environment:
Ubuntu21.04 5.11.0-49-generic
GPU:RTX3080
lspci | grep -i nvidia
0b:00.0 VGA compatible controller: NVIDIA Corporation GA102 [GeForce RTX 3080] (rev a1)
0b:00.1 Audio device: NVIDIA Corporation GA102 High Definition Audio Controller (rev a1)
ubuntu-drivers devices
== /sys/devices/pci0000:00/0000:00:16.0/0000:0b:00.0 ==
modalias : pci:v000010DEd00002206sv00001462sd00003890bc03sc00i00
vendor : NVIDIA Corporation
model : GA102 [GeForce RTX 3080]
driver : nvidia-driver-470-server - distro non-free
driver : nvidia-driver-460-server - distro non-free
driver : nvidia-driver-460 - distro non-free
driver : nvidia-driver-470 - distro non-free recommended
driver : nvidia-driver-495 - distro non-free
driver : xserver-xorg-video-nouveau - distro free builtin
== /sys/devices/pci0000:00/0000:00:0f.0 ==
modalias : pci:v000015ADd00000405sv000015ADsd00000405bc03sc00i00
vendor : VMware
model : SVGA II Adapter
manual_install: True
driver : open-vm-tools-desktop - distro free
I installed the nVidia driver version (470.86) recommended by the system,but when I run nvidia-smi
command, I get no devices were found
problem.
# dmesg | grep NVRM
[ 8.832610] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 470.86 Tue Oct 26 21:55:45 UTC 2021
[ 14.365869] NVRM: GPU 0000:0b:00.0: RmInitAdapter failed! (0x26:0x56:1262)
[ 14.366019] NVRM: GPU 0000:0b:00.0: rm_init_adapter failed, device minor number 0
[ 15.021382] NVRM: GPU 0000:0b:00.0: RmInitAdapter failed! (0x26:0x56:1262)
[ 15.021486] NVRM: GPU 0000:0b:00.0: rm_init_adapter failed, device minor number 0
[ 17.924658] NVRM: GPU 0000:0b:00.0: RmInitAdapter failed! (0x26:0x56:1262)
[ 17.924766] NVRM: GPU 0000:0b:00.0: rm_init_adapter failed, device minor number 0
[ 18.579437] NVRM: GPU 0000:0b:00.0: RmInitAdapter failed! (0x26:0x56:1262)
[ 18.579542] NVRM: GPU 0000:0b:00.0: rm_init_adapter failed, device minor number 0
[ 19.236264] NVRM: GPU 0000:0b:00.0: RmInitAdapter failed! (0x26:0x56:1262)
[ 19.236375] NVRM: GPU 0000:0b:00.0: rm_init_adapter failed, device minor number 0
[ 19.890026] NVRM: GPU 0000:0b:00.0: RmInitAdapter failed! (0x26:0x56:1262)
[ 19.890136] NVRM: GPU 0000:0b:00.0: rm_init_adapter failed, device minor number 0
[ 25.567368] NVRM: GPU 0000:0b:00.0: RmInitAdapter failed! (0x26:0x56:1262)
[ 25.567497] NVRM: GPU 0000:0b:00.0: rm_init_adapter failed, device minor number 0
[ 26.228258] NVRM: GPU 0000:0b:00.0: RmInitAdapter failed! (0x26:0x56:1262)
[ 26.228381] NVRM: GPU 0000:0b:00.0: rm_init_adapter failed, device minor number 0
# dmesg | grep nvidia
[ 8.707262] nvidia: loading out-of-tree module taints kernel.
[ 8.707278] nvidia: module license 'NVIDIA' taints kernel.
[ 8.742163] nvidia: module verification failed: signature and/or required key missing - tainting kernel
[ 8.780543] nvidia-nvlink: Nvlink Core is being initialized, major device number 236
[ 8.782226] nvidia 0000:0b:00.0: enabling device (0000 -> 0003)
[ 8.787416] nvidia 0000:0b:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=none
[ 8.885320] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms 470.86 Tue Oct 26 21:46:51 UTC 2021
[ 8.899207] [drm] [nvidia-drm] [GPU ID 0x00000b00] Loading driver
[ 8.899210] [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:0b:00.0 on minor 0
[ 8.966232] nvidia_uvm: module uses symbols from proprietary module nvidia, inheriting taint.
[ 8.974154] nvidia-uvm: Loaded the UVM driver, major device number 234.
[ 9.101203] audit: type=1400 audit(1649987595.034:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=3348 comm="apparmor_parser"
[ 9.101212] audit: type=1400 audit(1649987595.034:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=3348 comm="apparmor_parser"
Here is the log file
nvidia-bug-report.log.gz (108 KB)
Could you please help me to find out what is wrong with me? thanks very much !
(It was good to use RTX3080 in Ubuntu 18.04 before, but suddenly encountered this problem, thinking it was the reason for the incompatibility between the kernel and the driver version, so I reinstalled the Ubuntu 21.04 system, but you still encounter this problem.)
