No devices were found
error in installing
ZOTAC GAMING GeForce RTX 3080 Ti Trinity OC in Ubuntu 20.04.
cat /proc/driver/nvidia/version command gives
NVRM version: NVIDIA UNIX x86_64 Kernel Module 525.85.05 Sat Jan 14 00:49:50 UTC 2023
GCC version: gcc version 9.4.0 (Ubuntu 9.4.0-1ubuntu1~20.04.1)
lspci | grep -i nvidia command gives
06:00.0 VGA compatible controller: NVIDIA Corporation Device 2216 (rev a1)
06:00.1 Audio device: NVIDIA Corporation Device 1aef (rev a1)
The system has Nvidia driver version and 525.85.05
Cuda 11.6.
All installed successfully using run files.
But nvidia-smi command gives
What is wrong with installation?
EDIT:
dpkg -l | grep -i nvidia command has outputs as below
ii libnvidia-compute-510:i386 510.108.03-0ubuntu0.20.04.1 i386 NVIDIA libcompute package
ii libnvidia-decode-510:i386 510.108.03-0ubuntu0.20.04.1 i386 NVIDIA Video Decoding runtime libraries
ii libnvidia-encode-510:i386 510.108.03-0ubuntu0.20.04.1 i386 NVENC Video Encoding runtime library
ii libnvidia-fbc1-510:i386 510.108.03-0ubuntu0.20.04.1 i386 NVIDIA OpenGL-based Framebuffer Capture runtime library
ii screen-resolution-extra 0.18build1 all Extension for the nvidia-settings control panel
