I am using tcpdump for capturing packets. I see the following options for interfaces on the switch.
1.lo
2.mgmt0
3.mgmt1
4.mgmts0
5.mgmts1
6.vlan1
I was trying to capture at vlan1 using the following command “tcpdump -w switch.pcap --time-stamp-precision=nano -s70 -i vlan1” . But it only captures the ARP packets and not all the packets passing through the interface.
I also try to capture at one of the ports “ethernet 1/1” using the command in the reference:
“Mellanox Interconnect Community”. But then it gives me the following error.
ualloc-mlnx2 [standalone: master] (config) # tcpdump -i eth1.0
tcpdump: eth1.0: No such device exists
(SIOCGIFHWADDR: No such device)
Although I have the router port (see below)
ualloc-mlnx2 [standalone: master] (config) # show interfaces ethernet 1/1
Eth1/1:
Admin state : Enabled
Operational state : Up
Last change in operational status: 3d and 12:21:50 ago (1 oper change)
Boot delay time : 0 sec
Description : N\A
Mac address : ec:0d:9a:5f:d8:3c
MTU : 1500 bytes (Maximum packet size 1522 bytes)
Fec : auto
Flow-control : receive off send off
Actual speed : 10 Gbps
Auto-negotiation : Disabled
Width reduction mode : Unknown
Switchport mode : hybrid
MAC learning mode : Enabled
Forwarding mode : inherited cut-through
Can you please tell me how can I capture all other packets on the switch?
Thank you,
Paridhika
