How can I embed a scene into another one in Omniverse Create, rather than quote them as x-forms?
Hi @yuanmiaomiao1994 ,
Are you saying like you have a scene in one usd.file then you wanted to put this into another usd file ? If this is the case, then just open one of the usd file then navigate to the second usd file and select and right click and insert as sublayer, possible to collapse everything into one layer if you wanted to under the layer tab. Hope that helps !
Yes, this is just what I need. Thanks.
Nice! Please mark this topic then as solved, it helps Nvidia staff.
Sure :)
