Hi all:
I will be so appreciate if anybody let me know that after i have installed GPU nVidia Geforce on windows , how i could make program in CUDA environment? from where i should start ?
Hi all:
you can read Dr. Dobb’s lecture note on
http://www.drdobbs.com/cpp/207200659
and check CUDA programming guide
Thanks alot, but the problem i that he did not mention the steps to open a project and running a CUDA program. I need to know what steps I should pass to create a project and give me a simple code and let me know how to Run it. For example where i should add header file in C, or .cu and…
The best way is to use cmake. I would recommend cmake 2.6.3 or higher.
DarkTerror
Have you tried the CUDA SDK samples? The template may be where you want to look.
