• Hardware Platform (Jetson / GPU): GPU • DeepStream Version: deepstream:5.1-21.02-triton • JetPack Version (valid for Jetson only) • TensorRT Version • NVIDIA GPU Driver Version (valid for GPU only): Driver Version: 460.32.03 • Issue Type( questions, new requirements, bugs) Issue • How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) Try installing torch>=1.7.0 inside deepstream:5.1-21.02-triton container and trying import torch.
Getting,
File "deepstream/deepstream_yolov5/yolov5_main.py", line 535, in <module>
sys.exit(main(sys.argv))
File "deepstream/deepstream_yolov5/yolov5_main.py", line 424, in main
import torch
File "/usr/local/lib/python3.6/dist-packages/torch/__init__.py", line 196, in <module>
from torch._C import *
ImportError: /usr/local/lib/python3.6/dist-packages/torch/lib/libtorch_python.so: undefined symbol: _ZNK3c104Type14isSubtypeOfExtERKSt10shared_ptrIS0_EPSo
To solve this did, export LD_LIBRARY_PATH=/usr/local/cuda/lib64:$LD_LIBRARY_PATH. But getting the same error.
When overwritten all the LD_LIBRARY_PATH, export LD_LIBRARY_PATH=/usr/local/cuda/lib64, was able to import torch but got the following error:
Creating Pipeline
Creating streamux
Creating source_bin 0
Creating source bin
source-bin-00
Creating Pgie
0:00:00.053752633 151 0x1b7a200 WARN GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: libtritonserver.so: cannot open shared object file: No such file or directory
(python3:151): GStreamer-WARNING **: 12:19:34.160: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_inferserver.so': libtritonserver.so: cannot open shared object file: No such file or directory
0:00:00.053921445 151 0x1b7a200 WARN GST_PLUGIN_LOADING gstplugin.c:1329:gst_plugin_load_by_name: load_plugin error: Opening module failed: libtritonserver.so: cannot open shared object file: No such file or directory
0:00:00.053950290 151 0x1b7a200 WARN GST_PLUGIN_LOADING gstpluginfeature.c:133:gst_plugin_feature_load: Failed to load plugin containing feature 'nvinferserver'.
0:00:00.053998831 151 0x1b7a200 WARN GST_ELEMENT_FACTORY gstelementfactory.c:397:gst_element_factory_create:<nvinferserver> loading plugin containing feature primary-inference returned NULL!
Unable to create pgie
Creating tiler
Creating nvvidconv
@mchi I did see this solution, but I want to run triton server a long with deepstream. Thats why I chose deepstream:5.1-21.02-triton docker image.
Does nvcr.io/nvidia/deepstream:5.1-21.02-devel have all the required triton-server installations along with deepstream? If so, that would be wonderful.
I am trying to use ONNX model in triton server and using nvinferserver inside deepstream to run the pipeline.
DeepStream does not have all the triton-server components, the nvinferserver plugin in deepstream uses triton as its backend to inference the data from other GST plugins.
When I say running triton server along with deepstream, I meants deepstream using triton backend only. Sorry for miscommunication.
Yes, current triton is DS meets my requirements. I am able to run the deepstream with triton backend as well. Its just that I need to use pytorch to do some sort of post-processing on top of the results obtained from
@mchi even though current triton in DS meets my requirements, I was not able to import and use torch inside deepstream:5.1-21.02-triton. As I could see, I can do that inside nvcr.io/nvidia/deepstream:5.1-21.02-devel, I still would like to know if nvcr.io/nvidia/deepstream:5.1-21.02-devel cones along with required triton environment as deepstream:5.1-21.02-triton container. If not what can be done to replicate the same environment. I would really appreciate if you could suggest a way to make this work.
When I say required triton environment, I mean similar to the case why we use deepstream:5.1-21.02-triton container. To use triton backend in DS. Does nvcr.io/nvidia/deepstream:5.1-21.02-devel also supports running DS with triton backend?
As you know I cannot use deepstream:5.1-21.02-triton container to run triton backend in DS as I am unable to import torch. I would like to run DS with triton backend inside nvcr.io/nvidia/deepstream:5.1-21.02-devel. Is it possible?
As stated here on nvidia deepstream’s docker container section; nvcr.io/nvidia/deepstream:5.1-21.02-triton comes along with triton and deepstream dependencies preinstalled. Thats why I am able to run triton backend with DS.
So, the question is can it be done in nvcr.io/nvidia/deepstream:5.1-21.02-devel container as well?
@mchi , I tried running my pipeline inside nvcr.io/nvidia/deepstream:5.1-21.02-devel container. I am able to import torch but getting the following error:
/opt/nvidia/yolov5
Creating Pipeline
Creating streamux
Creating source bin
source-bin-00
Creating Pgie
0:00:00.041191480 50 0x16d4590 WARN GST_ELEMENT_FACTORY gstelementfactory.c:456:gst_element_factory_make: no such element factory "nvinferserver"!
Creating tiler
Creating nvvidconv
Creating nvosd
Creating EGLSink
Atleast one of the sources is live
File "deepstream/deepstream_yolov5/yolov5_main.py", line 458, in main
pgie.set_property('config-file-path', "deepstream/deepstream_yolov5/deepstream_yolov5_config.txt")
AttributeError: 'NoneType' object has no attribute 'set_property
seems like I dont have /lib/gst-plugins/libnvdsgst_inferserver.so lib plugin inside nvcr.io/nvidia/deepstream:5.1-21.02-devel container. This is what I was talking about running DS with triton backend.
do you find /opt/nvidia/deepstream/deepstream-5.1/lib/gst-plugins/libnvdsgst_inferserver.so in your docker?
