I accidentally overwrote the /usr/bin folder on my ORIN.
Now I cannot login. I was using it as a headless system following the instructions here: Getting Started with Jetson AGX Orin Developer Kit | NVIDIA Developer
Is there a way to restore the OS? Maybe I can flash a miroSD card boot with it. But I don’t know where to get one from.
AGX Orin does not support booting from SD cards, so you have to re-flash your device with SDK Manager.
Thank you DaveYYY.
I just downloaded the docker sdk manager from SDK Manager | NVIDIA Developer and now I am following the instructions here Docker Images :: NVIDIA SDK Manager Documentation , I am trying to flash the ORIN device.
docker run -it --privileged -v /dev/bus/usb:/dev/bus/usb/ -v /dev:/dev -v /media/$USER:/media/nvidia:slave --name JetPack_AGX_Devkit --network host sdkmanager --cli install --logintype devzone --product Jetson --version 5.1.1 --targetos Linux --host --target JETSON_AGX_XAVIER_TARGETS --flash all --additionalsdk ‘DeepStream 6.2’ --license accept --staylogin true --datacollection enable --exitonfinish
Then I select option 1 after getting prompted , and open the link of the presented URL, and login with password.
After that I do
docker commit JetPack_AGX_Devkit jetpack_agx_devkit:5.5.1_flash
docker container rm JetPack_AGX_Devkit
docker run -it --rm --privileged -v /dev/bus/usb:/dev/bus/usb/ jetpack_agx_devkit:5.5.1_flash --cli --flash all --product jetson-agx-orin-devkit
Error: missing argument ‘–version’
Error: missing argument ‘–targetos’
I don’t know what values to use for --product, --version --targetos
The ORIN is connected with USB-A port to my PC and USB-C port to the ORIN
I’m sorry but I actually haven’t done it inside Docker before, and we usually use the GUI of SDK Manager directly inside a real Ubuntu.
Or download our BSP directly, and flash you device with scripts provided in the BSP:
sudo ./flash.sh jetson-agx-orin-devkit internal
NVIDIA® Jetson™ Linux Driver Package is the board support package for Jetson. It includes Linux Kernel, UEFI bootloader, NVIDIA drivers, flashing utilities, sample filesystem based on Ubuntu, and more for the Jetson platform. NVIDIA Jetson Linux...
https://docs.nvidia.com/jetson/archives/r35.3.1/DeveloperGuide/index.html
Finally this is how I flashed the NVIDIA AGX ORIN devicekit
Download L4T Driver Package (BSP):
wget https://developer.nvidia.com/embedded/l4t/r34_release_v1.0/release/jetson_linux_r34.1.0_aarch64.tbz2
Downlad Sample Root Filesystem:
wget https://developer.nvidia.com/embedded/l4t/r34_release_v1.0/release/tegra_linux_sample-root-filesystem_r34.1.0_aarch64.tbz2
(Taken from Jetson Linux 34.1 | NVIDIA Developer )
Follow the guide:
https://docs.nvidia.com/jetson/archives/r34.1/DeveloperGuide/text/IN/QuickStart.html#in-quickstart
export L4T_RELEASE_PACKAGE=“Jetson_Linux_R34.1.0_aarch64.tbz2”
export SAMPLE_FS_PACKAGE=“Tegra_Linux_Sample-Root-Filesystem_R34.1.0_aarch64.tbz2”
export BOARD=“jetson-agx-orin-devkit”
cd ~/Downloads
tar xf ${L4T_RELEASE_PACKAGE}
cd Linux_for_Tegra/rootfs/
sudo tar xpf …/…/${SAMPLE_FS_PACKAGE}
cd …
sudo apt-get -y install qemu-user-static
sudo ./apply_binaries.sh
#Put the AGX ORIN device into Forced Recovery mode
##Press and hold down the Force Recovery button.
##Press , then release the Power button.
##Release the Force Recovery button.
#Confirm the device is in forced recovery mode by running
lsusb | grep NVIDIA
#(deatails at Quick Start — Jetson Linux<br/>Developer Guide 34.1 documentation )
#if confirmed, then flash:
sudo ./flash.sh ${BOARD} mmcblk0p1
Yes, glad you figured it out.
system
Closed
August 9, 2023, 1:34am
10
