Hi there. I am busy configuring my UART (as part of another ongoing forum) and have suddenly lost HDMI output after reflashing. I typically plug the hdmi in as soon as its finished flashing, so perhaps something went wrong when i plugged it in. Below is the boot logs, and dmesg. Please advise if there are any obvious things that could cause this problem.
I have a fear that the display hardware inside the jetson is damaged as i also had the monitors hdmi get damaged at the same time. Please advise how I can check for any damage.
Ive got HDMI connected to DP2. I configured it and it worked in a previous forum. See attached, ive replicated it again from scratch to see what went wrong, but still having the same issues. See that forum here:
Im just going to post the troubvleshooting that im doing here incase it helps solve the issue
With the HDMI plugged in from boot, i cant access the debug uart to troubleshoot - so clearly something to do with the HPD is working. When i boot without HDMI connected and then plug it in after ive got access to uart, the card1-HDMI is disabled and disconnected.
I saw a previous forum had issues with the HPD, a file was overwriting the HPD to be active low. I’m not sure what the GPIO_ACTIVE_HIGH is in hex so cant check the dts file i attached above
comparing with other gpio_active_high values in hex, it seems as though the current dtc is 0x01, while active high seems to be 0x04
I didn’t mean any special trick or anything that needs technical knowlege.
Just check the timestamp of your /var/log/xorg.0.log… is that a timestamp that happened right after you do a hotplug? or it is a date that is totally not today.
