you may just modify ODMDDATA bits 17:16 in the config file to enable pmic-wdt; it’s 0 to disable and 1 to enable. bit 16: Tegra Denver Watchdog Timer bit 17: PMIC Watchdog Timer
In this file
/home/kimjishu/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/p2771-0000.conf.commonJetPack_4.6_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/p2771-0000.conf.common
I modified all “ODMDATA=0x1090000;” text to “ODMDATA=0x10a0000;”
but after flashing, result is pmic: reset reason (nverc) : 0x0
