Hardware time stamp mismatch Connectx 5
Hello everyone,
I have created a DPDK (21.11) capture application in linux that reads the hardware timestamp of received packets but, for instance, if I do a capture of 1 minute and I calculate the difference of timestamps from the last received packet and the first packet, I get a duration around 10 seconds. I transmit traffic all time so I expected that the timestamp difference should be of 1 minute. Why could it be happening?
Regards
Albert
The problem is that the returned timestamp is in raw format. I used the function use mlx5dv_ts_to_ns to convert the timestamp to ns
@albert.lopez when you say hardware timestamp of packet received, did u embedded the timestamp in packet before sending or on receiving the packet u read the hardware timestamp on destination side.Also hardware timestamp is the HCA Core clock here right now the PTP Hardware clock?
