HDMI Connectivity for Orin Dev Kit
Hi.
There is no HDMI port at the Orin dev kit spec.
So, the DisplayPort of Orin dev kit supports DP++?
Or the type-C port of Orin dev kit supports video like AGX Xavier dev kit?
Otherwise, do we need to prepare a monitor which has an actual DisplayPort connector?
I am not positive, but I think the kit will include a DP-to-HDMI adapter. If this is the case (I am not certain), then this will pass through EDID.
linuxdev
Thank you for your comment.
I hope that we can use DP-to-HDMI adapter for Orin dev kit.
I will wait for an answer from NVIDIA.
Please refer to Jetson AGX Orin Developer Kit User Guide - Hardware Layout | NVIDIA Developer
kayccc,
Thank you for your answer.
I understand that we can use a DP to HDMI converter cable for Orin dev kit.
