I’m having a second screen + a videoprojector connected via HDMI from my laptop.
It works in Windows, but it does not in Mint 21 (except in discrete GPU mode in Bios, but grub does not boot the system in this mode, I can only see that the second screen displays the attempt of loading too).
Drivers and kernel are up-to-date, Nvidia card is set at performance mode (other modes = same issue).
I suspect some issue with dual graphic cards support.
The HDMI port is not even detected with xrandr command.
I tried everything, including modeset=0 for nvidia-drm.
I bought an adaptor miniDP-HDMI, does not work either.
Thanks for your reply.
In fact, I had no xorg.conf file at all (there is no xorg.conf by default now).
I just generated the file with the nvidia-xconfig command, I added the Module and Device settings recommended in the posts of the forum admins, and it perfectly works after graphic server restart.
I add solved to my post.
Thanks a lot for helping !
Cath
Really really sorry, I read your post far too quickly.
I missed /usr/share/X11 for xorg.conf as I was in /etc/X11 at the same time.
20-intel.conf is there allright.
I’ll do this tomorrow morning and post the result
Thanks,
Cath
