Fiji ImageJ installation using dockerfile
Tyring to use ImageJ or any imageJ distribution in Jetson nano dev kit.
pyimage J requires maven and java8 or 11.
https://github.com/imagej/pyimagej/blob/master/doc/Install.md
i used the following command inside my docker file
FROM nvcr.io/nvidia/l4t-ml:r32.5.0-py3
RUN apt -y update && apt -y upgrade
#Installs maven and java 11
RUN apt -y install maven
However once i start python3 inside the docker image,
import imagej
ij = imagej.init() #the code is stuck here.
If anyone has had luck installing imagej or any distribution of imagej, would they mind posting instructions ?
Due to limited resource, sometimes instruction may take longer on the Jetson Nano.
Would you mind to wait it longer and monitor the system status with tegrastats.
$ sudo tegrastats
Hi AastaLLL,
I have attached a txt file that contains the output from tegrastats.
tstats.txt (14.6 KB)
RAM 755/3963MB (lfb 464x4MB) SWAP 0/1981MB (cached 0MB) CPU [0%@1224,0%@1224,0%@1224,0%@1224] EMC_FREQ 0% GR3D_FREQ 0% PLL@35.5C CPU@38C PMIC@100C GPU@37.5C AO@45.5C thermal@37.75C
RAM 755/3963MB (lfb 464x4MB) SWAP 0/1981MB (cached 0MB) CPU [0%@1224,1%@1224,0%@1224,0%@1224] EMC_FREQ 0% GR3D_FREQ 0% PLL@36C CPU@38C PMIC@100C GPU@38C AO@45.5C thermal@37.75C
RAM 755/3963MB (lfb 464x4MB) SWAP 0/1981MB (cached 0MB) CPU [1%@1224,2%@1224,0%@1224,0%@1224] EMC_FREQ 0% GR3D_FREQ 0% PLL@35.5C CPU@38C PMIC@100C GPU@37.5C AO@45.5C thermal@37.75C
RAM 755/3963MB (lfb 464x4MB) SWAP 0/1981MB (cached 0MB) CPU [1%@1224,0%@1224,1%@1224,0%@1224] EMC_FREQ 0% GR3D_FREQ 0% PLL@35.5C CPU@38.5C PMIC@100C GPU@37.5C AO@45.5C thermal@38.25C
RAM 755/3963MB (lfb 464x4MB) SWAP 0/1981MB (cached 0MB) CPU [0%@1224,0%@1224,0%@1224,0%@1224] EMC_FREQ 0% GR3D_FREQ 0% PLL@36C CPU@38C PMIC@100C GPU@38C AO@45.5C thermal@38C
RAM 762/3963MB (lfb 464x4MB) SWAP 0/1981MB (cached 0MB) CPU [0%@1479,1%@1479,32%@1479,1%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@36.5C CPU@39.5C PMIC@100C GPU@38.5C AO@46C thermal@38C
RAM 780/3963MB (lfb 464x4MB) SWAP 0/1981MB (cached 0MB) CPU [27%@1479,27%@1479,100%@1479,27%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@36.5C CPU@39C PMIC@100C GPU@38.5C AO@46.5C thermal@40C
RAM 808/3963MB (lfb 464x4MB) SWAP 0/1981MB (cached 0MB) CPU [3%@1479,0%@1479,100%@1479,0%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@36.5C CPU@39.5C PMIC@100C GPU@38.5C AO@46C thermal@39C
RAM 815/3963MB (lfb 464x4MB) SWAP 0/1981MB (cached 0MB) CPU [0%@1224,0%@1224,35%@1224,1%@1224] EMC_FREQ 0% GR3D_FREQ 0% PLL@36C CPU@39.5C PMIC@100C GPU@38C AO@46C thermal@38.5C
RAM 815/3963MB (lfb 464x4MB) SWAP 0/1981MB (cached 0MB) CPU [0%@1224,0%@1224,0%@1224,0%@1224] EMC_FREQ 0% GR3D_FREQ 0% PLL@35.5C CPU@38C PMIC@100C GPU@37.5C AO@45.5C thermal@38C
RAM 815/3963MB (lfb 464x4MB) SWAP 0/1981MB (cached 0MB) CPU [1%@1224,0%@1224,0%@1224,0%@1224] EMC_FREQ 0% GR3D_FREQ 0% PLL@36C CPU@38C PMIC@100C GPU@38C AO@45.5C thermal@38C
RAM 815/3963MB (lfb 464x4MB) SWAP 0/1981MB (cached 0MB) CPU [0%@1224,0%@1224,0%@1224,1%@1224] EMC_FREQ 0% GR3D_FREQ 0% PLL@35.5C CPU@38C PMIC@100C GPU@37.5C AO@45.5C thermal@38.25C
RAM 815/3963MB (lfb 464x4MB) SWAP 0/1981MB (cached 0MB) CPU [0%@1224,0%@1224,0%@1224,0%@1224] EMC_FREQ 0% GR3D_FREQ 0% PLL@36C CPU@38C PMIC@100C GPU@38C AO@45.5C thermal@37.75C
RAM 821/3963MB (lfb 464x4MB) SWAP 0/1981MB (cached 0MB) CPU [2%@1479,2%@1479,2%@1479,2%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@36C CPU@38.5C PMIC@100C GPU@38C AO@45.5C thermal@38C
RAM 861/3963MB (lfb 459x4MB) SWAP 0/1981MB (cached 0MB) CPU [56%@1479,23%@1479,55%@1479,54%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@36.5C CPU@40C PMIC@100C GPU@38.5C AO@46.5C thermal@39C
RAM 881/3963MB (lfb 458x4MB) SWAP 0/1981MB (cached 0MB) CPU [82%@1479,62%@1479,74%@1479,71%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@37.5C CPU@40.5C PMIC@100C GPU@39.5C AO@46.5C thermal@39.75C
RAM 900/3963MB (lfb 458x4MB) SWAP 0/1981MB (cached 0MB) CPU [98%@1479,54%@1479,30%@1479,19%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@37C CPU@40.5C PMIC@100C GPU@39C AO@46.5C thermal@39.25C
RAM 908/3963MB (lfb 458x4MB) SWAP 0/1981MB (cached 0MB) CPU [94%@1479,74%@1479,72%@1479,61%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@38C CPU@41.5C PMIC@100C GPU@40C AO@46.5C thermal@40.25C
RAM 933/3963MB (lfb 457x4MB) SWAP 0/1981MB (cached 0MB) CPU [69%@1479,99%@1479,79%@1479,92%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@38C CPU@41.5C PMIC@100C GPU@40C AO@47C thermal@40.75C
RAM 937/3963MB (lfb 457x4MB) SWAP 0/1981MB (cached 0MB) CPU [85%@1479,73%@1479,40%@1479,67%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@37.5C CPU@41C PMIC@100C GPU@39.5C AO@46.5C thermal@40.25C
RAM 939/3963MB (lfb 457x4MB) SWAP 0/1981MB (cached 0MB) CPU [33%@1224,25%@1224,12%@1224,20%@1224] EMC_FREQ 0% GR3D_FREQ 0% PLL@36.5C CPU@40C PMIC@100C GPU@38.5C AO@46C thermal@40.25C
RAM 949/3963MB (lfb 455x4MB) SWAP 0/1981MB (cached 0MB) CPU [47%@1479,53%@1479,26%@1479,53%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@37C CPU@39.5C PMIC@100C GPU@39C AO@46.5C thermal@38.25C
RAM 959/3963MB (lfb 453x4MB) SWAP 0/1981MB (cached 0MB) CPU [60%@1479,58%@1479,59%@1479,53%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@37C CPU@40C PMIC@100C GPU@39C AO@46.5C thermal@39.25C
RAM 963/3963MB (lfb 452x4MB) SWAP 0/1981MB (cached 0MB) CPU [45%@1326,39%@1326,32%@1326,39%@1326] EMC_FREQ 0% GR3D_FREQ 0% PLL@37C CPU@39.5C PMIC@100C GPU@39C AO@46.5C thermal@39.25C
RAM 961/3963MB (lfb 452x4MB) SWAP 0/1981MB (cached 0MB) CPU [40%@1479,72%@1479,20%@1479,34%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@37.5C CPU@40C PMIC@100C GPU@39.5C AO@46.5C thermal@39.25C
RAM 972/3963MB (lfb 451x4MB) SWAP 0/1981MB (cached 0MB) CPU [53%@1479,42%@1479,88%@1479,87%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@37.5C CPU@40.5C PMIC@100C GPU@39.5C AO@46.5C thermal@40.5C
RAM 975/3963MB (lfb 451x4MB) SWAP 0/1981MB (cached 0MB) CPU [26%@1479,13%@1479,100%@1479,65%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@38C CPU@40.5C PMIC@100C GPU@40C AO@46.5C thermal@40C
RAM 976/3963MB (lfb 451x4MB) SWAP 0/1981MB (cached 0MB) CPU [31%@1479,17%@1479,66%@1479,86%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@37.5C CPU@39.5C PMIC@100C GPU@39.5C AO@46.5C thermal@40.25C
RAM 978/3963MB (lfb 450x4MB) SWAP 0/1981MB (cached 0MB) CPU [37%@1479,15%@1479,71%@1479,72%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@37C CPU@39C PMIC@100C GPU@39C AO@46.5C thermal@39.5C
RAM 988/3963MB (lfb 450x4MB) SWAP 0/1981MB (cached 0MB) CPU [23%@1479,8%@1479,76%@1479,100%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@37.5C CPU@40.5C PMIC@100C GPU@39.5C AO@46.5C thermal@39.5C
RAM 988/3963MB (lfb 450x4MB) SWAP 0/1981MB (cached 0MB) CPU [21%@1224,12%@1224,5%@1224,53%@1224] EMC_FREQ 0% GR3D_FREQ 0% PLL@36.5C CPU@39C PMIC@100C GPU@38.5C AO@46.5C thermal@40C
RAM 993/3963MB (lfb 449x4MB) SWAP 0/1981MB (cached 0MB) CPU [28%@1479,14%@1479,11%@1479,40%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@37C CPU@39.5C PMIC@100C GPU@39C AO@46.5C thermal@39.25C
RAM 993/3963MB (lfb 449x4MB) SWAP 0/1981MB (cached 0MB) CPU [24%@1479,17%@1479,3%@1479,57%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@36.5C CPU@39.5C PMIC@100C GPU@38.5C AO@46.5C thermal@39.25C
RAM 993/3963MB (lfb 449x4MB) SWAP 0/1981MB (cached 0MB) CPU [48%@1224,53%@1224,4%@1224,8%@1224] EMC_FREQ 0% GR3D_FREQ 0% PLL@36.5C CPU@39C PMIC@100C GPU@38.5C AO@46.5C thermal@39.25C
RAM 993/3963MB (lfb 449x4MB) SWAP 0/1981MB (cached 0MB) CPU [20%@1479,7%@1479,5%@1479,27%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@37C CPU@39.5C PMIC@100C GPU@39C AO@46.5C thermal@38.5C
RAM 995/3963MB (lfb 449x4MB) SWAP 0/1981MB (cached 0MB) CPU [29%@1224,11%@1224,44%@1224,42%@1224] EMC_FREQ 0% GR3D_FREQ 0% PLL@36.5C CPU@39C PMIC@100C GPU@38.5C AO@46.5C thermal@39.75C
RAM 995/3963MB (lfb 449x4MB) SWAP 0/1981MB (cached 0MB) CPU [21%@1479,11%@1479,10%@1479,9%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@36.5C CPU@38.5C PMIC@100C GPU@38.5C AO@46.5C thermal@38.75C
RAM 995/3963MB (lfb 449x4MB) SWAP 0/1981MB (cached 0MB) CPU [26%@1479,8%@1479,3%@1479,62%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@36.5C CPU@39C PMIC@100C GPU@38.5C AO@46.5C thermal@39.25C
RAM 996/3963MB (lfb 449x4MB) SWAP 0/1981MB (cached 0MB) CPU [23%@1479,9%@1479,4%@1479,26%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@36.5C CPU@40C PMIC@100C GPU@38.5C AO@46.5C thermal@39C
RAM 996/3963MB (lfb 449x4MB) SWAP 0/1981MB (cached 0MB) CPU [23%@1479,40%@1479,11%@1479,10%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@37C CPU@39.5C PMIC@100C GPU@39C AO@46.5C thermal@39C
RAM 998/3963MB (lfb 449x4MB) SWAP 0/1981MB (cached 0MB) CPU [19%@1224,76%@1224,1%@1224,7%@1224] EMC_FREQ 0% GR3D_FREQ 0% PLL@36.5C CPU@39C PMIC@100C GPU@38.5C AO@46.5C thermal@39.5C
RAM 1001/3963MB (lfb 449x4MB) SWAP 0/1981MB (cached 0MB) CPU [27%@1224,15%@1224,6%@1224,9%@1224] EMC_FREQ 0% GR3D_FREQ 0% PLL@36C CPU@39C PMIC@100C GPU@38C AO@46.5C thermal@39C
RAM 1002/3963MB (lfb 449x4MB) SWAP 0/1981MB (cached 0MB) CPU [21%@1479,68%@1479,4%@1479,12%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@37C CPU@39.5C PMIC@100C GPU@39C AO@46.5C thermal@38.5C
RAM 1002/3963MB (lfb 449x4MB) SWAP 0/1981MB (cached 0MB) CPU [23%@1479,11%@1479,5%@1479,7%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@36.5C CPU@39C PMIC@100C GPU@38.5C AO@46.5C thermal@38.75C
RAM 1000/3963MB (lfb 449x4MB) SWAP 0/1981MB (cached 0MB) CPU [20%@1224,23%@1224,1%@1224,18%@1224] EMC_FREQ 0% GR3D_FREQ 0% PLL@37C CPU@39C PMIC@100C GPU@39C AO@46.5C thermal@38.75C
RAM 1002/3963MB (lfb 448x4MB) SWAP 0/1981MB (cached 0MB) CPU [16%@1224,8%@1224,4%@1224,77%@1224] EMC_FREQ 0% GR3D_FREQ 0% PLL@36.5C CPU@39C PMIC@100C GPU@38.5C AO@46.5C thermal@39.25C
RAM 1002/3963MB (lfb 448x4MB) SWAP 0/1981MB (cached 0MB) CPU [20%@1479,16%@1479,16%@1479,4%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@36.5C CPU@39C PMIC@100C GPU@38.5C AO@46.5C thermal@38.5C
RAM 1002/3963MB (lfb 448x4MB) SWAP 0/1981MB (cached 0MB) CPU [19%@1479,14%@1479,6%@1479,20%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@37C CPU@39C PMIC@100C GPU@39C AO@46.5C thermal@39C
RAM 1003/3963MB (lfb 448x4MB) SWAP 0/1981MB (cached 0MB) CPU [17%@1224,11%@1224,6%@1224,10%@1224] EMC_FREQ 0% GR3D_FREQ 0% PLL@36.5C CPU@38.5C PMIC@100C GPU@38.5C AO@46.5C thermal@39C
RAM 1005/3963MB (lfb 448x4MB) SWAP 0/1981MB (cached 0MB) CPU [22%@1479,6%@1479,7%@1479,7%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@36.5C CPU@38.5C PMIC@100C GPU@38.5C AO@46.5C thermal@38.5C
RAM 1005/3963MB (lfb 448x4MB) SWAP 0/1981MB (cached 0MB) CPU [21%@1479,48%@1479,2%@1479,5%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@37C CPU@40C PMIC@100C GPU@39C AO@46.5C thermal@38.75C
RAM 1005/3963MB (lfb 448x4MB) SWAP 0/1981MB (cached 0MB) CPU [17%@1479,8%@1479,14%@1479,1%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@37C CPU@40C PMIC@100C GPU@39C AO@46.5C thermal@38.5C
RAM 1005/3963MB (lfb 448x4MB) SWAP 0/1981MB (cached 0MB) CPU [21%@1224,6%@1224,4%@1224,5%@1224] EMC_FREQ 0% GR3D_FREQ 0% PLL@37C CPU@39C PMIC@100C GPU@39C AO@46.5C thermal@38.75C
RAM 1006/3963MB (lfb 448x4MB) SWAP 0/1981MB (cached 0MB) CPU [15%@1224,8%@1224,2%@1224,5%@1224] EMC_FREQ 0% GR3D_FREQ 0% PLL@36.5C CPU@38.5C PMIC@100C GPU@38.5C AO@46.5C thermal@38.75C
RAM 1006/3963MB (lfb 448x4MB) SWAP 0/1981MB (cached 0MB) CPU [19%@1428,34%@1428,3%@1428,14%@1428] EMC_FREQ 0% GR3D_FREQ 0% PLL@37C CPU@39C PMIC@100C GPU@39C AO@46.5C thermal@39.25C
RAM 1006/3963MB (lfb 448x4MB) SWAP 0/1981MB (cached 0MB) CPU [18%@1224,5%@1224,2%@1224,10%@1224] EMC_FREQ 0% GR3D_FREQ 0% PLL@36.5C CPU@38.5C PMIC@100C GPU@38.5C AO@46.5C thermal@38.75C
RAM 1006/3963MB (lfb 448x4MB) SWAP 0/1981MB (cached 0MB) CPU [23%@1224,4%@1224,20%@1224,15%@1224] EMC_FREQ 0% GR3D_FREQ 0% PLL@37C CPU@39C PMIC@100C GPU@39C AO@46.5C thermal@39.25C
RAM 1007/3963MB (lfb 448x4MB) SWAP 0/1981MB (cached 0MB) CPU [19%@1479,11%@1479,5%@1479,14%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@37C CPU@39.5C PMIC@100C GPU@39C AO@46.5C thermal@39.25C
RAM 1007/3963MB (lfb 448x4MB) SWAP 0/1981MB (cached 0MB) CPU [19%@1224,4%@1224,3%@1224,5%@1224] EMC_FREQ 0% GR3D_FREQ 0% PLL@36.5C CPU@39C PMIC@100C GPU@38.5C AO@46C thermal@39.25C
RAM 1007/3963MB (lfb 448x4MB) SWAP 0/1981MB (cached 0MB) CPU [27%@1479,4%@1479,3%@1479,9%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@37C CPU@40.5C PMIC@100C GPU@39C AO@47C thermal@38.75C
RAM 1008/3963MB (lfb 448x4MB) SWAP 0/1981MB (cached 0MB) CPU [21%@1224,4%@1224,2%@1224,9%@1224] EMC_FREQ 0% GR3D_FREQ 0% PLL@37C CPU@38.5C PMIC@100C GPU@39C AO@46.5C thermal@38.75C
RAM 1008/3963MB (lfb 448x4MB) SWAP 0/1981MB (cached 0MB) CPU [19%@1479,31%@1479,3%@1479,2%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@37.5C CPU@39.5C PMIC@100C GPU@39.5C AO@46.5C thermal@38.75C
RAM 1008/3963MB (lfb 448x4MB) SWAP 0/1981MB (cached 0MB) CPU [19%@1224,31%@1224,2%@1224,7%@1224] EMC_FREQ 0% GR3D_FREQ 0% PLL@37C CPU@39C PMIC@100C GPU@39C AO@46.5C thermal@39.25C
RAM 1008/3963MB (lfb 448x4MB) SWAP 0/1981MB (cached 0MB) CPU [16%@1224,8%@1224,2%@1224,8%@1224] EMC_FREQ 0% GR3D_FREQ 0% PLL@37C CPU@39C PMIC@100C GPU@39C AO@46.5C thermal@38.5C
RAM 1009/3963MB (lfb 448x4MB) SWAP 0/1981MB (cached 0MB) CPU [17%@1224,2%@1224,1%@1224,31%@1224] EMC_FREQ 0% GR3D_FREQ 0% PLL@36.5C CPU@39C PMIC@100C GPU@38.5C AO@46.5C thermal@39.5C
RAM 1009/3963MB (lfb 448x4MB) SWAP 0/1981MB (cached 0MB) CPU [18%@1224,3%@1224,1%@1224,4%@1224] EMC_FREQ 0% GR3D_FREQ 0% PLL@37C CPU@38.5C PMIC@100C GPU@39C AO@46.5C thermal@38.75C
RAM 1009/3963MB (lfb 448x4MB) SWAP 0/1981MB (cached 0MB) CPU [20%@1479,29%@1479,17%@1479,12%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@37C CPU@39.5C PMIC@100C GPU@39C AO@46.5C thermal@39.25C
RAM 1009/3963MB (lfb 448x4MB) SWAP 0/1981MB (cached 0MB) CPU [20%@1224,1%@1224,2%@1224,7%@1224] EMC_FREQ 0% GR3D_FREQ 0% PLL@37C CPU@39C PMIC@100C GPU@39C AO@46.5C thermal@39.25C
RAM 1010/3963MB (lfb 448x4MB) SWAP 0/1981MB (cached 0MB) CPU [19%@1479,1%@1479,5%@1479,4%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@36.5C CPU@39C PMIC@100C GPU@38.5C AO@46.5C thermal@38.75C
RAM 1010/3963MB (lfb 448x4MB) SWAP 0/1981MB (cached 0MB) CPU [17%@1224,10%@1224,2%@1224,7%@1224] EMC_FREQ 0% GR3D_FREQ 0% PLL@36.5C CPU@39C PMIC@100C GPU@38.5C AO@46.5C thermal@38.75C
RAM 1010/3963MB (lfb 448x4MB) SWAP 0/1981MB (cached 0MB) CPU [14%@1224,5%@1224,3%@1224,3%@1224] EMC_FREQ 0% GR3D_FREQ 0% PLL@36.5C CPU@39C PMIC@100C GPU@38.5C AO@46.5C thermal@38.75C
RAM 1010/3963MB (lfb 448x4MB) SWAP 0/1981MB (cached 0MB) CPU [20%@1479,7%@1479,6%@1479,3%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@37C CPU@40.5C PMIC@100C GPU@39C AO@47C thermal@38.5C
RAM 1010/3963MB (lfb 448x4MB) SWAP 0/1981MB (cached 0MB) CPU [12%@1224,3%@1224,1%@1224,0%@1224] EMC_FREQ 0% GR3D_FREQ 0% PLL@36.5C CPU@38.5C PMIC@100C GPU@38.5C AO@46C thermal@38.5C
RAM 1010/3963MB (lfb 448x4MB) SWAP 0/1981MB (cached 0MB) CPU [15%@1224,0%@1224,0%@1224,1%@1224] EMC_FREQ 0% GR3D_FREQ 0% PLL@36.5C CPU@38.5C PMIC@100C GPU@38.5C AO@46C thermal@38.5C
RAM 1011/3963MB (lfb 448x4MB) SWAP 0/1981MB (cached 0MB) CPU [14%@1479,17%@1479,1%@1479,2%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@37C CPU@39.5C PMIC@100C GPU@39C AO@46.5C thermal@38.5C
RAM 1011/3963MB (lfb 448x4MB) SWAP 0/1981MB (cached 0MB) CPU [15%@1224,6%@1224,1%@1224,5%@1224] EMC_FREQ 0% GR3D_FREQ 0% PLL@36.5C CPU@39C PMIC@100C GPU@38.5C AO@46.5C thermal@38.5C
RAM 1011/3963MB (lfb 448x4MB) SWAP 0/1981MB (cached 0MB) CPU [12%@1224,1%@1224,0%@1224,0%@1224] EMC_FREQ 0% GR3D_FREQ 0% PLL@36.5C CPU@38.5C PMIC@100C GPU@38.5C AO@46.5C thermal@38.5C
RAM 1011/3963MB (lfb 448x4MB) SWAP 0/1981MB (cached 0MB) CPU [14%@1224,8%@1224,2%@1224,10%@1224] EMC_FREQ 0% GR3D_FREQ 0% PLL@36.5C CPU@39C PMIC@100C GPU@38.5C AO@46.5C thermal@38.75C
RAM 1011/3963MB (lfb 448x4MB) SWAP 0/1981MB (cached 0MB) CPU [14%@1224,5%@1224,2%@1224,5%@1224] EMC_FREQ 0% GR3D_FREQ 0% PLL@36.5C CPU@38.5C PMIC@100C GPU@38.5C AO@46.5C thermal@38.5C
RAM 1011/3963MB (lfb 448x4MB) SWAP 0/1981MB (cached 0MB) CPU [16%@1224,6%@1224,1%@1224,55%@1224] EMC_FREQ 0% GR3D_FREQ 0% PLL@37C CPU@39.5C PMIC@100C GPU@39C AO@46.5C thermal@38.75C
RAM 1014/3963MB (lfb 448x4MB) SWAP 0/1981MB (cached 0MB) CPU [14%@1479,71%@1479,12%@1479,1%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@37C CPU@39.5C PMIC@100C GPU@39C AO@47C thermal@39.25C
RAM 1016/3963MB (lfb 448x4MB) SWAP 0/1981MB (cached 0MB) CPU [14%@1224,24%@1224,1%@1224,16%@1224] EMC_FREQ 0% GR3D_FREQ 0% PLL@37C CPU@38.5C PMIC@100C GPU@39C AO@46.5C thermal@39.25C
Sometime memory shortage will lead to system freeze inside the docker.
Would you mind to add some extra memory for the docker as shown in the below comment?
