For some reasons, I want to clone the system image of the Jetson AGX Orin 32GB to the Jetson AGX Orin 64GB. After receiving a successful message, The target t186ref has been flashed successfully. When resetting the board to boot from the internal eMMC, it fails to enter the system successfully, and there is a fleeting message on the screen saying that the hvc_sysfs hypervisor is not present.
I’m unsure if such cloning operations are feasible?
If the device cannot be flashed/booted, please refer to the page to get uart log from the device: https://elinux.org/Jetson/General_debug
And get logs of host PC and Jetson device for reference. If you are using custom board, you can compare uart log of developer kit and custom board to get more information.
Also please check FAQs: Jetson AGX Orin FAQ
If possible, we would suggest follow quick start in developer guide to re-flash the system: Quick Start — NVIDIA Jetson Linux Developer Guide 1 documentation
And see if the issue still persists on a clean-flashed system.
