I installed Fedora 42 on my new Lenovo Legion pro 7 with 5090. Now I’ve a problems with Nvidia’s drivers loading.
I’ve tried a lot of things including rebuild modules with akmods
and dracut
, login with Wayland or X11, but nothing works. So, any help will be appreciated.
nvidia-smi
No devices were found
sudo modinfo nvidia
filename: /lib/modules/6.14.9-300.fc42.x86_64/extra/nvidia/nvidia.ko
import_ns: DMA_BUF
alias: char-major-195-*
version: 575.57.08
supported: external
license: Dual MIT/GPL
firmware: nvidia/575.57.08/gsp_tu10x.bin
firmware: nvidia/575.57.08/gsp_ga10x.bin
srcversion: AA6B6D25AE218AFF04CB762
alias: pci:v000010DEdsvsdbc06sc80i00
alias: pci:v000010DEdsvsdbc03sc02i00
alias: pci:v000010DEdsvsdbc03sc00i00
alias: of:NTCnvidia,tegra234-displayC*
depends:
retpoline: Y
vermagic: 6.14.9-300.fc42.x86_64 SMP preempt mod_unload
sudo dmesg | grep -i nvidia
[ 0.000000] Command line: BOOT_IMAGE=(hd0,gpt2)/vmlinuz-6.14.9-300.fc42.x86_64 root=/dev/mapper/fedora–01-root ro rd.lvm.lv=fedora-01/root rd.luks.uuid=luks-0b1c3a25-5c66-4f3a-9684-6d8b489ab123 rd.driver.blacklist=nouveau,nova_core modprobe.blacklist=nouveau,nova_core nvidia-drm.modeset=1
[ 0.069275] Kernel command line: BOOT_IMAGE=(hd0,gpt2)/vmlinuz-6.14.9-300.fc42.x86_64 root=/dev/mapper/fedora–01-root ro rd.lvm.lv=fedora-01/root rd.luks.uuid=luks-0b1c3a25-5c66-4f3a-9684-6d8b489ab123 rd.driver.blacklist=nouveau,nova_core modprobe.blacklist=nouveau,nova_core nvidia-drm.modeset=1
[ 143.185648] nvidia: loading out-of-tree module taints kernel.
[ 143.186860] nvidia: module verification failed: signature and/or required key missing - tainting kernel
[ 143.303870] nvidia-nvlink: Nvlink Core is being initialized, major device number 509
[ 143.308540] nvidia 0000:02:00.0: enabling device (0000 → 0003)
[ 143.310456] nvidia 0000:02:00.0: vgaarb: VGA decodes changed: olddecodes=io+mem,decodes=none:owns=none
[ 143.322404] NVRM: loading NVIDIA UNIX Open Kernel Module for x86_64 575.57.08 Release Build (dvs-builder@U22-I3-H04-01-5) Sat May 24 07:03:13 UTC 2025
[ 143.468644] nvidia-modeset: Loading NVIDIA UNIX Open Kernel Mode Setting Driver for x86_64 575.57.08 Release Build (dvs-builder@U22-I3-H04-01-5) Sat May 24 06:53:21 UTC 2025
[ 143.471163] [drm] [nvidia-drm] [GPU ID 0x00000200] Loading driver
[ 144.206290] nvidia 0000:02:00.0: Enabling HDA controller
[ 144.233111] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:06.0/0000:02:00.1/sound/card0/input17
[ 144.233766] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:06.0/0000:02:00.1/sound/card0/input18
[ 146.500482] [drm:nv_drm_load [nvidia_drm]] ERROR [nvidia-drm] [GPU ID 0x00000200] Failed to allocate NvKmsKapiDevice
[ 146.501950] [drm:nv_drm_register_drm_device [nvidia_drm]] ERROR [nvidia-drm] [GPU ID 0x00000200] Failed to register device
[ 147.382461] nvidia 0000:02:00.0: Enabling HDA controller
[ 150.518403] nvidia 0000:02:00.0: Enabling HDA controller
[ 238.558273] nvidia 0000:02:00.0: Enabling HDA controller
