How can I add a timestamp in Roce?
follow the manual. I used ibv_exp_query_device to query device capability, but I got an error as follows.
ibv_exp_query_device: invalid comp_mask !!! (comp_mask = 0x30373839 valid_mask = 0x7fffff)
my adapter is ConnectX-4.
ethtools -T eth1
Time stamping parameters for eth1:
Capabilities:
hardware-transmit (SOF_TIMESTAMPING_TX_HARDWARE)
software-transmit (SOF_TIMESTAMPING_TX_SOFTWARE)
hardware-receive (SOF_TIMESTAMPING_RX_HARDWARE)
software-receive (SOF_TIMESTAMPING_RX_SOFTWARE)
software-system-clock (SOF_TIMESTAMPING_SOFTWARE)
hardware-raw-clock (SOF_TIMESTAMPING_RAW_HARDWARE)
PTP Hardware Clock: 0
Hardware Transmit Timestamp Modes:
off (HWTSTAMP_TX_OFF)
on (HWTSTAMP_TX_ON)
Hardware Receive Filter Modes:
none (HWTSTAMP_FILTER_NONE)
all (HWTSTAMP_FILTER_ALL)
Hi Chris,
For this issue please open a case with Mellanox support providing the configuration that was done in order to use time stamping.
support@mellanox.com mailto:support@mellanox.com .
Thank you,
Hi Chris,
have you received a solution for your problem?
I’m quite interested because we just have installed a new cluster in our compagny and, unfortunately, we have the same error messsage than you when we launch some MPI jobs.
It is a very strong problem for us since, up to now, we are not able to start our studies.
Thank you.
If using HPC-X or OpenMPI from the Mellanox OFED, you might add ‘-mca btl self -mca pml ucx’
