@921 APE 25 PLL@46.5C CPU@52.5C PMIC@100C GPU@48.5C AO@58C thermal@50.75C POM_5V_IN 6907/6022 POM_5V_GPU 3428/2849 POM_5V_CPU 463/552
RAM 2866/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [3%@1428,5%@1428,5%@1428,1%@1428] EMC_FREQ 51%@1600 GR3D_FREQ 99%@921 APE 25 PLL@47C CPU@52.5C PMIC@100C GPU@48.5C AO@57.5C thermal@50.75C POM_5V_IN 7204/6034 POM_5V_GPU 3615/2857 POM_5V_CPU 461/551
RAM 2866/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [3%@1428,5%@1428,8%@1428,2%@1428] EMC_FREQ 50%@1600 GR3D_FREQ 99%@921 APE 25 PLL@46.5C CPU@52.5C PMIC@100C GPU@49C AO@58C thermal@51C POM_5V_IN 7062/6045 POM_5V_GPU 3506/2864 POM_5V_CPU 423/550
RAM 2866/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [5%@1428,14%@1428,3%@1428,4%@1428] EMC_FREQ 48%@1600 GR3D_FREQ 99%@921 APE 25 PLL@47C CPU@52.5C PMIC@100C GPU@48.5C AO@58C thermal@50.75C POM_5V_IN 6184/6047 POM_5V_GPU 2662/2862 POM_5V_CPU 656/551
RAM 2866/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [5%@1428,1%@1428,6%@1428,1%@1428] EMC_FREQ 50%@1600 GR3D_FREQ 99%@921 APE 25 PLL@47C CPU@53C PMIC@100C GPU@49C AO@58C thermal@51C POM_5V_IN 7089/6058 POM_5V_GPU 3506/2869 POM_5V_CPU 462/550
RAM 2866/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [6%@1428,1%@1428,5%@1428,2%@1428] EMC_FREQ 54%@1600 GR3D_FREQ 99%@921 APE 25 PLL@47C CPU@53C PMIC@100C GPU@49C AO@58C thermal@51C POM_5V_IN 7281/6071 POM_5V_GPU 3230/2873 POM_5V_CPU 423/549
RAM 2866/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [3%@1428,1%@1428,9%@1428,1%@1428] EMC_FREQ 58%@1600 GR3D_FREQ 57%@921 APE 25 PLL@47.5C CPU@53C PMIC@100C GPU@49C AO@58C thermal@51.5C POM_5V_IN 7008/6080 POM_5V_GPU 3247/2877 POM_5V_CPU 579/549
RAM 2866/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [1%@1428,7%@1428,3%@1428,1%@1428] EMC_FREQ 57%@1600 GR3D_FREQ 99%@921 APE 25 PLL@47C CPU@53.5C PMIC@100C GPU@49C AO@58C thermal@51.25C POM_5V_IN 7062/6090 POM_5V_GPU 3660/2885 POM_5V_CPU 462/548
RAM 2866/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [3%@1428,2%@1428,5%@1428,2%@1428] EMC_FREQ 58%@1600 GR3D_FREQ 99%@921 APE 25 PLL@47C CPU@53C PMIC@100C GPU@49C AO@58C thermal@51C POM_5V_IN 6687/6096 POM_5V_GPU 3318/2889 POM_5V_CPU 463/547
RAM 2866/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [1%@1428,0%@1428,5%@1428,1%@1428] EMC_FREQ 56%@1600 GR3D_FREQ 99%@921 APE 25 PLL@47C CPU@54C PMIC@100C GPU@49.5C AO@58.5C thermal@51C POM_5V_IN 8012/6115 POM_5V_GPU 4171/2902 POM_5V_CPU 421/546
RAM 2866/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [1%@1428,3%@1428,3%@1428,3%@1428] EMC_FREQ 54%@1600 GR3D_FREQ 99%@921 APE 25 PLL@47C CPU@53.5C PMIC@100C GPU@49C AO@58C thermal@51C POM_5V_IN 7127/6125 POM_5V_GPU 3583/2909 POM_5V_CPU 423/545
RAM 2866/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [4%@1428,1%@1428,5%@1428,6%@1428] EMC_FREQ 54%@1600 GR3D_FREQ 99%@921 APE 25 PLL@47.5C CPU@53.5C PMIC@100C GPU@49.5C AO@58.5C thermal@51.5C POM_5V_IN 7718/6141 POM_5V_GPU 3680/2916 POM_5V_CPU 460/544
RAM 2866/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [3%@1428,1%@1428,5%@1428,5%@1428] EMC_FREQ 54%@1600 GR3D_FREQ 62%@921 APE 25 PLL@47.5C CPU@53.5C PMIC@100C GPU@50C AO@58.5C thermal@51.25C POM_5V_IN 7330/6153 POM_5V_GPU 3335/2920 POM_5V_CPU 582/544
RAM 2866/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [7%@1428,1%@1428,4%@1428,1%@1428] EMC_FREQ 56%@1600 GR3D_FREQ 99%@921 APE 25 PLL@47.5C CPU@54C PMIC@100C GPU@50C AO@58.5C thermal@51.5C POM_5V_IN 7718/6168 POM_5V_GPU 3704/2928 POM_5V_CPU 541/544
RAM 2866/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [3%@1428,3%@1428,2%@1428,4%@1428] EMC_FREQ 52%@1600 GR3D_FREQ 99%@921 APE 25 PLL@47C CPU@53.5C PMIC@100C GPU@49C AO@58.5C thermal@51.75C POM_5V_IN 6021/6166 POM_5V_GPU 3412/2932 POM_5V_CPU 426/543
RAM 2866/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [2%@1428,0%@1428,7%@1428,2%@1428] EMC_FREQ 41%@1600 GR3D_FREQ 99%@921 APE 25 PLL@47.5C CPU@53.5C PMIC@100C GPU@49C AO@58.5C thermal@51.25C POM_5V_IN 6089/6165 POM_5V_GPU 3451/2937 POM_5V_CPU 465/542
RAM 2866/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [3%@1428,1%@1428,5%@1428,1%@1428] EMC_FREQ 38%@1600 GR3D_FREQ 99%@921 APE 25 PLL@47.5C CPU@53.5C PMIC@100C GPU@49.5C AO@58.5C thermal@51.25C POM_5V_IN 6311/6167 POM_5V_GPU 3633/2944 POM_5V_CPU 464/542
RAM 2866/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [3%@1428,7%@1428,3%@1428,2%@1428] EMC_FREQ 32%@1600 GR3D_FREQ 99%@921 APE 25 PLL@47.5C CPU@53.5C PMIC@100C GPU@49.5C AO@59C thermal@51.75C POM_5V_IN 6388/6169 POM_5V_GPU 3672/2950 POM_5V_CPU 425/541
RAM 2866/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [3%@1428,2%@1428,3%@1428,4%@1428] EMC_FREQ 29%@1600 GR3D_FREQ 99%@921 APE 25 PLL@48C CPU@53.5C PMIC@100C GPU@49C AO@59C thermal@51.25C POM_5V_IN 5982/6167 POM_5V_GPU 3257/2953 POM_5V_CPU 465/540
RAM 2866/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [0%@1428,7%@1428,11%@1428,3%@1428] EMC_FREQ 31%@1600 GR3D_FREQ 99%@921 APE 25 PLL@48C CPU@54C PMIC@100C GPU@50C AO@59C thermal@51.25C POM_5V_IN 7897/6183 POM_5V_GPU 3910/2962 POM_5V_CPU 460/539
RAM 2866/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [3%@1428,6%@1428,5%@1428,1%@1428] EMC_FREQ 42%@1600 GR3D_FREQ 99%@921 APE 25 PLL@48.5C CPU@54C PMIC@100C GPU@50C AO@59C thermal@52.25C POM_5V_IN 7089/6191 POM_5V_GPU 3384/2966 POM_5V_CPU 538/539
RAM 2866/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [4%@1428,1%@1428,3%@1428,0%@1428] EMC_FREQ 47%@1600 GR3D_FREQ 99%@921 APE 25 PLL@48.5C CPU@54C PMIC@100C GPU@50C AO@59C thermal@52.25C POM_5V_IN 6907/6197 POM_5V_GPU 3467/2970 POM_5V_CPU 424/538
RAM 2866/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [1%@1428,1%@1428,4%@1428,6%@1428] EMC_FREQ 50%@1600 GR3D_FREQ 99%@921 APE 25 PLL@48.5C CPU@54.5C PMIC@100C GPU@50C AO@59C thermal@52C POM_5V_IN 7320/6207 POM_5V_GPU 3769/2977 POM_5V_CPU 423/537
RAM 2866/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [12%@1428,4%@1428,11%@1428,0%@1428] EMC_FREQ 49%@1600 GR3D_FREQ 49%@921 APE 25 PLL@48.5C CPU@54C PMIC@100C GPU@49.5C AO@59.5C thermal@52.25C POM_5V_IN 6526/6210 POM_5V_GPU 2753/2975 POM_5V_CPU 813/539
RAM 2866/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [14%@1428,16%@1428,5%@1428,10%@1428] EMC_FREQ 48%@1600 GR3D_FREQ 90%@921 APE 25 PLL@48.5C CPU@54C PMIC@100C GPU@50C AO@59.5C thermal@51.75C POM_5V_IN 7320/6220 POM_5V_GPU 3461/2980 POM_5V_CPU 653/540
RAM 2866/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [29%@1428,14%@1428,16%@1428,10%@1428] EMC_FREQ 49%@1600 GR3D_FREQ 99%@921 APE 25 PLL@49C CPU@54.5C PMIC@100C GPU@50.5C AO@60C thermal@52.25C POM_5V_IN 7641/6232 POM_5V_GPU 3066/2980 POM_5V_CPU 1418/548
RAM 2866/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [33%@1428,16%@1428,34%@1428,12%@1428] EMC_FREQ 52%@1600 GR3D_FREQ 93%@921 APE 25 PLL@49C CPU@55.5C PMIC@100C GPU@50.5C AO@60C thermal@53C POM_5V_IN 7718/6245 POM_5V_GPU 3143/2982 POM_5V_CPU 1267/554
RAM 2866/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [19%@1428,12%@1428,51%@1428,18%@1428] EMC_FREQ 55%@1600 GR3D_FREQ 99%@921 APE 25 PLL@49C CPU@56C PMIC@100C GPU@51C AO@60C thermal@53.5C POM_5V_IN 8305/6262 POM_5V_GPU 3591/2987 POM_5V_CPU 1375/561
RAM 2866/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [18%@1428,53%@1428,21%@1428,9%@1428] EMC_FREQ 55%@1600 GR3D_FREQ 99%@921 APE 25 PLL@49C CPU@54.5C PMIC@100C GPU@51C AO@60C thermal@52.75C POM_5V_IN 7089/6269 POM_5V_GPU 3654/2992 POM_5V_CPU 500/561
RAM 2866/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [36%@1428,19%@1428,18%@1428,12%@1428] EMC_FREQ 55%@1600 GR3D_FREQ 99%@921 APE 25 PLL@49.5C CPU@55C PMIC@100C GPU@50.5C AO@60C thermal@52.75C POM_5V_IN 7166/6277 POM_5V_GPU 2966/2992 POM_5V_CPU 1040/565
RAM 2866/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [19%@1428,11%@1428,8%@1428,18%@1428] EMC_FREQ 53%@1600 GR3D_FREQ 99%@921 APE 25 PLL@49C CPU@55C PMIC@100C GPU@50.5C AO@60C thermal@52.75C POM_5V_IN 7538/6287 POM_5V_GPU 3686/2998 POM_5V_CPU 614/565
RAM 2866/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [0%@1428,5%@1428,3%@1428,2%@1428] EMC_FREQ 53%@1600 GR3D_FREQ 99%@921 APE 25 PLL@49C CPU@55C PMIC@100C GPU@51.5C AO@60C thermal@53C POM_5V_IN 7358/6296 POM_5V_GPU 3654/3003 POM_5V_CPU 461/564
RAM 2866/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [2%@1428,10%@1428,1%@1428,1%@1428] EMC_FREQ 53%@1600 GR3D_FREQ 99%@921 APE 25 PLL@49C CPU@55C PMIC@100C GPU@50.5C AO@59.5C thermal@53C POM_5V_IN 6935/6301 POM_5V_GPU 3428/3007 POM_5V_CPU 462/563
RAM 2866/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [1%@1428,7%@1428,1%@1428,0%@1428] EMC_FREQ 53%@1600 GR3D_FREQ 99%@921 APE 25 PLL@49C CPU@55C PMIC@100C GPU@51C AO@60.5C thermal@53.25C POM_5V_IN 6792/6305 POM_5V_GPU 3589/3011 POM_5V_CPU 463/562
RAM 2866/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [2%@1428,3%@1428,4%@1428,1%@1428] EMC_FREQ 54%@1600 GR3D_FREQ 99%@921 APE 25 PLL@49C CPU@55.5C PMIC@100C GPU@51.5C AO@60C thermal@53C POM_5V_IN 7538/6315 POM_5V_GPU 3801/3018 POM_5V_CPU 460/562
RAM 2866/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [1%@1428,1%@1428,5%@1428,1%@1428] EMC_FREQ 55%@1600 GR3D_FREQ 96%@921 APE 25 PLL@49C CPU@55C PMIC@100C GPU@51C AO@60C thermal@53C POM_5V_IN 7385/6323 POM_5V_GPU 3648/3023 POM_5V_CPU 461/561
RAM 2866/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [2%@1428,1%@1428,7%@1428,1%@1428] EMC_FREQ 45%@1600 GR3D_FREQ 96%@921 APE 25 PLL@49C CPU@55C PMIC@100C GPU@51C AO@60.5C thermal@53C POM_5V_IN 6532/6325 POM_5V_GPU 3710/3028 POM_5V_CPU 463/560
RAM 2866/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [13%@1428,6%@1428,8%@1428,6%@1428] EMC_FREQ 40%@1600 GR3D_FREQ 99%@921 APE 25 PLL@49C CPU@55C PMIC@100C GPU@51C AO@60C thermal@52.75C POM_5V_IN 6156/6324 POM_5V_GPU 3324/3030 POM_5V_CPU 542/560
RAM 2866/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [7%@1428,3%@1428,4%@1428,1%@1428] EMC_FREQ 33%@1600 GR3D_FREQ 99%@921 APE 25 PLL@49C CPU@55C PMIC@100C GPU@51C AO@60C thermal@52.75C POM_5V_IN 6416/6324 POM_5V_GPU 3595/3035 POM_5V_CPU 463/559
RAM 2866/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [3%@1428,6%@1428,3%@1428,1%@1428] EMC_FREQ 31%@1600 GR3D_FREQ 99%@921 APE 25 PLL@49C CPU@54.5C PMIC@100C GPU@51C AO@60C thermal@53C POM_5V_IN 5720/6320 POM_5V_GPU 2879/3034 POM_5V_CPU 466/558
RAM 2866/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [2%@1428,1%@1428,8%@1428,6%@1428] EMC_FREQ 30%@1600 GR3D_FREQ 2%@921 APE 25 PLL@49C CPU@54.5C PMIC@100C GPU@50.5C AO@60.5C thermal@52.75C POM_5V_IN 4558/6306 POM_5V_GPU 1257/3020 POM_5V_CPU 943/561
RAM 2874/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [3%@1428,5%@1428,24%@1428,3%@1428] EMC_FREQ 36%@1600 GR3D_FREQ 0%@921 APE 25 PLL@49C CPU@55C PMIC@100C GPU@51C AO@61C thermal@52.75C POM_5V_IN 5914/6303 POM_5V_GPU 2111/3013 POM_5V_CPU 782/563
RAM 2874/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [2%@1428,4%@1428,19%@1428,1%@1428] EMC_FREQ 41%@1600 GR3D_FREQ 90%@921 APE 25 PLL@49.5C CPU@55.5C PMIC@100C GPU@51.5C AO@60.5C thermal@53.25C POM_5V_IN 7500/6312 POM_5V_GPU 3680/3018 POM_5V_CPU 498/563
RAM 2874/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [2%@1428,1%@1428,19%@1428,4%@1428] EMC_FREQ 43%@1600 GR3D_FREQ 99%@921 APE 25 PLL@49.5C CPU@55C PMIC@100C GPU@51C AO@60.5C thermal@53.5C POM_5V_IN 6973/6317 POM_5V_GPU 3428/3021 POM_5V_CPU 462/562
RAM 2874/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [11%@1428,3%@1428,19%@1428,3%@1428] EMC_FREQ 44%@1600 GR3D_FREQ 0%@921 APE 25 PLL@49.5C CPU@55C PMIC@100C GPU@50.5C AO@60.5C thermal@53.25C POM_5V_IN 5265/6309 POM_5V_GPU 1647/3011 POM_5V_CPU 822/564
RAM 2874/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [3%@1428,2%@1428,17%@1428,6%@1428] EMC_FREQ 48%@1600 GR3D_FREQ 9%@921 APE 25 PLL@49.5C CPU@55C PMIC@100C GPU@51C AO@60.5C thermal@53.75C POM_5V_IN 6011/6307 POM_5V_GPU 2361/3006 POM_5V_CPU 734/565
RAM 2874/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [4%@1428,2%@1428,18%@1428,2%@1428] EMC_FREQ 51%@1600 GR3D_FREQ 99%@921 APE 25 PLL@49.5C CPU@56C PMIC@100C GPU@51.5C AO@61C thermal@53.5C POM_5V_IN 7935/6319 POM_5V_GPU 3865/3013 POM_5V_CPU 459/564
RAM 2874/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [1%@1428,15%@1428,8%@1428,2%@1428] EMC_FREQ 50%@1600 GR3D_FREQ 99%@921 APE 25 PLL@49.5C CPU@56C PMIC@100C GPU@51.5C AO@60.5C thermal@53.5C POM_5V_IN 7935/6331 POM_5V_GPU 4095/3020 POM_5V_CPU 497/564
RAM 2874/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [3%@1428,23%@1428,0%@1428,3%@1428] EMC_FREQ 48%@1600 GR3D_FREQ 99%@921 APE 25 PLL@49.5C CPU@55.5C PMIC@100C GPU@51.5C AO@60.5C thermal@53.5C POM_5V_IN 6560/6332 POM_5V_GPU 3043/3021 POM_5V_CPU 617/564
RAM 2874/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [1%@1428,17%@1428,1%@1428,6%@1428] EMC_FREQ 49%@1600 GR3D_FREQ 99%@921 APE 25 PLL@49.5C CPU@55.5C PMIC@100C GPU@51.5C AO@60.5C thermal@53.5C POM_5V_IN 7127/6338 POM_5V_GPU 3538/3024 POM_5V_CPU 461/563
RAM 2874/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [2%@1428,20%@1428,1%@1428,3%@1428] EMC_FREQ 49%@1600 GR3D_FREQ 99%@921 APE 25 PLL@49.5C CPU@55.5C PMIC@100C GPU@51.5C AO@61C thermal@53.5C POM_5V_IN 6137/6337 POM_5V_GPU 3296/3026 POM_5V_CPU 504/563
RAM 2874/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [7%@1428,14%@1428,2%@1428,2%@1428] EMC_FREQ 41%@1600 GR3D_FREQ 99%@921 APE 25 PLL@50C CPU@55.5C PMIC@100C GPU@51.5C AO@61C thermal@53.5C POM_5V_IN 6166/6335 POM_5V_GPU 3329/3028 POM_5V_CPU 542/563
RAM 2874/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [1%@1428,12%@1428,2%@1428,3%@1428] EMC_FREQ 34%@1600 GR3D_FREQ 99%@921 APE 25 PLL@50C CPU@55.5C PMIC@100C GPU@51C AO@60.5C thermal@53.5C POM_5V_IN 5603/6330 POM_5V_GPU 2719/3026 POM_5V_CPU 505/562
RAM 2878/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [1%@1428,30%@1428,5%@1428,3%@1428] EMC_FREQ 30%@1600 GR3D_FREQ 90%@921 APE 25 PLL@50C CPU@55.5C PMIC@100C GPU@51.5C AO@61C thermal@52.5C POM_5V_IN 6973/6335 POM_5V_GPU 3461/3029 POM_5V_CPU 538/562
RAM 2878/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [8%@1428,19%@1428,9%@1428,1%@1428] EMC_FREQ 38%@1600 GR3D_FREQ 0%@921 APE 25 PLL@50.5C CPU@55.5C PMIC@100C GPU@51C AO@61.5C thermal@53.25C POM_5V_IN 4920/6325 POM_5V_GPU 1218/3017 POM_5V_CPU 943/565
RAM 2878/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [1%@1428,19%@1428,3%@1428,3%@1428] EMC_FREQ 43%@1600 GR3D_FREQ 99%@921 APE 25 PLL@50C CPU@56.5C PMIC@100C GPU@52C AO@61C thermal@54.25C POM_5V_IN 7858/6336 POM_5V_GPU 4056/3024 POM_5V_CPU 498/564
RAM 2878/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [2%@1428,22%@1428,1%@1428,1%@1428] EMC_FREQ 46%@1600 GR3D_FREQ 99%@921 APE 25 PLL@50C CPU@56.5C PMIC@100C GPU@52C AO@61.5C thermal@53.75C POM_5V_IN 7526/6344 POM_5V_GPU 3801/3029 POM_5V_CPU 460/564
RAM 2878/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [3%@1428,29%@1428,1%@1428,3%@1428] EMC_FREQ 46%@1600 GR3D_FREQ 71%@921 APE 25 PLL@50C CPU@55C PMIC@100C GPU@51C AO@61C thermal@54.25C POM_5V_IN 4997/6335 POM_5V_GPU 1559/3019 POM_5V_CPU 857/566
RAM 2878/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [6%@1428,19%@1428,2%@1428,1%@1428] EMC_FREQ 46%@1600 GR3D_FREQ 99%@921 APE 25 PLL@50.5C CPU@55.5C PMIC@100C GPU@51.5C AO@61.5C thermal@54.25C POM_5V_IN 5808/6331 POM_5V_GPU 2280/3014 POM_5V_CPU 695/566
RAM 2879/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [8%@1428,21%@1428,4%@1428,6%@1428] EMC_FREQ 44%@1600 GR3D_FREQ 99%@921 APE 25 PLL@50.5C CPU@56C PMIC@100C GPU@52C AO@61.5C thermal@54C POM_5V_IN 7027/6336 POM_5V_GPU 2836/3013 POM_5V_CPU 958/569
RAM 2879/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [30%@1428,21%@1428,5%@1428,4%@1428] EMC_FREQ 45%@1600 GR3D_FREQ 89%@921 APE 25 PLL@50.5C CPU@56.5C PMIC@100C GPU@52.5C AO@61.5C thermal@54.25C POM_5V_IN 7178/6341 POM_5V_GPU 3390/3015 POM_5V_CPU 732/570
RAM 2878/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [15%@1428,11%@1428,3%@1428,5%@1428] EMC_FREQ 49%@1600 GR3D_FREQ 99%@921 APE 25 PLL@50C CPU@56.5C PMIC@100C GPU@52.5C AO@61.5C thermal@53.25C POM_5V_IN 7308/6348 POM_5V_GPU 3807/3021 POM_5V_CPU 500/570
RAM 2879/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [17%@1428,13%@1428,12%@1428,3%@1428] EMC_FREQ 52%@1600 GR3D_FREQ 99%@921 APE 25 PLL@51C CPU@56.5C PMIC@100C GPU@52C AO@61.5C thermal@54.5C POM_5V_IN 7243/6353 POM_5V_GPU 3615/3025 POM_5V_CPU 500/569
RAM 2879/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [6%@1428,26%@1428,1%@1428,3%@1428] EMC_FREQ 54%@1600 GR3D_FREQ 0%@921 APE 25 PLL@50.5C CPU@55.5C PMIC@100C GPU@51.5C AO@61.5C thermal@54.75C POM_5V_IN 4920/6344 POM_5V_GPU 1141/3012 POM_5V_CPU 905/571
RAM 2879/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [0%@1428,20%@1428,2%@1428,4%@1428] EMC_FREQ 53%@1600 GR3D_FREQ 99%@921 APE 25 PLL@50.5C CPU@57C PMIC@100C GPU@53C AO@61.5C thermal@54.75C POM_5V_IN 7998/6355 POM_5V_GPU 3897/3018 POM_5V_CPU 497/571
RAM 2879/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [1%@1428,19%@1428,5%@1428,2%@1428] EMC_FREQ 54%@1600 GR3D_FREQ 99%@921 APE 25 PLL@50.5C CPU@56.5C PMIC@100C GPU@52C AO@62C thermal@54.5C POM_5V_IN 6830/6358 POM_5V_GPU 3428/3021 POM_5V_CPU 462/570
RAM 2879/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [2%@1428,20%@1428,6%@1428,1%@1428] EMC_FREQ 52%@1600 GR3D_FREQ 99%@921 APE 25 PLL@51C CPU@57C PMIC@100C GPU@53C AO@61.5C thermal@53.25C POM_5V_IN 7935/6368 POM_5V_GPU 4095/3027 POM_5V_CPU 460/570
RAM 2879/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [3%@1428,18%@1428,0%@1428,3%@1428] EMC_FREQ 51%@1600 GR3D_FREQ 99%@921 APE 25 PLL@51C CPU@57C PMIC@100C GPU@53C AO@61.5C thermal@54.75C POM_5V_IN 7795/6377 POM_5V_GPU 3871/3033 POM_5V_CPU 460/569
RAM 2879/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [2%@1428,28%@1428,2%@1428,1%@1428] EMC_FREQ 48%@1600 GR3D_FREQ 99%@921 APE 25 PLL@50.5C CPU@56.5C PMIC@100C GPU@52C AO@62C thermal@54.75C POM_5V_IN 6146/6375 POM_5V_GPU 2624/3030 POM_5V_CPU 656/569
RAM 2879/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [2%@1428,19%@1428,2%@1428,2%@1428] EMC_FREQ 51%@1600 GR3D_FREQ 99%@921 APE 25 PLL@50.5C CPU@56.5C PMIC@100C GPU@52.5C AO@62C thermal@54.5C POM_5V_IN 6676/6377 POM_5V_GPU 3428/3033 POM_5V_CPU 501/569
RAM 2879/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [9%@1428,14%@1428,12%@1428,15%@1428] EMC_FREQ 49%@1600 GR3D_FREQ 99%@921 APE 25 PLL@51C CPU@57C PMIC@100C GPU@52.5C AO@62C thermal@54.75C POM_5V_IN 7346/6383 POM_5V_GPU 3609/3036 POM_5V_CPU 538/569
RAM 2865/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [5%@1428,30%@1428,6%@1428,15%@1428] EMC_FREQ 51%@1600 GR3D_FREQ 0%@921 APE 25 PLL@51.5C CPU@56C PMIC@100C GPU@52C AO@62C thermal@54.5C POM_5V_IN 4612/6372 POM_5V_GPU 985/3024 POM_5V_CPU 944/571
RAM 2865/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [8%@1428,6%@1428,11%@1428,7%@1428] EMC_FREQ 48%@1600 GR3D_FREQ 90%@921 APE 25 PLL@51C CPU@56.5C PMIC@100C GPU@52.5C AO@62C thermal@55C POM_5V_IN 6283/6372 POM_5V_GPU 3329/3025 POM_5V_CPU 735/572
RAM 2865/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [8%@1428,10%@1428,1%@1428,0%@1428] EMC_FREQ 38%@1600 GR3D_FREQ 99%@921 APE 25 PLL@51C CPU@56.5C PMIC@100C GPU@52.5C AO@62C thermal@54.75C POM_5V_IN 6050/6370 POM_5V_GPU 3136/3026 POM_5V_CPU 696/573
RAM 2865/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [24%@1428,37%@1428,15%@1428,18%@1428] EMC_FREQ 37%@1600 GR3D_FREQ 99%@921 APE 25 PLL@51C CPU@57C PMIC@100C GPU@53C AO@62C thermal@54.5C POM_5V_IN 6427/6370 POM_5V_GPU 3595/3030 POM_5V_CPU 502/572
RAM 2866/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [19%@1428,14%@1428,11%@1428,8%@1428] EMC_FREQ 30%@1600 GR3D_FREQ 99%@921 APE 25 PLL@51C CPU@57.5C PMIC@100C GPU@52.5C AO@62C thermal@54.75C POM_5V_IN 6339/6370 POM_5V_GPU 3280/3031 POM_5V_CPU 850/574
RAM 2866/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [6%@1428,16%@1428,5%@1428,10%@1428] EMC_FREQ 28%@1600 GR3D_FREQ 99%@921 APE 25 PLL@51.5C CPU@56.5C PMIC@100C GPU@52.5C AO@62.5C thermal@54.75C POM_5V_IN 5749/6366 POM_5V_GPU 2947/3031 POM_5V_CPU 505/574
RAM 2848/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [4%@1428,18%@1428,4%@1428,5%@1428] EMC_FREQ 24%@1600 GR3D_FREQ 99%@921 APE 25 PLL@51C CPU@56.5C PMIC@100C GPU@52.5C AO@62.5C thermal@54.5C POM_5V_IN 6050/6364 POM_5V_GPU 3335/3032 POM_5V_CPU 504/573
RAM 2866/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [1%@1428,30%@1428,4%@1428,1%@1428] EMC_FREQ 32%@1600 GR3D_FREQ 99%@921 APE 25 PLL@51C CPU@57C PMIC@100C GPU@53C AO@62.5C thermal@54.5C POM_5V_IN 7154/6369 POM_5V_GPU 3340/3034 POM_5V_CPU 537/573
RAM 2866/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [4%@1428,19%@1428,1%@1428,1%@1428] EMC_FREQ 40%@1600 GR3D_FREQ 99%@921 APE 25 PLL@51.5C CPU@57.5C PMIC@100C GPU@53.5C AO@62.5C thermal@55C POM_5V_IN 7973/6378 POM_5V_GPU 4209/3041 POM_5V_CPU 460/572
RAM 2866/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [3%@1428,24%@1428,3%@1428,5%@1428] EMC_FREQ 43%@1600 GR3D_FREQ 0%@921 APE 25 PLL@51.5C CPU@56.5C PMIC@100C GPU@52.5C AO@62.5C thermal@54.25C POM_5V_IN 5265/6372 POM_5V_GPU 1569/3033 POM_5V_CPU 863/574
RAM 2866/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [1%@1428,22%@1428,2%@1428,1%@1428] EMC_FREQ 47%@1600 GR3D_FREQ 99%@921 APE 25 PLL@51C CPU@57C PMIC@100C GPU@53.5C AO@62.5C thermal@55.25C POM_5V_IN 7231/6377 POM_5V_GPU 3763/3037 POM_5V_CPU 538/574
RAM 2866/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [1%@1428,18%@1428,2%@1428,2%@1428] EMC_FREQ 45%@1600 GR3D_FREQ 99%@921 APE 25 PLL@51.5C CPU@57C PMIC@100C GPU@53.5C AO@62.5C thermal@55C POM_5V_IN 7166/6382 POM_5V_GPU 3577/3040 POM_5V_CPU 461/573
RAM 2866/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [2%@1428,18%@1428,1%@1428,4%@1428] EMC_FREQ 44%@1600 GR3D_FREQ 99%@921 APE 25 PLL@51.5C CPU@57C PMIC@100C GPU@53C AO@63C thermal@55C POM_5V_IN 5827/6378 POM_5V_GPU 2714/3038 POM_5V_CPU 466/573
RAM 2866/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [7%@1428,23%@1428,5%@1428,3%@1428] EMC_FREQ 46%@1600 GR3D_FREQ 99%@921 APE 25 PLL@51.5C CPU@57.5C PMIC@100C GPU@53C AO@63C thermal@55.25C POM_5V_IN 7231/6383 POM_5V_GPU 3654/3042 POM_5V_CPU 692/573
RAM 2865/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [4%@1428,21%@1428,10%@1428,7%@1428] EMC_FREQ 48%@1600 GR3D_FREQ 99%@921 APE 25 PLL@51.5C CPU@57C PMIC@100C GPU@53C AO@63C thermal@55.5C POM_5V_IN 6367/6383 POM_5V_GPU 2928/3041 POM_5V_CPU 616/573
RAM 2865/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [2%@1428,18%@1428,1%@1428,3%@1428] EMC_FREQ 52%@1600 GR3D_FREQ 6%@921 APE 25 PLL@51.5C CPU@56.5C PMIC@100C GPU@52.5C AO@63C thermal@55.75C POM_5V_IN 4605/6373 POM_5V_GPU 865/3029 POM_5V_CPU 984/576
RAM 2865/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [1%@1428,19%@1428,3%@1428,5%@1428] EMC_FREQ 53%@1600 GR3D_FREQ 99%@921 APE 25 PLL@51.5C CPU@58C PMIC@100C GPU@53.5C AO@63C thermal@55.25C POM_5V_IN 7564/6380 POM_5V_GPU 3680/3032 POM_5V_CPU 536/576
RAM 2865/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [2%@1428,19%@1428,2%@1428,2%@1428] EMC_FREQ 53%@1600 GR3D_FREQ 99%@921 APE 25 PLL@51.5C CPU@57.5C PMIC@100C GPU@53.5C AO@63C thermal@55.25C POM_5V_IN 7231/6385 POM_5V_GPU 3769/3036 POM_5V_CPU 461/575
RAM 2865/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [2%@1428,19%@1428,2%@1428,1%@1428] EMC_FREQ 55%@1600 GR3D_FREQ 99%@921 APE 25 PLL@52C CPU@57.5C PMIC@100C GPU@53.5C AO@63C thermal@55.25C POM_5V_IN 7089/6388 POM_5V_GPU 3307/3038 POM_5V_CPU 462/574
RAM 2865/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [3%@1428,13%@1428,10%@1428,2%@1428] EMC_FREQ 52%@1600 GR3D_FREQ 0%@921 APE 25 PLL@52C CPU@57.5C PMIC@100C GPU@53C AO@63C thermal@55.5C POM_5V_IN 6178/6387 POM_5V_GPU 2342/3034 POM_5V_CPU 742/575
RAM 2865/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [2%@1428,25%@1428,2%@1428,1%@1428] EMC_FREQ 50%@1600 GR3D_FREQ 99%@921 APE 25 PLL@52C CPU@57.5C PMIC@100C GPU@53.5C AO@63C thermal@55.75C POM_5V_IN 6692/6389 POM_5V_GPU 2956/3034 POM_5V_CPU 652/576
RAM 2866/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [5%@1428,11%@1428,13%@1428,4%@1428] EMC_FREQ 49%@1600 GR3D_FREQ 99%@921 APE 25 PLL@52C CPU@58C PMIC@100C GPU@53.5C AO@63C thermal@55.25C POM_5V_IN 7166/6393 POM_5V_GPU 3692/3037 POM_5V_CPU 538/575
RAM 2866/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [3%@1428,19%@1428,1%@1428,2%@1428] EMC_FREQ 51%@1600 GR3D_FREQ 99%@921 APE 25 PLL@52C CPU@58.5C PMIC@100C GPU@54C AO@63C thermal@55.75C POM_5V_IN 7973/6402 POM_5V_GPU 3756/3041 POM_5V_CPU 460/575
RAM 2866/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [3%@1428,22%@1428,10%@1428,3%@1428] EMC_FREQ 50%@1600 GR3D_FREQ 0%@921 APE 25 PLL@51.5C CPU@57C PMIC@100C GPU@52.5C AO@63.5C thermal@56C POM_5V_IN 4565/6392 POM_5V_GPU 1021/3030 POM_5V_CPU 980/577
RAM 2866/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [2%@1428,19%@1428,0%@1428,4%@1428] EMC_FREQ 50%@1600 GR3D_FREQ 99%@921 APE 25 PLL@52C CPU@58.5C PMIC@100C GPU@54C AO@63.5C thermal@55.75C POM_5V_IN 7935/6400 POM_5V_GPU 4018/3035 POM_5V_CPU 536/577
RAM 2866/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [2%@1428,17%@1428,1%@1428,2%@1428] EMC_FREQ 50%@1600 GR3D_FREQ 99%@921 APE 25 PLL@52C CPU@58.5C PMIC@100C GPU@54C AO@63C thermal@55.75C POM_5V_IN 7641/6407 POM_5V_GPU 3833/3040 POM_5V_CPU 499/576
RAM 2866/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [2%@1428,11%@1428,1%@1428,1%@1428] EMC_FREQ 40%@1600 GR3D_FREQ 99%@921 APE 25 PLL@52C CPU@57.5C PMIC@100C GPU@53.5C AO@63C thermal@56C POM_5V_IN 6610/6408 POM_5V_GPU 3743/3043 POM_5V_CPU 501/576
RAM 2866/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [1%@1428,17%@1428,6%@1428,4%@1428] EMC_FREQ 37%@1600 GR3D_FREQ 17%@921 APE 25 PLL@52.5C CPU@57.5C PMIC@100C GPU@53C AO@63.5C thermal@56C POM_5V_IN 5357/6402 POM_5V_GPU 1916/3037 POM_5V_CPU 821/577
RAM 2866/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [4%@1428,8%@1428,2%@1428,1%@1428] EMC_FREQ 30%@1600 GR3D_FREQ 99%@921 APE 25 PLL@52C CPU@58C PMIC@100C GPU@54C AO@63.5C thermal@55.75C POM_5V_IN 6166/6401 POM_5V_GPU 3484/3040 POM_5V_CPU 464/577
RAM 2866/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [1%@1428,13%@1428,3%@1428,2%@1428] EMC_FREQ 29%@1600 GR3D_FREQ 8%@921 APE 25 PLL@52.5C CPU@57.5C PMIC@100C GPU@53C AO@63.5C thermal@56C POM_5V_IN 5426/6396 POM_5V_GPU 2143/3035 POM_5V_CPU 701/577
RAM 2847/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [1%@1428,16%@1428,4%@1428,3%@1428] EMC_FREQ 25%@1600 GR3D_FREQ 0%@921 APE 25 PLL@52C CPU@56.5C PMIC@100C GPU@52.5C AO@63.5C thermal@55.75C POM_5V_IN 3942/6383 POM_5V_GPU 433/3022 POM_5V_CPU 1102/580
RAM 2865/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [3%@1428,40%@1428,14%@1428,2%@1428] EMC_FREQ 29%@1600 GR3D_FREQ 99%@921 APE 25 PLL@52C CPU@58C PMIC@100C GPU@54C AO@63.5C thermal@55.75C POM_5V_IN 7142/6387 POM_5V_GPU 3450/3024 POM_5V_CPU 576/580
RAM 2865/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [3%@1428,53%@1428,4%@1428,1%@1428] EMC_FREQ 31%@1600 GR3D_FREQ 3%@921 APE 25 PLL@52.5C CPU@56.5C PMIC@100C GPU@53C AO@63.5C thermal@55C POM_5V_IN 4676/6378 POM_5V_GPU 1021/3013 POM_5V_CPU 984/582
RAM 2865/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [5%@1428,48%@1428,3%@1428,1%@1428] EMC_FREQ 32%@1600 GR3D_FREQ 6%@921 APE 25 PLL@52.5C CPU@56.5C PMIC@100C GPU@52.5C AO@63.5C thermal@55.25C POM_5V_IN 4408/6368 POM_5V_GPU 826/3002 POM_5V_CPU 982/584
RAM 2865/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [4%@1428,46%@1428,5%@1428,1%@1428] EMC_FREQ 35%@1600 GR3D_FREQ 16%@921 APE 25 PLL@52.5C CPU@57C PMIC@100C GPU@53C AO@63C thermal@54.75C POM_5V_IN 5105/6362 POM_5V_GPU 1556/2995 POM_5V_CPU 856/585
RAM 2865/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [3%@1428,45%@1428,3%@1428,5%@1428] EMC_FREQ 36%@1600 GR3D_FREQ 89%@921 APE 25 PLL@52.5C CPU@58.5C PMIC@100C GPU@54C AO@63.5C thermal@55.5C POM_5V_IN 6923/6365 POM_5V_GPU 3033/2995 POM_5V_CPU 691/586
RAM 2865/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [1%@1428,37%@1428,13%@1428,3%@1428] EMC_FREQ 37%@1600 GR3D_FREQ 99%@921 APE 25 PLL@52.5C CPU@57.5C PMIC@100C GPU@53.5C AO@63.5C thermal@55C POM_5V_IN 6107/6363 POM_5V_GPU 2624/2993 POM_5V_CPU 694/587
RAM 2865/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [3%@1428,37%@1428,4%@1428,10%@1428] EMC_FREQ 37%@1600 GR3D_FREQ 90%@921 APE 25 PLL@52.5C CPU@58C PMIC@100C GPU@54C AO@63.5C thermal@55C POM_5V_IN 7065/6367 POM_5V_GPU 3033/2993 POM_5V_CPU 614/587
RAM 2865/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [3%@1428,50%@1428,3%@1428,2%@1428] EMC_FREQ 37%@1600 GR3D_FREQ 0%@921 APE 25 PLL@52.5C CPU@58C PMIC@100C GPU@53.5C AO@64C thermal@55C POM_5V_IN 5875/6364 POM_5V_GPU 1994/2988 POM_5V_CPU 861/588
RAM 2865/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [2%@1428,39%@1428,5%@1428,5%@1428] EMC_FREQ 33%@1600 GR3D_FREQ 99%@921 APE 25 PLL@52.5C CPU@57.5C PMIC@100C GPU@53.5C AO@63.5C thermal@55.5C POM_5V_IN 5378/6359 POM_5V_GPU 2062/2984 POM_5V_CPU 739/589
RAM 2845/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [3%@1428,30%@1428,7%@1428,3%@1428] EMC_FREQ 29%@1600 GR3D_FREQ 7%@921 APE 25 PLL@52.5C CPU@57.5C PMIC@100C GPU@53.5C AO@64C thermal@55.5C POM_5V_IN 4644/6351 POM_5V_GPU 1336/2976 POM_5V_CPU 943/591
RAM 2865/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [2%@1428,56%@1428,6%@1428,1%@1428] EMC_FREQ 30%@1600 GR3D_FREQ 88%@921 APE 25 PLL@52.5C CPU@57C PMIC@100C GPU@53C AO@64C thermal@54.75C POM_5V_IN 5584/6347 POM_5V_GPU 1974/2971 POM_5V_CPU 813/592
RAM 2865/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [3%@1428,47%@1428,2%@1428,5%@1428] EMC_FREQ 32%@1600 GR3D_FREQ 99%@921 APE 25 PLL@52.5C CPU@58C PMIC@100C GPU@54C AO@63.5C thermal@55C POM_5V_IN 6360/6347 POM_5V_GPU 2792/2970 POM_5V_CPU 699/592
RAM 2865/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [3%@1428,49%@1428,4%@1428,1%@1428] EMC_FREQ 34%@1600 GR3D_FREQ 54%@921 APE 25 PLL@52.5C CPU@57.5C PMIC@100C GPU@54C AO@63.5C thermal@54.75C POM_5V_IN 6090/6346 POM_5V_GPU 2104/2966 POM_5V_CPU 819/593
RAM 2865/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [3%@1428,49%@1428,2%@1428,3%@1428] EMC_FREQ 36%@1600 GR3D_FREQ 0%@921 APE 25 PLL@52.5C CPU@58C PMIC@100C GPU@53.5C AO@64C thermal@55.5C POM_5V_IN 5374/6341 POM_5V_GPU 1451/2958 POM_5V_CPU 863/595
RAM 2865/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [1%@1428,50%@1428,4%@1428,2%@1428] EMC_FREQ 37%@1600 GR3D_FREQ 7%@921 APE 25 PLL@53C CPU@57C PMIC@100C GPU@53C AO@64C thermal@56C POM_5V_IN 4919/6334 POM_5V_GPU 1400/2951 POM_5V_CPU 894/596
RAM 2865/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [5%@1428,46%@1428,4%@1428,2%@1428] EMC_FREQ 37%@1600 GR3D_FREQ 7%@921 APE 25 PLL@53C CPU@57.5C PMIC@100C GPU@53C AO@64C thermal@55.25C POM_5V_IN 4683/6326 POM_5V_GPU 982/2941 POM_5V_CPU 1023/598
RAM 2865/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [3%@1428,47%@1428,5%@1428,2%@1428] EMC_FREQ 36%@1600 GR3D_FREQ 76%@921 APE 25 PLL@52.5C CPU@57C PMIC@100C GPU@53C AO@64C thermal@55.25C POM_5V_IN 5546/6323 POM_5V_GPU 1819/2936 POM_5V_CPU 811/599
RAM 2865/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [7%@1428,39%@1428,12%@1428,1%@1428] EMC_FREQ 37%@1600 GR3D_FREQ 90%@921 APE 25 PLL@52.5C CPU@58.5C PMIC@100C GPU@54C AO@64C thermal@56.5C POM_5V_IN 6885/6325 POM_5V_GPU 3148/2937 POM_5V_CPU 614/599
RAM 2865/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [2%@1428,43%@1428,6%@1428,1%@1428] EMC_FREQ 33%@1600 GR3D_FREQ 11%@921 APE 25 PLL@53C CPU@57.5C PMIC@100C GPU@53C AO@63.5C thermal@56.25C POM_5V_IN 5248/6320 POM_5V_GPU 1759/2931 POM_5V_CPU 1016/601
RAM 2865/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [2%@1428,30%@1428,7%@1428,4%@1428] EMC_FREQ 29%@1600 GR3D_FREQ 97%@921 APE 25 PLL@52.5C CPU@58C PMIC@100C GPU@53.5C AO@64C thermal@56.25C POM_5V_IN 5827/6318 POM_5V_GPU 3025/2932 POM_5V_CPU 542/601
RAM 2865/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [2%@1428,60%@1428,5%@1428,3%@1428] EMC_FREQ 30%@1600 GR3D_FREQ 0%@921 APE 25 PLL@53C CPU@57.5C PMIC@100C GPU@53.5C AO@64C thermal@55.75C POM_5V_IN 5226/6313 POM_5V_GPU 1412/2925 POM_5V_CPU 902/602
RAM 2865/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [2%@1428,51%@1428,4%@1428,2%@1428] EMC_FREQ 33%@1600 GR3D_FREQ 99%@921 APE 25 PLL@53C CPU@58.5C PMIC@100C GPU@54C AO@64C thermal@55.75C POM_5V_IN 5914/6311 POM_5V_GPU 2473/2922 POM_5V_CPU 734/603
RAM 2865/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [2%@1428,48%@1428,4%@1428,4%@1428] EMC_FREQ 33%@1600 GR3D_FREQ 99%@921 APE 25 PLL@53C CPU@58.5C PMIC@100C GPU@53.5C AO@64C thermal@56.25C POM_5V_IN 6367/6311 POM_5V_GPU 2658/2921 POM_5V_CPU 654/603
RAM 2865/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [3%@1428,48%@1428,4%@1428,0%@1428] EMC_FREQ 36%@1600 GR3D_FREQ 99%@921 APE 25 PLL@53C CPU@58.5C PMIC@100C GPU@54.5C AO@64C thermal@56.5C POM_5V_IN 7308/6316 POM_5V_GPU 3110/2922 POM_5V_CPU 576/603
RAM 2865/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [2%@1428,52%@1428,5%@1428,2%@1428] EMC_FREQ 37%@1600 GR3D_FREQ 0%@921 APE 25 PLL@53C CPU@58C PMIC@100C GPU@54C AO@64C thermal@55.75C POM_5V_IN 5453/6312 POM_5V_GPU 1762/2917 POM_5V_CPU 861/604
RAM 2865/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [3%@1428,39%@1428,11%@1428,2%@1428] EMC_FREQ 38%@1600 GR3D_FREQ 6%@921 APE 25 PLL@53C CPU@58C PMIC@100C GPU@54.5C AO@64C thermal@55.75C POM_5V_IN 6129/6311 POM_5V_GPU 2303/2914 POM_5V_CPU 821/605
RAM 2865/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [2%@1428,50%@1428,4%@1428,1%@1428] EMC_FREQ 36%@1600 GR3D_FREQ 3%@921 APE 25 PLL@53C CPU@58C PMIC@100C GPU@54C AO@64.5C thermal@55.75C POM_5V_IN 4990/6305 POM_5V_GPU 1255/2906 POM_5V_CPU 980/607
RAM 2865/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [2%@1428,50%@1428,5%@1428,3%@1428] EMC_FREQ 37%@1600 GR3D_FREQ 35%@921 APE 25 PLL@53C CPU@57.5C PMIC@100C GPU@53C AO@64C thermal@56.5C POM_5V_IN 5066/6299 POM_5V_GPU 1517/2900 POM_5V_CPU 893/608
RAM 2865/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [5%@1428,40%@1428,5%@1428,2%@1428] EMC_FREQ 33%@1600 GR3D_FREQ 75%@921 APE 25 PLL@53C CPU@58.5C PMIC@100C GPU@54C AO@64.5C thermal@56.25C POM_5V_IN 5701/6297 POM_5V_GPU 2327/2897 POM_5V_CPU 814/609
RAM 2865/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [3%@1428,34%@1428,7%@1428,2%@1428] EMC_FREQ 29%@1600 GR3D_FREQ 64%@921 APE 25 PLL@53C CPU@58.5C PMIC@100C GPU@54.5C AO@64C thermal@56.25C POM_5V_IN 5309/6292 POM_5V_GPU 2377/2895 POM_5V_CPU 701/610
RAM 2865/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [3%@1428,54%@1428,6%@1428,2%@1428] EMC_FREQ 30%@1600 GR3D_FREQ 99%@921 APE 25 PLL@53C CPU@58.5C PMIC@100C GPU@54.5C AO@64.5C thermal@56.25C POM_5V_IN 6923/6295 POM_5V_GPU 3187/2896 POM_5V_CPU 614/610
RAM 2865/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [3%@1428,54%@1428,4%@1428,2%@1428] EMC_FREQ 33%@1600 GR3D_FREQ 0%@921 APE 25 PLL@53C CPU@57.5C PMIC@100C GPU@53.5C AO@64C thermal@56.5C POM_5V_IN 4920/6289 POM_5V_GPU 1100/2888 POM_5V_CPU 982/611
RAM 2865/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [1%@1428,51%@1428,4%@1428,1%@1428] EMC_FREQ 32%@1600 GR3D_FREQ 7%@921 APE 25 PLL@53C CPU@57.5C PMIC@100C GPU@53.5C AO@64C thermal@56.75C POM_5V_IN 4257/6280 POM_5V_GPU 708/2879 POM_5V_CPU 980/613
RAM 2865/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [9%@1428,47%@1428,2%@1428,2%@1428] EMC_FREQ 34%@1600 GR3D_FREQ 99%@921 APE 25 PLL@53C CPU@58.5C PMIC@100C GPU@54.5C AO@64C thermal@56.25C POM_5V_IN 6626/6281 POM_5V_GPU 2654/2878 POM_5V_CPU 653/613
RAM 2865/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [4%@1428,39%@1428,12%@1428,2%@1428] EMC_FREQ 37%@1600 GR3D_FREQ 90%@921 APE 25 PLL@53C CPU@59C PMIC@100C GPU@54.5C AO@64C thermal@55.5C POM_5V_IN 6599/6283 POM_5V_GPU 3120/2879 POM_5V_CPU 654/613
RAM 2865/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [3%@1428,47%@1428,3%@1428,2%@1428] EMC_FREQ 37%@1600 GR3D_FREQ 90%@921 APE 25 PLL@53C CPU@58.5C PMIC@100C GPU@54.5C AO@64.5C thermal@55.5C POM_5V_IN 6808/6285 POM_5V_GPU 3038/2879 POM_5V_CPU 729/614
RAM 2865/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [2%@1428,47%@1428,2%@1428,4%@1428] EMC_FREQ 36%@1600 GR3D_FREQ 99%@921 APE 25 PLL@53C CPU@58.5C PMIC@100C GPU@54.5C AO@64C thermal@57C POM_5V_IN 6483/6286 POM_5V_GPU 3005/2880 POM_5V_CPU 578/614
RAM 2865/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [1%@1428,51%@1428,6%@1428,1%@1428] EMC_FREQ 37%@1600 GR3D_FREQ 3%@921 APE 25 PLL@53C CPU@58C PMIC@100C GPU@54.5C AO@64.5C thermal@56C POM_5V_IN 5591/6283 POM_5V_GPU 1759/2875 POM_5V_CPU 899/615
RAM 2865/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [3%@1428,40%@1428,3%@1428,3%@1428] EMC_FREQ 34%@1600 GR3D_FREQ 47%@921 APE 25 PLL@53C CPU@58.5C PMIC@100C GPU@54.5C AO@64.5C thermal@55.5C POM_5V_IN 5396/6279 POM_5V_GPU 2502/2874 POM_5V_CPU 705/615
RAM 2865/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [4%@1428,34%@1428,7%@1428,2%@1428] EMC_FREQ 29%@1600 GR3D_FREQ 89%@921 APE 25 PLL@53C CPU@58.5C PMIC@100C GPU@54.5C AO@64.5C thermal@57C POM_5V_IN 5603/6276 POM_5V_GPU 2719/2873 POM_5V_CPU 582/615
RAM 2832/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [10%@1428,10%@1428,4%@1428,1%@1428] EMC_FREQ 25%@1600 GR3D_FREQ 63%@921 APE 25 PLL@53C CPU@58C PMIC@100C GPU@53.5C AO@64.5C thermal@56C POM_5V_IN 4472/6268 POM_5V_GPU 1801/2868 POM_5V_CPU 588/615
RAM 3085/3957MB (lfb 107x4MB) IRAM 0/252kB(lfb 252kB) CPU [70%@1428,6%@1428,26%@1428,2%@1428] EMC_FREQ 20%@1600 GR3D_FREQ 28%@921 APE 25 PLL@53C CPU@57.5C PMIC@100C GPU@53.5C AO@64.5C thermal@56C POM_5V_IN 4707/6262 POM_5V_GPU 745/2859 POM_5V_CPU 1294/618
RAM 2956/3957MB (lfb 119x4MB) IRAM 0/252kB(lfb 252kB) CPU [98%@1428,17%@1428,11%@1428,90%@1428] EMC_FREQ 16%@1600 GR3D_FREQ 0%@921 APE 25 PLL@53.5C CPU@58C PMIC@100C GPU@53.5C AO@64.5C thermal@55.75C POM_5V_IN 4621/6255 POM_5V_GPU 235/2848 POM_5V_CPU 2150/624
RAM 1803/3957MB (lfb 273x4MB) IRAM 0/252kB(lfb 252kB) CPU [22%@1428,14%@1428,1%@1428,13%@1428] EMC_FREQ 12%@1600 GR3D_FREQ 0%@921 APE 25 PLL@52.5C CPU@57C PMIC@100C GPU@53C AO@64C thermal@55C POM_5V_IN 2644/6239 POM_5V_GPU 240/2837 POM_5V_CPU 520/624
RAM 1803/3957MB (lfb 273x4MB) IRAM 0/252kB(lfb 252kB) CPU [2%@1428,3%@1428,2%@1428,2%@1428] EMC_FREQ 9%@1600 GR3D_FREQ 0%@921 APE 25 PLL@52.5C CPU@57C PMIC@100C GPU@53C AO@64C thermal@55C POM_5V_IN 2568/6224 POM_5V_GPU 200/2826 POM_5V_CPU 481/623
RAM 1803/3957MB (lfb 273x4MB) IRAM 0/252kB(lfb 252kB) CPU [13%@1428,10%@1428,4%@1428,2%@1428] EMC_FREQ 7%@1600 GR3D_FREQ 0%@921 APE 25 PLL@52C CPU@56.5C PMIC@100C GPU@53C AO@63.5C thermal@55C POM_5V_IN 2572/6209 POM_5V_GPU 200/2815 POM_5V_CPU 521/623
RAM 1803/3957MB (lfb 273x4MB) IRAM 0/252kB(lfb 252kB) CPU [5%@1428,5%@1428,3%@1428,1%@1428] EMC_FREQ 5%@1600 GR3D_FREQ 0%@921 APE 25 PLL@52C CPU@56.5C PMIC@100C GPU@53C AO@64C thermal@55C POM_5V_IN 2532/6193 POM_5V_GPU 200/2804 POM_5V_CPU 481/622
I am also Getting the Same Issue. What can I do to fix this? I am Running an Embedding and After some time the Process is Killed
I can execute this sample without issue.
Would you mind to close X server and to see if helps?
If the error still occur, please decrease the batch size to one and try it again.
diff --git a/sampleFasterRCNN.cpp b/sampleFasterRCNN.cpp
index 7c107c2..e688030 100644
--- a/sampleFasterRCNN.cpp
+++ b/sampleFasterRCNN.cpp
@@ -277,7 +277,7 @@ int main(int argc, char** argv)
     initLibNvInferPlugins(&gLogger, "");
     // batch size
-    const int N = 2;
+    const int N = 1;
     caffeToTRTModel("faster_rcnn_test_iplugin.prototxt",
                     "VGG16_faster_rcnn_final.caffemodel",
                     std::vector<std::string>{OUTPUT_BLOB_NAME0, OUTPUT_BLOB_NAME1, OUTPUT_BLOB_NAME2},
Hi, thanks for reply,
I do this
sudo systemctl stop gdm.service
then ssh to nano with windows10, run
./sample_fasterRCNN
the nano display device shows
[940.985056] sample_fasterRC invoked oom-killer: gfp_mask=0x24082c2(GFP_KERNEL|__GFP_HIGHMEM|__GFP_NOWARN|__GFP_ZERO), nodemask=0, order=0, oom_score_adj=0
[941.001152] Out of memory: Kill process 8957(sample_fasterRC) score 332 or sacrifice child
[941.011339] Killed process 8957(sample_fasterRC) total-vm:10409288kB, anon-rss:1180560kB,file-rss:163232kB, shmem-rss:0kB
and windows10 does not show ‘killed’, it shows
Begin parsing model...
End parsing model...
Begin building engine...
and it could not stop to return back $
the batchsize keeps to 1
It looks weird to me.
We can build and execute the sample without issue.
Do you apply any modification on the sample?
More, would you mind to reflash the device and try it again?
