Hello
In continuation of our conversation about HDMI - we haven’t any visual issues with HDMI, but we have several questions regarding the warnings/errors that we see during the boot sequence (CBoot) // (for easy of reading, we have combined them into bloks)
--------We want to understand what these warnings/errors are and whether it is possible to remove/fix them in a custom build.----------
WARNING: no registered clock for FMON_NAFLL_CLUSTER1 (id 281)
clk_set_parent failed for clk can1, parent pll_aon (-22)
clk_set_parent failed for clk can2, parent pll_aon (-22)
clk_set_parent failed for clk dmic5, parent pll_aon (-22)
clk_set_parent failed for clk i2c2, parent pll_aon (-22)
clk_set_parent failed for clk i2c8, parent pll_aon (-22)
clk_set_parent failed for clk spi2, parent pll_aon (-22)
clk_set_parent failed for clk pwm4, parent pll_aon (-22)
Failed to register PTO counter for id 281
rm_rail_debugfs_init: /rm/vdd_cpu: failed
[0001.755] E> DEVICE_PROD: Invalid value data = 0, size = 0.
[0001.760] W> device prod register failed
[0001.847] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.848] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.849] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via ins.
[0001.857] E> eeprom: Retry to read I2C slave device.
[0001.862] E> I2C: slave not found in slaves.
[0001.866] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.874] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.879] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via ins.
[0001.889] E> eeprom: Failed to read I2C slave device
[0001.894] I> Eeprom read failed 0x3526070d
[0002.034] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x46
[0002.041] E> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0002.049] E> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0002.056] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0002.062] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x44
[0002.069] E> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0002.076] E> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0002.084] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0002.184] I> Found 47 partitions in QSPI_FLASH (instance 0)
[0002.204] W> Cannot find any partition table for 00000003
[0002.278] E> Error -9 when finding node with path /boot-configuration
[0002.280] E> tegrabl_cbo_parse_info: “boot-configuration” not found in CBO file.
[0005.509] W> WARNING: event and command not matching, cmd_trb_ptr = 0xa0ea0800, cmd_ring.dma = 0xa0
[0005.610] I> Start to enumerate device
[0005.611] W> WARNING: event and command not matching, cmd_trb_ptr = 0xa0ea0800, cmd_ring.dma = 0xa0
WARNING: pll_d2 has no dyn ramp
WARNING: at platform/drivers/pg/pg-gpu-t194.c:185
WARNING: at platform/drivers/pg/pg-cv-t194.c:73
- Which device connected to I2C slave address 0x00a0?
