I want to know if I can run 2 deepstream app on startup in Jetson nano to take inference. Can this be replicated later using docker or kubernetes
Please refer to
Autrun deepstream app at startup on jetson nano - #10 by DaneLLL
Ideally it should work if you put two commands with &
(runin background) in rc.local. Please give it a try. One concern is if the models are heavy, it may not achieve target performance on Jetson Nano.
