The application cannot find the ConnectX device. I am not familiar with setting up Mallanox nic card. This Linux system we using already has a mlx5_core driver loaded upon power-up.
Any suggestion would be very helpful.
Here is more detail
Application Error
master001:~/9.MI2/Innova_2_Flex_Open_18_12/app # ./innova2_flex_app -v
Verbosity: 1
BOPE device: None
ConnectX device: None
Cannot find appropriate ConnectX device
lspci Command
master001:~/9.MI2/Innova_2_Flex_Open_18_12/app # lspci -v | grep Mellanox
03:00.0 PCI bridge: Mellanox Technologies Device 1974 (prog-if 00 [Normal decode])
04:08.0 PCI bridge: Mellanox Technologies Device 1974 (prog-if 00 [Normal decode])
04:10.0 PCI bridge: Mellanox Technologies Device 1974 (prog-if 00 [Normal decode])
05:00.0 Class 2000: Mellanox Technologies Device 0264
Subsystem: Mellanox Technologies Device 0264
06:00.0 Ethernet controller: Mellanox Technologies MT27800 Family [ConnectX-5, PCIe 3.0]
Subsystem: Mellanox Technologies Device 0046
06:00.1 Ethernet controller: Mellanox Technologies MT27800 Family [ConnectX-5, PCIe 3.0]
08:00.0 Network controller: Mellanox Technologies MT27500 Family [ConnectX-3]
Subsystem: Mellanox Technologies Device 016c
More Details
master001:~/9.MI2/Innova_2_Flex_Open_18_12 # lspci -vvv -s 06:00.0
Control: I/O- Mem+ BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- SERR- <PERR- INTx-
Interrupt: pin A routed to IRQ 26
Region 0: Memory at c2000000 (64-bit, prefetchable) [size=32M]
Expansion ROM at c7400000 [disabled] [size=1M]
Capabilities: [60] Express (v2) Endpoint, MSI 00
DevCap: MaxPayload 512 bytes, PhantFunc 0, Latency L0s unlimited, L1 unlimited
ExtTag+ AttnBtn- AttnInd- PwrInd- RBE+ FLReset+
DevCtl: Report errors: Correctable- Non-Fatal- Fatal- Unsupported-
RlxdOrd- ExtTag- PhantFunc- AuxPwr- NoSnoop+ FLReset-
MaxPayload 256 bytes, MaxReadReq 512 bytes
DevSta: CorrErr+ UncorrErr- FatalErr- UnsuppReq+ AuxPwr- TransPend-
LnkCap: Port #0, Speed unknown, Width x16, ASPM not supported, Exit Latency L0s unlimited, L1 <4us
ClockPM- Surprise- LLActRep- BwNot-
LnkCtl: ASPM Disabled; RCB 64 bytes Disabled- CommClk+
ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
LnkSta: Speed unknown, Width x16, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
DevCap2: Completion Timeout: Range ABC, TimeoutDis+, LTR-, OBFF Not Supported
DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR-, OBFF Disabled
LnkCtl2: Target Link Speed: Unknown, EnterCompliance- SpeedDis-
Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
Compliance De-emphasis: -6dB
LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete+, EqualizationPhase1+
EqualizationPhase2+, EqualizationPhase3+, LinkEqualizationRequest-
Capabilities: [48] Vital Product Data
Product Name: Innova-2 Flex Open for Application Acceleration, dual-port SFP28, 25GbE, KU15P, No Crypto, PCI4.0 x8, HHHL, active heat sink, tall bracket, ROHS R6
Read-only fields:
[PN] Part number: MNV303212A-ADLT
[EC] Engineering changes: AA
[V2] Vendor specific: MNV303212A-ADLT
[SN] Serial number: MT2045X09746
[V3] Vendor specific: b8d4ac17c321eb118000043f72e6e896
[VA] Vendor specific: MLX:MODL=NV303212A:MN=MLNX:CSKU=V2:UUID=V3:PCI=V0
[V0] Vendor specific: PCIeGen4 x8
[RV] Reserved: checksum good, 1 byte(s) reserved
End
Capabilities: [9c] MSI-X: Enable- Count=64 Masked-
Vector table: BAR=0 offset=00002000
PBA: BAR=0 offset=00003000
Capabilities: [c0] Vendor Specific Information: Len=18 <?>
Capabilities: [40] Power Management version 3
Flags: PMEClk- DSI- D1- D2- AuxCurrent=375mA PME(D0-,D1-,D2-,D3hot-,D3cold+)
Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
Capabilities: [100 v1] Advanced Error Reporting
UESta: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UEMsk: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UESvrt: DLP+ SDES- TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
CESta: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr-
CEMsk: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr+
AERCap: First Error Pointer: 04, GenCap+ CGenEn- ChkCap+ ChkEn-
Capabilities: [150 v1] Alternative Routing-ID Interpretation (ARI)
ARICap: MFVC- ACS-, Next Function: 1
ARICtl: MFVC- ACS-, Function Group: 0
Capabilities: [180 v1] Single Root I/O Virtualization (SR-IOV)
IOVCap: Migration-, Interrupt Message Number: 000
IOVCtl: Enable- Migration- Interrupt- MSE- ARIHierarchy+
IOVSta: Migration-
Initial VFs: 8, Total VFs: 8, Number of VFs: 0, Function Dependency Link: 00
VF offset: 2, stride: 1, Device ID: 1018
Supported Page Size: 000007ff, System Page Size: 00000001
Region 0: Memory at 0000000000000000 (64-bit, prefetchable)
VF Migration: offset: 00000000, BIR: 0
Capabilities: [1c0 v1] #19
Capabilities: [230 v1] Access Control Services
ACSCap: SrcValid- TransBlk- ReqRedir- CmpltRedir- UpstreamFwd- EgressCtrl- DirectTrans-
ACSCtl: SrcValid- TransBlk- ReqRedir- CmpltRedir- UpstreamFwd- EgressCtrl- DirectTrans-
Capabilities: [320 v1] #27
Capabilities: [370 v1] #26
Capabilities: [420 v1] #25
Kernel modules: mlx5_core
