Headles VNC (VINO) only shows Nvidia logo
I’m working on a Jetson AGX board, that should be headless in the future. But we still wants to be able to connect to it through VNC. I am running JetPack 4.4 (L4T_32.4.3) and have configured the virtual display like this:
$ cat /etc/X11/xorg.conf
Section “Module”
Disable “dri”
SubSection “extmod”
Option “omit xfree86-dga”
EndSubSection
EndSection
Section “Device”
Identifier “Tegra0”
Driver “nvidia”
Option “AllowEmptyInitialConfiguration” “true”
Option “EnableAllGpus” “true”
Option “ForceGenerate” “true”
EndSection
Section “Screen”
DefaultDepth 16
Identifier “Screen0”
Device “Tegra0”
SubSection “Display”
Virtual 1920 1080
EndSubSection
EndSection
Auto-login is configured like this:
$ cat /etc/gdm3/custom.conf
# GDM configuration storage
# See /usr/share/gdm/gdm.schemas for a list of available options.
[daemon]
# Uncoment the line below to force the login screen to use Xorg
#WaylandEnable=true
# Enabling automatic login
AutomaticLoginEnable=True
AutomaticLogin=nvidia
# Enabling timed login
# TimedLoginEnable = true
# TimedLogin = user1
# TimedLoginDelay = 10
[security]
[xdmcp]
[chooser]
[debug]
# Uncomment the line below to turn on debugging
# More verbose logs
# Additionally lets the X server dump core if it crashes
#Enable=true
I am using Vino as the VNC server. When I try to connect to the server, the only thing I see is an Nvidia logo, like this.
Does anybody know how to get around this, and get onto the desktop?
please check this page.
Thanks for the reply! I however have setup VNC and have no problems connecting and following the guide did not fix the problem. The problem is, that when i connect i get stuck on a Nvidia logo (maybe the login screen) and cannot do anything, when I am running the machine headless. However when a screen is connected there seams to be no problems. But running it with a screen connected is not an option in the future.
What is the log from vino and xorg.0.log?
This is the output of Xorg.0.log:
[ 13.024] (–) Log file renamed from “/var/log/Xorg.pid-6957.log” to “/var/log/Xorg.0.log”
[ 13.026]
X.Org X Server 1.20.8
X Protocol Version 11, Revision 0
[ 13.026] Build Operating System: Linux 4.15.0-109-generic aarch64 Ubuntu
[ 13.026] Current Operating System: Linux cs-tracker2 4.9.140-tegra #8 SMP PREEMPT Wed Jul 22 17:34:41 CST 2020 aarch64
[ 13.026] Kernel command line: console=ttyTCU0,115200 video=tegrafb no_console_suspend=1 earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt usbcore.old_scheme_first=1 tegraid=19.1.2.0.0 maxcpus=8 boot.slot_suffix= boot.ratchetvalues=0.4.2 vpr_resize sdhci_tegra.en_boot_part_access=1 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4$
[ 13.026] Build Date: 04 September 2020 01:36:23PM
[ 13.026] xorg-server-hwe-18.04 2:1.20.8-2ubuntu2.2~18.04.3 (For technical support please see Enterprise open source support | Ubuntu)
[ 13.026] Current version of pixman: 0.34.0
[ 13.026] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 13.026] Markers: (–) probed, () from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 13.026] (==) Log file: “/var/log/Xorg.0.log”, Time: Thu Nov 12 06:08:16 2020
[ 13.028] (==) Using config file: “/etc/X11/xorg.conf”
[ 13.028] (==) Using system config directory “/usr/share/X11/xorg.conf.d”
[ 13.029] (==) No Layout section. Using the first Screen section.
[ 13.029] (
) |–>Screen “Screen0” (0)
[ 13.029] () | |–>Monitor “Monitor0”
[ 13.030] (
) | |–>Device “Tegra0”
[ 13.030] (==) Automatically adding devices
[ 13.030] (==) Automatically enabling devices
[ 13.030] (==) Automatically adding GPU devices
[ 13.030] (==) Automatically binding GPU devices
[ 13.030] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 13.037] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/cyrillic,
/usr/share/fonts/X11/100dpi/:unscaled,
/usr/share/fonts/X11/75dpi/:unscaled,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/100dpi,
/usr/share/fonts/X11/75dpi,
built-ins
[ 13.037] (==) ModulePath set to “/usr/lib/xorg/modules”
[ 13.037] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 13.037] (II) Loader magic: 0x5591552010
[ 13.037] (II) Module ABI versions:
[ 13.037] X.Org ANSI C Emulation: 0.4
[ 13.037] X.Org Video Driver: 24.1
[ 13.037] X.Org XInput driver : 24.1
[ 13.037] X.Org Server Extension : 10.0
[ 13.040] (++) using VT number 1
[ 13.045] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_31
[ 13.053] (–) PCI:*(11@5:0:0) 1461:0054:1461:3120 rev 0, Mem @ 0x3aa00000/524288
[ 13.053] (WW) “dri” will not be loaded unless you’ve specified it to be loaded elsewhere.
[ 13.053] (II) “glx” will be loaded by default.
[ 13.053] (II) LoadModule: “extmod”
[ 13.053] (II) Module “extmod” already built-in
[ 13.053] (II) LoadModule: “glx”
[ 13.055] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 13.073] (II) Module glx: vendor=“X.Org Foundation”
[ 13.073] compiled for 1.20.8, module version = 1.0.0
[ 13.073] ABI class: X.Org Server Extension, version 10.0
[ 13.074] (II) LoadModule: “nvidia”
[ 13.075] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 13.090] (II) Module nvidia: vendor=“NVIDIA Corporation”
[ 13.090] compiled for 4.0.2, module version = 1.0.0
[ 13.090] Module class: X.Org Video Driver
[ 13.092] (II) NVIDIA dlloader X Driver 32.4.3 Release Build (integ_stage_rel) (buildbrain@mobile-u64-3357) Thu Jun 25 21:23:41 PDT 2020
[ 13.092] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 13.093] (WW) Falling back to old probe method for NVIDIA
[ 13.093] (II) Loading sub module “fb”
[ 13.093] (II) LoadModule: “fb”
[ 13.094] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 13.096] (II) Module fb: vendor=“X.Org Foundation”
[ 13.096] compiled for 1.20.8, module version = 1.0.0
[ 13.096] ABI class: X.Org ANSI C Emulation, version 0.4
[ 13.096] (II) Loading sub module “wfb”
[ 13.096] (II) LoadModule: “wfb”
[ 13.096] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 13.098] (II) Module wfb: vendor=“X.Org Foundation”
[ 13.098] compiled for 1.20.8, module version = 1.0.0
[ 13.098] ABI class: X.Org ANSI C Emulation, version 0.4
[ 13.098] (II) Loading sub module “ramdac”
[ 13.099] (II) LoadModule: “ramdac”
[ 13.099] (II) Module “ramdac” already built-in
[ 13.100] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
[ 13.100] () NVIDIA(0): Depth 24, (–) framebuffer bpp 32
[ 13.100] (==) NVIDIA(0): RGB weight 888
[ 13.100] (==) NVIDIA(0): Default visual is TrueColor
[ 13.100] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 13.100] (DB) xf86MergeOutputClassOptions unsupported bus type 0
[ 13.100] (
) NVIDIA(0): Option “ConnectToAcpid” “Off”
[ 13.100] () NVIDIA(0): Option “AllowEmptyInitialConfiguration” “true”
[ 13.100] (
) NVIDIA(0): Option “UseEDID” “False”
[ 13.100] () NVIDIA(0): Enabling 2D acceleration
[ 13.101] (
) NVIDIA(0): Ignoring EDIDs
[ 13.101] (II) Loading sub module “glxserver_nvidia”
[ 13.101] (II) LoadModule: “glxserver_nvidia”
[ 13.101] (II) Loading /usr/lib/xorg/modules/extensions/libglxserver_nvidia.so
[ 13.177] (II) Module glxserver_nvidia: vendor=“NVIDIA Corporation”
[ 13.177] compiled for 4.0.2, module version = 1.0.0
[ 13.178] Module class: X.Org Server Extension
[ 13.178] (II) NVIDIA GLX Module 32.4.3 Release Build (integ_stage_rel) (buildbrain@mobile-u64-3357) Thu Jun 25 21:22:13 PDT 2020
[ 13.210] (–) NVIDIA(0): Valid display device(s) on GPU-0 at SoC
[ 13.210] (–) NVIDIA(0): DFP-0
[ 13.210] (–) NVIDIA(0): DFP-1
[ 13.210] (–) NVIDIA(0): DFP-2
[ 13.210] (II) NVIDIA(0): NVIDIA GPU Xavier (nvgpu) (GV11B) at SoC (GPU-0)
[ 13.210] (–) NVIDIA(0): Memory: 32693004 kBytes
[ 13.210] (–) NVIDIA(0): VideoBIOS:
[ 13.210] (–) NVIDIA(0): No enabled display devices found; starting anyway because
[ 13.210] (–) NVIDIA(0): AllowEmptyInitialConfiguration is enabled
[ 13.210] (II) NVIDIA(0): Validated MetaModes:
[ 13.211] (II) NVIDIA(0): “NULL”
[ 13.211] (**) NVIDIA(0): Virtual screen size configured to be 1920 x 1080
[ 13.211] (WW) NVIDIA(0): Unable to get display device for DPI computation.
[ 13.211] (==) NVIDIA(0): DPI set to (75, 75); computed from built-in default
[ 13.211] (II) NVIDIA: Reserving 24576.00 MB of virtual memory for indirect memory
[ 13.211] (II) NVIDIA: access.
[ 13.220] (EE) NVIDIA(0): Failed to allocate NVIDIA Error Handler
[ 13.270] (II) NVIDIA(0): Setting mode “NULL”
[ 13.275] (==) NVIDIA(0): Disabling shared memory pixmaps
[ 13.275] (==) NVIDIA(0): Backing store enabled
[ 13.275] (==) NVIDIA(0): Silken mouse enabled
[ 13.275] (==) NVIDIA(0): DPMS enabled
[ 13.276] (II) Loading sub module “dri2”
[ 13.276] (II) LoadModule: “dri2”
[ 13.276] (II) Module “dri2” already built-in
[ 13.276] (II) NVIDIA(0): [DRI2] Setup complete
[ 13.276] (II) NVIDIA(0): [DRI2] VDPAU driver: nvidia
[ 13.276] (II) Initializing extension Generic Event Extension
[ 13.277] (II) Initializing extension SHAPE
[ 13.277] (II) Initializing extension MIT-SHM
[ 13.278] (II) Initializing extension XInputExtension
[ 13.279] (II) Initializing extension XTEST
[ 13.279] (II) Initializing extension BIG-REQUESTS
[ 13.280] (II) Initializing extension SYNC
[ 13.280] (II) Initializing extension XKEYBOARD
[ 13.281] (II) Initializing extension XC-MISC
[ 13.282] (II) Initializing extension SECURITY
[ 13.282] (II) Initializing extension XFIXES
[ 13.283] (II) Initializing extension RENDER
[ 13.283] (II) Initializing extension RANDR
[ 13.284] (II) Initializing extension COMPOSITE
[ 13.284] (II) Initializing extension DAMAGE
[ 13.285] (II) Initializing extension MIT-SCREEN-SAVER
[ 13.285] (II) Initializing extension DOUBLE-BUFFER
[ 13.285] (II) Initializing extension RECORD
[ 13.285] (II) Initializing extension DPMS
[ 13.286] (II) Initializing extension Present
[ 13.286] (II) Initializing extension DRI3
[ 13.286] (II) Initializing extension X-Resource
[ 13.286] (II) Initializing extension XVideo
[ 13.287] (II) Initializing extension XVideo-MotionCompensation
[ 13.287] (II) Initializing extension SELinux
[ 13.287] (II) SELinux: Disabled on system
[ 13.287] (II) Initializing extension GLX
[ 13.287] (II) Indirect GLX disabled.
[ 13.287] (II) GLX: Another vendor is already registered for screen 0
[ 13.287] (II) Initializing extension XFree86-VidModeExtension
[ 13.288] (II) Initializing extension XFree86-DGA
[ 13.288] (II) Initializing extension XFree86-DRI
[ 13.288] (II) Initializing extension DRI2
[ 13.288] (II) Initializing extension NV-GLX
[ 13.289] (II) Initializing extension NV-CONTROL
[ 13.440] (II) config/udev: Adding input device tegra-hda-galen-t194 HDMI/DP,pcm=3 (/dev/input/event0)
[ 13.440] (II) No input driver specified, ignoring this device.
[ 13.440] (II) This device may have been added with another device file.
[ 13.441] (II) config/udev: Adding input device tegra-hda-galen-t194 HDMI/DP,pcm=7 (/dev/input/event1)
[ 13.441] (II) No input driver specified, ignoring this device.
[ 13.441] (II) This device may have been added with another device file.
[ 13.441] (II) config/udev: Adding input device tegra-hda-galen-t194 HDMI/DP,pcm=8 (/dev/input/event2)
[ 13.442] (II) config/udev: Adding input device tegra-hda-galen-t194 HDMI/DP,pcm=9 (/dev/input/event3)
[ 13.442] (II) No input driver specified, ignoring this device.
[ 13.442] (II) This device may have been added with another device file.
[ 13.443] (II) config/udev: Adding input device Logitech MX Master 2S (/dev/input/event6)
[ 13.444] (II) No input driver specified, ignoring this device.
[ 13.444] (II) This device may have been added with another device file.
[ 13.445] (II) config/udev: Adding input device Logitech MX Master 2S (/dev/input/mouse0)
[ 13.445] (II) No input driver specified, ignoring this device.
[ 13.445] (II) This device may have been added with another device file.
[ 13.445] (II) config/udev: Adding input device gpio-keys (/dev/input/event5)
[ 13.446] (II) config/udev: Adding input device tegra-snd-t19x-mobile-rt565x Headset Jack (/dev/input/event4)
[ 13.446] (II) No input driver specified, ignoring this device.
[ 13.446] (II) This device may have been added with another device file.
As far as I could see Vino does not output a log file. None is present in /var/log. If I run vino-server manually this is the output:
12/11/2020 06:53:43 AM Autoprobing TCP port in (all) network interface
12/11/2020 06:53:43 AM Listening IPv6://[::]:5900
12/11/2020 06:53:43 AM Listening IPv4://0.0.0.0:5900
12/11/2020 06:53:43 AM Autoprobing selected port 5900
12/11/2020 06:53:43 AM Advertising security type: ‘TLS’ (18)
12/11/2020 06:53:43 AM Re-binding socket to listen for VNC connections on TCP port 5900 in (all) interface
12/11/2020 06:53:43 AM Clearing securityTypes
12/11/2020 06:53:43 AM Advertising authentication type: ‘No Authentication’ (1)
12/11/2020 06:53:43 AM Clearing authTypes
12/11/2020 06:53:43 AM Advertising authentication type: ‘VNC Authentication’ (2)
12/11/2020 06:53:43 AM Advertising security type: ‘VNC Authentication’ (2)
------- After connecting --------
12/11/2020 06:54:05 AM [IPv4] Got connection from client 10.230.240.116
12/11/2020 06:54:05 AM other clients:
12/11/2020 06:54:05 AM Client Protocol Version 3.7
12/11/2020 06:54:05 AM Advertising security type 18
12/11/2020 06:54:05 AM Advertising security type 2
12/11/2020 06:54:05 AM Client returned security type 2
12/11/2020 06:54:09 AM rfbProcessClientNormalMessage: ignoring unknown encoding type 24
12/11/2020 06:54:09 AM rfbProcessClientNormalMessage: ignoring unknown encoding type 22
12/11/2020 06:54:09 AM rfbProcessClientNormalMessage: ignoring unknown encoding type 21
12/11/2020 06:54:09 AM rfbProcessClientNormalMessage: ignoring unknown encoding type 15
12/11/2020 06:54:09 AM rfbProcessClientNormalMessage: ignoring unknown encoding type -314
12/11/2020 06:54:09 AM Enabling NewFBSize protocol extension for client 10.230.240.116
12/11/2020 06:54:09 AM Pixel format for client 10.230.240.116:
12/11/2020 06:54:09 AM 8 bpp, depth 6
12/11/2020 06:54:09 AM true colour: max r 3 g 3 b 3, shift r 4 g 2 b 0
12/11/2020 06:54:09 AM 32 bpp, depth 24, little endian
12/11/2020 06:54:09 AM true colour: max r 255 g 255 b 255, shift r 16 g 8 b 0
12/11/2020 06:54:09 AM no translation needed
It was fixed by reflashing the board with a new image. It seams that somebody had changed something that made the desktop manager never load correctly, thus being stuck at the logo screen previous to that.
