These are all headless nodes, made so this way (I’ll explain the commands in <> in a moment):
<sudo systemctl set-default multi-user.target>
sudo reboot now
I’ve successfully configured one of the boards, but the second one - even though I’m configuring it identically - fails in a strange way.
Specifically, on the first board, I can connect via ssh upon boot. On the second board, however, the ssh service never starts UNLESS I FIRST login in to tty1…and then the service starts immediately.
Now, I tried to purge the display manager, since I don’t need it to run headless, using these commands on both boards:
If I do all of these on the first board, no problem: upon boot, I can ssh in directly. However, on the second board…the ssh service never starts. IF I don’t carry out the command in <>, I CAN start ssh into the second board (even though there is no graphical display manager running).
Strange…
Any thoughts?
(am about to try boards 3 and 4, and see what happens next)
But that doesn’t make the node fully headless, because it leaves me with the Light Display Manager. If I go all the way (on one all but one of my three nodes!) and cut off the head completely with this
Then I get the weirdness I mentioned: I can’t ssh in (and I can’t even get a response from a remote ping) until I login via TTY1.
As such, where I’ve left matters, is to do the first set of commands but not the set-default one.
This gave me no problem prior to the latest Jet Pack.
(and so…even if I set up serial access to the console as above, I still end up having to log in before I can ssh)
I appreciate your post for multiple reasons, I had no idea that LibreOffice was installed. Why that would be included in the Jetpack I have no idea. I removed it from mine, too, saved significant SD space.
I just experienced the same issue. I have not resolved it yet. I was in the middle of connecting my Raspberry PI camera when I ran into it.
I could not ssh into my Jetson Nano, nor did it turn up in a network map command (zmap) that I ran from other computers. The Jetson Nano did not respond to pings either. All of those issues resolved after logging in to it first.
I really hope I can get this resolved easily. I am planning to use several Jetson Nano’s and eventually higher end AI boards in a cluster along with Raspberry PI’s and some Dell servers that I have here.
