May I know if you are using xavier devkit? We don’t suggest the use of adapter and JP4.1.1 is a developer preview. I would suggest to use JP4.2.
Also, there are 3 heads on xaiver devkit that can run as display head. There is a HDMI port and 2 type C ports which support DP. You just need a DP to typeC cable.
If you insist using the HDMI port and it got nothing, please share the dmesg with us and I can help check.
After unminimizing the distro, and reconfiguring lightdm to be the desktop manager again the device now reboots into the full Gnome desktop with launcher and icons etc.
Glad to hear that is resolved. I am not sure when do we shift the display manager from lightdm to gdm. We are using gdm on rel-32.1 now. Please note that we don’t suggest user to use VM anyway.
I am running into a similar issue. After trying to install the latest jetpack 4.4, my hdmi port stopped working. The monitor says that it is not receiving a hdmi signal. I tried plugging other sources into the monitor, so I know the monitor and the cable are fine.
I tried downgrading by manually flashing jetpack 4.3 as described in this post (Xavier Update Difficulties) and that process seems to complete successfully. But even so, the monitor does not detect hdmi signal on reboot. I have captured the log from the manual flash. I have also captured the log from the debug port during the manual flash and another log from a regular bootup after the manual flash. manualflash.log (43.6 KB)
Could someone take a look at these logs and suggest a solution? I hope I haven’t bricked the board. I’m not sure how the original poster was able to reconfigure the desktop manager. But I would love to try that solution… or any other solution for that matter. debug.log (49.4 KB) flash0904.log (350.6 KB)
There is problem with HDMI if the Jetson AGX Xavier is Flashed with latest jet-packs (4.4.1).
Solution
The initial boot requires USB-C to HDMI converter. After the first boot remove the converter and connect the HDMI without turning off the machine. The HDMI will work now.
Sudo apt-get update
Sudo apt-get upgrade
will solve the HDMI issue then The HDMI will work fine without converter.
After first boot with USB-C to HDMI converter. proper update is fine need not convert it into lightDM.
but Drawback is sing USB-c to HDMI converter for first boot.
To solve the display port problem in the Jetson TX and Xavier NX you have to use an active adapter from the display port of the board to the HDMI of the monitor. I you use a passive adapter it will not work. Buy an active DP->HDMI adapter instead. I found some good ones in amazon: Active DP to HDMI
