• Hardware Platform (Jetson / GPU) RTX 3070
• DeepStream Version 5.1 ( docker triton 02.26.2021 version)
• JetPack Version (valid for Jetson only) no
• TensorRT Version 7.2.1 , 7.2.2
• NVIDIA GPU Driver Version (valid for GPU only) 460.39
Please answer quickly. :)
I have deepstream 5.1 docker image, sample version and triton version.
I installed it inside container to use pytorch.
but trition container was not import pytorch
- error code
Python 3.6.9 (default, Oct 8 2020, 12:12:24)
[GCC 8.4.0] on linux
Type “help”, “copyright”, “credits” or “license” for more information.import torch
File “”, line 1, in
File “/usr/local/lib/python3.6/dist-packages/torch/init.py”, line 190, in
from torch._C import *
ImportError: /usr/local/lib/python3.6/dist-packages/torch/lib/libtorch_python.so: undefined symbol:
_ZTIN5torch11distributed3rpc8RpcAgentE - pip3 list
root@d1ae1024f8b6:/opt/nvidia/deepstream/deepstream-5.1# pip3 list
Package Version
dataclasses 0.8
graphsurgeon 0.4.5
grpcio 1.33.2
grpcio-channelz 1.33.2
grpcio-tools 1.33.2
numpy 1.19.4
Pillow 8.1.1
pip 21.0.1
protobuf 3.13.0
setuptools 50.3.2
six 1.15.0
tensorrt 7.2.1.6
torch 1.7.1+cu110
torchaudio 0.7.2
torchvision 0.8.2+cu110
typing-extensions 3.7.4.3
uff 0.6.9
wheel 0.35.1
BUT!
sample version is good worked ^^;;
code
Python 3.6.9 (default, Jan 26 2021, 15:33:00)
pip3 list
root@a4c597aa8bd1:/# pip3 list
DEPRECATION: The default format will switch to columns in the future. You can use --format=(legacy|columns) (or
define a format=(legacy|columns) in your pip.conf under the [list] section) to disable this warning.
asn1crypto (0.24.0)
cryptography (2.1.4)
Cython (0.29.22)
dataclasses (0.8)
graphsurgeon (0.4.5)
idna (2.6)
keyring (10.6.0)
keyrings.alt (3.0)
numpy (1.19.5)
onnx (1.8.1)
onnxruntime (1.3.0)
Pillow (8.1.1)
pip (9.0.1)
protobuf (3.15.4)
pycrypto (2.6.1)
pygobject (3.26.1)
pyxdg (0.25)
SecretStorage (2.3.1)
setuptools (39.0.1)
six (1.11.0)
tensorrt (7.2.3.4)
torch (1.7.1+cu110)
torchaudio (0.7.2)
torchvision (0.8.2+cu110)
typing-extensions (3.7.4.3)
uff (0.6.9)
wheel (0.30.0) -
install command
try1
pip3 install torch==1.7.1+cu110 torchvision==0.8.2+cu110 torchaudio===0.7.2 -f https://download.pytorch.org/whl/torch_stable.html -
try 2
pip3 install torch
same result …
As above ImportError …
this is bugs???
I want to use the triton version. because sample verion not install tensorRT trtexec.
In addition to
deepstream was good worked.
ex) deepstream-app -c <.txt>
