I’m trying to update all the code of our systems from the old sysfs method to the new libgpiod suggested in JP 6.0, but after reading here in the forums for a while I’ve not seen a way to toggle hardware PWM in pins 15, 32 and 33.
I know I can software-pwm any pin, but I’d like the hardware gpio abilities of these old pins, as the “configure-and-go” means we do not need to time or thread a loop ourselves to toggle the pins.
Is there any link, document, tutorial or similar to achieve this?
Also, using “gpioinfo” shows no info on any pin, like “SDA, GND, SPI, etc” shows in the Raspberry Pi. What am I missing?
Going back to libgpiod, supposing the pins are configured as PWM using jetson-io, it lacks support for hardware PWM. Does that mean we should still use sysfs for hardware PWM related work?
I thought Jetson-GPIO was also going to be deprecated because the last time I checked it it was using sysfs to control the GPIO. Should have checked it again…
Thanks a lot DaveYYY, and sorry for the inconvenience
It’s the sysfs part for changing the function of a pin that is deprecated, but if the pin is configured correctly, all other things of Jetson.GPIO should still work.
