How can i copy/transplant a jetson orin systems to another orin board? such as using SD card or SDK flash
I have tried both, all failed on orin board. but it can be run successfully in Xavier board.
can somebody help me !!!
Hi 2673648021,
Are you using the devkit or custom board?
You could refer to the following instruction to clone system.img from your original board and flash to another target board.
Flashing Support — To clone a Jetson device and flash
Thanks KevinFFF!
Check out this, sdkmanager shows that i had connected the orin board,but when i run “sudo ./flash.sh -r -k APP -G mmcblk0p1”,it came out Error
You have to enter Force Recovery Mode before run this command.
Please refer to the following instruction to enter force recovery state.
Jetson AGX Orin can't turn into force recovery mode - #5 by WayneWWW
